  4. [HowTo] ioBroker unter Docker auf Synology DiskStation
    5.9k
iobrokerdockerbuanetsynologydiskstation
2.9k Beiträge 248 Kommentatoren 2.0m Aufrufe 123 Beobachtet
    stevie77
    #2441
    Moin. Über Nacht ist mein ioBroker plötzlich nicht mehr über die Weboberfläche erreichbar (Administration und VIS-Seiten). Raspi läuft aber, auch kann ich mich in den Container verbinden. Das einzige was davor gemacht wurde war ein Philips-hue-Adapter-Update.
    Irgendwie scheint mein Admin-Adapter kaputt zu sein? Hatte das schonmal jemand?
    Log sagt folgendes:
    ---------------     2021-06-02 13:44:55      ---------------
    -----       Welcome to your ioBroker-container!        -----
    -----          Startupscript is now running.           -----
    -----                Please be patient!                -----
    -----              Debugging information               -----
    -----                      System                      -----
    -----               arch:      armv7l                  -----
    -----                     Versions                     -----
    -----               image:     v4.2.0                  -----
    -----               node:      v12.22.1                -----
    -----               npm:       6.14.12                 -----
    -----                       ENV                        -----
    -----               PACKAGES:  nano                   build-essential libcairo2-dev          libpango1.0-dev libjpeg-dev            libgif-dev librsvg2-dev            -----
    -----               SETGID:    1000                    -----
    -----               SETUID:    1000                    -----
    -----               USBDEVICES: /dev/ttyUSB0           /dev/ttyAMA0                         -----
    -----         Step 1 of 5: Preparing container         -----
    Installing additional packages is set by ENV.
    The following packages will be installed: nano build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev...
    Done.
    -----   Step 2 of 5: Detecting ioBroker installation   -----
    Existing installation of ioBroker detected in /opt/iobroker.
    -----   Step 3 of 5: Checking ioBroker installation    -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    Done.
    The object system.adapter.admin.0 was not found!
    /opt/scripts/iobroker_startup.sh: line 173: [: !=: unary operator expected
    -----      Step 4 of 5: Applying special settings      -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information take a look at readme.md on Github!
    Usb-device-support is activated by ENV.
    Setting permissions for /dev/ttyUSB0 /dev/ttyAMA0...
    Done.
    -----          Step 5 of 5: ioBroker startup           -----
    Starting ioBroker...
    doc.rows is not iterable
    TypeError: doc.rows is not iterable
        at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2782:27)
    object system.meta.uuid cannot be updated: Error: DB closed
    object system.user.admin created
      doerk32
      #2442
      Guten Morgen,
      ich habe portainer installliert. Bei "üben habe ichVlans erstellt, die nicht mehr zu löschen sind.
      Wie bekomme ich das trotzdem hin. Ich möchte sozusagen aufräumen.
      mfg
      Dirk
      • S stevie77
        Log sagt folgendes:
        -----                      System                      -----
        -----                       ENV                        -----
        Done.
        Done.
        Done.
        Done.
        stevie77
        #2443
        @stevie77 Es war vermutlich tatsächlich ein warum auch immer irgendwie misslungenes Update des Adapters Admin auf 5.1.6. Ich konnte ein komplettes Backup des Raspi von Sonntag einspielen und sah, dass ich wohl in den zwei Tagen auch Admin aktualisiert hatte. Wie zuvor lief der automatische Prozess gut durch und der Docker-Container startete auch danach wieder korrekt. Mal sehen, ob es stabil bleibt oder wieder nach zwei Tagen plötzlich hängt...
        • S stevie77
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #2444
          @stevie77 sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
          @stevie77 Es war vermutlich ......misslungenes Update des Adapters Admin auf 5.1.6. ............
          Da du Beta Tester bist , kann es schon vorkommen das etwas nicht funktioniert , hat aber nichts mit diesem Thread zu tun .
          • D doerk32
            Guten Morgen,
            mfg
            Dirk
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            #2445
            @doerk32 sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
            Kann dir da nicht ganz helfen , da ich kein Vlan nutze .
            Schau mal hier , vorletzter Beitrag vielleicht kommst du damit weiter :
            https://www.synology-forum.de/threads/docker-portainer-netzwerk-laesst-sich-nicht-loeschen.108179/
            • GlasfaserG Glasfaser
              stevie77
              #2446
              @glasfaser Upps, das war mir gar nicht bewusst. Danke für den Hinweis. Keine Ahnung, wie ich dazu komme (Gedächtnislücke?). Als Anfänger will ich mich eigentlich von Betas und deren Fehlern fern halten. Einfach den 2. Eintrag löschen, nehme ich an?
              • S stevie77
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #2447
                Nix löschen !
                Einfach in der Haupteinstellung : "Aktiver Verwahrungsort" auf stable stellen
                  Nix löschen !
                  stevie77
                  #2448
                  @glasfaser Okay, ich habe hier 686a864e-af3a-4535-93e4-4970c9752e6a-image.png jetzt stable eingetragen und dann Speichern und schließen geklickt. Jetzt hängt der Dialog seit 5 min ohne dass die Buttons aktiv wären. Werden da im Hintergrund alle Adapter nochmals umkopiert/heruntergeladen oder ist mir ioBroker abgeschmiert? Naja, warte ich wohl mal bis heute Abend bevor ich den Container neu starte...
                  • S stevie77
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    #2449
                    Da dürfte nicht´s abschmieren , es werden nur im Hintergrund die Adapter dann erneut geprüft ( Version) , da du ja den Verwahrungsort geändert hast .
                    EDIT:
                    Nutzt du die neue Admin 5 WebUI
                      EDIT:
                      stevie77
                      schrieb am zuletzt editiert von stevie77
                      #2450
                      @glasfaser Ich hab erst jetzt gemerkt, dass alles mit 5.x von Admin nicht stable ist. Dass die GUI einfriert hat dann sicher damit zu tun, das hatte ich jetzt mehrmals, trat aber immer auf wenn ich Admin aktualisierte. Dachte nur, dass das normal sei, weil Admin halt die GUI erzeugt oder so. Jetzt bin ich wieder bei 4.2.1 und alles ist gut. Danke für die Hilfestellung. Und nun offtopic Ende. :-)
                      PS: Ja, die GUI nutzte ich wohl, die ist aber ziemlich blöd und unübersichtlich.
                      • K Offline
                        kayfun
                        #2451
                        bei mir läuft iobroker seit 1,5 Jahren unter Unraid im Docker ohne Probleme.
                        Nun habe ich vorgestern gesehen das meine Visualisierung nicht mehr angezeigt wird und habe dann den Docker neu gestartet.
                        Leider läuft nun nichts mehr.
                        Hoffe das jemand helfen kann.
                        --------------- 2021-06-04 03:18:05 ---------------
                        ----- System -----
                        ----- arch: x86_64 -----
                        ----- image: v5.1.0 -----
                        ----- ENV -----
                        Nothing to do here.
                        Done.
                        Done.
                        Done.
                        Done.
                        /opt/scripts/iobroker_startup.sh: Zeile 197: [: !=: Einstelliger (unärer) Operator erwartet.
                        GlasfaserG S 2 Antworten Letzte Antwort
                        • K kayfun
                          ----- System -----
                          ----- ENV -----
                          Nothing to do here.
                          Done.
                          Done.
                          Done.
                          Done.
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #2452
                          @kayfun
                          Zeige mal
                          iobroker update
                          iobroker version
                          iobroker repo list
                          • K kayfun
                            ----- System -----
                            ----- ENV -----
                            Nothing to do here.
                            Done.
                            Done.
                            Done.
                            Done.
                            stevie77
                            #2453
                            @kayfun sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
                            Kann es sein, dass du - wie ich - Admin 5.x installiert hast, absichtlich oder versehentlich? Admin 5 ist beta. Genau den Fehler hatte ich auch vor wenigen Tagen nach nem Update des Admin-Adapters, siehe Postings etwas weiter unten.
                            Ich ging dann wieder auf Admin 4.2.1 zurück (in der ioBroker-Konsole). Das Dumme daran ist, dass dann die Instanzenseite leer bleibt (bekannter Fehler). Deswegen bin ich heute Nacht wieder auf die neueste Beta, und das hat dann funktioniert.
                            • K Offline
                              kayfun
                              #2454
                              # iobroker update
                               Cannot read system.config: null (OK when migrating or restoring)
                               Cannot find view "system" for search "host"
                              Error: Object "system.config" not found
                              ^C
                              # iobroker version
                              3.2.16
                              # iobroker repo list
                              Cannot get list: undefined
                              Mit dem Admin 5.x muss ich mal schauen. Ich steh auf Kriegsfuß mit konsolen.
                              • K kayfun
                                # iobroker update
                                ^C
                                # iobroker version
                                3.2.16
                                stevie77
                                #2455
                                @kayfun Hmmm, "ioBroker update" hat bei mir (wie Adapter installieren und downgraden) noch problemlos funktioniert - vielleicht doch ein anderes Problem?!
                                • GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #2456
                                  iobroker update
                                  Nimm mal dieses howto
                                  https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host
                                  • K Offline
                                    kayfun
                                    #2457
                                    # ls -la /opt/iobroker/iobroker-data/backup-objects/
                                    insgesamt 49408
                                    drwxrwxrwx 1 iobroker iobroker    4096 Jun  4 03:19 .
                                    drwxrwxrwx 1 iobroker iobroker     204 Jun  4 04:54 ..
                                    -rw-r--r-- 1 iobroker iobroker 2180058 Mai 31 05:15 2021-05-31_05-15_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2179991 Mai 31 07:15 2021-05-31_07-15_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2179989 Mai 31 09:30 2021-05-31_09-30_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2179982 Mai 31 11:30 2021-05-31_11-30_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180066 Mai 31 13:30 2021-05-31_13-30_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180072 Mai 31 15:45 2021-05-31_15-45_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180049 Mai 31 17:45 2021-05-31_17-45_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194287 Mai 31 19:09 2021-05-31_19-09_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180115 Mai 31 19:45 2021-05-31_19-45_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194394 Mai 31 21:10 2021-05-31_21-10_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180105 Mai 31 22:00 2021-05-31_22-00_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194186 Mai 31 23:10 2021-05-31_23-10_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180135 Jun  1 00:00 2021-06-01_00-00_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194312 Jun  1 01:10 2021-06-01_01-10_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180119 Jun  1 02:00 2021-06-01_02-00_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194857 Jun  1 03:11 2021-06-01_03-11_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180116 Jun  1 04:00 2021-06-01_04-00_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194720 Jun  1 05:11 2021-06-01_05-11_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180129 Jun  1 06:06 2021-06-01_06-06_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194964 Jun  1 07:12 2021-06-01_07-12_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180130 Jun  1 08:15 2021-06-01_08-15_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194800 Jun  1 09:12 2021-06-01_09-12_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180112 Jun  1 09:35 2021-06-01_09-35_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193835 Jun  1 09:35 2021-06-01_09-35_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194005 Jun  1 09:36 2021-06-01_09-36_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194855 Jun  1 11:36 2021-06-01_11-36_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180123 Jun  1 11:40 2021-06-01_11-40_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194771 Jun  1 13:36 2021-06-01_13-36_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180152 Jun  1 13:45 2021-06-01_13-45_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  194787 Jun  1 15:37 2021-06-01_15-37_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180122 Jun  1 15:51 2021-06-01_15-51_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193988 Jun  1 15:51 2021-06-01_15-51_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180199 Jun  1 16:13 2021-06-01_16-12_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193870 Jun  1 16:12 2021-06-01_16-12_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193992 Jun  1 16:13 2021-06-01_16-13_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180190 Jun  1 16:25 2021-06-01_16-25_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193670 Jun  1 16:25 2021-06-01_16-25_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker 2180216 Jun  1 16:33 2021-06-01_16-33_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193596 Jun  1 16:33 2021-06-01_16-33_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193735 Jun  1 16:34 2021-06-01_16-34_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker    4304 Jun  2 01:25 2021-06-02_01-25_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193684 Jun  2 01:25 2021-06-02_01-25_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193665 Jun  2 01:26 2021-06-02_01-26_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker    4305 Jun  2 01:33 2021-06-02_01-33_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193642 Jun  2 01:33 2021-06-02_01-33_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker    4292 Jun  4 03:18 2021-06-04_03-18_objects.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193647 Jun  4 03:18 2021-06-04_03-18_states.json.gz
                                    -rw-r--r-- 1 iobroker iobroker  193659 Jun  4 03:19 2021-06-04_03-19_states.json.gz
                                    Hm, wären diese das dann?
                                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                    • K kayfun
                                      insgesamt 49408
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      #2458
                                      Thomas-Braun hat es doch im HowTo erklärt !?
                                      Ich ... kann dir nicht sagen seit wann es bei dir abgeschmiert ist .
                                      Vielleicht ist es beim 1. Juni Ok
                                      • K kayfun
                                        insgesamt 49408
                                        #2459
                                        Ich würde ja behaupten das waren die letzten vollständigen Versionen.
                                        Wobei die states.json besser aussehen. Reicht vielleicht nur die objects.json wieder reinzuholen.
                                          DiveDancer
                                          #2460
                                          Moin moin Männers,
                                          ich weiß nicht wohin mit meinem Problem,
                                          scheint hier alles schon angesprochen zu sein,
                                          aber ich finde die Nadel in diesem riesigen Heuhaufen nicht.
                                          Ich versuche jungfräulich mit einem ioBroker Backup in einen Container einzuziehen.
                                          (Raspberry Pi 4 (4GB))
                                          Neben dem Problem das ich die USB Devices nicht durchgereicht bekomme, kriege ich auch das Backup nicht eingespielt.
                                          Aktuelle Fehlermeldung:
                                          [ Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
                                          Done. ]
                                          Die gepackte Backupdatei liegt derzeit im Pfad /opt/iobroker/backups/
                                          Diese zusammengeklauten Compose Befehle nutze ich derzeit um den Container zu erstellen.
                                          version: "2"
                                          services:
                                            iobroker:
                                              container_name: iobroker
                                              image: buanet/iobroker:latest-v5
                                              hostname: RasPi4b
                                              domainname: fritz.box
                                              restart: always
                                              privileged: true
                                              stdin_open: true
                                              tty: true
                                              ports:          # Ports die nach Außen durchgereicht werden sollen
                                               - "1880:1880"  # node-red
                                               - "1883:1883"  # mqtt
                                               - "8081:8081"  # Port für die ioBroker Admin Oberfläche
                                               - "8282:8282"  # flot
                                               - "8088:8088"  # terminal
                                               - "8284:8284"  # socketIO
                                              devices:
                                               - "/dev:/dev"
                                              volumes:
                                               - /opt/iobroker:/var/lib/docker/volumes/iobrokerdata
                                              environment:
                                               - DEBIAN_FRONTEND=teletype
                                               - LANG=de_DE.UTF‑8
                                               - LANGUAGE=de_DE:de
                                               - LC_ALL=de_DE.UTF‑8
                                               - TZ=Europe/Berlin
                                               - PACKAGES=nano
                                               - Zigbee=false
                                               - ZWAVE=false
                                               - USBDEVICES=/dev/ttyACM0
                                               - USBDEVICES=/dev/serial/by-id/zigbee
                                               - USBDEVICES=/dev/serial/by-id/zwave
                                          -----                      System                      -----
                                          -----                       ENV                        -----
                                          -----               PACKAGES:  nano                    -----
                                          -----               USBDEVICES: /dev/serial/by-id/      -----
                                          -----               ZWAVE:     false                   -----
                                          The following packages will be installed: nano...
                                          debconf: unable to initialize frontend: Dialog
                                          debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.)
                                          debconf: falling back to frontend: Readline
                                          Selecting previously unselected package nano.
                                          (Reading database ...
                                          (Reading database ... 5%
                                          (Reading database ... 10%
                                          (Reading database ... 15%
                                          (Reading database ... 20%
                                          (Reading database ... 25%
                                          (Reading database ... 30%
                                          (Reading database ... 35%
                                          (Reading database ... 40%
                                          (Reading database ... 45%
                                          (Reading database ... 50%
                                          (Reading database ... 55%
                                          (Reading database ... 60%
                                          (Reading database ... 65%
                                          (Reading database ... 70%
                                          (Reading database ... 75%
                                          (Reading database ... 80%
                                          (Reading database ... 85%
                                          (Reading database ... 90%
                                          (Reading database ... 95%
                                          (Reading database ... 100%
                                          (Reading database ... 25575 files and directories currently installed.)
                                          Preparing to unpack .../archives/nano_3.2-3_armhf.deb ...
                                          Unpacking nano (3.2-3) ...
                                          Setting up nano (3.2-3) ...
                                          update-alternatives: using /bin/nano to provide /usr/bin/editor (editor) in auto mode
                                          update-alternatives: warning: skip creation of /usr/share/man/man1/editor.1.gz because associated file /usr/share/man/man1/nano.1.gz (of link group editor) doesn't exist
                                          update-alternatives: using /bin/nano to provide /usr/bin/pico (pico) in auto mode
                                          update-alternatives: warning: skip creation of /usr/share/man/man1/pico.1.gz because associated file /usr/share/man/man1/nano.1.gz (of link group pico) doesn't exist
                                          Done.
                                          Registering maintenance script as command.
                                          Done.
                                          Done.
                                          Done.
                                          Hostname in ioBroker does not match the hostname of this container.
                                          Updating hostname to  RasPi4b...
                                          The host for instance "system.adapter.admin.0" was changed from "c9b7b12a8335" to "RasPi4b".
                                          The host for instance "system.adapter.discovery.0" was changed from "c9b7b12a8335" to "RasPi4b".
                                          The host for instance "system.adapter.info.0" was changed from "c9b7b12a8335" to "RasPi4b".
                                          Done.
                                          Setting permissions for /dev/serial/by-id/...
                                          Done.
                                          host.RasPi4b check instance "system.adapter.admin.0" for host "RasPi4b"
                                          host.RasPi4b check instance "system.adapter.discovery.0" for host "RasPi4b"
                                          host.RasPi4b check instance "system.adapter.info.0" for host "RasPi4b"
                                          Send diag info: {"uuid":"ab265f4a-67f9-a46a-c0b2-61e4b95cefe5","language":"","country":"","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.22.1","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"discovery":{"version":"2.6.1","platform":"Javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013191168,"ostype":"Linux","city":""}
                                          hash changed or no sources cached => force download of new sources
                                          ls: cannot access '/dev/disk/by-id/': No such file or directory
                                          ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                                          Send diag info: {"uuid":"ab265f4a-67f9-a46a-c0b2-61e4b95cefe5","language":"de","country":"","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.22.1","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"discovery":{"version":"2.6.1","platform":"Javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013191168,"ostype":"Linux","city":""}
                                          Adapter    "zwave2"        : 1.9.3
                                          root@RasPi4b:/opt/iobroker# iobroker version
                                          3.2.16
                                          root@RasPi4b:/opt/iobroker# bniobroker repo list
                                          bash: bniobroker: command not found
                                          root@RasPi4b:/opt/iobroker# iobroker repo list
                                          default     : http://download.iobroker.net/sources-dist.json
                                          latest      : http://download.iobroker.net/sources-dist-latest.json
                                          Active repo: default
                                          Iobroker läuft, aber immer in der Minimalkonfiguration (3 Adapter).
                                          Wie weit bin ich entfernt?
                                          LG DiveDancer
