  4. Lidl Silvercrest Smart Button *gelöst*
    6.3k
65 Beiträge 10 Kommentatoren 11.0k Aufrufe 8 Beobachtet
  • B bigfun_de
    Hallo ich habe mir den Button auch gekauft und bekomme ihn nicht gekoppelt.
    Mein System ist ein pi3 mit den deConz-Stick.
    pi@iobroker-pi:~ $ iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "echarts"      : 1.0.7    , installed 1.0.7
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
    Wenn ich in Zigbee-Adapter auf pairing gehe, passiert nichts.
    Im log steht:
    Error: Failed to touchlinkReset Error: Touchlink operation already in progress
        at Touchlink.lock (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/touchlink.ts:20:19)
        at Touchlink.factoryResetFirst (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/touchlink.ts:110:14)
        at Controller.touchlinkFactoryResetFirst (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:202:31)
        at ZigbeeController.touchlinkReset (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:913:33)
        at Commands.touchlinkReset (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:156:31)
        at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:56:30)
        at Zigbee.emit (events.js:412:35)
        at Zigbee.emit (domain.js:475:12)
        at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37). undefined
    Touchlink reset started
    Ich kann den Fehler leider nicht sogrichtig deuten :-(
    Alle anderen Geräte gehen ja.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #41
    @bigfun_de der Fehler deutet darauf hin das du mehrfach versucht hast einen touchlink-reset durchzuführen ohne zu warten was passiert.
    Er hat mit dem Gerät selber nichts zu tun.
    A.
    B 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      bigfun_de
      #42
      @asgothian
      Danke für die Rückmeldung!
      Wenn die Meldung mit dem Pairing nichts zu tun hat, woran kann es liegen, dass der Button nicht erkannt wird.
      Zur Ergänzung, ich habe den deConz II Stick.
      • O oFbEQnpoLKKl6mbY5e13
        @gluecksmann
        Bei zweimal Drücken geht der Datenpunkt "off" auf True statt der Datenpunkt "on".
        kamolus
        #43
        @ofbeqnpolkkl6mby5e13 said in Lidl Silvercrest Smart Button *gelöst*:
        @gluecksmann
        Hallo, ich bekomme den script nicht zum laufen
        K 1 Antwort Letzte Antwort
        • K kamolus
          @gluecksmann
          kamolus
          #44
          @kamolus said in Lidl Silvercrest Smart Button *gelöst*:
          @gluecksmann
          "on/off state of the switch" ist das selbst erzeugte Datapunkt in 0_datauser ?
          Ändert sich gar nicht.
          Das funktioniert aber tadellos
          • K kamolus
            @gluecksmann
            kamolus
            #45
            @gluecksmann
            O 1 Antwort Letzte Antwort
            • K kamolus
              @gluecksmann
              O Offline
              O Offline
              schrieb am zuletzt editiert von oFbEQnpoLKKl6mbY5e13
              #46
              @kamolus sagte in Lidl Silvercrest Smart Button *gelöst*:
              "on/off state of the switch" ist das selbst erzeugte >Datapunkt in 0_datauser ?
              Das ist völlig irrelevant. Hier wird der Datenpunkt ausgewählt, dessen Zustand durch Drücken des Smart Button geändert werden soll.
              totocotonioT 1 Antwort Letzte Antwort
                totocotonioT Offline
                totocotonio
                schrieb am zuletzt editiert von totocotonio
                #47
                @ofbeqnpolkkl6mby5e13 Hi,
                ich habe das gleiche Problem mit dem Ding. Habt ihr schon eine LÖsung gefunden. Klar kann ich auf alles Triggern
                aber die on/off werte ändern sich trotzdem nicht, das scheint doch noch ein Bug zu sein
                Gruß Totocotonio
                Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
                O K 2 Antworten Letzte Antwort
                • totocotonioT totocotonio
                  O Offline
                  O Offline
                  #48
                  @totocotonio
                  Keine Ahnung, wovon du sprichst, das "Ding" funktioniert hier einwandfrei.
                    kamolus
                    #49
                    @totocotonio said in Lidl Silvercrest Smart Button *gelöst*:
                    Funktioniert diese script bei Dir?
                    K totocotonioT 2 Antworten Letzte Antwort
                    • K kamolus
                      kamolus
                      #50
                      Das funktioniert schon bei mir, keine Ahnung warum
                      state ändert sich einmal drücken - wahr, zweimal drücken - falsch
                      • K kamolus
                        kamolus
                        #51
                        Das funktioniert schon bei mir, keine Ahnung warum,
                        • K kamolus
                          O Offline
                          O Offline
                          #52
                          @kamolus
                          Weshalb verstehst du nicht, warum es funktioniert?
                          Kann man so machen, verschwendet aber Funktionalität. Du verwendest 1x und 2x Drücken für Ein- und Ausschalten desselben Gerätes.
                          Wenn du "toggelst", dann kannst du mit dem Smart Button bis zu drei verschiedene Geräte steuern.
                            @kamolus
                            kamolus
                            #53
                            @kamolus
                            Ich habe ein wenig mit dem Button "gespielt" und festgestellt mein Button "verliert" Verbindung mit dem Iobroker (wenn man so "wild"klickt"). Nix hilft nur neu pairen. Unter Instanzen/zigbee/Geräte im Kachel von Button erscheint beim drücken (wenn alles gut funktioniert) kleine Rechteck für kurze Moment.
                            Wenn die Verbindung "weg" ist, erscheint diese "Rechteck" nicht und im log kann auch nix sehen, da kann ich den Adapter neu starten oder ganze Iobroker, hilft gar nicht nur Button entfernen und neu Pairen.
                            • K kamolus
                              @kamolus
                              kamolus
                              #54
                              @kamolus
                              Ich habe ein wenig mit dem Button "gespielt" und festgestellt mein Button "verliert" Verbindung mit dem Iobroker (wenn man so "wild klickt"). Nix hilft nur neu pairen. Unter Instanzen/zigbee/Geräte im Kachel von Button erscheint beim drücken (wenn alles gut funktioniert) kleine Rechteck für kurze Moment.
                                @totocotonio
                                totocotonio
                                #55
                                es schaltet zum Beispiel nicht von false auf true um oder umgekehrt
                                Gruß Totocotonio
                                • K kamolus
                                  totocotonio
                                  #56
                                  @kamolus Hi, ja das funktioniert.
                                  Gruß Totocotonio
                                    O Offline
                                    O Offline
                                    #57
                                    @totocotonio
                                    Du widersprichst dir...
                                      @totocotonio
                                      totocotonio
                                      #58
                                      @ofbeqnpolkkl6mby5e13 Nein, warum das script gibt immer ein True raus aber der Wert in den Objekten ändert sich nicht
                                      Gruß Totocotonio
                                        @gluecksmann
                                        Einmal drücken = "on" geht kurz auf True und fällt wieder auf False zurück
                                        Zweimal schnell hintereinander drücken = "off" geht kurz auf True und fällt wieder auf False zurück
                                        Halten = "brightness_step_up" wechselt so lange zwischen True und False bis "brightness_step_down" zwischen True und False wechselt und wieder von vorn...
                                        Loslassen = "brightness_stop" geht kurz auf True und fällt wieder auf False zurück
                                        O Offline
                                        O Offline
                                        #59
                                        @ofbeqnpolkkl6mby5e13 sagte in Lidl Silvercrest Smart Button *gelöst*:
                                        @gluecksmann
                                        Die Änderungen gehen so schnell, dass der Admin das nicht anzeigt.
                                          @gluecksmann
                                          totocotonio
                                          #60
                                          @ofbeqnpolkkl6mby5e13 ok,
                                          das wäre eine Erklärung für mich
                                          Gruß Totocotonio
