  3. Einsteigerfragen
  4. Installation
  5. RPi Version Node.js
    6.3k
RPi Version Node.js
Geplant Angeheftet Gesperrt Verschoben Installation
18 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
    Broker Tester
    Hallo...
    bin am installieren des ioBrokers auf meinem PI.
    Welche Node.js Version wird denn unterstützt? Die 10.24. anscheinend nicht.
    Wie bekomme ich die richtige Version installiert??
    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/local/bin/npm
    v10.24.0
    v10.24.0
    npm does not support Node.js v10.24.0
    You should probably upgrade to a newer version of node as we
    can't make any promises that npm will work with this version.
    You can find the latest version at https://nodejs.org/
    /usr/local/lib/node_modules/npm/lib/npm.js:32
      #unloaded = false
    SyntaxError: Invalid or unexpected token
        at Module._compile (internal/modules/cjs/loader.js:723:23)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:692:17)
        at require (internal/modules/cjs/helpers.js:25:18)
        at module.exports (/usr/local/lib/node_modules/npm/lib/cli.js:22:15)
        at Object.<anonymous> (/usr/local/lib/node_modules/npm/bin/npm-cli.js:2:25)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
    ## Installing the NodeSource Node.js 14.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Ign:3 https://pi4j.com/download v1 InRelease
    Fehl:4 https://pi4j.com/download v1 Release
      Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification. [IP: 185.199.108.153 443]
    E: Das Depot »https://pi4j.com/download v1 Release« enthält keine Release-Datei.
    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
    Error executing command, exiting
    pi@raspberrypi:~ $ sudo apt install nodejs
    nodejs ist schon die neueste Version (10.24.0~dfsg-1~deb10u1).
    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
      gyp libjs-inherits libjs-is-typedarray libnode-dev libssl-dev libuv1-dev
    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 367 nicht aktualisiert.
    pi@raspberrypi:~ $ node -v
    v10.24.0
    • B Broker Tester
      Hallo...
      /usr/bin/nodejs
      /usr/bin/node
      /usr/local/bin/npm
      v10.24.0
      v10.24.0
        #unloaded = false
      pi@raspberrypi:~ $
      + apt-get update
      v10.24.0
      @broker-tester sagte in RPi Version Node.js:
      wie?
      Die momentan empfohlene Version ist node 14.x; bei anderen gewünschten Versionen in Schritt 4.1. die “14.x” gegen Y.x” austauschen.
      Quelle: https://www.iobroker.net/#de/documentation/install/linux.md
      nein, die ist viel zu alt.
      die 14 würde mit dem einfachen Einzeiler automatisch mit installiert, wenn noch kein node drauf ist.
      Ansonsten nach der verlinkten Anleitung vorgehen
      • B Broker Tester
        Hallo...
        /usr/bin/nodejs
        /usr/bin/node
        /usr/local/bin/npm
        v10.24.0
        v10.24.0
          #unloaded = false
        pi@raspberrypi:~ $
        + apt-get update
        v10.24.0
        Das ist aber keine futschneue Installation da, oder?
        Da ist irgendwas 'komisches' noch mit installiert.
        Jedenfalls ist
        eine Quelle die ich noch nie gesehen habe. (Und auch falsch aufgesetzt ist, sonst gäbe es die Fehlermeldung nicht).
        Offenbar ist da auch die sog. dfsg-Version von nodejs installiert. Die ist etwas schwierig zu bändigen.
        Zuerst musst du mal schauen, wo die Quelle mit pi4j.com herkommt.
        Müsste entweder in der Datei
        /etc/apt/sources.list
        oder in einer der NAME.list-Dateien im Verzeichnis
        /etc/apt/sources.list.d/
        zu finden sein.
        B 1 Antwort Letzte Antwort
          Jedenfalls ist
          zu finden sein.
          Broker Tester
          @thomas-braun said in RPi Version Node.js:
          Nein, keine neue Installation. Arbeite schon damit.
          Das ist ein Paket, welches ich für Python brauche.
          • B Broker Tester
            @broker-tester
            Dann musst du das zunächst reparieren. Sonst wird dein Paketmanager nicht funktionieren.
              @broker-tester
              Broker Tester
              @broker-tester
              Wie kann ich das denn reparieren?
              • B Broker Tester
                @broker-tester
                @broker-tester
                Ich vermute, da ist halt eine krumme .list-Datei von
                reingerutscht. Da ich aber nicht weiß, was das ist oder woher das kommt kann ich da auch nichts konkretes zu raten.
                Hast du denn mal in dem Verzeichnis das ich oben genannt habe rumgeschaut?
                  @broker-tester
                  Broker Tester
                  @broker-tester
                  ja die Datei steht da drin. Screenshot geht leider nicht.
                  Das pi4j Paket hab ich schon deinstalliert. bekomme ich die pi4j.list irgendwie gelöscht?
                  • B Broker Tester
                    @broker-tester
                    @broker-tester
                    Leg die erstmal auf Eis.
                    Mach aus der krummen Zeile einen Kommentar. Einfach ein Hashtag in die erste Spalte eintragen. So ungefähr:
                    # ich bin ein Kommentar und werde vom Paketmanager überlesen
                      @broker-tester
                      Broker Tester
                      @broker-tester
                      habe keine Berechtigung zum Speichern.
                      • B Broker Tester
                        @broker-tester
                        Warum nicht?
                        sudo nano /pfad/zur/datei
                        funktioniert nicht?
                          Warum nicht?
                          funktioniert nicht?
                          Broker Tester
                          Warum nicht?
                          funktioniert nicht?
                          Wenn man weiß wie, dann schon.....👍
                          • B Broker Tester
                            Warum nicht?
                            funktioniert nicht?
                            @broker-tester
                            sudo apt update
                            liefert?
                              @broker-tester
                              sudo apt update
                              liefert?
                              Broker Tester
                              @broker-tester
                              sudo apt update
                              liefert?
                              sudo apt update jetzt lief es durch.
                              node -v
                              und
                              nodejs -v
                              liefern jetzt die 14.19.0
                              ich versuche jetzt mit der ioBroker Installation fortzufahren... Danke schon mal
                              • B Broker Tester
                                @broker-tester
                                sudo apt update
                                liefert?
                                node -v
                                und
                                nodejs -v
                                node -v
                                und
                                nodejs -v
                                ein sudo apt update ändert niemals die node-Version von 10.x in 14.x
                                Was hast du gemacht?
                                • B Broker Tester
                                  @broker-tester
                                  sudo apt update
                                  liefert?
                                  node -v
                                  und
                                  nodejs -v
                                  @broker-tester
                                  Dann nochmal den kompletten Sermon:
                                    node -v
                                    und
                                    nodejs -v
                                    Broker Tester
                                    @homoran said in RPi Version Node.js:
                                    node -v
                                    und
                                    nodejs -v
                                    ich habe gemacht:
                                    sudo apt-get update && sudo apt-get upgrade
                                    sudo apt install -y nodejs
                                    sudo reboot
                                    • B Broker Tester
                                      node -v
                                      und
                                      nodejs -v
                                      ich habe gemacht:
                                      sudo reboot
                                      Broker Tester
                                      @broker-tester
                                      die Installation lief jetzt durch.
                                      Allerdings ließ sich die Website nicht öffnen.
                                      Bin dann auf einen Workaround gestoßen:
                                      cd /opt/iobroker
                                      iobroker stop
                                      npm install iobroker.js-controller
                                      iobroker setup
                                      iobroker add admin
                                      iobroker start
                                      und was soll ich sagen, es läuft jetzt. Danke
