  3. Einsteigerfragen
  4. [done] Nach Influxdb Adapterupdate --> No connection to DB
    5.6k
13 Beiträge 6 Kommentatoren 1.3k Aufrufe 6 Beobachtet
    tklein
    schrieb am zuletzt editiert von tklein
    ich habe meinen Influxdb Adapter auf 2.6.3 aktualisiert. Seitdem bekomme ich folgende Info im Log:
    influxdb.0	2022-03-12 18:43:12.777	warn	(3848) No connection to DB
    Downgrade auf 2.6.2 bzw. 2.5.2 hat leider nix gebracht.
    Der Service läuft:
    pi@raspberrypi-iob:~ $ sudo service influxdb status
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: active (running) since Sat 2022-03-12 18:30:10 CET; 11min ago
         Docs: man:influxd(1)
     Main PID: 466 (influxd)
        Tasks: 15 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               └─466 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.415980Z lvl=info msg="Snapshot for path written" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCS0000 op_name=tsm1_cache_snapshot path=/var/lib/influxdb/data/iobroker/au
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.417464Z lvl=info msg="Cache snapshot (end)" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCS0000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=17.221ms
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.421438Z lvl=info msg="Snapshot for path written" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCRl000 op_name=tsm1_cache_snapshot path=/var/lib/influxdb/data/iobroker/au
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.421588Z lvl=info msg="Cache snapshot (end)" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCRl000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=21.736ms
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.440947Z lvl=info msg="Snapshot for path written" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCSl000 op_name=tsm1_cache_snapshot path=/var/lib/influxdb/data/iobroker/au
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.441607Z lvl=info msg="Cache snapshot (end)" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCSl000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=38.242ms
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.442258Z lvl=info msg="Snapshot for path written" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCT0000 op_name=tsm1_cache_snapshot path=/var/lib/influxdb/data/iobroker/au
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.442397Z lvl=info msg="Cache snapshot (end)" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCT0000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=38.000ms
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.447013Z lvl=info msg="Snapshot for path written" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCSW000 op_name=tsm1_cache_snapshot path=/var/lib/influxdb/data/iobroker/au
    Mar 12 18:40:28 raspberrypi-iob influxd[466]: ts=2022-03-12T17:40:28.447141Z lvl=info msg="Cache snapshot (end)" log_id=0_BnjTvG000 engine=tsm1 trace_id=0_BoKCSW000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=44.723ms
    Version:
    pi@raspberrypi-iob:~ $ influxd version
    InfluxDB v1.6.4 (git: unknown unknown)
     8888888           .d888 888                   8888888b.  888888b.
       888            d88P"  888                   888  "Y88b 888  "88b
       888            888    888                   888    888 888  .88P
       888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
       888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
       888   888  888 888    888 888  888   X88K   888    888 888    888
       888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
     8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
    2022-03-12T17:43:41.195366Z     info    InfluxDB starting       {"log_id": "0_BoVyYl000", "version": "1.6.4", "branch": "unknown", "commit": "unknown"}
    2022-03-12T17:43:41.195520Z     info    Go runtime      {"log_id": "0_BoVyYl000", "version": "go1.11.6", "maxprocs": 4}
    run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
    Systeminfo:
    • Linux Buster auf Raspi 4 mit 4GB
    • Node.js: v14.17.0
    • NPM: 6.14.13
    • JS-Controller: 3.3.22
    • T tklein
      Der Service läuft:
      Version:
      Systeminfo:
      • Node.js: v14.17.0
      • NPM: 6.14.13
      @tklein
      Passwort nochmal neu im Adapter eingegeben?
      Und halt den Rest vom System auch auf Stand:
      Node.js: v14.17.0
      NPM: 6.14.13
        @tklein
        Node.js: v14.17.0
        NPM: 6.14.13
        tklein
        @thomas-braun said in Nach Influxdb Adapterupdate --> No connection to DB:
        ich glaube das ja nicht. Beim Verbindungstest habe ich immer ein ok bekommen. Dann werde ich jetzt wieder auf 2.6.3 updaten
        • T tklein
          @tklein sagte in [done] Nach Influxdb Adapterupdate --> No connection to DB:
          Vergiss den Rest nicht.
          • GLH 510G Offline
            GLH 510G Offline
            GLH 510
            Ich hatte das gleiche Problem mit der 2.6.3.
            Erneutes eingeben des Passwortes hat das Problem gelöst.
            Dank sehr.
              Marcus_Muc
              Bei mir war seit gestern nach dem Update von dem Adapter das gleiche Problem. Hatte vorher 1.9.5. Habe die Zugangsdaten neu eingegeben und trotzdem ging es nicht. Hab auch noch auf dem Raspberry Pi seit über einem Jahr Influxbd nicht aktualisiert, vielleicht liegts daran. Hab jetzt erstmal das Backup wieder eingespielt das ich vor dem updaten des Adapters gemacht habe. Jetzt wart ich erstmal ein bisschen bevor ich den update :-)
              • M Marcus_Muc
                @marcus_muc sagte in [done] Nach Influxdb Adapterupdate --> No connection to DB:
                Möglich. Der Rest vom Fest ist auch noch unberührt?
                • TilimankaT Offline
                  TilimankaT Offline
                  Tilimanka
                  hallo
                  Ich habe auch ein problem
                  bei mir wird der adapter nach dem update von 1.9.5 auf 2.3.6 nicht grün.
                  gesehen habe ich im log einen "http error 404" nachdem die Organisation gechecked wurde.
                  muss da evtl. im adapter noch was eingetragen werden ?
                  (node: v12.21.0, js-controller: 4.0.19)
                  T crunchipC 2 Antworten Letzte Antwort
                  • TilimankaT Tilimanka
                    hallo
                    tklein
                    @tilimanka said in [done] Nach Influxdb Adapterupdate --> No connection to DB:
                    hallo
                    Welches Protokoll hast du ausgewählt?
                      hallo
                      crunchipC Offline
                      crunchipC Offline
                      @tilimanka hast du auch ein upgrade deiner InfluxDB auf v2.x gemacht, oder nur den Adapter umgestellt auf DB Version 2.x
                        TilimankaT Offline
                        Tilimanka
                        @tklein
                        protokoll siehe grafik oben --> http
                        @crunchip
                        ja , siehe oben, upgrade von 1.9.5 auf 2.3.6
                        • crunchipC Offline
                          crunchipC Offline
                          @tilimanka sagte in [done] Nach Influxdb Adapterupdate --> No connection to DB:
                          nochmal, deine InfluxDB selbst, die aktuelle Version gibt es nur v2.1.1 und es gibt auch keine Organization mehr in Influx2, sondern bucket
                          somit musst du, wenn du die Datenbank nicht auf v2 umgestellt hast, in deiner Instanz weiterhin DB Version 1.x einstellen
                          https://docs.influxdata.com/influxdb/v2.1/upgrade/v1-to-v2/automatic-upgrade/
                            TilimankaT Offline
                            Tilimanka
                            ah verstehe , die DB selbst muss auch upgedated werden ( da war doch mal was...)
                            Habe den Adapter auf 1.x gestellt, Passwort neu eingegeben und jetzt wird er grün.
                            Danke für Deine Hilfe
                            Tili
