  4. Updates funktionieren nicht mehr
    6.3k
84 Beiträge 5 Kommentatoren 12.7k Aufrufe 4 Beobachtet
  • M mfroeschl
    @thomas-braun said in Updates funktionieren nicht mehr:
    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.14.2
    v16.14.2
    Error: Cannot find module 'json-parse-better-errors'
    Require stack:
    - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/node_modules/node-fetch-npm/src/body.js
    - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/node_modules/node-fetch-npm/src/index.js
    - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/index.js
    - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/lib/index.js
    - /usr/lib/node_modules/npm/node_modules/pacote/lib/remote.js
    - /usr/lib/node_modules/npm/node_modules/pacote/lib/git.js
    - /usr/lib/node_modules/npm/node_modules/pacote/lib/fetcher.js
    - /usr/lib/node_modules/npm/node_modules/pacote/lib/index.js
    - /usr/lib/node_modules/npm/lib/utils/update-notifier.js
    - /usr/lib/node_modules/npm/lib/cli.js
    - /usr/lib/node_modules/npm/bin/npm-cli.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/node_modules/node-fetch-npm/src/body.js:14:19)
        at Module._compile (node:internal/modules/cjs/loader:1103:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    pi@raspberrypi-iobroker:~ $
    @mfroeschl sagte in Updates funktionieren nicht mehr:
    Wassn jetzt kaputt?
    /usr/bin/npm -v
      Wassn jetzt kaputt?
      /usr/bin/npm -v
      mfroeschl
      /usr/bin/npm -v
      /usr/bin/npm -v
      Require stack:
      • M mfroeschl
        /usr/bin/npm -v
        /usr/bin/npm -v
        Require stack:
        @mfroeschl
        Keine Ahnung was da kaputt ist.
          @mfroeschl
          mfroeschl
          Schade. Trotzdem Danke für deinen Support.
          Dann mach ich mich mal dran das Backup wieder up-to-date zu bringen.
          Grüße
          • M mfroeschl
            Grüße
            @mfroeschl
            Haste kein gescheites aktuelles Backup? Vom Backitup-Adapter?
            Ein fullimage aus Januar ist ja nur unwesentlich besser als gar nix.
            Und die 'krumme Installation von npm und Konsorten' war da noch nicht drin? Sonst knallst du dir den Kram ja wieder per Image auf die Kiste.
            M 2 Antworten Letzte Antwort
              @mfroeschl
              mfroeschl
              Eigentlich schon. Ich habe jeden Tage in Backup auf dem FTP abgelegt.
              Leider funktionert der Restore überhaupt nicht. Ich hatte vorgestern ein neues Image runtergeladen und mittels
              curl -sL https://iobroker.net/install.sh | bash -
              den iobroker installiert.
              ein
              iobroker restore 0
              hatte 4x das gleiche ergebnis. Zunächst wurde der Admin und der Backitup Adapter lt. Meldungen deinstalliert, dann wurde der Admin Adapter wieder installiert.
              Dann kam die Meldung, dass der Restore erfolgreich beendet ist.
              nach iobroker start und diversen reboots war aber immer der admin adatper nicht mehr erreichbar.
              Hab dann irgendwann aufgegeben.
              Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                @mfroeschl
                mfroeschl
                ...weiß ich nicht, zumindest kann ich auf diesem Backup alle Adapter prolbemlos updaten
                • M mfroeschl
                  ein
                  iobroker restore 0
                  Image von was?
                    Image von was?
                    mfroeschl
                    Ein neues Image von buster für den Raspi.
                    • M mfroeschl
                      mfroeschl
                      @mfroeschl
                      ähh Bullseye
                      • M mfroeschl
                        ein
                        iobroker restore 0
                        Womöglich war der nur nicht gestartet.
                          mfroeschl
                          Ich hatte auch
                          iobroker start all
                          mehrfach probiert
                          • M mfroeschl
                            ein
                            iobroker restore 0
                            ein
                            iobroker restore 0
                            wieso nehmt ihr alle die 0 und nicht den Dateinamen?
                            und welches Ergebnis genau?
                              ein
                              iobroker restore 0
                              mfroeschl
                              habe den Befehl im Internet gefunden und mir da nix dabei gedacht.
                              Das Ergebnis nach der Meldung dass der Restore successful gewesen sein war immer gleich. Der admin Adpater des iobrokers war nicht über 192.xxx.xxx.xxx:8081 erreichbar.
                              Es wurden auch keine Adapter installiert die im Backup enthalten waren, lediglich der Admin-Adapter, sonst nix.
                              • M mfroeschl
                                und wie lange hast du dann gewartet um den admin aufzurufen?
                                Danach werden erst alle Adapter neu gebaut. Das dauert schon mal gerne 1h+
                                Allerdings müsste der Admin erreichbar sein.
                                Wie Thomas schon schreibt war der wahrscheinlich nur nicht gestartet
                                  mfroeschl
                                  Hab einige Minuten gewartet, genau weiß ich das aber nicht mehr.
                                  Ist aber kein Problem, hab hier noch einen Pi3B rumlegen, da installier ich jetzt einfach nochmal das aktuelle Image, dann installiere ich den iobroker drauf und mache ein restore.
                                  Ich poste hier dann die Meldungen und Screenshots..
                                  • M mfroeschl
                                    und dann bekommen wir das schon ans laufen!
                                    Welcher Controller läuft auf dem Backup?
                                    Schon mit jsonl oder noch mit file/redis
                                      mfroeschl
                                      @homoran said in Updates funktionieren nicht mehr:
                                      Wie finde ich das heraus, das sagt mir nix, sorry
                                      • M mfroeschl
                                        das sagt mir nix,
                                        die interne Datenbank für die States/objects wurde mit dem neuen Controller auf jsonl umgestellt. Davor wurden sie ind einfache JSON Dateien (File) geschriebn
                                        Wenn du im Backup noch einen älteren Controller (v3x) laufen hast musst du nach der Neuinstallaton diesen erst downgraden.
                                        ggf. war das dein Problem
                                          das sagt mir nix,
                                          mfroeschl
                                          Ich hatte die js-controller immer up-to-date gehalten. Da müsste der 4.0.21 drauf gewesen sein
                                          Hab jetzt eine neues Image von bulleyes auf eine neue SD Karte gespielt und den iobroker installiert.
                                          library: loaded
                                          Library version=2022-02-10
                                              Welcome to the ioBroker installer!
                                              Installer version: 2022-02-13
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/4)
                                          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Holen:2 http://archive.raspberrypi.org/debian bullseye InRelease [23,7 kB]
                                          OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                                          Holen:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
                                          Es wurden 306 kB in 2 s geholt (198 kB/s).
                                          Changing npm registry to https://registry.npmjs.org
                                          Installed gcc-c++
                                          Installed python-dev
                                              Creating ioBroker user and directory (2/4)
                                          Created /etc/sudoers.d/iobroker
                                          Directory /opt/iobroker created
                                              Installing ioBroker (3/4)
                                              Finalizing installation (4/4)
                                          Enabling autostart...
                                          Autostart enabled!
                                              ioBroker was installed successfully
                                              Open http://192.168.0.73:8081 in a browser and start configuring!
                                          You need to re-login before doing anything else on the console!
                                          pi@raspberrypi:~ $
