  4. gelöst: Backitup Adapter verweigert Rücksicherung nach crash
    5.6k
73 Beiträge 7 Kommentatoren 7.4k Aufrufe 6 Beobachtet
  • R Rosi8818
    @thomas-braun said in Backitup Adapter verweigert Rücksicherung nach iob crash:
    Ich sehe das an den vier Einträgen in der mount-Tabelle:
    ach so, habe jetzt alle mal entfernt bis auf den letzten
    //192.168.254.4/Ralf/Sicherung/iobroker/SmartHomePi on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=Admin,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.254.4,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
    cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
    cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
    cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
    cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
    /dev/sda2 on / type ext4 (rw,noatime,stripe=8191)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=1806144k,nr_inodes=84128,mode=755)
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    proc on /proc type proc (rw,relatime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=394200k,mode=700,uid=1000,gid=1000)
    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
    @rosi8818 sagte in Backitup Adapter verweigert Rücksicherung nach iob crash:
    warum nicht alle?
    • R Rosi8818
      Wie entfernt?
      Die entfernt man nur per umount. Und die solltest du alle umounten.
      R 1 Antwort Letzte Antwort
        Wie entfernt?
        Rosi8818
        Wie entfernt?
        soory, entfernt, damit miente ich den unmount Befehl den du genannt hattest. nehme jetzt auch den letzten raus und versuche das mal. Melde mich gleich hier
        • R Rosi8818
          Wie entfernt?
          @rosi8818
          Wenn die Freigaben alle umounted sind, dann bitte nochmal
          ls -la /opt/iobroker/backups
          Im Idealfall ist das dann leer.
            Rosi8818
            habe folgendes gemacht
            jetzt hat er nur noch diesen hier (der ist schon älter)
            alle einzelnen Adapter sind weg, den alten will ich nicht ausführen, zu viele Schritte zurück.
            HomoranH simatecS 2 Antworten Letzte Antwort
            • R Rosi8818
              passt, die anderen waren auf dem gemounteten NAS
              Dann jetzt das machen, was @simatec geschrieben hat und das aktuellste backup vom NAS mit filezilla auf den iobroker kopieren
              • R Rosi8818
                simatecS Offline
                simatecS Offline
                simatec
                schrieb am zuletzt editiert von simatec
                @rosi8818 Dann jetzt vom NAS in den Ordner /opt/iobroker/backups per SFTP Tool die Backups ablegen
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                  @homoran sagte in Backitup Adapter verweigert Rücksicherung nach iob crash:
                  Falsch, da SIND die immer noch. :-D
                    Rosi8818
                    so habe jetzt eine Datei vom NAS genommen (influxdb-die mir zusätzlich sorgen macht) und diese lokal kopiert.
                    die leif durch ohne Fehlermeldung, muss noch mal genauer schauen.
                    was mir noch auffällt, ich habe mit winscp die sicherungsdatei kopiert und die hat andere Berechtigungen
                    grüne Pfeil die manuell kopierte
                      Rosi8818
                      stimmt 😆
                      bin schon ganz fertig...voll mit Panik
                      • simatecS simatec
                        Rosi8818
                        @simatec said in Backitup Adapter verweigert Rücksicherung nach iob crash:
                        habe ich, sind jetzt wieder sichtbar, muss jetzt noch prüfen ob die auch funktionieren...
                        • R Rosi8818
                          das ist ja dein Problem
                          Auf dem NAS gehören die Daten root
                          R Thomas BraunT 2 Antworten Letzte Antwort
                            Rosi8818
                            @homoran said in Backitup Adapter verweigert Rücksicherung nach iob crash:
                            also brauche ich da einen user iobroker?
                              Aber wohl auch nur eines (was aber auch im eigentlichen Sinne gar kein Problem ist).
                              Viel mehr machen mir die vier mounts da Sorgen. Mir ist noch nicht so ganz klar wo die alle herkommen. Aus der fstab? Vom Adapter? Von allem gleichzeitig?
                              • R Rosi8818
                                Ja, ich würde da einen user dafür anlegen. Schraubst du da immer 'mit alles und 'charf' als root rum?
                                  Rosi8818
                                  ich vermute durch meine Panik, als nichts mehr lief habe ich versucht zu retten mit restore u.ä. ich schätze dabei habe ich das Problem irgendwie verursacht. Ich schaue mal meine Logs heute Nacht durch was ich alles getrieben habe.
                                  Wie gesagt bis vor ein paar Tagen lief das mit dem NAS bestens. Daher der Verdacht das Problem sitzt vor dem PC...
                                    Rosi8818
                                    nei eigentlich nicht, warum ich den da genutzt habe ist mir unklar. Ich nutze immer eigene User für irgendwelche Dinge um sie klar zuzuordnen.
                                      Rosi8818
                                      @Thomas-Braun , @Homoran , @simatec , ich danke euch für Eure Gedult.
                                      Ich
                                      • setze den Thread auf gelöst
                                      • schaue dann jetzt erst mal ob alles funktioniert was ich zurückgesetzt habe
                                      • ändere dann den Benutzer des NAS
                                      • und gehe heute Nacht mal die Logfiles durch, das lässt mir keine Ruhe
                                      • R Rosi8818
                                        @rosi8818
                                        Ja, das ist ja auch Sinn und Zweck von usern.
                                        Läuft das denn jetzt mit dem lokalen Backup?
                                        Dann denk dran, diese Dateien auch wieder aus /opt/iobroker/backups zu löschen, bevor du zum automatischen Backup via Backitup-Adapter zurückgehst.
                                          Rosi8818
                                          Admin geändert auf anderen User mit weniger rechten, lokale und NAS Backup läuft und vorher auch das Restore (was ich so sehen konnte). Alle Backups sind komplett woanders gesichert (verschoben) so das jetzt alles wieder frei ist...
                                          ich freu mich wie bolle und brauche jetzt erst mal ein Kaffee mit Schuss ;)
