  4. Admin nach JavaScript-Update nicht mehr erreichbar
    6.3k
27 Beiträge 4 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • YunkieY Yunkie
    iobroker@iobroker-pi:~ $ iobroker update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
    Adapter    "bring"         : 1.7.8    , installed 1.7.8
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "discovery"     : 2.7.3    , installed 2.7.3
    Adapter    "ebus"          : 2.3.2    , installed 2.3.2
    Adapter    "flot"          : 1.10.7   , installed 1.10.7
    Adapter    "history"       : 1.9.13   , installed 1.9.13
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.13   , installed 5.2.13
    Controller "js-controller" : 3.3.18   , installed 3.3.18
    Adapter    "knx"           : 1.0.45   , installed 1.0.45
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
    Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
    Adapter    "pushover"      : 2.0.5    , installed 2.0.5
    Adapter    "ring"          : 1.2.8    , installed 1.2.6 [Updateable]
    Adapter    "samsung"       : 0.2.9    , installed 0.2.9
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "smartmeter"    : 3.2.1    , installed 3.2.1
    Adapter    "snmp"          : 0.5.0    , installed 0.5.0
    Adapter    "socketio"      : 3.1.4    , installed 3.1.5
    Adapter    "sql"           : 1.15.7   , installed 1.15.7
    Adapter    "vis"           : 1.4.5    , installed 1.4.5
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
    Adapter    "vw-connect"    : 0.0.45   , installed 0.0.45
    Adapter    "web"           : 3.4.9    , installed 3.4.9
    @yunkie
    iobroker upgrade
    YunkieY 1 Antwort Letzte Antwort
      @yunkie
      iobroker upgrade
      YunkieY Offline
      YunkieY Offline
      Yunkie
      liefert leider das:
      iobroker@iobroker-pi:~ $ iobroker upgrade
      Would you like to upgrade ring from @1.2.6 to @1.2.8 now? [(y)es, (n)o]: y
      Update ring from @1.2.6 to @1.2.8
      NPM version: 6.14.15
      npm install iobroker.ring@1.2.8 --loglevel error --prefix "/opt/iobroker" (System call)
      gyp ERR! UNCAUGHT EXCEPTION
      gyp ERR! stack /opt/iobroker/node_modules/fstream/lib/dir-reader.js:192
      gyp ERR! stack     ].forEach(function!(evi {
      gyp ERR! stack                       ^
      gyp ERR! stack
      gyp ERR! stack SyntaxError: Unexpected token '!'
      gyp ERR! stack     at wrapSafe (internal/modules/cjs/loader.js:915:16)
      gyp ERR! stack     at Module._compile (internal/modules/cjs/loader.js:963:27)
      gyp ERR! stack     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      gyp ERR! stack     at Module.load (internal/modules/cjs/loader.js:863:32)
      gyp ERR! stack     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      gyp ERR! stack     at Module.require (internal/modules/cjs/loader.js:887:19)
      gyp ERR! stack     at require (internal/modules/cjs/helpers.js:74:18)
      gyp ERR! stack     at Object.<anonymous> (/opt/iobroker/node_modules/fstream/fstream.js:11:11)
      gyp ERR! stack     at Module._compile (internal/modules/cjs/loader.js:999:30)
      gyp ERR! System Linux 5.10.63-v7l+
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
      gyp ERR! node -v v12.22.7
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! This is a bug in `node-gyp`.
      gyp ERR! Try to update node-gyp and file an Issue if it does not help:
      gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
      npm ERR! code ELIFECYCLE
      npm ERR! errno 7
      npm ERR! utf-8-validate@5.0.7 install: `node-gyp-build`
      npm ERR! Exit status 7
      npm ERR!
      npm ERR! Failed at the utf-8-validate@5.0.7 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2021-11-16T21_07_26_795Z-debug.log
      host.iobroker-pi Cannot install iobroker.ring@1.2.8: 7
      • YunkieY Yunkie
        liefert leider das:
        gyp ERR! stack                       ^
        gyp ERR! stack
        npm ERR! errno 7
        npm ERR!
        @yunkie
        cd /opt/iobroker
        npm list utf-8-validate
          @yunkie
          cd /opt/iobroker
          YunkieY Offline
          YunkieY Offline
          Yunkie
          @thomas-braun said in Admin nach JavaScript-Update nicht mehr erreichbar:
          liefert dies:
          iobroker@iobroker-pi:/opt/iobroker $ npm list utf-8-validate
          iobroker.inst@3.0.0 /opt/iobroker
          └─┬ UNMET DEPENDENCY iobroker.ring@1.2.6
            └── UNMET DEPENDENCY utf-8-validate@5.0.5
          npm ERR! missing: iobroker.ring@1.2.6, required by iobroker.inst@3.0.0
          npm ERR! missing: utf-8-validate@5.0.5, required by iobroker.ring@1.2.6
          • YunkieY Yunkie
            liefert dies:
            @yunkie
            Fällt mir nichts mehr zu ein.
              @yunkie
              YunkieY Offline
              YunkieY Offline
              Yunkie
              Verdammt... Schade! Trotzdem vielen Dank!
              Ich werde mal versuchen den Adapter komplett neu zu installieren.
              • YunkieY Yunkie
                YunkieY Offline
                YunkieY Offline
                Yunkie
                Eine komplette Neuinstallation des Adapters war erfolgreich
                Wollte nur das Ergebnis mitteilen ;-)
