  4. Ich weis nicht mehr weiter!
    6.5k
37 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    pskiel
    Moin Moin,
    nach dem Update bekomme ich den IOBroker nicht mehr zum laufen!
    Auch eine neue Installation bringt mir diesen Fehler! Kann mir einer einen Tipp Geben?
    Raspberry 4 ist am Start. und ext. Festplatte, läuft aber auch auf der SD Karte nicht.
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:58,
                     from ../src/main.cpp:3:
    /home/pi/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:58,
                     from ../src/./serialport.h:13,
                     from ../src/serialport.cpp:1:
    /home/pi/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    MOD-Edit: Code in code-tags gesetzt!
    • P pskiel
      Moin Moin,
      @pskiel sagte in Ich weis nicht mehr weiter!:
      Geduld!
      da ist kein Fehler. Da läuft die Installation noch im Hintergrund weiter.
      Das dauert schon ein paar Minuten, dann erscheint auch wieder was auf dem Schirm
      P 1 Antwort Letzte Antwort
        Geduld!
        pskiel
        @homoran ok , herzlichen Dank, nun scheint es durch zu sein, aber ich komme nun nicht auf die htts://192.xxx.xxx.xxx:8081
        die Instance lebt
        pi@raspberrypi:/opt/iobroker $ iobroker start
        pi@raspberrypi:/opt/iobroker $ node -v
        v12.22.5
        pi@raspberrypi:/opt/iobroker $ npm -v
        6.14.14
        pi@raspberrypi:/opt/iobroker $ iobroker list instances
        + instance is alive
        • P pskiel
          die Instance lebt
          v12.22.5
          6.14.14
          + instance is alive
          @pskiel
          Bitte Konsolentext in CodeTags einbetten.
          iobroker list adapters
          iobroker status
            @pskiel
            iobroker status
            pskiel
            Entschuldigung, ich lerne noch :-)
            v12.22.5
            6.14.14
            + instance is alive
            • P pskiel
              v12.22.5
              6.14.14
              + instance is alive
              @pskiel
              Da läuft nix.
              Bitte noch
              iobroker status
              nachreichen.
              P 2 Antworten Letzte Antwort
                @pskiel
                Da läuft nix.
                Bitte noch
                iobroker status
                nachreichen.
                pskiel
                schrieb am zuletzt editiert von pskiel
                @thomas-braun said in Ich weis nicht mehr weiter!:
                pi@raspberrypi:/opt/iobroker $ iobroker status
                Objects type: file
                States  type: file
                pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                  @pskiel
                  Da läuft nix.
                  Bitte noch
                  iobroker status
                  nachreichen.
                  pskiel
                  Objects type: file
                  States  type: file
                  • P pskiel
                    Objects type: file
                    States  type: file
                    @pskiel
                    Da sind überhaupt keine Adapter hinterlegt.
                    Versuch mal
                    iobroker add admin
                    iobroker start admin
                      @pskiel
                      Versuch mal
                      iobroker add admin
                      pskiel
                      ich habe ja schon mit iobroker gearbeitet, aber anscheint bin ich zu blöd geworden! Oder beim ersten Mal ohne Probleme durchgelaufen! Ab es bewahrheitet sich "“Never change a running system”"
                      pi@raspberrypi:/opt/iobroker $ iobroker start admin
                      Cannot find any instances of "admin"!
                      Ich habe es nun gelöscht und installiere NEU!
                      Herzlichen Dank und schönen Sonntag
                      • P pskiel
                        die Instance lebt
                        v12.22.5
                        6.14.14
                        + instance is alive
                        die Instance lebt
                        nope! da lebt gar nix
                        • P pskiel
                          absolut falscher Ansatz in der schnelllebigen Smarthome Thematik!
                          bitte wie hast du es denn zuletzt gemacht?
                          P Meister MopperM 2 Antworten Letzte Antwort
                            pskiel
                            ich habe es nun NEU aufgesetzt und nun läuft es.... nur!! noch die Sicherung einspielen... OH MANN und drei Kreuze machen.
                            • P pskiel
                              so sollte es sein.
                              Aber bitte etwa 1-2 Stunden Zeit einplanen, bis alles wieder sauber nachinstalliert wurde
                                so sollte es sein.
                                pskiel
                                @homoran naja 2 -3 Stunden wir nichts, ich glaube eher an 2 - 3 Tage ;-)
                                LG Peter
                                  Meister MopperM Online
                                  Meister Mopper
                                  @homoran sagte in Ich weis nicht mehr weiter!:
                                  @pskiel
                                  Und insbesondere in der Sicherheitsproblematik :man-facepalming:
                                  Proxmox und HA ...
                                  • P pskiel
                                    LG Peter
                                    LG Peter
                                    wieso?
                                    Der Restore geht relativ schnell bis das System sagt: "restore completetd" (oder ähnlich)
                                    Damit sind aber nur die Konfigurationsdateien, die VIS, die Scripte und die Objects eingelesen.
                                    Alle Instanzen werden neu installiert. Das dauert auf einem Pi4 je nach Umfang der Installation etwa 1-2 Stunden in denen du nichts am System ändern solltest.
                                    Danach ist alles wieder beim "alten".
                                      LG Peter
                                      wieso?
                                      pskiel
                                      Wenn es denn so einfach ist...nur nicht bei mir!
                                      pi@raspberrypi:/opt/iobroker $ iobroker stop
                                      pi@raspberrypi:/opt/iobroker $ iobroker restore 0
                                      host.raspberrypi Using backup file iobroker_2021_07_05-02_40_10_backupiobroker.tar.gz
                                      iobroker controller daemon is not running
                                      host.raspberrypi OK.
                                      <--- Last few GCs --->
                                      [1111:0x21a4388]    15599 ms: Mark-sweep 471.1 (472.6) -> 471.2 (473.9) MB, 287.4 / 0.0 ms  (average mu = 0.172, current mu = 0.083) allocation failure scavenge might not succeed
                                      [1111:0x21a4388]    15925 ms: Mark-sweep 472.4 (473.9) -> 472.4 (474.6) MB, 170.8 / 0.0 ms  (+ 119.0 ms in 6 steps since start of marking, biggest step 82.2 ms, walltime since start of marking 303 ms) (average mu = 0.142, current mu = 0.110) allocation fa
                                      <--- JS stacktrace --->
                                      ==== JS stack trace =========================================
                                      Security context: 0x2ff8ea35 <JSObject>
                                          0: builtin exit frame: parse(this=0x2ff865bd <Object map = 0x44080a15>,0x916c008d <Very long string[106779942]>,0x2ff865bd <Object map = 0x44080a15>)
                                          1: restoreAfterStop [0x2e4dc279] [/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:649] [bytecode=0x2e4f4ba1 offset=161](this=0x244ac9d9 <BackupRestore map = 0x4c610d25>,0x3a8803c1 <false>,0x244ac9bd <JSFunction (sfi ...
                                      FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                      /usr/bin/iobroker: Zeile 8:  1110 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                      pi@raspberrypi:/opt/iobroker $ iobroker start all
                                      • P pskiel
                                        nur nicht bei mir!
                                        was ist denn bei dir anders als bei anderen?
                                        was sagt
                                        htop
                                          nur nicht bei mir!
                                          was sagt
                                          htop
                                          pskiel
                                          nur der Kopf
                                          MEM 229M/1.83G
                                          Sollte reichen
