  4. Script Konvertierung HSV <==> Hex
    5.2k
javascript
4 Beiträge 4 Kommentatoren 1.2k Aufrufe 5 Beobachtet
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    schrieb am zuletzt editiert von Dutchman
    Hi all,
    Auf anfrage und. z.b. praktisch fuer Yahka, hier ein script zum konvertieren von HEX nach HSV und umgekehrt :
    // ######### DutchmanNL #########
    // ###### HSV Color to HEX ######
    // ############ V1.0 ############
    // Add the state containing HEX values here :
    const zigbeeDevice = [
        'zigbee.0.group_2.color',     // Bank
        'zigbee.0.group_3.color'     // Vensterbank
    // ## Don't change anything from here ##
    // Prepare variables
    const mySubscription = {}, debounceTimer = {};
    // Create Folder structure
    extendObjectAsync(`0_userdata.0.HEXtoHSL` , {
        "type": "folder",
        "common": {
        "name": 'Convert HEX to HSL color',
            "role": "",
            "icon": "",
        "native": {},
    // Read all array objects, create new state in javascript instance and subscribe on changes
    for (const device in zigbeeDevice) {
        // Define folder structure in userdata directory
        const statePrepare = zigbeeDevice[device].split('.');
    	const deviceName = `0_userdata.0.HEXtoHSL.${statePrepare[0]}_${statePrepare[1]}_${statePrepare[2]}`
        // Create Device Structure
        extendObjectAsync(deviceName , {
            "type": "device",
            "common": {
            "name": statePrepare[2],
                "role": "",
                "icon": "",
            "native": {},
        // States to cover Hue and Sat values
    	createState(`${deviceName}.hue` , {
    		'name': `Hue of ${statePrepare[2]}`,
    		'role': 'level.color.hue',
    		'type': 'number'
    	// @ts-ignore
    	createState(`${deviceName}.sat`, {
    		'name': `Sat of ${statePrepare[2]}`,
    		'role': 'level.color.sat',
    		'type': 'number'
    	// Subscribe on state changes for HUE and Saturation
    	// @ts-ignore
    	mySubscription[`${deviceName}.hue`] = on(
            [`${deviceName}.hue`,
            `${deviceName}.sat`
            ], (data) => {
            // DebounceTimer
            // Reset timer (if running) and start new one for next watchdog interval
    		if (debounceTimer[zigbeeDevice[device]]) {
    			clearTimeout(debounceTimer[zigbeeDevice[device]]);
    			debounceTimer[zigbeeDevice[device]] = null;
    		debounceTimer[zigbeeDevice[device]] = setTimeout(() => {
                if (!data.state.ack){
                    const h = getState(`${deviceName}.hue`).val / 360;
                    const s = getState(`${deviceName}.sat`).val / 100;
                    const v = 1;
                    const colorRGB = hsvTOrgb(h,s,v)
                    const colorHEX = rgbTOhex(colorRGB)
                    console.log(`HSV value : ${h}, ${s}, ${v}`);
                    setState(`${zigbeeDevice[device]}`, colorHEX);
                    // setState(`${deviceName}.hue`, h * 360, true)
                    // setState(`${deviceName}.sat`, h * 100, true)
            }, (500));
        // Subscribe on state changes for HEX surce
            ], (data) => {
                console.log(`Device change detected : ${JSON.stringify(data.id)} value : ${data.state.val} | ack : ${data.state.ack}`);
            // DebounceTimer
                    const colorHEX = data.state.val;
                    const colorRGB = hexTOrgb(colorHEX)
                    const colorHSV = rgbTOhsv(colorRGB)
                    const h = roundDigit(colorHSV[0]);
                    console.log(colorHSV);
                    const s = roundDigit(colorHSV[1]);
                    setState(`${deviceName}.sat`, s, true);
                    setState(`${deviceName}.hue`, h, true);
            }, (500));
    ////////////////Funktionen////////////////
     * Coonvert HSV to RGB
     * @param {number} h - HUE value
     * @param {number} s - Saturation value
     * @param {number} v - Brightness value
    function hsvTOrgb(h, s, v) {
                var r, g, b, i, f, p, q, t;
                i = Math.floor(h * 6);
                f = h * 6 - i;
                p = v * (1 - s);
                q = v * (1 - f * s);
                t = v * (1 - (1 - f) * s);
                switch (i % 6) {
                    case 0: r = v, g = t, b = p; break;
                    case 1: r = q, g = v, b = p; break;
                    case 2: r = p, g = v, b = t; break;
                    case 3: r = p, g = q, b = v; break;
                    case 4: r = t, g = p, b = v; break;
                    case 5: r = v, g = p, b = q; break;
                console.log(`${r} ${g} ${b}`)
                r=Math.round(255 * r);
                g=Math.round(255 * g);
                b=Math.round(255 * b);
                return [r,g,b];
    function rgbTOhsv(rgb) {
    	let rdif;
    	let gdif;
    	let bdif;
    	let h;
    	let s;
    	const r = rgb[0] / 255;
    	const g = rgb[1] / 255;
    	const b = rgb[2] / 255;
    	const v = Math.max(r, g, b);
    	const diff = v - Math.min(r, g, b);
    	const diffc = function (c) {
    		return (v - c) / 6 / diff + 1 / 2;
    	if (diff === 0) {
    		h = 0;
    		s = 0;
    	} else {
    		s = diff / v;
    		rdif = diffc(r);
    		gdif = diffc(g);
    		bdif = diffc(b);
    		if (r === v) {
    			h = bdif - gdif;
    		} else if (g === v) {
    			h = (1 / 3) + rdif - bdif;
    		} else if (b === v) {
    			h = (2 / 3) + gdif - rdif;
    		if (h < 0) {
    			h += 1;
    		} else if (h > 1) {
    			h -= 1;
    	return [
    		h * 360,
    		s * 100,
    		v * 100
    function rgbTOhex (args) {
    	const integer = ((Math.round(args[0]) & 0xFF) << 16)
    		+ ((Math.round(args[1]) & 0xFF) << 8)
    		+ (Math.round(args[2]) & 0xFF);
    	const string = integer.toString(16).toUpperCase();
    	return '000000'.substring(string.length) + string;
    //In HEX konvertieren
    function toHex(number) {
        if (number < 0) number = 0xFFFFFFFF + number + 1;
        var n = number.toString(16).toUpperCase();
        if (n.length == 1) {
            n = '0' + n;
        return n;
    // Function to convert HEX to RGB
    function hexTOrgb(args) {
        const match = args.toString(16).match(/[a-f0-9]{6}|[a-f0-9]{3}/i);
        if (!match) {
            return [0, 0, 0];
        let colorString = match[0];
        if (match[0].length === 3) {
            colorString = colorString.split('').map(char => {
                return char + char;
            }).join('');
        const integer = parseInt(colorString, 16);
        const r = (integer >> 16) & 0xFF;
        const g = (integer >> 8) & 0xFF;
        const b = integer & 0xFF;
        return [r, g, b];
    // Function to convert RGB to HSL
    function rgbTOhsl (rgb) {
    	const min = Math.min(r, g, b);
    	const max = Math.max(r, g, b);
    	const delta = max - min;
    	let h;
    	let s;
    	if (max === min) {
    		h = 0;
    	} else if (r === max) {
    		h = (g - b) / delta;
    	} else if (g === max) {
    		h = 2 + (b - r) / delta;
    	} else if (b === max) {
    		h = 4 + (r - g) / delta;
    	h = Math.min(h * 60, 360);
    	if (h < 0) {
    		h += 360;
    	const l = (min + max) / 2;
    	if (max === min) {
    		s = 0;
    	} else if (l <= 0.5) {
    		s = delta / (max + min);
    	} else {
    		s = delta / (2 - max - min);
    	return [h, s * 100, l * 100];
    // Funtion to round digits properly
    function roundDigit(num){
        // return Math.round((num + Number.EPSILON) * 100) / 100
        return Math.round((num + Number.EPSILON));
    paul53P S 2 Antworten Letzte Antwort
    • DutchmanD Dutchman
      Hi all,
          "type": "folder",
          "common": {
              "role": "",
              "icon": "",
          "native": {},
              "type": "device",
              "common": {
                  "role": "",
                  "icon": "",
              "native": {},
      		'type': 'number'
      	// @ts-ignore
      		'type': 'number'
      	// @ts-ignore
              `${deviceName}.sat`
              ], (data) => {
              // DebounceTimer
                      const v = 1;
              }, (500));
              ], (data) => {
              // DebounceTimer
              }, (500));
                  f = h * 6 - i;
                  p = v * (1 - s);
                  switch (i % 6) {
                  return [r,g,b];
      	let rdif;
      	let gdif;
      	let bdif;
      	let h;
      	let s;
      	if (diff === 0) {
      		h = 0;
      		s = 0;
      	} else {
      		s = diff / v;
      		rdif = diffc(r);
      		gdif = diffc(g);
      		bdif = diffc(b);
      		if (r === v) {
      			h = bdif - gdif;
      		if (h < 0) {
      			h += 1;
      		} else if (h > 1) {
      			h -= 1;
      	return [
      		h * 360,
      		s * 100,
      		v * 100
              n = '0' + n;
          return n;
          if (!match) {
              return [0, 0, 0];
                  return char + char;
              }).join('');
          return [r, g, b];
      	let h;
      	let s;
      	if (max === min) {
      		h = 0;
      	if (h < 0) {
      		h += 360;
      	if (max === min) {
      		s = 0;
      	} else {
      @dutchman
      Markiere bitte das Thema gemäß den Forum Rules als [Vorlage].
        Hi all,
            "type": "folder",
            "common": {
                "role": "",
                "icon": "",
            "native": {},
                "type": "device",
                "common": {
                    "role": "",
                    "icon": "",
                "native": {},
        		'type': 'number'
        	// @ts-ignore
        		'type': 'number'
        	// @ts-ignore
                `${deviceName}.sat`
                ], (data) => {
                // DebounceTimer
                        const v = 1;
                }, (500));
                ], (data) => {
                // DebounceTimer
                }, (500));
                    f = h * 6 - i;
                    p = v * (1 - s);
                    switch (i % 6) {
                    return [r,g,b];
        	let rdif;
        	let gdif;
        	let bdif;
        	let h;
        	let s;
        	if (diff === 0) {
        		h = 0;
        		s = 0;
        	} else {
        		s = diff / v;
        		rdif = diffc(r);
        		gdif = diffc(g);
        		bdif = diffc(b);
        		if (r === v) {
        			h = bdif - gdif;
        		if (h < 0) {
        			h += 1;
        		} else if (h > 1) {
        			h -= 1;
        	return [
        		h * 360,
        		s * 100,
        		v * 100
                n = '0' + n;
            return n;
            if (!match) {
                return [0, 0, 0];
                    return char + char;
                }).join('');
            return [r, g, b];
        	let h;
        	let s;
        	if (max === min) {
        		h = 0;
        	if (h < 0) {
        		h += 360;
        	if (max === min) {
        		s = 0;
        	} else {
        stan23
        Statt dieser Schleife for-in
            // pick device from array using index
            myDevice = zigbeeDevice[device];
        kann man auch for-of benutzen, sofern man den Index nicht braucht.
        for (const device of zigbeeDevice) {
            // no need to pick from array, because 'of' returns the element and not the index
            myDevice = device;
        Hab ich aus JavaScript-Tutorials gelernt ;)
        Viele Grüße
        Marco
        • T Online
          T Online
          tklein
          hi,
          sorry stehe momentan a bissl auf dem Schlauch: wie kann ich das Script nutzen/konfigurieren?
          Werden Datenpunkte angelegt?
          Grüße
          Thomas
