  4. Wiederherstellung nach Neuinstallation Backitup Probleme
48 Beiträge 6 Kommentatoren 5.4k Aufrufe 4 Beobachtet
    @fox1985 sagte in Wiederherstellung nach Neuinstallation Backitup Probleme:
    habe nun einen neuen Nutzer angelegt.
    dann führe unter diesem durch;
    iob stop
    iob fix
    iob start
    Um erst einmal die Rechte wieder ins Lot zu bringen
    Fox1985
    #41
    Habe ich ausgeführt
    root@iobroker2:/opt/iobroker/backups# cd ..
    root@iobroker2:/opt/iobroker# cd ..
    root@iobroker2:/opt# cd ..
    root@iobroker2:/# logout
    Debian GNU/Linux 11 iobroker2 tty1
    iobroker2 login: iobroker_config
    Password:
    Linux iobroker2 5.15.102-1-pve #1 SMP PVE 5.15.102-1 (2023-03-14T13:48Z) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    iobroker_config@iobroker2:~$ sudo apt install cifs-utils
    We trust you have received the usual lecture from the local System
    Administrator. It usually boils down to these three things:
        #1) Respect the privacy of others.
        #2) Think before you type.
        #3) With great power comes great responsibility.
    [sudo] password for iobroker_config:
    Reading package lists... Done
    Building dependency tree... Done
    cifs-utils is already the newest version (2:6.11-3.1+deb11u1).
    0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
    iobroker_config@iobroker2:~$ sudo apt update
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    37 packages can be upgraded. Run 'apt list --upgradable' to see them.
    iobroker_config@iobroker2:~$ apt policy cifs-utils
    cifs-utils:
      Installed: 2:6.11-3.1+deb11u1
      Candidate: 2:6.11-3.1+deb11u1
      Version table:
     *** 2:6.11-3.1+deb11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org bullseye-security/main amd64 Packages
            100 /var/lib/dpkg/status
    iobroker_config@iobroker2:~$ ^C
    iobroker_config@iobroker2:~$ iob stop
    iobroker_config@iobroker2:~$ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
    Created /etc/sudoers.d/iobroker
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
    iobroker_config@iobroker2:~$ iob start
    iobroker_config@iobroker2:~$ cd opt
    -bash: cd: opt: No such file or directory
    iobroker_config@iobroker2:~$ cd iobroker
    -bash: cd: iobroker: No such file or directory
    iobroker_config@iobroker2:~$ ls
    iobroker_config@iobroker2:~$ cd /opt
    iobroker_config@iobroker2:/opt$ cd /iobroker/backups
    -bash: cd: /iobroker/backups: No such file or directory
    -bash: cd: /iobroker/: No such file or directory
    iobroker_config@iobroker2:/opt$ ls
    iobroker
    -bash: cd: /iobroker: No such file or directory
    iobroker_config@iobroker2:~$ cd /iobroker/backups
    iobroker_config@iobroker2:~$ cd /iobroker/backups/
    -bash: cd: /iobroker/backups/: No such file or directory
    iobroker_config@iobroker2:~$ cd apt update
    -bash: cd: too many arguments
    cifs-utils:
      Version table:
    iobroker_config@iobroker2:/opt$ cd iobroker
    iobroker_config@iobroker2:/opt/iobroker$ cd backups
    iobroker_config@iobroker2:/opt/iobroker/backups$ iob stop
    iobroker_config@iobroker2:/opt/iobroker/backups$ sudo iobroker restore 0
    host.iobroker2 Using backup file iobroker_2023_05_01-02_40_10_backupiobroker.tar.gz
    iobroker controller daemon is not running
    host.iobroker2 OK.
    Removing current installation of iobroker.admin
    removed 24 packages in 2s
    44 packages are looking for funding
      run `npm fund` for details
    Removing current installation of iobroker.backitup
    removed 147 packages in 2s
    25 packages are looking for funding
    Removing current installation of iobroker.discovery
    removed 43 packages in 1s
    13 packages are looking for funding
    host.iobroker2 Clear all objects and states...
    clean 142 objects...
    clean 102 states...
    host.iobroker2 done.
    host.iobroker2 Processed 0/143 objects
    143 objects restored.
    host.iobroker2 Processed 0/102 states
    102 states restored.
    Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
    added 80 packages in 7s
    20 packages are looking for funding
    Reinstalling adapter "backitup" from "iobroker.backitup@2.6.16"
    added 94 packages in 10s
    33 packages are looking for funding
    System successfully restored!
    iobroker_config@iobroker2:/opt/iobroker/backups$ sudo iobroker start all
    The adapter "discovery.0" was started.
    iobroker_config@iobroker2:/opt/iobroker/backups$ sudo iobroker upload all
    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    Update "system.adapter.admin.0"
    upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    Update "system.adapter.backitup.0"
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    HomoranH crunchipC 2 Antworten Letzte Antwort
    • F Fox1985
      Habe ich ausgeführt
      Password:
      cifs-utils:
        Version table:
      library: loaded
      Installed gcc-c++
      Done.
      Autostart enabled!
      iobroker
      cifs-utils:
        Version table:
      host.iobroker2 OK.
      clean 102 states...
      HomoranH Offline
      HomoranH Offline
      #42
      Habe ich ausgeführt
      bitte lesen und befolgen!
      hier Teil 2
      Was hast du jetzt schon alles gemacht?
      • F Fox1985
        Habe ich ausgeführt
        Password:
        cifs-utils:
          Version table:
        library: loaded
        Installed gcc-c++
        Done.
        Autostart enabled!
        iobroker
        cifs-utils:
          Version table:
        host.iobroker2 OK.
        clean 102 states...
        crunchipC Offline
        crunchipC Offline
        #43
        sudo iobroker start
        iobroker Befehle werden genauso wenig mit sudo eingeleitet
          sudo iobroker start
          HomoranH Offline
          HomoranH Offline
          #44
          @crunchip sagte in Wiederherstellung nach Neuinstallation Backitup Probleme:
          sudo iobroker start
          zum zweiten!
          @thomas-braun sagte in Wiederherstellung nach Neuinstallation Backitup Probleme:
          Und dann wird der Befehl iobroker NIE, NIE, NIE mit sudo direkt kombiniert.
          F 1 Antwort Letzte Antwort
            sudo iobroker start
            zum zweiten!
            Fox1985
            #45
            Am besten werde ich heute Abend den iobroker komplett neu in proxmox installieren und dann
            entsprechend euren Ratschlägen versuchen wiederherzustellen.
            oder was meint ihr?
            crunchipC D3ltoroxpD 2 Antworten Letzte Antwort
            • F Fox1985
              oder was meint ihr?
              crunchipC Offline
              crunchipC Offline
              #46
              https://www.iobroker.net/#de/documentation/install/proxmox.md
              • F Fox1985
                oder was meint ihr?
                D3ltoroxpD Offline
                D3ltoroxpD Offline
                D3ltoroxp
                #47
                @fox1985 Also ich handhabe es so. Ich mach nur noch Backups in Proxmox. Automatische und bevor ich irgendwas update. Mit dem Backitup hat es bei mir ja damals nicht geklappt und viele Fehler verursacht.
                Daher fahr ich nur noch mit Proxmox Backups und bin damit sehr sehr zufrieden. Es geht was nicht oder man hat etwas verbogt, einfach schnell das letzte Backup einspielen und alles geht wieder.
                Mit Backitup hab ichs nicht hinbekommen, hab aber dann auch nicht mehr probiert.
                • D3ltoroxpD D3ltoroxp
                  #48
                  @d3ltoroxp
                  Nützt dir aber nix, wenn der gebackuppte Kram komplett windschief ist.
