  5. Lange Ladezeit vom iobroker
149 Beiträge 6 Kommentatoren 31.2k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @spidermike sagte in Lange Ladezeit vom iobroker:
    erst nach ein paar Std lief dann nichts mehr.
    dann ... das mal zeigen , wenn er lahm ist
    einmal gefiltert nach ioBroker
    ps auxww|grep io
    und einmal komplett :
    ps auxww
    Spidermike
    #101
    @glasfaser sagte in Lange Ladezeit vom iobroker:
    ps auxww|grep io
    und einmal kompett:
    ps auxww
    pi@raspberrypi4-iobroker:/opt/iobroker $ cd /opt/iobroker
    npm ls | grep -E 'github.com|ERR'
    iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "growatt"      : 1.1.15   , installed 1.1.15
    Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
    Adapter    "hs100"        : 2.0.7    , installed 2.0.7
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mbus"         : 2.3.4    , installed 2.3.4
    Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    pi@raspberrypi4-iobroker:/opt/iobroker $ ^C
    pi@raspberrypi4-iobroker:/opt/iobroker $ cat /etc/debian_version
    11.4
    pi@raspberrypi4-iobroker:/opt/iobroker $ pi@raspberrypi4-iobroker:/opt/iobroker $ cat /etc/debian_version
    11.4^C
    pi@raspberrypi4-iobroker:/opt/iobroker $ ps auxww|grep io
    root        13  0.0  0.0      0     0 ?        S    22:20   0:00 [migration/0]
    root        16  0.0  0.0      0     0 ?        S    22:20   0:00 [migration/1]
    root        21  0.0  0.0      0     0 ?        S    22:20   0:00 [migration/2]
    root        26  0.0  0.0      0     0 ?        S    22:20   0:00 [migration/3]
    root        62  0.0  0.0      0     0 ?        I<   22:20   0:00 [blkcg_punt_bio]
    root        64  0.0  0.0      0     0 ?        I    22:20   0:00 [kworker/u8:1-ext4-rsv-conversion]
    root        66  0.0  0.0      0     0 ?        I<   22:20   0:00 [rpciod]
    root        68  0.0  0.0      0     0 ?        I<   22:20   0:00 [xprtiod]
    root        71  0.0  0.0      0     0 ?        I<   22:20   0:00 [nfsiod]
    root        83  0.0  0.0      0     0 ?        I<   22:20   0:00 [DWC Notificatio]
    avahi      395  0.1  0.0   7048  3268 ?        Ss   22:20   0:03 avahi-daemon: running [raspberrypi4-iobroker.local]
    message+   399  0.0  0.0   7784  3668 ?        Ss   22:20   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    root       465  0.3  0.2  63872 21536 ?        Ssl  22:20   0:05 /usr/bin/python /usr/local/bin/meyectl startserver -c /etc/motioneye/motioneye.conf
    root       650 63.2  2.4 451240 195240 ?       SLl  22:20  16:52 /usr/bin/motion -n -c /etc/motioneye/motion.conf -d 5
    root       736  0.0  0.1  35956 12520 ?        S    22:20   0:00 /usr/bin/python /usr/local/bin/meyectl startserver -c /etc/motioneye/motioneye.conf
    iobroker  1231 86.1  1.8 263268 147108 ?       Rsl  22:20  22:48 iobroker.js-controller
    iobroker  2015 15.8  1.1 195976 89724 ?        Sl   22:20   4:10 io.admin.0
    iobroker  2055  0.7  1.0 190928 81044 ?        Sl   22:20   0:11 io.telegram.0
    iobroker  2147 23.2  1.5 241032 124864 ?       Sl   22:20   6:05 io.javascript.0
    iobroker  2247  0.3  0.7 178232 59204 ?        Sl   22:20   0:05 io.whatsapp-cmb.0
    iobroker  2311  7.6  1.2 209864 98784 ?        Sl   22:21   2:00 io.shelly.0
    iobroker  2401 69.8  1.1 204400 91196 ?        Rl   22:21  18:11 io.mqtt.0
    iobroker  2440  0.6  0.7 176412 57872 ?        Sl   22:21   0:10 io.rpi2.0
    iobroker  2505  0.8  0.8 183876 65172 ?        Sl   22:21   0:13 io.alexa2.0
    iobroker  2611  0.4  0.8 183368 65640 ?        Sl   22:21   0:06 io.cloud.0
    iobroker  2667  0.9  0.8 180764 66008 ?        Sl   22:21   0:15 io.deconz.0
    iobroker  2752  0.5  0.7 177380 60048 ?        Sl   22:21   0:08 io.wled.0
    iobroker  2819  0.3  0.7 180000 61376 ?        Sl   22:21   0:06 io.web.0
    iobroker  2961  0.4  0.9 184700 72972 ?        Sl   22:21   0:07 io.iot.0
    iobroker  3025  8.8  1.0 192512 80976 ?        Sl   22:21   2:14 io.plenticore.0
    iobroker  3055  0.5  0.8 181084 64732 ?        Sl   22:21   0:07 io.homeconnect.0
    iobroker  3134  2.8  0.9 188568 77172 ?        Sl   22:21   0:43 io.growatt.0
    iobroker  3256  0.4  0.8 181496 71480 ?        Sl   22:21   0:06 io.backitup.0
    iobroker  3333  1.3  0.7 179788 62144 ?        Sl   22:21   0:20 io.hs100.0
    iobroker  3393  0.9  0.8 185492 71060 ?        Rl   22:22   0:13 io.fb-checkpresence.0
    iobroker  3430  0.3  0.7 176564 57188 ?        Sl   22:22   0:05 io.discovery.0
    pi       23634  0.0  0.0   7472   564 pts/0    S+   22:47   0:00 grep --color=auto io
    GlasfaserG S Thomas BraunT 3 Antworten Letzte Antwort
    • S Spidermike
      ps auxww|grep io
      und einmal kompett:
      ps auxww
      iobroker update -i
      11.4
      11.4^C
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #102
      @spidermike
      du schreibts doch erst nach Stunden ... wird er lahm .
      jetzt brauche ich erstmal die Ausgabe nicht !
      • S Spidermike
        ps auxww|grep io
        und einmal kompett:
        ps auxww
        iobroker update -i
        11.4
        11.4^C
        Spidermike
        #103
        ps auxww
        USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
        root         1  0.2  0.1  33920  9020 ?        Ss   22:20   0:03 /sbin/init
        root         2  0.0  0.0      0     0 ?        S    22:20   0:00 [kthreadd]
        root         3  0.0  0.0      0     0 ?        I<   22:20   0:00 [rcu_gp]
        root         4  0.0  0.0      0     0 ?        I<   22:20   0:00 [rcu_par_gp]
        root         6  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/0:0H-k        blockd]
        root         7  0.1  0.0      0     0 ?        I    22:20   0:02 [kworker/u8:0-e        vents_unbound]
        root         8  0.0  0.0      0     0 ?        I<   22:20   0:00 [mm_percpu_wq]
        root         9  0.0  0.0      0     0 ?        S    22:20   0:00 [rcu_tasks_rude        _]
        root        10  0.0  0.0      0     0 ?        S    22:20   0:00 [rcu_tasks_trac        e]
        root        11  0.0  0.0      0     0 ?        S    22:20   0:01 [ksoftirqd/0]
        root        12  0.1  0.0      0     0 ?        I    22:20   0:02 [rcu_sched]
        root        14  0.0  0.0      0     0 ?        S    22:20   0:00 [cpuhp/0]
        root        15  0.0  0.0      0     0 ?        S    22:20   0:00 [cpuhp/1]
        root        17  0.0  0.0      0     0 ?        S    22:20   0:00 [ksoftirqd/1]
        root        19  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/1:0H-e        vents_highpri]
        root        20  0.0  0.0      0     0 ?        S    22:20   0:00 [cpuhp/2]
        root        22  0.0  0.0      0     0 ?        S    22:20   0:00 [ksoftirqd/2]
        root        24  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/2:0H-k        blockd]
        root        25  0.0  0.0      0     0 ?        S    22:20   0:00 [cpuhp/3]
        root        27  0.0  0.0      0     0 ?        S    22:20   0:00 [ksoftirqd/3]
        root        29  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/3:0H-k        blockd]
        root        30  0.0  0.0      0     0 ?        S    22:20   0:00 [kdevtmpfs]
        root        31  0.0  0.0      0     0 ?        I<   22:20   0:00 [netns]
        root        32  0.0  0.0      0     0 ?        I<   22:20   0:00 [inet_frag_wq]
        root        37  0.0  0.0      0     0 ?        S    22:20   0:00 [kauditd]
        root        38  0.0  0.0      0     0 ?        S    22:20   0:00 [khungtaskd]
        root        39  0.0  0.0      0     0 ?        S    22:20   0:00 [oom_reaper]
        root        40  0.0  0.0      0     0 ?        I<   22:20   0:00 [writeback]
        root        41  0.0  0.0      0     0 ?        S    22:20   0:00 [kcompactd0]
        root        61  0.0  0.0      0     0 ?        I<   22:20   0:00 [kblockd]
        root        62  0.0  0.0      0     0 ?        I<   22:20   0:00 [blkcg_punt_bio        ]
        root        63  0.0  0.0      0     0 ?        S    22:20   0:00 [watchdogd]
        root        64  0.0  0.0      0     0 ?        I    22:20   0:00 [kworker/u8:1-f        lush-8:0]
        root        65  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/1:1H-k        blockd]
        root        67  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/u9:0-h        ci0]
        root        70  0.0  0.0      0     0 ?        S    22:20   0:00 [kswapd0]
        root        72  0.0  0.0      0     0 ?        I<   22:20   0:00 [kthrotld]
        root        76  0.0  0.0      0     0 ?        I    22:20   0:00 [kworker/1:5-mm        _percpu_wq]
        root        77  0.0  0.0      0     0 ?        I<   22:20   0:00 [iscsi_eh]
        root        78  0.0  0.0      0     0 ?        I<   22:20   0:00 [iscsi_conn_cle        a]
        root        79  0.0  0.0      0     0 ?        I<   22:20   0:00 [nvme-wq]
        root        80  0.0  0.0      0     0 ?        I<   22:20   0:00 [nvme-reset-wq]
        root        81  0.0  0.0      0     0 ?        I<   22:20   0:00 [nvme-delete-wq        ]
        root        83  0.0  0.0      0     0 ?        I<   22:20   0:00 [DWC Notificati        o]
        root        84  0.0  0.0      0     0 ?        I<   22:20   0:00 [uas]
        root        85  0.0  0.0      0     0 ?        S<   22:20   0:00 [vchiq-slot/0]
        root        86  0.0  0.0      0     0 ?        S<   22:20   0:00 [vchiq-recy/0]
        root        87  0.0  0.0      0     0 ?        S<   22:20   0:00 [vchiq-sync/0]
        root        88  0.0  0.0      0     0 ?        I<   22:20   0:00 [zswap-shrink]
        root        89  0.5  0.0      0     0 ?        I    22:20   0:08 [kworker/2:2-mm        _percpu_wq]
        root        90  0.0  0.0      0     0 ?        I<   22:20   0:00 [sdhci]
        root        91  0.2  0.0      0     0 ?        S    22:20   0:04 [irq/64-mmc0]
        root        92  0.0  0.0      0     0 ?        S    22:20   0:00 [scsi_eh_0]
        root        93  0.0  0.0      0     0 ?        I<   22:20   0:00 [scsi_tmf_0]
        root        94  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/2:1H-k        blockd]
        root        95  0.0  0.0      0     0 ?        S    22:20   0:00 [jbd2/sda2-8]
        root        96  0.0  0.0      0     0 ?        I<   22:20   0:00 [ext4-rsv-conve        r]
        root        98  0.0  0.0      0     0 ?        I<   22:20   0:00 [mld]
        root        99  0.0  0.0      0     0 ?        I<   22:20   0:00 [ipv6_addrconf]
        root       114  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/3:1H-k        blockd]
        root       121  0.0  0.0      0     0 ?        I<   22:20   0:00 [kworker/0:1H-k        blockd]
        root       142  0.1  0.2  62100 17984 ?        Ss   22:20   0:02 /lib/systemd/sy        stemd-journald
        root       163  0.0  0.0  19804  4844 ?        Ss   22:20   0:01 /lib/systemd/sy        stemd-udevd
        root       188  0.0  0.0      0     0 ?        S    22:20   0:00 [vchiq-keep/0]
        root       189  0.0  0.0      0     0 ?        S<   22:20   0:00 [SMIO]
        root       206  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       209  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       212  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       215  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       218  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       220  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       222  0.0  0.0      0     0 ?        I<   22:20   0:00 [mmal-vchiq]
        root       225  0.0  0.0      0     0 ?        S    22:20   0:00 [v3d_bin]
        root       226  0.0  0.0      0     0 ?        S    22:20   0:00 [v3d_render]
        root       227  0.0  0.0      0     0 ?        S    22:20   0:00 [v3d_tfu]
        root       228  0.0  0.0      0     0 ?        S    22:20   0:00 [v3d_csd]
        root       229  0.0  0.0      0     0 ?        S    22:20   0:00 [v3d_cache_clea        n]
        root       264  0.0  0.0      0     0 ?        I<   22:20   0:00 [cfg80211]
        root       277  0.0  0.0      0     0 ?        I<   22:20   0:00 [brcmf_wq/mmc1:        0]
        root       278  0.0  0.0      0     0 ?        S    22:20   0:00 [brcmf_wdog/mmc        1]
        root       304  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/55-vc4 hdm        i]
        root       306  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/56-vc4 hdm        i]
        root       307  0.0  0.0      0     0 ?        S    22:20   0:00 [cec-vc4]
        root       308  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/52-vc4 hdm        i]
        root       309  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/51-vc4 hdm        i]
        root       311  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/61-vc4 hdm        i]
        root       313  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/62-vc4 hdm        i]
        root       314  0.0  0.0      0     0 ?        S    22:20   0:00 [cec-vc4]
        root       315  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/58-vc4 hdm        i]
        root       316  0.0  0.0      0     0 ?        S    22:20   0:00 [irq/57-vc4 hdm        i]
        root       317  0.0  0.0      0     0 ?        S    22:20   0:00 [card1-crtc0]
        root       318  0.0  0.0      0     0 ?        S    22:20   0:00 [card1-crtc1]
        root       319  0.0  0.0      0     0 ?        S    22:20   0:00 [card1-crtc2]
        root       320  0.0  0.0      0     0 ?        S    22:20   0:00 [card1-crtc3]
        root       321  0.0  0.0      0     0 ?        S    22:20   0:00 [card1-crtc4]
        root       322  0.0  0.0      0     0 ?        S    22:20   0:00 [card1-crtc5]
        avahi      395  0.1  0.0   7048  3268 ?        Ss   22:20   0:03 avahi-daemon: r        unning [raspberrypi4-iobroker.local]
        root       396  0.0  0.0   8200  2392 ?        Ss   22:20   0:00 /usr/sbin/cron        -f
        avahi      397  0.0  0.0   6756   260 ?        S    22:20   0:00 avahi-daemon: c        hroot helper
        message+   399  0.0  0.0   7784  3668 ?        Ss   22:20   0:00 /usr/bin/dbus-d        aemon --system --address=systemd: --nofork --nopidfile --systemd-activation --sy        slog-only
        root       405  0.1  0.0   7900  3092 ?        Ss   22:20   0:03 /bin/bash /usr/        bin/deCONZ-update2.sh
        root       416  0.4  0.0   8428  3692 ?        Ss   22:20   0:07 /bin/bash /usr/        bin/deCONZ-WIFI2.sh
        pi         423  1.2  0.6 151936 49540 ?        Ssl  22:20   0:21 /usr/bin/deCONZ        -platform minimal --http-port=80
        influxdb   464  5.2  1.6 1291848 136496 ?      Sl   22:20   1:28 /usr/bin/influx        d -config /etc/influxdb/influxdb.conf
        root       493  0.0  0.0  26544  3240 ?        Ssl  22:20   0:00 /usr/sbin/rsysl        ogd -n -iNONE
        root       502  0.0  0.0  12940  5932 ?        Ss   22:20   0:00 /lib/systemd/sy        stemd-logind
        nobody     503  0.0  0.0   5312  2320 ?        Ss   22:20   0:00 /usr/sbin/thd -        -triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody -        -deviceglob /dev/input/event*
        root       504  0.0  0.0  11788  1952 ?        Ss   22:20   0:00 /sbin/wpa_suppl        icant -u -s -O /run/wpa_supplicant
        root       550  0.0  0.0   2876  1888 ?        Ss   22:20   0:00 /usr/sbin/dhcpc        d -b -q
        root       566  0.0  0.0  27696    80 ?        SLsl 22:20   0:00 /usr/sbin/rngd        -r /dev/hwrng
        root       579  0.0  0.0   4484  1480 tty1     Ss+  22:20   0:00 /sbin/agetty -o        -p -- \u --noclear tty1 linux
        root       583  0.0  0.0   6652  1836 ttyS0    Ss+  22:20   0:00 /sbin/agetty -o        -p -- \u --keep-baud 115200,57600,38400,9600 ttyS0 vt220
        mosquit+   591  5.0  0.0  12232  5464 ?        Ss   22:20   1:25 /usr/sbin/mosqu        itto -c /etc/mosquitto/mosquitto.conf
        root       592  0.0  0.0  12408  6132 ?        Ss   22:20   0:00 sshd: /usr/sbin        /sshd -D [listener] 0 of 10-100 startups
        root       612  0.0  0.0  12052  3520 ?        Ss   22:20   0:00 wpa_supplicant        -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
        root       650 63.2  2.4 451240 195240 ?       SLl  22:20  17:40 /usr/bin/motion        -n -c /etc/motioneye/motion.conf -d 5
        root       756  0.0  0.0   2056   116 ?        S    22:20   0:00 /usr/bin/hciatt        ach /dev/serial1 bcm43xx 3000000 flow -
        root       760  0.2  0.0      0     0 ?        I<   22:20   0:04 [kworker/u9:2-b        rcmf_wq/mmc1:0001:1]
        root       772  0.0  0.0  21160  6652 ?        Ss   22:20   0:00 /usr/libexec/bl        uetooth/bluetoothd
        root       778  0.0  0.0      0     0 ?        I<   22:20   0:00 [cryptd]
        iobroker  1231 86.3  1.8 263268 147016 ?       Rsl  22:20  23:57 iobroker.js-con        troller
        root      1232  0.0  0.0  33284  7028 ?        Ssl  22:20   0:00 /usr/bin/python        3 /usr/bin/argononed.py
        root      1888  0.0  0.0  14544  6996 ?        Ss   22:20   0:00 sshd: pi [priv]
        iobroker  2015 15.9  1.1 196244 89984 ?        Sl   22:20   4:24 io.admin.0
        iobroker  2055  0.7  1.0 191184 81156 ?        Sl   22:20   0:11 io.telegram.0
        pi        2100  0.0  0.0  14420  7640 ?        Ss   22:20   0:00 /lib/systemd/sy        stemd --user
        pi        2101  0.0  0.0  37372  3752 ?        S    22:20   0:00 (sd-pam)
        pi        2125  0.0  0.0  14544  4484 ?        S    22:20   0:00 sshd: pi@pts/0
        pi        2130  0.0  0.0   8596  3848 pts/0    Ss   22:20   0:00 -bash
        iobroker  2147 23.2  1.5 241800 125300 ?       Sl   22:20   6:23 io.javascript.0
        iobroker  2247  0.3  0.7 178232 59204 ?        Sl   22:20   0:05 io.whatsapp-cmb        .0
        iobroker  2311  7.6  1.2 210120 98896 ?        Sl   22:21   2:05 io.shelly.0
        iobroker  2401 69.8  1.1 204680 91460 ?        Rl   22:21  19:05 io.mqtt.0
        iobroker  2440  0.6  0.7 176412 58764 ?        Sl   22:21   0:11 io.rpi2.0
        iobroker  2505  0.8  0.8 183232 65336 ?        Sl   22:21   0:13 io.alexa2.0
        iobroker  2611  0.4  0.8 183560 65640 ?        Sl   22:21   0:06 io.cloud.0
        iobroker  2667  0.9  0.8 180764 66020 ?        Sl   22:21   0:15 io.deconz.0
        iobroker  2752  0.5  0.7 177380 60080 ?        Sl   22:21   0:08 io.wled.0
        iobroker  3025  8.7  1.0 193052 81232 ?        Sl   22:21   2:20 io.plenticore.0
        iobroker  3055  0.5  0.8 181084 64732 ?        Sl   22:21   0:08 io.homeconnect.        0
        iobroker  3134  2.8  0.9 188728 77440 ?        Sl   22:21   0:45 io.growatt.0
        iobroker  3333  1.3  0.7 179928 62424 ?        Sl   22:21   0:21 io.hs100.0
        iobroker  3393  0.8  0.8 185492 71164 ?        Sl   22:22   0:14 io.fb-checkpres        ence.0
        iobroker  3430  0.3  0.7 176564 57220 ?        Sl   22:22   0:05 io.discovery.0
        root      6475  0.0  0.0      0     0 ?        I    22:25   0:00 [kworker/3:0-mm        _percpu_wq]
        root     14455  0.0  0.0      0     0 ?        I    22:35   0:00 [kworker/2:1-mm        _percpu_wq]
        root     15481  0.1  0.0      0     0 ?        I    22:37   0:00 [kworker/0:2-ev        ents]
        root     16825  0.0  0.0      0     0 ?        I    22:38   0:00 [kworker/1:1-ev        ents]
        root     18721  0.0  0.0      0     0 ?        I    22:40   0:00 [kworker/2:0-mm        _percpu_wq]
        root     19143  0.0  0.0      0     0 ?        I    22:41   0:00 [kworker/3:1-mm        _percpu_wq]
        root     20208  0.2  0.0      0     0 ?        I    22:42   0:00 [kworker/0:1-mm        _percpu_wq]
        root     20374  0.0  0.0      0     0 ?        I    22:43   0:00 [kworker/u8:2]
        root     23327  0.0  0.0      0     0 ?        I    22:46   0:00 [kworker/3:2-mm        _percpu_wq]
        root     23811  0.0  0.0      0     0 ?        I    22:47   0:00 [kworker/1:0]
        systemd+ 24101  0.3  0.0  22288  2588 ?        Ssl  22:47   0:00 /lib/systemd/sy        stemd-timesyncd
        root     24721  0.0  0.0   6488   400 ?        S    22:48   0:00 sleep 10
        root     24782  0.0  0.0   6488   400 ?        S    22:48   0:00 sleep 1
        pi       24783  0.0  0.0  10936  2716 pts/0    R+   22:48   0:00 ps auxww
        • S Spidermike
          ps auxww|grep io
          und einmal kompett:
          ps auxww
          iobroker update -i
          11.4
          11.4^C
          #104
          /usr/bin/motion
          Das dürfte auch der Grund für das Einknicken des Systems sein...
          Das knüppelt je nach Einstellung richtig auf die Hardware ein und die macht irgendwann die Tür zu.
            /usr/bin/motion
            Spidermike
            #105
            @thomas-braun sagte in Lange Ladezeit vom iobroker:
            /usr/bin/motion
            Das dürfte auch der Grund für das einknicken des Systems sein...
            wie bekomme ich das wieder runter?????
              @spidermike
              Spidermike
              schrieb am zuletzt editiert von Spidermike
              #106
              @spidermike
              ok dann sende ich dir das morgen nochmal `??????
              oder???
              • S Spidermike
                /usr/bin/motion
                #107
                Wie du es drauf bekommen hast, nur rückwärts...
                • S Spidermike
                  @spidermike
                  oder???
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #108
                  @spidermike
                  ist es das hier :
                  https://forum-raspberrypi.de/forum/thread/3258-überwachungscamera-webcam-server-installieren/?pageNo=2
                    @spidermike
                    ist es das hier :
                    Spidermike
                    #109
                    @spidermike
                    ist es das hier :
                    was soll ich da jetzt machen?
                    • S Spidermike
                      @spidermike
                      ist es das hier :
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #110
                      @spidermike
                      Na ... ob es dieses im Link ist !??
                      dann würde ich eventuell sagen :
                      sudo apt-get remove --purge motion
                      • S Spidermike
                        @spidermike
                        ist es das hier :
                        Spidermike
                        #111
                        @spidermike
                        momentan läuft der raspi wie sau, richtig schnell kann ich zwischen den einzelnen Objekten hin und her springen. das ging noch nie so gut
                        • S Spidermike
                          @spidermike
                          ist es das hier :
                          #112
                          @spidermike
                          motion und motioneye ist etwas komplexer zu installieren und es gibt mehrere Wege (hängt auch vom Release ab, wie das gerade geht).
                          apt policy motion
                          dpkg -l motion
                          systemctl status motion
                            @spidermike
                            Spidermike
                            #113
                            @spidermike
                            habe ich gemacht
                            pi@raspberrypi4-iobroker:/opt/iobroker $ sudo apt-get remove --purge motion
                            Die folgenden Pakete werden ENTFERNT:
                              motion*
                            0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
                            Nach dieser Operation werden 2.171 kB Plattenplatz freigegeben.
                            Möchten Sie fortfahren? [J/n] j
                            (Lese Datenbank ... 65772 Dateien und Verzeichnisse sind derzeit installiert.)
                            Entfernen von motion (4.3.2-1) ...
                            Trigger für man-db (2.9.4-2) werden verarbeitet ...
                            (Lese Datenbank ... 65735 Dateien und Verzeichnisse sind derzeit installiert.)
                            Löschen der Konfigurationsdateien von motion (4.3.2-1) ...
                            • S Spidermike
                              @spidermike
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              #114
                              Na ... dann erstmal bis morgen .... sieht ja schon gut aus .
                                @spidermike
                                apt policy motion
                                dpkg -l motion
                                Spidermike
                                #115
                                @spidermike
                                apt policy motion
                                dpkg -l motion
                                Ja da hatte ich mich damals auch bei einen Youtuper das abgeschaut, wollte es so haben das ich die zwei Kameras vom Grundstück auf meine VIS zum anschauen bekomme.
                                  Spidermike
                                  #116
                                  Ich danke Dir und ich melde mich morgen wenn ich von der Maloche zu hause bin
                                  GlasfaserG S 2 Antworten Letzte Antwort
                                  • S Spidermike
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    #117
                                    Ich danke Dir
                                    Nee ... da gehören hier mehrere in diesem Thread dazu ;)
                                    • S Spidermike
                                      Spidermike
                                      #118
                                      @spidermike
                                      das ganze hier ist so dermaßen komplex und es ändert sich alles minutlich das ich da nicht mehr mitkomme.
                                      • S Spidermike
                                        @spidermike
                                        apt policy motion
                                        dpkg -l motion
                                        #119
                                        Youtube-Vorlesungen...
                                        Fast immer Murks. Ausnahmen sind rar und bestätigen nur den generellen Eindruck.
                                          Spidermike
                                          #120
                                          was bleibt mir übrig?
                                          Thomas BraunT S 2 Antworten Letzte Antwort
