  4. Geofency auf Karte in Vis darstellen
698 Beiträge 3 Kommentatoren 105.8k Aufrufe 3 Beobachtet
  • Damrak2022D Damrak2022
    @mickym Hallo, dann müsste das jetzt so korrekt sein
            "id": "2bbe99b34fc4bb8b",
            "type": "tab",
            "label": "",
            "disabled": false,
            "info": "",
            "env": []
            "id": "6166eb8642382a9a",
            "type": "worldmap",
            "z": "2bbe99b34fc4bb8b",
            "name": "",
            "lat": "50.0915584",
            "lon": "8.6735563",
            "zoom": "11",
            "layer": "OSMG",
            "cluster": "",
            "maxage": "",
            "usermenu": "show",
            "layers": "show",
            "panit": "false",
            "panlock": "false",
            "zoomlock": "false",
            "hiderightclick": "false",
            "coords": "none",
            "showgrid": "false",
            "allowFileDrop": "false",
            "path": "/worldmap",
            "overlist": "DR,CO,RA,DN,HM",
            "maplist": "OSMG,OSMC,EsriC,EsriS,EsriT,EsriDG,UKOS",
            "mapname": "",
            "mapurl": "",
            "mapopt": "",
            "mapwms": false,
            "x": 1200,
            "y": 120,
            "wires": []
            "id": "bc225ef817b44d59",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 120,
            "y": 120,
            "wires": [
                    "c8c44c680d778fc8"
            "id": "c2d6a759332e675c",
            "type": "ioBroker get",
            "name": "Longitude",
            "topic": "geofency.0.andy.My_Home.currentLongitude",
            "attrname": "lon",
            "payloadType": "value",
            "errOnInvalidState": "nothing",
            "x": 580,
            "y": 120,
            "wires": [
                    "565b9a8df5cdd987"
            "id": "565b9a8df5cdd987",
            "name": "Latitude",
            "topic": "geofency.0.andy.My_Home.currentLatitude",
            "attrname": "lat",
            "x": 820,
            "y": 120,
            "wires": [
                    "6166eb8642382a9a"
            "id": "c8c44c680d778fc8",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "{    \"name\":\"Andy\",    \"lat\":lat,    \"lon\":lon,    \"color\":\"orange\",    \"weight\":10,    \"icon\":\"automobile\",    \"iconColor\":\"green\",    \"extrainfo\":\"Hallo Andy\"    }",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 350,
            "y": 120,
            "wires": [
                    "c2d6a759332e675c"
    mickymM Offline
    mickymM Offline
    mickym
    #81
    @damrak2022 Nein die Change Node muss natürlich ans Ende - die soll ja die Daten der beiden iobroker Nodes aufnehmen:
    Du musst Dir immer vorstellen - der Flow verläuft immer von LINKS nach RECHTS - also wie beim Lesen startet man links und dann reichert man die Informationen an und verarbeitet diese und am Ende kommt rechts das Ergebnis raus.
    • mickymM mickym
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #82
      @mickym Ja, jetzt pass es. Ich würde jetzt gerne selbst versuchen meine restlichen 9 überwachen Orte hinzuzufügen.
      Also muss. ich weiter get nodes einfügen, umbenennen und mit meinen Datenpunkten befüllen, richtig?
      Mit besten Grüßen
      Andy
        mickymM Offline
        mickymM Offline
        mickym
        #83
        @damrak2022 Bevor Du das machst - kannst Du mir etwas erzählen, wo die Datenpunkte gespeichert sind und was Du gerne erreichen möchtest?
        Eine Beschreibung was die Node alles kann - findest Du hier:
        https://flows.nodered.org/node/node-red-contrib-web-worldmap
        Bedenke - wenn Du alle Nodes auf einmal darstellen willst dann braucht jede Node einen eigenen Namen mit der sie zu identifizieren ist. Ansonsten wird der eine Punkt (Geolokation) auf der Karte nur verschoben. Später kannst Du dann auch noch mit Layern arbeiten. Im Moment haben wir noch keinen Namen dafür vergeben - deswegen sind die alle im Layer unknown gelandet.
        Deshalb die Frage: sind das fixe Punkte oder ändern die Ihre Position? Du willst ja nicht dauern die Inject Node drücken müssen, sondern das soll ja wohl automatisch oder zumindest über einen Kommando Datenpunkt getriggert werden.
        • mickymM mickym
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          schrieb am zuletzt editiert von Damrak2022
          #84
          @mickym Okay, ich versuche es zu erklären. Meine Datenpunkte sind hier vorhanden:
          Nun möchte ich jeden Datenpunkt (momentan insgesamt 10, könnten aber mehr werden) auf der Karte mit einem farbigen Punkt darstellen.
          Dann kommt schon der Teil mit der Tabelle:
          Wenn ich auf den farbigen Kreis klicke möchte ich gerne eine Anzeige haben, an welchen Daten ich für welchen Zeitraum ich schon an diesem Ort war. Das sollte ungefähr so aussehen, wobei hier eigentlich immer nur der ausgewählte Standort angezeigt werden sollte:
          IMG_62E7EDC5F38E-1.png Gut wäre es auch, wenn sich das Jahr auswählen ließe, sodass ich mir im Jahr 2023 auch noch die Daten von 2022 anzeigen lassen könnte.
          Wenn das aber zu kompliziert ist, bin ich für Deine Vorschläge offen.
          Mit besten Grüßen
          Andy
          mickymM DJMarc75D 2 Antworten Letzte Antwort
            mickymM Offline
            mickymM Offline
            mickym
            #85
            @damrak2022 Wenn ich das richtig verstanden habe - möchtest Du auf einen der markierten Punkte auf der Karte klicken und dann soll eine Tabelle befüllt werden. Diese befüllst Du aber mit Blockly oder keine Ahnung mit was?
            Wenn die Datenpunkte fix sind, warum müssen wir die aus dem iobroker lesen - Du könntest die doch auch statisch in der Karte definieren?
            Solle der Name aus dem Datenpunkt (den Datenpunkten) verwendet werden? - Also MyHome?
            Wie soll die Darstellung auf der Karte getriggert werden? (Automatisch gleich zu Anfang?)
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #86
              @damrak2022 sagte in Geofency auf Karte in Vis darstellen:
              Na dann mach doch mal selbst irgendwelche Vorschläge... bisher lebst Du nur von Vorlagen und es kommt NIX an Initiativen von Dir selbst...
              Lehrling seit 1975 !!!
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #87
                @mickym Die Tabellendarstelung ist ja aus der App und wenn ich das richtig sehe, werden die Daten so garnicht an iobroker übermittelt.
                Somit müsste das irgendwie erfasst werden. Also wenn ich an dem Ort ankomme, wenn ich den Ort verlasse, ergibt das Datum und die Zeit die ich mich an dem Ort aufgehalten habe.
                Das müsste ich als mit node Red irgendwie umsetzten und dann wahrscheinlich für jeden Ort in einen eigenen Datenpunkt schreiben
                Mit besten Grüßen
                Andy
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #88
                  Na dann vergiss diese Tabelle erst mal bzw. die musst ja dann erst mal bauen?
                  Frage 1:
                  Das hat auch mit der Karte auch überhaupt nichts zu tun. Ich gehe mal davon aus, dass EINE Tabelle EINEN zu überwachenden Standort enthält man links die Personen oder was weiß ich auf der Y-Achse sieht, also in den Zeilen und die Spalten einen Zeitachse darstellen. Ist das richtig?
                  Frage 2:
                  Enthalten dann die Datenpunkte auch die Person, des zu überwachenden Gebietes?
                  Diese ganze Tabellengeschichte hat erst mal nichts mit der Karte zu tun. Du kannst das auch mit Deinen anderen Mitteln umsetzen. Da musst halt schauen, wie Du das machst.
                  Damrak2022D 2 Antworten Letzte Antwort
                  • mickymM mickym
                    Frage 1:
                    Frage 2:
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #89
                    @mickym Ja links wäre der Ort und dann rects die Zeiten zu denen ich dort anwesend war.
                    Die Person bin immer ich, es geht nur darum: Wann war ich wie lange an einem Ort
                    Mit besten Grüßen
                    Andy
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #90
                      @damrak2022 Und wie soll das visualisiert werden? Wenn das nicht ewig viele Daten sind sondern nur ein paar Tage?
                      • mickymM mickym
                        Frage 1:
                        Frage 2:
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #91
                        @mickym Okay, zurück zur Karte. Wenn ich nun die weiteren Orte anlegen will füge ich jeweils zwei get nodes mit den entsprechenden Geodaten hinzu. Da alle Geodaten jeweils unter einem anderen Ort sind, haben Sie ja unterschiedlicheBezeichnungen.
                        Mit besten Grüßen
                        Andy
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #92
                          @mickym sagte in Geofency auf Karte in Vis darstellen:
                          Lesen bildet 😜
                          • mickymM mickym
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #93
                            @mickym Ich probiere das jetzt erstmal aus die restlichen Orte hinzuzufügen.
                            Mit besten Grüßen
                            Andy
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #94
                              Nein dann machen wir das ganz anders. Das ist viel zu umständlich sonst.
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #95
                                @mickym Okay, was schlägst Du vor?
                                Mit besten Grüßen
                                Andy
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #96
                                  Stop -
                                  Sind alle Datenpunkte über den geofency.0.andy.* Ast zu erreichen?
                                  • mickymM mickym
                                    Stop -
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #97
                                    @mickym Ja, unterhalb von Andy sind alle Orte in Ordnern aufgeführt. Jeder Ordner enthält die entsprechenden Latitude und Lontitude
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #98
                                      @damrak2022 Na ist mir jetzt bissi zuviel Aufwand wie gesagt mach noch eine get Node rein, wo Du den Namen ausliest. Für 10 Datenpunkte gehts auch so, wie Du gesagt hast.
                                      Du kopierst dann einfach die 3 get Nodes und änderst die Pfade entsprechende und verkabelst dann.
                                      sollte dann so aussehen:
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #99
                                        @mickym Okay, mache ich. Das mit einer Tabelle versuche ich dann selbst hinzubekommen. Danke Dir
                                        Mit besten Grüßen
                                        Andy
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #100
                                          @mickym So, das habe ich alles so angelegt. Nur das Auto wird mir wieder mal nicht angezeigt, obwohl es in msg.payload ja eingetragen ist. Browser habe ch gewechselt und auch mal Cache gelöscht, bringt aber nichts.
                                          Ist mein Ansatz für die Tabelle richtig. Ich habe mir gedacht ich versuche ein Blockly zu basteln, welches bei Ankommen und Verlassen die Zeit berechnet die ich zu Hause war und dann in einen neuen Datenpunkt schreibt, welchen ich dann in einem Table darstelle?
                                          Oder ist der Ansatz völlig verkehrt? Dann gib mir nur einen kleinen Tipp wie ich es versuchen sollte
                                          Mit besten Grüßen
                                          Andy
