  5. Json korrekt parsen
Json korrekt parsen
blockly
12 Beiträge 4 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • J Offline
    Joker971
    Hi allerseits,
    ich bekomme folgende Payload von meinem Mqtt und muss hier ein paar Werte rausholen. Das klappt soweit auch aber bei einem Wert scheitere ich. Hier mal zunächst die Payload:
      "end_device_ids": {
        "device_id": "bodensensor-hinten",
        "application_ids": {
          "application_id": "garden-soil-sensors"
        "dev_eui": "",
        "join_eui": "",
        "dev_addr": ""
      "correlation_ids": [
        "as:up:01FMJMEY3F4R8BRK933ZF831B8",
        "gs:conn:01FMHQKYR8ACAACXVMR5ETGBX0",
        "gs:up:host:01FMHQKYRRTNB1Y256R5BBFZ5B",
        "gs:uplink:01FMJMEXW5QENYW0X7ESBWKT7E",
        "ns:uplink:01FMJMEXW6V0WTERVH73FZ316Q",
        "rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FMJMEXW64H4ZYQGZ6JYFSBK3",
        "rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FMJMEY3ETSZPN33KJ591WZ1K"
      "received_at": "2021-11-15T20:26:20.655807658Z",
      "uplink_message": {
        "session_key_id": "AX0kon3s3ubZFDDLFdgJEw==",
        "f_port": 2,
        "f_cnt": 9,
        "frm_payload": "DS4AAAAACLQAABA=",
        "decoded_payload": {
          "Bat": "3.374 V",
          "TempC_DS18B20": "0.00 °C",
          "conduct_SOIL": "0 uS/cm",
          "temp_SOIL": "22.28 °C",
          "water_SOIL": "0.00 %"
        "rx_metadata": [
            "gateway_ids": {
              "gateway_id": "myindoorgatewayhub",
              "eui": ""
            "time": "2021-11-15T20:26:20.344300985Z",
            "timestamp": 177918228,
            "rssi": -63,
            "channel_rssi": -63,
            "snr": 10.75,
            "location": {
              "latitude": 51.7100722182447,
              "longitude": 7.923237383365632,
              "altitude": 5,
              "source": "SOURCE_REGISTRY"
            "uplink_token": "CiAKHgoSbXlpbmRvb3JnYXRld2F5aHViEghYoMv//oBEFBCUoutUGgwI7ITLjAYQuPfgyAEgoOyC5pbwBioMCOyEy4wGELm7lqQB"
        "settings": {
          "data_rate": {
            "lora": {
              "bandwidth": 125000,
              "spreading_factor": 7
          "coding_rate": "4/5",
          "frequency": "867900000",
        "received_at": "2021-11-15T20:26:20.422462557Z",
        "consumed_airtime": "0.061696s",
        "locations": {
          "user": {
            "latitude": 51.71014867049504,
            "longitude": 7.923138141632081,
        "version_ids": {
          "brand_id": "dragino",
          "model_id": "lse01",
          "hardware_version": "_unknown_hw_version_",
          "firmware_version": "1.3",
          "band_id": "EU_863_870"
        "network_ids": {
          "net_id": "000013",
          "tenant_id": "ttn",
          "cluster_id": "ttn-eu1"
    Ich bekomme die Werte indem ich die Payload mit dem "JSON nach Objekt" Baustein in ein Objekt umwandle und mit dem "ATTRIB" Baustein und der Pfadangabe bekomme ich die Werte bis auf einen!
    Folgende Pfade funktionieren super und ich kriege ein Ergebniss:
    uplink_message.decoded_payload.Bat
    uplink_message.decoded_payload.water_SOIL
    uplink_message.decoded_payload.conduct_SOIL
    uplink_message.decoded_payload.temp_SOIL
    Ich möchte aber noch den Wert rssi haben der in rx_metadata steckt. Vergeblich.
    Dieser Pfad funktioniert nicht:
    uplink_message.rx_metadata[0].rssi
    Das sollte er aber oder übersehe ich hier was ?
    Wenn ich nur uplink_message.rx_metadata verwende bekomme ich alles angezeigt was da drin steckt, darunter auch rssi aber ich kann nicht explizit darauf zugreifen.
    Jemand eine Idee ?
    HomoranH F OliverIOO 3 Antworten Letzte Antwort
    • J Joker971
      Hi allerseits,
        "end_device_ids": {
          "dev_eui": "",
          "join_eui": "",
          "dev_addr": ""
        "uplink_message": {
          "f_port": 2,
          "f_cnt": 9,
            "Bat": "3.374 V",
          "rx_metadata": [
              "gateway_ids": {
                "eui": ""
              "rssi": -63,
              "snr": 10.75,
              "location": {
                "altitude": 5,
          "settings": {
            "data_rate": {
              "lora": {
          "locations": {
            "user": {
          "version_ids": {
          "network_ids": {
            "net_id": "000013",
            "tenant_id": "ttn",
      Jemand eine Idee ?
      @joker971
      Was hast du bereits gemacht?
      Blockly oder js?
      Wenn ich mich jetzt in den Ebenen nicht verrant habe müüsste es sein:
      Attribut von: uplink_message.rx_metadata.0.rssi
        @joker971
        Blockly oder js?
        @homoran sagte in Json korrekt parsen:
        @joker971
        Blockly oder js?
        @joker971 sagte in Json korrekt parsen:
        keine Array-Klammern sondern Punkte zur Ebenentrennung
        J F 2 Antworten Letzte Antwort
        • J Joker971
          Hi allerseits,
            "end_device_ids": {
              "dev_eui": "",
              "join_eui": "",
              "dev_addr": ""
            "uplink_message": {
              "f_port": 2,
              "f_cnt": 9,
                "Bat": "3.374 V",
              "rx_metadata": [
                  "gateway_ids": {
                    "eui": ""
                  "rssi": -63,
                  "snr": 10.75,
                  "location": {
                    "altitude": 5,
              "settings": {
                "data_rate": {
                  "lora": {
              "locations": {
                "user": {
              "version_ids": {
              "network_ids": {
                "net_id": "000013",
                "tenant_id": "ttn",
          Jemand eine Idee ?
          F Online
          F Online
          fastfoot
          versuche uplink_message.rx_metadata.0.rssi. getAttr() funktioniert hier nicht wie erwartet
          iobroker läuft unter Docker auf Windows (WSL2)
            @joker971
            Blockly oder js?
            Joker971
            :man-facepalming: :man-facepalming: :man-facepalming:
            Alles hab ich versucht, nur nicht die Klammern mal weg zu lassen 😇
            Daaaaanke für den Denkanstoss, das funktioniert jetzt 👍
            • J Joker971
              Hi allerseits,
                "end_device_ids": {
                  "dev_eui": "",
                  "join_eui": "",
                  "dev_addr": ""
                "uplink_message": {
                  "f_port": 2,
                  "f_cnt": 9,
                    "Bat": "3.374 V",
                  "rx_metadata": [
                      "gateway_ids": {
                        "eui": ""
                      "rssi": -63,
                      "snr": 10.75,
                      "location": {
                        "altitude": 5,
                  "settings": {
                    "data_rate": {
                      "lora": {
                  "locations": {
                    "user": {
                  "version_ids": {
                  "network_ids": {
                    "net_id": "000013",
                    "tenant_id": "ttn",
              Jemand eine Idee ?
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @joker971
              so müsste korrekt sein
              bei meinem test kam -63 raus
              Meine Adapter und Widgets
              Links im Profil
                @joker971
                Blockly oder js?
                F Online
                F Online
                fastfoot
                ja, in JS würde man es aber mit Klammer machen (müssen!)
                • F fastfoot
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @fastfoot
                  ich habe es in JS getestet und eckige array-klammern verwendet
                  am besten du schreibst deine version mal hin
                  Links im Profil
                  F 1 Antwort Letzte Antwort
                  • OliverIOO OliverIO
                    @fastfoot
                    F Online
                    F Online
                    fastfoot
                    @oliverio sagte in Json korrekt parsen:
                    @fastfoot
                    ich gehe davo aus dass er es in Blockly probiert hat, welches getAttr() verwendet und dort klappt das mit Klammer eben nicht :-)
                    J HomoranH 2 Antworten Letzte Antwort
                    • F fastfoot
                      @fastfoot
                      Joker971
                      Es geht jetzt, ohne Klammern !
                      Danke euch 😄
                      • F fastfoot
                        @fastfoot
                        @fastfoot sagte in Json korrekt parsen:
                        ich auch, seine Formulierung:
                        waren ziemlich eindeutig.
                        und in Blockly muss man .0. sattt [0] nehmen, außer man geht mehrstufig vor indem man erst das Array zelegt und dann darin weitermacht
                        J 1 Antwort Letzte Antwort
                          Joker971
                          Ja natürlich Blockly, das ist doch auch das Blockly-Forum 🤓
