  4. Sonntag und wieder Grafana..
    6.3k
18 Beiträge 3 Kommentatoren 1.8k Aufrufe 3 Beobachtet
    pskiel
    ja, jeden Sonntag, darf ich an den Rechner und versuche es wieder, so nun kommt diese Meldung: s.o.
    Ich kann leider die Installation auch nicht neu starten, ich komme nur bis zu diesem Punkt!
    pi@iobroker:/ $ sudo service influxdb start
    Job for influxdb.service failed because the control process exited with error code.
    See "systemctl status influxdb.service" and "journalctl -xe" for details.
    pi@iobroker:/ $ systemctl status influxdb.service
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Sun 2021-10-31 14:47:42 CET; 10min ago
         Docs: https://docs.influxdata.com/influxdb/
      Process: 14528 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=1/FAILURE)
    Oct 31 14:47:42 iobroker systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
    Oct 31 14:47:42 iobroker systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
    Oct 31 14:47:42 iobroker systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    Oct 31 14:47:42 iobroker systemd[1]: influxdb.service: Start request repeated too quickly.
    Oct 31 14:47:42 iobroker systemd[1]: influxdb.service: Failed with result 'exit-code'.
    Oct 31 14:47:42 iobroker systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    pi@iobroker:/ $
    pi@iobroker:/ $ journalctl -xe
    -- The unit influxdb.service has entered the 'failed' state with result 'exit-code'.
    Oct 31 14:47:41 iobroker systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    -- Subject: A start job for unit influxdb.service has failed
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- A start job for unit influxdb.service has finished with a failure.
    -- The job identifier is 3906 and the job result is failed.
    -- Subject: Automatic restarting of a unit has been scheduled
    -- Automatic restarting of the unit influxdb.service has been scheduled, as the result for
    -- the configured Restart= setting for the unit.
    -- Subject: A stop job for unit influxdb.service has finished
    -- A stop job for unit influxdb.service has finished.
    -- The job identifier is 3963 and the job result is done.
    -- Subject: Unit failed
    -- The job identifier is 3963 and the job result is failed.
    lines 2359-2398/2398 (END)
    • P pskiel
      pi@iobroker:/ $
      @pskiel
      Was ist konkret dein 'Sonntags-Problem'?
      P 1 Antwort Letzte Antwort
        @pskiel
        pskiel
        @thomas-braun said in Sonntag und wieder Grafana..:
        @pskiel
        die Installation von Grafana klappt nicht, ich kann den Befehl sudo service influxdb start nicht ausführen...es kommt dann die Fehlermeldung:
        • P pskiel
          @pskiel
          @pskiel
          apt policy grafana*
            @pskiel
            apt policy grafana*
            pskiel
            apt policy grafana*
            pi@iobroker:/ $ apt policy grafana*
            grafana-zabbix:
              Installed: (none)
              Candidate: 2.5.1-1
              Version table:
                 2.5.1-1 500
            grafana:
              Installed: (none)
              Candidate: (none)
              Version table:
            grafana-rpi:
              Installed: 7.4.3
              Candidate: 7.4.3
              Version table:
             *** 7.4.3 100
                    100 /var/lib/dpkg/status
            • P pskiel
              apt policy grafana*
              grafana-zabbix:
                Installed: (none)
                Candidate: 2.5.1-1
                Version table:
                   2.5.1-1 500
              grafana:
                Installed: (none)
                Candidate: (none)
                Version table:
              grafana-rpi:
                Installed: 7.4.3
                Candidate: 7.4.3
                Version table:
               *** 7.4.3 100
              @pskiel Irgendwie krumm installiert.
                pskiel
                ja, das glaube ich auch, kann man alles rückgängig machen, bzw. welche Order, Dateien sollte man löschen?
                • P pskiel
                  @pskiel
                  apt remove grafana-rpi
                  Und dann das grafana-Repository anlegen und grafana daraus installieren.
                    @pskiel
                    pskiel
                    ok, das ging schon mal...
                    pi@iobroker:/ $ sudo apt remove grafana-rpi
                    Reading package lists... Done
                    Building dependency tree
                    The following packages will be REMOVED:
                      grafana-rpi
                    0 upgraded, 0 newly installed, 1 to remove and 10 not upgraded.
                    After this operation, 159 MB disk space will be freed.
                    Do you want to continue? [Y/n] y
                    (Reading database ... 52950 files and directories currently installed.)
                    Removing grafana-rpi (7.4.3) ...
                    • P pskiel
                        grafana-rpi
                      @pskiel
                      10 not upgraded
                      Zunächst das System durchpatchen!
                      sudo apt update
                      sudo apt dist-upgrade
                      sudo reboot
                        @pskiel
                        10 not upgraded
                        sudo apt update
                        sudo reboot
                        pskiel
                        sudo neustart
                        ok, alles gemacht, dann versuche ich es mal wieder :-)
                        • P pskiel
                            grafana-rpi
                          @pskiel
                          Dann nach dieser Anleitung (ab 'Install Grafana'):
                          https://grafana.com/tutorials/install-grafana-on-raspberry-pi/
                          P 3 Antworten Letzte Antwort
                            @pskiel
                            pskiel
                              @pskiel
                              pskiel
                              @pskiel
                              Du bist Toll!!!!
                              Bin ich den schon drin...... diese Frage stellte einmal Boris B. bei AOL!
                              LG
                              Peter
                                @pskiel
                                pskiel
                                @pskiel
                                leider ich noch mal...
                                es scheint die influxdb.0 läuft nicht, oder das PW ist falsch, kann ich das PW ändern, bzw. neu vergeben?
                                • P pskiel
                                  @pskiel
                                  @pskiel
                                  Keine Ahnung, setze weder grafana noch influx ein.
                                    @pskiel
                                    pskiel
                                    @pskiel
                                    ok
                                    • P pskiel
                                      @pskiel
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @pskiel sagte in Sonntag und wieder Grafana..:
                                      https://blog.lbdg.me/change-influxdb-password-user/
