  3. Einsteigerfragen
  4. Installation
  5. RPi Version Node.js
    6.3k
RPi Version Node.js
18 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • B Broker Tester
    Hallo...
    bin am installieren des ioBrokers auf meinem PI.
    Welche Node.js Version wird denn unterstützt? Die 10.24. anscheinend nicht.
    Wie bekomme ich die richtige Version installiert??
    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/local/bin/npm
    v10.24.0
    v10.24.0
    npm does not support Node.js v10.24.0
    You should probably upgrade to a newer version of node as we
    can't make any promises that npm will work with this version.
    You can find the latest version at https://nodejs.org/
    /usr/local/lib/node_modules/npm/lib/npm.js:32
      #unloaded = false
    SyntaxError: Invalid or unexpected token
        at Module._compile (internal/modules/cjs/loader.js:723:23)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:692:17)
        at require (internal/modules/cjs/helpers.js:25:18)
        at module.exports (/usr/local/lib/node_modules/npm/lib/cli.js:22:15)
        at Object.<anonymous> (/usr/local/lib/node_modules/npm/bin/npm-cli.js:2:25)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
    ## Installing the NodeSource Node.js 14.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Ign:3 https://pi4j.com/download v1 InRelease
    Fehl:4 https://pi4j.com/download v1 Release
      Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification. [IP: 185.199.108.153 443]
    E: Das Depot »https://pi4j.com/download v1 Release« enthält keine Release-Datei.
    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
    Error executing command, exiting
    pi@raspberrypi:~ $ sudo apt install nodejs
    nodejs ist schon die neueste Version (10.24.0~dfsg-1~deb10u1).
    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
      gyp libjs-inherits libjs-is-typedarray libnode-dev libssl-dev libuv1-dev
    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 367 nicht aktualisiert.
    pi@raspberrypi:~ $ node -v
    v10.24.0
    @broker-tester sagte in RPi Version Node.js:
    Das ist aber keine futschneue Installation da, oder?
    Da ist irgendwas 'komisches' noch mit installiert.
    Jedenfalls ist
    eine Quelle die ich noch nie gesehen habe. (Und auch falsch aufgesetzt ist, sonst gäbe es die Fehlermeldung nicht).
    Offenbar ist da auch die sog. dfsg-Version von nodejs installiert. Die ist etwas schwierig zu bändigen.
    Zuerst musst du mal schauen, wo die Quelle mit pi4j.com herkommt.
    Müsste entweder in der Datei
    /etc/apt/sources.list
    oder in einer der NAME.list-Dateien im Verzeichnis
    /etc/apt/sources.list.d/
    zu finden sein.
      Jedenfalls ist
      zu finden sein.
      Broker Tester
      @thomas-braun said in RPi Version Node.js:
      Nein, keine neue Installation. Arbeite schon damit.
      Das ist ein Paket, welches ich für Python brauche.
      • B Broker Tester
        @broker-tester
        Dann musst du das zunächst reparieren. Sonst wird dein Paketmanager nicht funktionieren.
          @broker-tester
          Broker Tester
          @broker-tester
          Wie kann ich das denn reparieren?
          • B Broker Tester
            @broker-tester
            @broker-tester
            Ich vermute, da ist halt eine krumme .list-Datei von
            reingerutscht. Da ich aber nicht weiß, was das ist oder woher das kommt kann ich da auch nichts konkretes zu raten.
            Hast du denn mal in dem Verzeichnis das ich oben genannt habe rumgeschaut?
              @broker-tester
              Broker Tester
              @broker-tester
              ja die Datei steht da drin. Screenshot geht leider nicht.
              Das pi4j Paket hab ich schon deinstalliert. bekomme ich die pi4j.list irgendwie gelöscht?
              • B Broker Tester
                @broker-tester
                @broker-tester
                Leg die erstmal auf Eis.
                Mach aus der krummen Zeile einen Kommentar. Einfach ein Hashtag in die erste Spalte eintragen. So ungefähr:
                # ich bin ein Kommentar und werde vom Paketmanager überlesen
                  @broker-tester
                  Broker Tester
                  @broker-tester
                  habe keine Berechtigung zum Speichern.
                  • B Broker Tester
                    @broker-tester
                    Warum nicht?
                    sudo nano /pfad/zur/datei
                    funktioniert nicht?
                      Warum nicht?
                      funktioniert nicht?
                      Broker Tester
                      Warum nicht?
                      funktioniert nicht?
                      Wenn man weiß wie, dann schon.....👍
                      • B Broker Tester
                        Warum nicht?
                        funktioniert nicht?
                        @broker-tester
                        sudo apt update
                        liefert?
                          @broker-tester
                          sudo apt update
                          liefert?
                          Broker Tester
                          @broker-tester
                          sudo apt update
                          liefert?
                          sudo apt update jetzt lief es durch.
                          node -v
                          und
                          nodejs -v
                          liefern jetzt die 14.19.0
                          ich versuche jetzt mit der ioBroker Installation fortzufahren... Danke schon mal
                          • B Broker Tester
                            @broker-tester
                            sudo apt update
                            liefert?
                            node -v
                            und
                            nodejs -v
                            node -v
                            und
                            nodejs -v
                            ein sudo apt update ändert niemals die node-Version von 10.x in 14.x
                            Was hast du gemacht?
                            • B Broker Tester
                              @broker-tester
                              sudo apt update
                              liefert?
                              node -v
                              und
                              nodejs -v
                              @broker-tester
                              Dann nochmal den kompletten Sermon:
                                node -v
                                und
                                nodejs -v
                                Broker Tester
                                @homoran said in RPi Version Node.js:
                                node -v
                                und
                                nodejs -v
                                ich habe gemacht:
                                sudo apt-get update && sudo apt-get upgrade
                                sudo apt install -y nodejs
                                sudo reboot
                                • B Broker Tester
                                  node -v
                                  und
                                  nodejs -v
                                  ich habe gemacht:
                                  sudo reboot
                                  Broker Tester
                                  @broker-tester
                                  die Installation lief jetzt durch.
                                  Allerdings ließ sich die Website nicht öffnen.
                                  Bin dann auf einen Workaround gestoßen:
                                  cd /opt/iobroker
                                  iobroker stop
                                  npm install iobroker.js-controller
                                  iobroker setup
                                  iobroker add admin
                                  iobroker start
                                  und was soll ich sagen, es läuft jetzt. Danke
