  4. [Aufruf] vis-beta Releasen?
    5.7k
97 Beiträge 13 Kommentatoren 10.5k Aufrufe
    pix
    #61
    Update in Admin über Update-Knopf von 0.12.16 auf 0.12.17 ergibt diesen Fehler unter Safari/OS X
    $ ./iobroker upgrade vis-beta
    npm install iobroker.vis-beta --production --prefix "/Users/pix/Documents/iobroker" (System call)
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@^0.5.1 (node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for bluetooth-hci-socket@0.5.1: wanted {"os":"linux,android,win32","arch":"any"} (current: {"os":"darwin","arch":"x64"})
    ERROR: host.MacMini-Ethernet.fritz.box Cannot install iobroker.vis-beta: 1
    Pix
    Edit:
    wurde aber trotzdem installiert
    ! MacMini-Ethernet:iobroker pix$ ./iobroker update update done Adapter "zwave" : 0.5.1 Adapter "yr" : 1.0.5 , installed 1.0.5 Adapter "yahka" : 0.5.4 , installed 0.5.2 [Updateable] Adapter "yamaha" : 0.3.7 Adapter "xs1" : 0.5.2 Adapter "wolf" : 0.9.2 Adapter "wifilight" : 0.1.1 Adapter "wm-bus" : 0.1.12 Adapter "wetty" : 0.1.1 Adapter "web" : 2.0.2 , installed 2.0.2 Adapter "weatherunderground": 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-plumb" : 0.1.6 Adapter "vis-players" : 0.1.4 Adapter "vis-metro" : 1.0.4 , installed 1.0.4 Adapter "vis-map" : 0.1.3 , installed 0.1.3 Adapter "vis-lcars" : 1.0.1 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-justgage" : 0.7.1 , installed 0.7.1 Adapter "vis-jqui-mfd" : 1.0.5 , installed 1.0.5 Adapter "vis-hqwidgets" : 1.0.6 , installed 1.0.6 Adapter "vis-history" : 0.2.4 , installed 0.2.4 Adapter "vis-google-fonts": 0.1.0 , installed 0.1.0 Adapter "vis-fancyswitch": 1.0.0 , installed 1.0.0 Adapter "vis-colorpicker": 1.1.1 , installed 1.1.1 Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5 Adapter "vis-beta" : 0.12.17 , installed 0.12.17 ... !
      pix
      #62
      @pix:
      @Bluefox:
      @pix:
      Hab es schon an anderer Stelle geschrieben:
      Unter VIS 0.12.16 bleiben Sayit-Ansagen stumm. Unter 0.10.X gibt es kein Problem.
      Übrigens: Danke für's Reparieren der Dropdown Auswahl:Bildschirmfoto 2017-03-21 um 11.24.32.jpgBisher konnte ich im Dropdown-Auswahlmenü nicht scrollen. Das geht jetzt wieder! :D
      Pix Ok. Werde sayit checken. Wie wird gesteuert? Über Instanz Name, FFFFFFFF oder * ?
      (Access Key im Screenshot anonymisiert)
      Pix `
      Sayit Browserausgabe bleibt unter 0.12.17 auch stumm. Jeweils mit * und FFFFFFFF und direkter Texteingabe im Objekt-Reiter von Admin getestet.
      • BluefoxB Offline
        BluefoxB Offline
        #63
        @KNXbroker:
        Komme auch nicht auf die 12.17. Er bringt mir immer folgenden Fehler:
        $ ./iobroker url "https://github.com/iobroker/ioBroker.vis-beta/tarball/master" vis-beta
        install https://github.com/iobroker/ioBroker.vis-beta/tarball/master
        npm install https://github.com/iobroker/ioBroker.vis-beta/tarball/master --production --prefix "/opt/iobroker" (System call)
        npm
        ERR!
        fetch failed https://github.com/iobroker/ioBroker.vis-beta/tarball/master
        npm WARN retry will retry, error on last attempt: Error: fetch failed with status code 404
        npm
        ERR!
        npm
        ERR! fetch failed https://github.com/iobroker/ioBroker.vis-beta/tarball/master
        npm
        ERR! Linux 4.4.38-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/iobroker/ioBroker.vis-beta/tarball/master" "--production" "--prefix" "/opt/iobroker"npm
        ERR! node v4.7.3npm ERR!
        npm v2.15.11
        npm ERR!
        fetch failed with status code 404npm ERR!
        npm ERR! If you need help, you may report this error at:
        npm ERR! <https: github.com/npm/issues="">
        ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
        ! ERROR: host.raspberrypi Cannot install https://github.com/iobroker/ioBroker.vis-beta/tarball/master: 1
        ERROR: process exited with code 25</https:>
        Die Debug Log habe ich beigefügt `
        cd /opt/iobroker
        npm i iobroker.vis-beta --production
        • BluefoxB Offline
          BluefoxB Offline
          #64
          @pix:
          ERROR: process exited with code 25 `
          Dieser Fehler gehört zu anderem Paket. Npm 3 versucht alle Pakete irgendwie noch mal zu installieren. Es gibt noch keine Lösung.
          • rantanplanR Offline
            rantanplanR Offline
            rantanplan
            #65
            😢 Keiner spricht mir mir 😢
            Rantanplan
            • K Offline
              KNXbroker
              #66
              Hi BlueFox,
              danke, mit der Terminal Eingabe hat es funktioniert! Damit ist auch das Font Problem behoben. Folgendes noch nicht
              • Rückgängigtaste geht nicht live (muss immer F5 drücken)
              • Das ändern eines Themas wird nicht Live übernommen (muss immer F5 drücken)
              • Interessanterweise fehlt auch die Zeile Lade Daten… beim Startbildschirm des Viewer
              • EDIT: Der dunkle Startbildschirm geht auch nicht
              Bei mir steht auch …html manifest... im header (siehe Anhang)
              Gruß KNX Broker
              • BluefoxB Offline
                BluefoxB Offline
                #67
                @pix:
                @pix:
                @Bluefox:
                Ok. Werde sayit checken. Wie wird gesteuert? Über Instanz Name, FFFFFFFF oder * ? `
                Pix `
                Sayit Browserausgabe bleibt unter 0.12.17 auch stumm. Jeweils mit * und FFFFFFFF und direkter Texteingabe im Objekt-Reiter von Admin getestet. `
                Ich hoffe du hast mit vis-beta.0.control.command und nicht mit vis.0.control.command probiert?
                Bei mir geht es.
                • BluefoxB Offline
                  BluefoxB Offline
                  #68
                  @rantanplan:
                  Hier noch mal meine Fehlermeldung.
                  info   exit 25
                  error   host.KDB-W10-Onl Cannot install iobroker.vis-beta: 1
                  info   1
                  info   code
                  info
                  info   ERR!
                  info
                  info   npm
                  info   starting. Version 0.12.17 in C:/ioBroker/node_modules/iobroker.vis-beta, node: v6.10.0
                  info   npm install iobroker.vis-beta --production --prefix "C:/ioBroker" (System call)
                  info   add vis-beta
                  Liegt es eventuell an node v6.10.0?
                  Grüße `
                  Kann es sein, dass trotz Fehlermeldungen ist vis-beta installiert?
                  • BluefoxB Offline
                    BluefoxB Offline
                    #69
                    @KNXbroker:
                    • EDIT: Der dunkle Startbildschirm geht auch nicht `
                      Danke. Es gibt wieder was zu tun. ;)
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      #70
                      @Bluefox:
                      und ne Entprellung in die VIS….für die Buttons
                        #71
                        @arteck:
                        und ne Entprellung in die VIS….für die Buttons `
                        funktioniert das nicht???
                        Rainer
                          rantanplanR Offline
                          rantanplan
                          #72
                          @Bluefox:
                          Kann es sein, dass trotz Fehlermeldungen ist vis-beta installiert? `
                          So war es bei beta-Versionen vorher.
                          Fehlermeldung bei Update.
                          Admin zeigte die neue Version an.
                          In Edit vis-beta wurde aber noch die Alte angezeigt.
                          Ich habe nun alle vis deinstalliert und neu installiert.
                          Zur Zeit ist alles ok.
                          Mal sehen was beim nächsten Update passiert.
                          Grüße
                          Rantanplan
                          • BluefoxB Offline
                            BluefoxB Offline
                            #73
                            @Bluefox:
                              Fixed
                              @Bluefox:
                                Fixed
                                @Bluefox:
                                  Die Daten im Runtime werden nicht mehr am Anfang geladen, sondern nur wenn ein View angezeigt werden sollte. Also muss so sein.
                                  @Bluefox:
                                    Kann nicht reproduzieren.
                                    48_2017-03-22_20_09_26-vis_-d__pwork_iobroker-data_files_vis-_…js_vis.js-_webstorm_2017.1.png
                                  Kann man mehr Info darüber haben? Ging in 0.10.15 und in 0.12.x nicht? `
                              akamia
                              #74
                              In der 0.12.8 funktionieren die Schriftfarben und -größen wieder, ebenso die Filter. Danke bluefox.
                              NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
                              piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
                                rantanplanR Offline
                                rantanplan
                                #75
                                In der 0.12.08 schneller und flüssiger View-Wechsel. Keine störende weiße Seite mehr. Sehr angenehm.
                                Habe auf einem Labtop 2 Browser geöffnet.
                                Einer mit vis und der andere mit vis-beta.
                                Wenn der Laptop aus dem Sleepmodus kommt zeigt vis "websocket error",
                                bei vis-beta alles Ok
                                Gute Arbeit!
                                Grüße
                                Rantanplan
                                • L Offline
                                  looxer01
                                  #76
                                  ich hatte vor einiger Zeit einen post aufgemacht mit einem Problem des Widgets " "Jqui control input datetime"
                                  Wenn das Widget mit einer View aufgemacht wird, dann ist alles ok. Wenn dass Widget aber in einem JQUI Conainer aufgemacht wird,
                                  dann kommt der Dialog nicht hoch. Auch ist das Widget abgeschnitten in der Länge.
                                  jetzt habe ich das Ganze mit VIS Beta getestet und das Problem ist nach wie vor da.
                                  Der ursprüngliche post mit allen Details ist hier: http://forum.iobroker.net/viewtopic.php … xer#p56145
                                  Demnach liegt es zwar nicht direkt an VIS Beta, waere aber toll, wenn das gefixt werden könnte.
                                  vG Looxer
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #77
                                    @looxer01:
                                    vG Looxer `
                                    Looxer01 ich bin momentan so ausgerichtet, dass ich endlich (nach 4 monate) mindestens, dass was 0.10 konnte, auch 0.12 kann.
                                    Natürlich habe ich dein Post vergessen. Kannst du denn auf Trello posten?
                                    • L Offline
                                      looxer01
                                      #78
                                      @Bluefox:
                                      ich bin momentan so ausgerichtet, dass ich endlich (nach 4 monate) mindestens, dass was 0.10 konnte, auch 0.12 kann `
                                      das verstehe ich. Danke fuer den Trello-Hinweis. Issue ist dort jetzt unter Bug vermerkt.
                                      Kleiner Kommentar zu VIS. Die VIS 10er release kann ich schon lange nicht mehr nutzen. Es kam zu erheblichen Performance Prolemen mit meinem Tablet. Daher habe ich schon lange die 11.2 im Einsatz. Die 12er Beta habe ich getestet auch die Gruppierungsfunktion.
                                      Mir macht das einen sehr stabilen Eindruck.
                                      vG Looxer
                                        Svemo
                                        #79
                                        Ich habe leider immer noch das Problem das ich keine Filterbar nutzen kann..
                                        hab testweise 2 widgets erstellt und filter gesetzt die Bar mit 2 knöpfen/ Filter gesetzt….
                                        Kann aber wie siehe Bild kein Wert für den Knopf auswählen.. "leeres Feld" manuell kann ich es zwar eingeben aber wenn ich dann einen Testlauf mache.. zeigen die Buttons keine Reaktion. Es wird weder was ein noch ausgeblendet!.
                                        kann mir jemand erklären wie ich diese zum laufen bekomme.
                                        Hatte früher mal 3 übernander liegende widgets die immer funktioniert haben.. mit ein und ausblenden!
                                        kann es Sein das div. Browser auch Probleme machen.
                                        kann manches nur im IE und manches nur im Firefox bearbeiten? da mir immer mal wieder keine Widget Konfig angezeigt wird.
                                        Grüße
                                        Svemo
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #80
                                          @Bluefox:
                                          @Bluefox:
                                            Fixed
                                            @Bluefox:
                                              Fixed
                                              @Bluefox:
                                                @Bluefox:
                                                2017-03-22 20_09_26-vis - [D__pWork_iobroker-data_files_vis] - …_js_vis.js - WebStorm 2017.1.png
                                                ohhhh. hab ich was verpasst… wo kann ich die ms einstellen für diese ??
