  3. Off Topic
  4. Proxmox
  5. Proxmox Update 6.x --> 7.x
    2.2k
    4.1k
Geplant Angeheftet Gesperrt Verschoben Proxmox
104 Beiträge 14 Kommentatoren 17.7k Aufrufe 12 Beobachtet
  • lobomauL lobomau
    Edit2: ups... grad neugestartet und es wird 7.x angezeigt:
    Achso... der error kommt weil da irgendwie eine enterprise quelle drin. Hmm. Komisch.
    proxmox-ve: 7.1-1 (running kernel: 5.13.19-1-pve)
    pve-manager: 7.1-7 (running version: 7.1-7/df5740ad)
    pve-kernel-5.13: 7.1-4
    pve-kernel-helper: 7.1-4
    pve-kernel-5.4: 6.4-7
    pve-kernel-5.13.19-1-pve: 5.13.19-3
    pve-kernel-5.4.143-1-pve: 5.4.143-1
    pve-kernel-4.15: 5.4-6
    pve-kernel-4.15.18-18-pve: 4.15.18-44
    pve-kernel-4.15.17-1-pve: 4.15.17-9
    ceph-fuse: 14.2.21-1
    @jleg @dslraser ja, ich war nach Anleitung vorgegangen. Nun habe ich aber mal 'Y' gedrückt anstatt 'N' wie default:
    Configuration file '/etc/apt/sources.list.d/pve-enterprise.list'
     ==> Modified (by you or by a script) since installation.
     ==> Package distributor has shipped an updated version.
       What would you like to do about it ?  Your options are:
        Y or I  : install the package maintainer's version
        N or O  : keep your currently-installed version
          D     : show the differences between the versions
          Z     : start a shell to examine the situation
     The default action is to keep your current version.
    *** pve-enterprise.list (Y/I/N/O/D/Z) [default=N] ?
    Aber ob es nun geklappt hat?
    Configuration file '/etc/vzdump.conf'
    *** vzdump.conf (Y/I/N/O/D/Z) [default=N] ? Y
    Installing new version of config file /etc/vzdump.conf ...
    Created symlink /etc/systemd/system/multi-user.target.wants/pvescheduler.service → /lib/systemd/system/pvescheduler.service.
    found static machine-id bug from Proxmox VE ISO installer <= 5.4, regenerating machine-id
    be4611b4b1d2406c9d98ede2cc7503df
    new machine-id generated, a reboot is recommended
    Backing up lvm.conf before setting pve-manager specific settings..
    '/etc/lvm/lvm.conf' -> '/etc/lvm/lvm.conf.bak'
    Setting 'global_filter' in /etc/lvm/lvm.conf to prevent zvols from being scanned:
    global_filter=["a|.*|"] => global_filter=["r|/dev/zd.*|"]
    Processing triggers for man-db (2.9.4-2) ...
    Processing triggers for dbus (1.12.20-2) ...
    Processing triggers for libgdk-pixbuf-2.0-0:amd64 (2.42.2+dfsg-1) ...
    Processing triggers for mailcap (3.69) ...
    Processing triggers for pve-ha-manager (3.3-1) ...
    Processing triggers for initramfs-tools (0.140) ...
    update-initramfs: Generating /boot/initrd.img-5.13.19-1-pve
    Running hook script 'zz-proxmox-boot'..
    Re-executing '/etc/kernel/postinst.d/zz-proxmox-boot' in new private mount namespace..
    No /etc/kernel/proxmox-boot-uuids found, skipping ESP sync.
    Processing triggers for libc-bin (2.31-13+deb11u2) ...
    W: Operation was interrupted before it could finish
    root@proxmox:~#
    Sieht nicht so aus. Geht nicht mal mehr apt update:
    root@proxmox:~# apt update
    Hit:1 http://download.proxmox.com/debian/pve bullseye InRelease
    Hit:2 http://security.debian.org bullseye-security InRelease
    Hit:3 http://download.proxmox.com/debian/pve buster InRelease
    Hit:4 http://ftp.de.debian.org/debian bullseye InRelease
    Hit:5 http://ftp.de.debian.org/debian bullseye-updates InRelease
    Err:6 https://enterprise.proxmox.com/debian/pve bullseye InRelease
      401  Unauthorized [IP: 212.224.123.70 443]
    Reading package lists... Done
    E: Failed to fetch https://enterprise.proxmox.com/debian/pve/dists/bullseye/InRelease  401  Unauthorized [IP: 212.224.123.70 443]
    E: The repository 'https://enterprise.proxmox.com/debian/pve bullseye InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    root@proxmox:~#
    Edit.:
    sources.list habe ich so wie aus https://pve.proxmox.com/wiki/Package_Repositories#sysadmin_no_subscription_repo übernommen.
    Das habe ich auch gemacht:
    wget https://enterprise.proxmox.com/debian/proxmox-release-bullseye.gpg -O /etc/apt/trusted.gpg.d/proxmox-release-bullseye.gpg
    Aus dem Folgenden werde ich nicht schlau. Was für ein cli tool?? "proxmox-release-bullseye.gpg" ist vorhanden. Darin ist wohl dieser Code um checken ob es echt ist oder wie soll man das verstehen?:
    *Verify the checksum afterwards with the sha512sum CLI tool:
    sha512sum /etc/apt/trusted.gpg.d/proxmox-release-bullseye.gpg
    7fb03ec8a1675723d2853b84aa4fdb49a46a3bb72b9951361488bfd19b29aab0a789a4f8c7406e71a69aabbc727c936d3549731c4659ffa1a08f44db8fdcebfa /etc/apt/trusted.gpg.d/proxmox-release-bullseye.gpg*
    Meister MopperM Offline
    Meister Mopper
    #101
    @lobomau
    Du musst die enterprise.list editieren.
    sudo nano /etc/apt/sources.list.d/pve-enterprise.list
    und dort ein hashtag vor die Zeile setzen:
    #deb https://enterprise.proxmox.com/debian/pve buster pve-enterprise
    Proxmox und HA - dank KI/AI endlich "blocklyfrei"
    lobomauL 1 Antwort Letzte Antwort
      @lobomau
      lobomauL Offline
      lobomauL Offline
      lobomau
      schrieb am zuletzt editiert von lobomau
      #102
      @meister-mopper ah, danke. Ich dachte mir schon dass es irgendwo noch so eine Liste geben muss 👍
      root@proxmox:~# nano /etc/apt/sources.list.d/pve-enterprise.list
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Get:3 http://download.proxmox.com/debian/pve bullseye InRelease [3,053 B]
      Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:5 http://download.proxmox.com/debian/pve buster InRelease
      Fetched 3,053 B in 2s (1,629 B/s)
      Building dependency tree... Done
      All packages are up to date.
      root@proxmox:~#
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        #103
        Hallo
        @crunchip @Meister-Mopper
        Ich möchte demnächst von 7.x auf 8.x upgraden.
        Allerdings steh ich schon wieder an (und Tante G will mir nichts sagen).
        root@proxmox:~# pve7to8
        -bash: pve7to8: command not found
        warum findet der das nicht?
        Läuft der Befehl erst mit 7.4?
        ° Fixer ---> iob fix
        • NegaleinN Negalein
          Hallo
          crunchipC Abwesend
          crunchipC Abwesend
          #104
          @negalein sagte in Proxmox Update 6.x --> 7.x:
          ja 7.4 wird benötigt
          https://pve.proxmox.com/wiki/Upgrade_from_7_to_8
