  4. Fehler bei SQL 1.4.2
20 Beiträge 2 Kommentatoren 2.1k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    wenn ich einen Adapter update (habe die neue Version des REGA-Adapters installiert)
    kachelt regelmäßig der SQL-Adapter ab:
    host.zotac	2017-02-11 09:09:29.342	error	instance system.adapter.sql.0 terminated with code 6 (uncaught exception)
    sql.0	2017-02-11 09:09:29.115	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
    sql.0	2017-02-11 09:09:29.114	error	at Immediate._tickCallback (internal/process/next_tick.js:98:9)
    sql.0	2017-02-11 09:09:29.114	error	at _combinedTickCallback (internal/process/next_tick.js:71:11)
    sql.0	2017-02-11 09:09:29.114	error	at listOnTimeoutNT (timers.js:255:26)
    sql.0	2017-02-11 09:09:29.114	error	at Timer.listOnTimeout (timers.js:207:5)
    sql.0	2017-02-11 09:09:29.114	error	at tryOnTimeout (timers.js:237:5)
    sql.0	2017-02-11 09:09:29.114	error	at ontimeout (timers.js:365:14)
    sql.0	2017-02-11 09:09:29.114	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:746:30)
    sql.0	2017-02-11 09:09:29.114	error	at Adapter.emit (events.js:191:7)
    sql.0	2017-02-11 09:09:29.114	error	at emitTwo (events.js:106:13)
    sql.0	2017-02-11 09:09:29.114	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49)
    sql.0	2017-02-11 09:09:29.114	error	TypeError: Cannot read property 'sql.0' of undefined
    sql.0	2017-02-11 09:09:29.113	error	uncaught exception: Cannot read property 'sql.0' of undefined
    sql.0	2017-02-11 09:09:29.111	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
    sql.0	2017-02-11 09:09:29.110	error	at Immediate._tickCallback (internal/process/next_tick.js:98:9)
    sql.0	2017-02-11 09:09:29.110	error	at _combinedTickCallback (internal/process/next_tick.js:71:11)
    sql.0	2017-02-11 09:09:29.110	error	at listOnTimeoutNT (timers.js:255:26)
    sql.0	2017-02-11 09:09:29.110	error	at Timer.listOnTimeout (timers.js:207:5)
    sql.0	2017-02-11 09:09:29.110	error	at tryOnTimeout (timers.js:237:5)
    sql.0	2017-02-11 09:09:29.110	error	at ontimeout (timers.js:365:14)
    sql.0	2017-02-11 09:09:29.110	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:746:30)
    sql.0	2017-02-11 09:09:29.110	error	at Adapter.emit (events.js:191:7)
    sql.0	2017-02-11 09:09:29.110	error	at emitTwo (events.js:106:13)
    sql.0	2017-02-11 09:09:29.110	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49)
    sql.0	2017-02-11 09:09:29.110	error	TypeError: Cannot read property 'sql.0' of undefined
    sql.0	2017-02-11 09:09:29.103	error	uncaught exception: Cannot read property 'sql.0' of undefined
    sql.0	2017-02-11 09:09:29.100	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
    Nach einem manuellen Neustart des SQL-Adapters ist wieder alles gut.
    Ist das in der 1.4.3 behoben? Leider zeigt er mir das Update nur in grau an, obwohl alles andere bei mir aktuell ist?
    PS: Echte MySQL-DB auf gesonderten Server.
    MfG
    Sissi
    • apollon77A Offline
      Für die neueste sql-version muss auch dein admin-Adapter aktuell sein. Dann geht das "graue" weg.
      Und du hast nen kleinen Bug gefunden :-) Nach dem Admin-Update SQL neu von Github installieren und testen bitte. Danke
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        @apollon77:
        Und du hast nen kleinen Bug gefunden :-) Nach dem Admin-Update SQL neu von Github installieren und testen bitte. Danke `
        ich habe 1.16.11 vom Admin. Was neueres wird mir nicht angezeigt.
        MfG
        Sissi
          Und der js-controller muss >=0.12.0 sein. Was hast Du?
          Was kommt denn als Mouseover wenn DU über das graue Icon gehst?
          • sissiwupS Offline
            sissiwupS Offline
            sissiwup
            @apollon77:
            Was kommt denn als Mouseover wenn DU über das graue Icon gehst? `
            Hallo, der JS-Controller ist 0.15.3
            PS: Den SQL-Adapter habe ich manuell aktualisert.
            Der Fehler ist aber immer noch da. Nachdem ich den REGA-Adapter neu gestartet habe, stürzt der SQL-Adapter ab.
            sql.0	2017-02-17 09:40:29.986	error	TypeError: Cannot read property 'sql.0' of undefined
            sql.0	2017-02-17 09:40:29.986	error	uncaught exception: Cannot read property 'sql.0' of undefined
            sql.0	2017-02-17 09:40:29.978	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
            sql.0	2017-02-17 09:40:29.973	error	at Timer.listOnTimeout (timers.js:207:5)
            sql.0	2017-02-17 09:40:29.973	error	at tryOnTimeout (timers.js:237:5)
            sql.0	2017-02-17 09:40:29.973	error	at ontimeout (timers.js:365:14)
            sql.0	2017-02-17 09:40:29.973	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:746:30)
            sql.0	2017-02-17 09:40:29.973	error	at Adapter.emit (events.js:191:7)
            sql.0	2017-02-17 09:40:29.973	error	at emitTwo (events.js:106:13)
            sql.0	2017-02-17 09:40:29.973	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49)
            sql.0	2017-02-17 09:40:29.973	error	TypeError: Cannot read property 'sql.0' of undefined
            sql.0	2017-02-17 09:40:29.965	error	uncaught exception: Cannot read property 'sql.0' of undefined
            hm-rega.0	2017-02-17 09:40:29.938	info	added/updated 89 programs
            hm-rega.0	2017-02-17 09:40:29.707	info	got 89 programs
            hm-rega.0	2017-02-17 09:40:27.975	info	added/updated rooms to enum.rooms
            hm-rega.0	2017-02-17 09:40:27.697	info	added/updated functions to enum.functions
            hm-rega.0	2017-02-17 09:40:27.243	info	added/updated 26 favorites to enum.favorites
            hm-rega.0	2017-02-17 09:40:26.747	info	time difference local-ccu 1s
            hm-rega.0	2017-02-17 09:40:26.669	info	ReGaHSS 192.168.1.11 up
            hm-rega.0	2017-02-17 09:40:25.534	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
            hm-rega.0	2017-02-17 09:40:25.476	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
            host.zotac	2017-02-17 09:40:24.156	info	instance system.adapter.hm-rega.0 started with pid 28888
            host.zotac	2017-02-17 09:40:21.742	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
            hm-rega.0	2017-02-17 09:40:21.636	info	terminating
            host.zotac	2017-02-17 09:40:21.582	info	stopInstance system.adapter.hm-rega.0 killing pid 6778
            host.zotac	2017-02-17 09:40:21.580	info	stopInstance system.adapter.hm-rega.0
            host.zotac	2017-02-17 09:40:21.572	info	object change system.adapter.hm-rega.0
            MfG
            Sissi
              Hast Du normal aktualisiert oder vom github aktualisiert? Musst von Githuvb holen weil erstmal nur da der Fehler gefixt ist (zum testen)
              • sissiwupS Offline
                sissiwupS Offline
                sissiwup
                @apollon77:
                Hast Du normal aktualisiert oder vom github aktualisiert? Musst von Githuvb holen weil erstmal nur da der Fehler gefixt ist (zum testen) `
                Habe ich jetzt:
                SQL 1.4.4
                bei admin gibt es aber:
                $ ./iobroker url "https://github.com/ioBroker/ioBroker.admin/tarball/master" admin
                install https://github.com/ioBroker/ioBroker.admin/tarball/master
                npm install https://github.com/ioBroker/ioBroker.admin/tarball/master --production --prefix "/opt/iobroker" (System call)
                npm WARN
                 enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/buildmail/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/commist/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/concat-stream/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/duplexify/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/follow-redirects/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/glob-stream/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/imap/package.json'
                ERROR: host.zotac Cannot install https://github.com/ioBroker/ioBroker.admin/tarball/master: 1
                MfG
                Sissi
                  Admin brauchst DU an sich nicht vom Github. Der Bugfix von mir war in sql drin.
                  • sissiwupS Offline
                    sissiwupS Offline
                    sissiwup
                    @apollon77:
                    Admin brauchst DU an sich nicht vom Github. Der Bugfix von mir war in sql drin. `
                    Ok,
                    nach Neustart Rega kommt jetzt:
                    hm-rega.0	2017-02-17 14:31:30.565	info	hm-rega.0 added/updated 66 variables
                    zotac	2017-02-17 14:31:28.887	info	host.zotac Restart adapter system.adapter.sql.0 because enabled
                    zotac	2017-02-17 14:31:28.886	error	host.zotac instance system.adapter.sql.0 terminated with code 0 (OK)
                    hm-rega.0	2017-02-17 14:31:28.824	info	hm-rega.0 got 66 variables
                    sql.0	2017-02-17 14:31:27.924	warn	sql.0 Exception: TypeError: Cannot read property 'sql.0' of undefined
                    sql.0	2017-02-17 14:31:27.924	error	sql.0 TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49) at emitTwo (events.js:106:13) at Adapter.emit (eve
                    sql.0	2017-02-17 14:31:27.924	error	sql.0 uncaught exception: Cannot read property 'sql.0' of undefined
                    sql.0	2017-02-17 14:31:27.922	warn	sql.0 Exception: TypeError: Cannot read property 'sql.0' of undefined
                    sql.0	2017-02-17 14:31:27.922	error	sql.0 TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49) at emitTwo (events.js:106:13) at Adapter.emit (eve
                    sql.0	2017-02-17 14:31:27.920	error	sql.0 uncaught exception: Cannot read property 'sql.0' of undefined
                    hm-rega.0	2017-02-17 14:31:27.874	info	hm-rega.0 deleted 0 programs
                    hm-rega.0	2017-02-17 14:31:27.874	info	hm-rega.0 added/updated 89 programs
                    hm-rega.0	2017-02-17 14:31:27.553	info	hm-rega.0 got 89 programs
                    MfG
                    Sissi
                      Ich kapiere es nicht …
                      Schau bitte mal auf der Platte in /opt/iobroker/node_modules/iobroker.sql/main.js in Zeile 42. Diese sollte mit dem Github Update so aussehen:
                              (obj.common.history && obj.common.history[adapter.namespace]) ||
                      Wenn nein ändere Sie mal so, dann hast Du irgendwie doch das upfdate von Github nicht bekommen (was komisch wäre). Aber erstmal egal :-)
                      • sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        da steht:
                        38 var adapter = utils.adapter('sql');
                             39 adapter.on('objectChange', function (id, obj) {
                             40     if (obj && obj.common && (
                             41             // todo remove history sometime (2016.08) - Do not forget object selector in io-package.json
                             42         (obj.common.history && obj.common.history[adapter.namespace]) ||
                             43         (obj.common.custom  && obj.common.custom[adapter.namespace])) &&
                             44         (obj.common.custom[adapter.namespace].enabled)
                             45     ) {
                             46         if (!sqlDPs[id] && !subscribeAll) {
                        MfG
                        Sissi
                          jetzt kapier ichs nimmer … versuch nochmal nicht das beim letzten update nicht neu gestartet war und deswegen noch das alte lief ... ;-)
                          ANsonsten kann ichs echt nicht mehr verstehen weil jetzt auch die Spaltennummer nicht mehr 49 sein kann ...
                          • sissiwupS Offline
                            sissiwupS Offline
                            sissiwup
                            Neustart hat er heute Nacht automatisch gemacht.
                            Restart REGA-Adapter:
                            hm-rega.0	2017-02-18 10:57:05.154	info	added/updated 66 variables
                            hm-rega.0	2017-02-18 10:57:04.640	info	got 66 variables
                            zotac	2017-02-18 10:57:04.637	info	host.zotac Restart adapter system.adapter.sql.0 because enabled
                            zotac	2017-02-18 10:57:04.636	error	host.zotac instance system.adapter.sql.0 terminated with code 6 (uncaught exception)
                            sql.0	2017-02-18 10:57:03.650	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.650	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.650	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.649	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.649	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.648	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.648	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.647	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.647	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.647	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.646	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.646	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.646	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.644	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.644	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.644	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.643	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.643	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.643	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.642	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.344	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                            sql.0	2017-02-18 10:57:03.318	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                            sql.0	2017-02-18 10:57:03.316	error	uncaught exception: Cannot read property 'sql.0' of undefined
                            hm-rega.0	2017-02-18 10:57:03.278	info	deleted 0 programs
                            hm-rega.0	2017-02-18 10:57:03.278	info	added/updated 89 programs
                            hm-rega.0	2017-02-18 10:57:02.944	info	got 89 programs
                            hm-rega.0	2017-02-18 10:57:00.781	info	added/updated rooms to enum.room
                            MfG
                            Sissi
                              Jetzt ists auch ne andere Zeilennummer :-)
                              Kannst Du mir einen gefallen tun (sonst muss ich weiter raten): Überleg mal welcher der hm-Datenpunkte die DU loggst der ist der am längsten loggt. Un bei den gehst DU in der "Objekte"-Ansicht auf den Stift rechts am Ende. Dort auf "Raw-Ansicht (Experten only)" und schick mir mal das JSON was Du da siehst. Dann sollte das simpel sein final zu fixen weil ich das Problem jetzt im Blick hab
                              • sissiwupS Offline
                                sissiwupS Offline
                                sissiwup
                                  "common": {
                                    "name": "HZ-01:4.ACTUAL_TEMPERATURE",
                                    "type": "number",
                                    "unit": "°C",
                                    "role": "value.temperature",
                                    "def": 0,
                                    "min": -10,
                                    "max": 56,
                                    "read": true,
                                    "write": false,
                                    "custom": {
                                      "history.0": {
                                        "enabled": true,
                                        "changesOnly": true,
                                        "minLength": 480,
                                        "maxLength": 960,
                                        "retention": 0,
                                        "debounce": 10000
                                      "sql.0": {
                                        "enabled": true,
                                        "changesOnly": false,
                                        "debounce": 1000,
                                        "retention": 63072000
                                  "native": {
                                    "CONTROL": "HEATING_CONTROL.TEMPERATURE",
                                    "ID": "ACTUAL_TEMPERATURE",
                                    "TYPE": "FLOAT",
                                    "UNIT": "�C",
                                    "DEFAULT": 0,
                                    "FLAGS": 1,
                                    "MAX": 56,
                                    "MIN": -10,
                                    "OPERATIONS": 5,
                                    "TAB_ORDER": 5
                                  "acl": {
                                    "object": 1638,
                                    "owner": "system.user.admin",
                                    "state": 1638
                                  "_id": "hm-rpc.0.MEQ0008905.4.ACTUAL_TEMPERATURE",
                                  "type": "state"
                                MfG
                                Sissi
                                  Der kanns nicht sein … aber naja ... versuch mal neu mit der github version ... und nach install (ist dann die 1.4.5) neu startenvom sql Adapter und dann versuch nochmal
                                  • sissiwupS Offline
                                    sissiwupS Offline
                                    sissiwup
                                    welcher der wirklich älteste ist, weiss ich nicht, habe einen recht alten ausgewählt.
                                    Mit neuer Version 1.4.5:
                                    sql.0	2017-02-19 15:36:24.010	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:24.010	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:24.010	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:24.009	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:24.009	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:24.009	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.694	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.694	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.693	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.570	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.569	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.569	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.569	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.568	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.568	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.568	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.562	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.562	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.562	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.561	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.561	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.561	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.560	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.306	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                    sql.0	2017-02-19 15:36:23.306	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                    sql.0	2017-02-19 15:36:23.305	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                    hm-rega.0	2017-02-19 15:36:23.278	info	deleted 0 programs
                                    hm-rega.0	2017-02-19 15:36:23.278	info	added/updated 89 programs
                                    hm-rega.0	2017-02-19 15:36:22.923	info	got 89 programs
                                    hm-rega.0	2017-02-19 15:36:21.147	info	added/updated rooms to enum.rooms
                                    hm-rega.0	2017-02-19 15:36:20.872	info	added/updated functions to enum.functions
                                    hm-rega.0	2017-02-19 15:36:20.385	info	added/updated 26 favorites to enum.favorites
                                    hm-rega.0	2017-02-19 15:36:20.077	info	time difference local-ccu 0s
                                    hm-rega.0	2017-02-19 15:36:20.004	info	ReGaHSS 192.168.1.11 up
                                    hm-rega.0	2017-02-19 15:36:18.934	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                    hm-rega.0	2017-02-19 15:36:18.917	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
                                    host.zotac	2017-02-19 15:36:17.848	info	instance system.adapter.hm-rega.0 started with pid 397
                                    host.zotac	2017-02-19 15:36:15.410	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                                    hm-rega.0	2017-02-19 15:36:15.343	info	terminating
                                    host.zotac	2017-02-19 15:36:15.287	info	stopInstance system.adapter.hm-rega.0 killing pid 19130
                                    host.zotac	2017-02-19 15:36:15.284	info	object change system.adapter.hm-rega.0
                                    host.zotac	2017-02-19 15:34:42.429	info	Update repository "default" under "conf/sources-dist.json"
                                    iobroker	2017-02-19 15:34:42.114	info	exit 0
                                    MfG
                                    Sissi
                                      Also irgendwie hat Install von Github nicht geklappt oder restart hat gefehlt.Zeilennnummer des Fehlers passen wieder nicht zur neuen Version :-)
                                      Ab Zeile 40 muss es so aussehen: https://github.com/ioBroker/ioBroker.sq … ain.js#L40
                                      • sissiwupS Offline
                                        sissiwupS Offline
                                        sissiwup
                                        der sql-Adapter ist immer neu gestartet. Der Rest natürlich nicht.
                                        Aber nach Neustart heute Nacht kommt folgendes:
                                        admin.0	2017-02-20 11:53:06.174	info	received all states
                                        admin.0	2017-02-20 11:53:05.196	info	Subscribe on all states again
                                        admin.0	2017-02-20 11:52:33.385	info	Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                                        hm-rega.0	2017-02-20 11:52:30.021	info	got state values
                                        hm-rega.0	2017-02-20 11:52:25.223	info	request state values
                                        hm-rega.0	2017-02-20 11:52:25.221	info	deleted 0 variables
                                        hm-rega.0	2017-02-20 11:52:25.220	info	added/updated 66 variables
                                        hm-rega.0	2017-02-20 11:52:24.707	info	got 66 variables
                                        hm-rega.0	2017-02-20 11:52:23.758	info	deleted 0 programs
                                        hm-rega.0	2017-02-20 11:52:23.757	info	added/updated 89 programs
                                        hm-rega.0	2017-02-20 11:52:23.430	info	got 89 programs
                                        hm-rega.0	2017-02-20 11:52:22.050	info	added/updated rooms to enum.rooms
                                        hm-rega.0	2017-02-20 11:52:21.348	info	added/updated functions to enum.functions
                                        hm-rega.0	2017-02-20 11:52:20.867	info	added/updated 26 favorites to enum.favorites
                                        hm-rega.0	2017-02-20 11:52:20.517	info	time difference local-ccu 1s
                                        hm-rega.0	2017-02-20 11:52:20.439	info	ReGaHSS 192.168.1.11 up
                                        hm-rega.0	2017-02-20 11:52:19.394	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                        hm-rega.0	2017-02-20 11:52:19.377	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
                                        host.zotac	2017-02-20 11:52:18.155	info	instance system.adapter.hm-rega.0 started with pid 31795
                                        host.zotac	2017-02-20 11:52:15.724	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                                        hm-rega.0	2017-02-20 11:52:15.652	info	terminating
                                        host.zotac	2017-02-20 11:52:15.607	info	stopInstance system.adapter.hm-rega.0 killing pid 21557
                                        host.zotac	2017-02-20 11:52:15.605	info	stopInstance system.adapter.hm-rega.0
                                        host.zotac	2017-02-20 11:52:15.598	info	object change system.adapter.hm-rega.0
                                        host.zotac	2017-02-20 11:46:03.026	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                                        MfG
                                        Sissi
                                          Ja das sieht doch dann nach "kein Fehler mehr "aus, oder ?! :-)))
