  5. Blockly für Sonoff D1 Dimmer
    2.8k
    4.9k
    4.1k
25 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • P plato
    @jan1 Jetzt hat er innerhalb weniger Sekunden mehrmals geschaltet
    12:07:43.020 MQT: verbunden
    12:07:43.023 MQT: tele/tasmota_2AA601/LWT = Online (beibehalten)
    12:07:43.026 MQT: cmnd/tasmota_2AA601/POWER =
    12:07:43.039 MQT: tele/tasmota_2AA601/INFO1 = {"Info1":{"Module":"Sonoff D1","Version":"10.0.0(tasmota)","FallbackTopic":"cmnd/Dimmer-Flur_fb/","GroupTopic":"cmnd/tasmotas/"}}
    12:07:43.045 MQT: tele/tasmota_2AA601/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-2AA601-1537","IPAddress":"10.10.5.25"}}
    12:07:43.049 MQT: tele/tasmota_2AA601/INFO3 = {"Info3":{"RestartReason":"Software/System restart"}}
    12:07:43.052 MQT: stat/tasmota_2AA601/RESULT = {"POWER":"ON"}
    12:07:43.054 MQT: stat/tasmota_2AA601/POWER = ON
    12:07:43.065 RUL: SYSTEM#BOOT performs "backlog Power1 1; Dimmer 8"
    12:07:43.072 MQT: stat/tasmota_2AA601/RESULT = {"POWER":"ON"}
    12:07:43.073 MQT: stat/tasmota_2AA601/POWER = ON
    12:07:43.276 MQT: stat/tasmota_2AA601/RESULT = {"POWER":"ON","Dimmer":8}
    12:07:44.471 QPC: Reset
    12:07:47.421 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:07:47","Uptime":"0T00:00:11","UptimeSec":11,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":84,"MqttCount":1,"POWER":"ON","Dimmer":8,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:12:47.423 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:12:47","Uptime":"0T00:05:11","UptimeSec":311,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER":"ON","Dimmer":8,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:17:47.422 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:17:47","Uptime":"0T00:10:11","UptimeSec":611,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER":"ON","Dimmer":8,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-42,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:22:47.428 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:22:47","Uptime":"0T00:15:11","UptimeSec":911,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER":"ON","Dimmer":8,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:27:47.417 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:27:47","Uptime":"0T00:20:11","UptimeSec":1211,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER":"ON","Dimmer":8,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:32:47.422 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:32:47","Uptime":"0T00:25:11","UptimeSec":1511,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER":"ON","Dimmer":8,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:35:24.343 MQT: stat/tasmota_2AA601/RESULT = {"POWER":"ON","Dimmer":100}
    12:35:52.826 MQT: stat/tasmota_2AA601/RESULT = {"POWER":"ON","Dimmer":40}
    12:37:47.415 MQT: tele/tasmota_2AA601/STATE = {"Time":"2021-10-30T12:37:47","Uptime":"0T00:30:11","UptimeSec":1811,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER":"ON","Dimmer":40,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Boos","BSSId":"DC:39:6F:C1:D7:55","Channel":11,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:05"}}
    12:38:21.105 MQT: stat/tasmota_2AA601/RESULT = {"POWER":"ON","Dimmer":100}
    Jan1
    @plato
    Hm, könnest mal ein Issues auf Github bei Tasmota öffnen. Vielleicht weiß einer was, oder ist speziell beim Sonoff ein Bug.
    P 1 Antwort Letzte Antwort
    • J Jan1
      @plato
      plato
      @jan1 kann ich machen. Wie könnte denn trotzdem so ein Blockly aussehen ?
      J 1 Antwort Letzte Antwort
      • P plato
        Jan1
        @plato
        Kein Plan, da ich die Ursache nicht kenne und man dann drum rum basteln muss, wobei ich eben lieber nach der Ursache forschen würde, weil sinnvoller ;)
        Alternativ kannst auch mal im CerationX Form fragen, da dort viel mit Tasmota gemacht wird und einige Spezis unterwegs sind.
        • J Jan1
          @ralla66
          Da brauchst keine Rule, sondern ne Setoption, wobei ich da auch erst m,al suchen müsste, welche das ist :)
          Ich hab nur ein Tuya Dimmer mit Tasmota laufen und der geistert nicht rum.
          plato
          @jan1 sagte in Blockly für Sonoff D1 Dimmer:
          Moin, ich habe eine Issue auf Github eröffnet.
          Was hast du denn für einen Tuya Dimmer im Einsatz einen AP oder UP ?
          • P plato
            Jan1
            @plato
            Den hier
