  4. Broker->BackItUp FTP->Synology
    6.3k
53 Beiträge 4 Kommentatoren 5.8k Aufrufe 3 Beobachtet
    Berlon
    Nachdem der Brocker endlich läuft will ich mich um die Datensicherheit kümmern.
    Habe nun aber Probleme mit dem BackItUp Einstellungen.
    Alle duchprobiert, keine schreibt Daten auf die Syno.
    Am erfolgreichsten erscheint mir der FTP da ich mit den gleichen Zugangsdaten mit Filezilla (Windows) auf das benötigte Verzeichnis
    zugreifen kann.
    Mit den gleichen Zugangsdaten bekomme ich aber mit dem RPI keine Daten auf die Syno.
    Hier das Log beim Backup:
    Started iobroker ...
    [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"Copy","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspberrypi 9522 states saved
    [DEBUG] [iobroker] - host.raspberrypi 11459 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_31-17_14_02_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
    [ERROR] [ftp] - [IGNORED] Error: Maximum number of tries exceeded. Please contact the site manager.
    [DEBUG] [ftp] start with {"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21","deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"Copy","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de","time":"31. Oktober 2021 um 17:14 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"Copy","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de","time":"31. Oktober 2021 um 17:14 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [historyJSON] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"Copy","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de","time":"31. Oktober 2021 um 17:14 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [EXIT] 0
    Wo liegt mein Fehler??
    • B Berlon
      zugreifen kann.
      [EXIT] 0
      @berlon
      Mach das über NFS oder SMB. Nicht über FTP.
      B 1 Antwort Letzte Antwort
      • B Berlon
        zugreifen kann.
        [EXIT] 0
        @berlon sagte in Broker->BackItUp FTP->Synology:
        zugreifen kann.
        ??? seltsame Logik
        nimm CIFS >= v3
        aber die CIFS-Utils installiern nicht vergessen
          @berlon
          Berlon
          schrieb am zuletzt editiert von Berlon
          cifs ist installiert
          Hier mal cifs.
          [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"}
          [DEBUG] [mount] - noserverino option: false
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
          mount error: cifs filesystem not supported by the system
          mount error(19): No such device
          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
          oder NFS.
          [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"}
          [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.6.10:/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
          [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.6.10:/Backup/RPI_IOBroker/IOBroker
          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount 192.168.6.10:/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
          • B Berlon
            Hier mal cifs.
            oder NFS.
            Da fehlen die cifs-utils, würde ich mal sagen.
            apt policy cifs-utils
              @thomas-braun sagte in Broker->BackItUp FTP->Synology:
              er behauptet:
                er behauptet:
                Berlon
                pi@raspberrypi:~ $ apt policy cifs-utils
                cifs-utils:
                  Installiert:           2:6.8-2
                  Installationskandidat: 2:6.8-2
                  Versionstabelle:
                 *** 2:6.8-2 500
                        100 /var/lib/dpkg/status
                • B Berlon
                  cifs-utils:
                    Versionstabelle:
                   *** 2:6.8-2 500
                  danach auch neu gestartet?
                  @berlon dann bitte die Freigabe auf der Syno zeigen
                    Berlon
                    Hoffe, das ist die richtige
                    • B Berlon
                      @berlon das wäre die nächste Frage gewesen ;-)
                      Nein, ich meine die Freigabe (= gemeinsame Ordner)
                        Berlon
                        • B Berlon
                          @berlon enäää
                          Das sind ja schon wieder die Berechtigungen.
                          ich meine die Daten zur Freigabe
                            @berlon enäää
                            Berlon
                            Die hier??
                            • B Berlon
                              Die hier??
                              @berlon Fast!
                              jetzt noch Backup anklicken und Berabeiten anzeigen
                              Und wenn du da schon in der Systemsteuerung drin bist, bitte auch überprüfen ob unter Dateidienste auch Samba aktiviert ist
                                @berlon Fast!
                                Berlon
                                Dein Wunsch ist mir Befehl
                                • B Berlon
                                  @berlon Gut!
                                  und darin befinden sich die Strukturen, die du im Adapter angegeben hast?
                                    @berlon Gut!
                                    Berlon
                                    Ich denke mal....
                                    Müssen die zusätzlichen Ordner (IOBroker und CCU3) schon vorhanden sein oder legt BackItUp diese an??
                                    • B Berlon
                                      Ich denke mal....
                                      Ich denke mal....
                                      ich habe deine Screenshots gelöscht, da waren private Daten zu sehen
                                      Bitte nochmal (sauber zugeschnitten) einstellen
                                        Ich denke mal....
                                        Berlon
                                        nochmal zugeschnitten.
                                        • B Berlon
                                          deswegen ja meine Frage.
                                          Die müssen angelegt sein.
                                          Aber dass der Adapter sagt, dass das System kein CIFS unterstützt, du aber die cifs-utils auf dem Pi installiert hast, könnte das System auch die Syno sein.
                                          Ist hier Samba aktiviert?
