  3. Einsteigerfragen
  4. Frage zu Instanz web.0
    5.6k
24 Beiträge 6 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • H Offline
    hausautomation.digital
    Selbes Problem mit web.0 bei mir. Blöderweise startet VIS nicht.
    Log web.0
    2022-03-10 21:30:10.592 - info: host.homebutler stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-10 21:30:10.601 - info: web.0 (27805) Got terminate signal TERMINATE_YOURSELF
    2022-03-10 21:30:10.608 - info: host.homebutler stopInstance system.adapter.web.0 send kill signal
    2022-03-10 21:30:10.604 - debug: web.0 (27805) terminating http server on port 8082
    2022-03-10 21:30:10.605 - info: web.0 (27805) terminated http server on port 8082
    2022-03-10 21:30:10.606 - info: web.0 (27805) terminating
    2022-03-10 21:30:10.608 - debug: web.0 (27805) Plugin sentry destroyed
    2022-03-10 21:30:10.609 - info: web.0 (27805) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-10 21:30:11.185 - info: host.homebutler instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-10 21:30:13.705 - info: host.homebutler instance system.adapter.web.0 started with pid 28352
    2022-03-10 21:30:15.267 - debug: web.0 (28352) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-03-10 21:30:15.308 - debug: web.0 (28352) Objects client ready ... initialize now
    2022-03-10 21:30:15.311 - debug: web.0 (28352) Objects create System PubSub Client
    2022-03-10 21:30:15.313 - debug: web.0 (28352) Objects create User PubSub Client
    2022-03-10 21:30:15.334 - debug: web.0 (28352) Objects client initialize lua scripts
    2022-03-10 21:30:15.342 - debug: web.0 (28352) Objects connected to redis: 127.0.0.1:9001
    2022-03-10 21:30:15.368 - debug: web.0 (28352) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-03-10 21:30:15.378 - debug: web.0 (28352) States create System PubSub Client
    2022-03-10 21:30:15.379 - debug: web.0 (28352) States create User PubSub Client
    2022-03-10 21:30:15.391 - debug: web.0 (28352) States connected to redis: 127.0.0.1:9000
    2022-03-10 21:30:15.428 - debug: web.0 (28352) Plugin sentry Initialize Plugin (enabled=true)
    2022-03-10 21:30:15.815 - info: web.0 (28352) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.19
    2022-03-10 21:30:15.939 - debug: web.0 (28352) Activating states & socket info
    2022-03-10 21:30:15.942 - debug: web.0 (28352) Using http createServer
    2022-03-10 21:30:15.949 - debug: web.0 (28352) Activating extensions
    2022-03-10 21:30:15.950 - debug: web.0 (28352) Activating web files from objectDB
    2022-03-10 21:30:15.956 - info: web.0 (28352) http server listening on port 8082
    Log VIS
    2022-03-10 21:35:46.655 - info: host.homebutler "system.adapter.vis.0" enabled
    2022-03-10 21:35:48.047 - debug: vis.0 (3261) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-03-10 21:35:48.099 - debug: vis.0 (3261) Objects client ready ... initialize now
    2022-03-10 21:35:48.102 - debug: vis.0 (3261) Objects create System PubSub Client
    2022-03-10 21:35:48.104 - debug: vis.0 (3261) Objects create User PubSub Client
    2022-03-10 21:35:48.132 - debug: vis.0 (3261) Objects client initialize lua scripts
    2022-03-10 21:35:48.139 - debug: vis.0 (3261) Objects connected to redis: 127.0.0.1:9001
    2022-03-10 21:35:48.164 - debug: vis.0 (3261) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-03-10 21:35:48.172 - debug: vis.0 (3261) States create System PubSub Client
    2022-03-10 21:35:48.174 - debug: vis.0 (3261) States create User PubSub Client
    2022-03-10 21:35:48.184 - debug: vis.0 (3261) States connected to redis: 127.0.0.1:9000
    2022-03-10 21:35:48.248 - info: vis.0 (3261) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.19
    2022-03-10 21:35:48.628 - info: vis.0 (3261) vis license is OK.
    2022-03-10 21:35:49.239 - info: vis.0 (3261) Terminated (NO_ERROR): Without reason
    2022-03-10 21:35:49.779 - info: host.homebutler instance system.adapter.vis.0 terminated while should be started once
    Ergebnis:
    • crunchipC Offline
      crunchipC Offline
      @hausautomation-digital was zeigt die Browserconsole?
      H 2 Antworten Letzte Antwort
        @crunchip said in Frage zu Instanz web.0:
        Was meinst Du damit? 👶
          Browserconsole
          Sorry, hab mich grad erst schlau gemacht. ;)
          AbortError: Actor 'Conduits' destroyed before query 'RuntimeMessage' was resolved 2 ConduitsParent.jsm:362
          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. SymBfw.js:115
          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. 2 SymBfw.js:116
          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. SymBfw.js:116
          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. 2 SymBfw.js:115
          TypeError: a is undefined BfwNotificationCenterProxy.js:6:65
          Alternate Service Mapping found: https://adservice.google.de:-1 to https://googleads.g.doubleclick.net:443 2
          Promise rejected after context unloaded: Actor 'Conduits' destroyed before query 'RuntimeMessage' was resolved
          SymBfwCS.js:90
          AbortError: Actor 'Conduits' destroyed before query 'RuntimeMessage' was resolved 12 ConduitsParent.jsm:362
          3 SymBfwCS.js:90
          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. 4 SymBfw.js:115
          AbortError: Actor 'ExtensionContent' destroyed before query 'DetectLanguage' was resolved 5 ExtensionCommon.jsm:727
          SymBfwCS.js:90
              sendMessage moz-extension://c0d11057-17ed-4a1d-881e-c84a0db224c7/content/scripts/SymBfwCS.js:90
          Unchecked lastError value: Error: An unexpected error occurred 5 SymBfw.js:102
