  4. [gelöst] Adapter löschen - IOBroker tot
    6.0k
15 Beiträge 7 Kommentatoren 1.2k Aufrufe 5 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    schrieb am zuletzt editiert von WolfgangFB
    Ich wollte meine IO Broker Installation aufräumen und nicht benötigte Adapter entfernen.
    pi@raspberrypi4:~ $ iobroker del ble
    Delete adapter "ble"
    host.raspberrypi4 Counted 1 instances of ble
    host.raspberrypi4 Counted 1 meta of ble
    host.raspberrypi4 Counted 1 adapter for ble
    host.raspberrypi4 Counted 15605 devices of ble
    host.raspberrypi4 Counted 15607 channels of ble
    host.raspberrypi4 Counted 31227 states of ble
    host.raspberrypi4 Counted 14 states of system.adapter.ble
    host.raspberrypi4 Counted 26739 states (io.ble.*) from states
    host.raspberrypi4 Counted 14 states (system.adapter.ble.*) from states
    host.raspberrypi4 file ble.admin deleted
    host.raspberrypi4 object ble deleted
    host.raspberrypi4 object ble.admin deleted
    host.raspberrypi4 Deleting 62456 object(s). Be patient...
    host.raspberrypi4: Only 62400 objects left to be deleted.
    host.raspberrypi4: Only 62200 objects left to be deleted.
    host.raspberrypi4: Only 62000 objects left to be deleted.
     Objects database error: read ECONNRESET
     Objects database error: connect ECONNREFUSED 0.0.0.0:9001
     States database error: connect ECONNREFUSED 0.0.0.0:9000
    host.raspberrypi4: Only 61800 objects left to be deleted.
    seitdem bekomme ich die unterschiedlichsten Statusmeldungen:
    pi@raspberrypi4:~ $ iobroker status
    Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
    No connection to databases possible ...
     Cannot load "custom": Connection is closed.
     Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
     Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
    Objects type: file
    States  type: file
    pi@raspberrypi4:~ $
    Wie bekomme ich das wieder repariert?
    arteckA HomoranH 2 Antworten Letzte Antwort
    • W WolfgangFB
      Objects type: file
      States  type: file
      pi@raspberrypi4:~ $
      arteckA Offline
      arteckA Offline
      arteck
      @wolfgangfb sagte in Adapter löschen - IOBroker tot:
      Try last Backup!
      • W Offline
        W Offline
        WolfgangFB
        @arteck
        Da beißt sich die Katze in den Schwanz. Dann frage ich anders rum. Wie werde ich die amokgelaufene ble Instanz wieder los? Wenn ich das Backup nehme ist die ble Instanz wieder da, wenn ich versuche die zu löschen stirbt IOBroker.
        J 1 Antwort Letzte Antwort
        • W WolfgangFB
          @arteck
          Jan1
          @wolfgangfb
          Stellt sich die Frage warum die Instanz beim Löschen des Adapter nicht einfach mit verschwindet so wie es eigentlich sein soll?
          Wenn Du das Backup restorst, wird eh alles frisch installiert und dann sollte sich auch der Adpter "normal" deinstallieren lassen. Ist das nicht der Fall, ist was anderes krumm.
          • W WolfgangFB
            Objects type: file
            States  type: file
            pi@raspberrypi4:~ $
            das ist wohl zu viel
            W 1 Antwort Letzte Antwort
              W Offline
              W Offline
              WolfgangFB
              Das das zu viel ist sehe ich auch so. Keine Ahnung woher der ble Adapter so viele Einträge hat. Aber wie werde ich den wieder los?
              Wenn ich ihn versuche mit
              iobroker del ble
              zu löschen reist mir das das System in den Tod.
              Auf welche Arten kann man einen Adapter (mit Objekten) noch löschen?
              • W WolfgangFB
                iobroker del ble
                Jan1
                @wolfgangfb
                Wenn Du dem Adapter erlaubst alle BT Geräte zu erkennen, dann hast je nach Wohnlage schnell mal paar tausend Objekte drin ;)
                Kannst die Objekte nicht manuell löschen (wird wohl lange dauern) und dann den Adapter normal deinstallieren?
                • W Offline
                  W Offline
                  WolfgangFB
                  @jan1
                  Ich habe jetzt mal versucht aus der "Objekte" Instanz die ersten 10 Datenpunkte von Hand zu löschen. Alleine das genügt um die objeects.json zu zerstören -:(
                  Hat noch irgend jemand eine Idee wie ich das repariert bekomme?
                  • W WolfgangFB
                    @jan1
                    @wolfgangfb
                    Hast du das
                    iobroker del ble
                    abgeschossen?
                    Lass das mal sein Werk tun, ggf. übernacht.
                    Und den Datenpunkt 'Allow new devices' oder so ähnlich auf false setzen.
                    Warum ist das eigentlich noch
                    Objects type: file
                    States type: file
                    und nicht zum aktuellen Format konvertiert? Mit dem js-controller 4 sollte das eigentlich der Fall sein.
                      @wolfgangfb
                      Hast du das
                      iobroker del ble
                      abgeschossen?
                      Objects type: file
                      States type: file
                      W Offline
                      W Offline
                      WolfgangFB
                      Ich habe den ble Adapter inzwischen ausgeschaltet.
                      iobroker del ble
                      läuft durch
                      host.raspberrypi4: Only 1000 states left to be deleted.
                      host.raspberrypi4: Only 800 states left to be deleted.
                      host.raspberrypi4: Only 600 states left to be deleted.
                      host.raspberrypi4: Only 400 states left to be deleted.
                      host.raspberrypi4: Only 200 states left to be deleted.
                      npm uninstall iobroker.ble --loglevel error --prefix "/opt/iobroker" (System call)
                      Aber schon zuvor ist das System tot.
                       Cannot find view "system" for search "enum"
                      host.raspberrypi4 error: Error: Cannot find view "system"
                      host.raspberrypi4 Deleting 26769 state(s). Be patient...
                      host.raspberrypi4: Only 26600 states left to be deleted.
                      host.raspberrypi4: Only 26400 states left to be deleted.
                      Ab diesem Zeitpunkt ist die objects.json kaputt und IOBrokker läuft nicht mehr.
                      Ich habe jetzt mal geschaut, ob es einen json Editor gibt, mit dem ich den ganzen ble Tree löschen kann. Ich habe aber noch keinen gefunden, der eine 37 MB große Datei laden kann.
                      • W WolfgangFB
                        iobroker del ble
                        läuft durch
                        BananaJoeB Online
                        BananaJoeB Online
                        BananaJoe
                        @wolfgangfb Notepad++ wird das können.
                        • BananaJoeB BananaJoe
                          W Offline
                          W Offline
                          WolfgangFB
                          @bananajoe
                          Notepadd++ kann die Datei zwar laden, aber nicht als Json Tree darstellen. Es wird eine Zeile mit 37142573 Zeichen angezeigt. Wenn ich zum Vergleich die iobroker.json lade bekomme ich die Baumstruktur.
                          FredFF 1 Antwort Letzte Antwort
                          • W WolfgangFB
                            @bananajoe
                            FredFF Online
                            FredFF Online
                            FredF
                            Most Active Forum Testing
                            @wolfgangfb Für Notepad++ gibt es ein JSON Viewer als Plugin
                            • FredFF FredF
                              W Offline
                              W Offline
                              WolfgangFB
                              @fredf
                              Hallo an alle
                              Notepad++ versucht sich immer noch an der Datei. Das wird wohl nichts mehr.
                              Aber: Mit UltraEdit konnte ich den ersten Block mit ca. 20000 Objekten löschen. Anschließend hat dann auch iobroker del ble funktioniert!
                              Jetzt bin ich den ble Adapter endlich los, das System läuft auf einmal wieder richtig flott. Ich hoffe dass mir das so schnell nicht wieder passiert.
                              • W WolfgangFB
                                @fredf
                                Hallo an alle
                                FredFF Online
                                FredFF Online
                                FredF
                                @wolfgangfb Schreibst noch ein [gelöst] in den Titel deines Beitrags?
