  4. PINE Rock64 bootet nicht mehr
    5.6k
170 Beiträge 3 Kommentatoren 12.9k Aufrufe 2 Beobachtet
    derrapf
    schrieb am zuletzt editiert von derrapf
    #41
    Ok, Hab das mal gemacht. Aber das sieht ungesund für mich aus:
    pi@rock64:/opt/iobroker$ npm install sharp
    [sudo] Passwort für pi:
    > sharp@0.28.1 install /opt/iobroker/node_modules/iobroker.iot/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
    sharp: Installation error: Use with glibc 2.28 requires manual installation of libvips >= 8.10.6
    sharp: Attempting to build from source via node-gyp but this may fail due to the above error
    sharp: Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Verzeichnis „/opt/iobroker/node_modules/iobroker.iot/node_modules/sharp/build“ wird betreten
      CC(target) Release/obj.target/nothing/../../../node-addon-api/nothing.o
      AR(target) Release/obj.target/../../../node-addon-api/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    ../src/common.cc:24:10: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/iobroker.iot/node_modules/sharp/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.43-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/sharp
    gyp ERR! node -v v12.22.5
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    > sharp@0.28.3 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node inst        all/dll-copy)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current        : {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"        any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.28.1 (node_modules/iobroker.iot/node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.28.1 install: `(node install/libvips && node install/dll-copy && prebuild-i        nstall) || (node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! sharp@0.28.3 install: `(node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile &&        node-gyp rebuild && node install/dll-copy)`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the sharp@0.28.3 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2021-08-17T13_13_06_524Z-debug.log
    Da steht was von "When using npm v6 or earlier, the npm install --unsafe-perm flag must be used when installing as root or a sudo user." aber ich hab's ja nicht als rott installiert.
    Oder soll man das?
    NPM ist bei mir 6.14.14
    Gruss Ralf
    • D derrapf
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      Oder soll man das?
      Gruss Ralf
      #42
      @derrapf
      Wie gesagt, da muss offenbar zuvor die libvips von Hand gebaut werden.
        @derrapf
        derrapf
        #43
        Ich hab mich mal durchgeklickt und bin hier gelandet
        Das mach ich heute nicht mehr. Mit ztiemlicher sicherheit explodoert dann alles. Wir fahren morgen nach Kroatien und ich muss noch packen. Ev. setze ich mich dort mal gemütlich hin und mache weiter.
        Wenn ich Dir richtig verstehe macht es aber nichts wenn das fehlt..
        Gruss Ralf
        • D derrapf
          Gruss Ralf
          #44
          @derrapf
          Nee, das wird dir nur bei jeder Installation wieder gemeldet werden.
          Und es kann sein, dass der iot-Adapter mit Bildern nicht anfangen kann. sharp ist für die Bildbearbeitung zuständig.
          Schönen Urlaub!
            @derrapf
            Schönen Urlaub!
            derrapf
            #45
            @thomas-braun Danke
            Ich starte jetz tmal den IOBroker und hoffe das Beste. Wenn er nicht geht mach ich übermorgen vielleicht weiter. Dann vom Hotel aus..
            Gruss Ralf
            • D derrapf
              @thomas-braun Danke
              Gruss Ralf
              derrapf
              #46
              @derrapf
              Oje. Sieh nicht so toll aus.
              Also das erste was mir auffällt ist, dass die Weboberfläche im Vergleich zu früher total langsam und unresponsive ist.
              Die Adapter werden alle als installiert angezeigt:
              Dann werden, soweit ich das sehe alle meine Adapter als installiert angezeigt:
              Die Instanzen sind aber alle weg:
              Das Drücken auf den Play Button bring keine Änderung.
              Muss ich ev. das Update nochmal laufen lassen?
              Ansonsten ist das Log voll mit Fehlern
              Ich glaub ich fang nochmal von vorne an...
              Und ihr meint echt das mit dem "Rezept" wäre ein guter Weg...?
              Gruss Ralf
              • D derrapf
                @derrapf
                Gruss Ralf
                #47
                @derrapf sagte in PINE Rock64 bootet nicht mehr:
                nein! sie sind herausgefiltert
                ggf. ist selbst das Rezept schon ranzig.
                Viele Fehlermeldungen sind bereits in anderen Threads gemeldet und sollten längst behoben sein.
                Was bringt
                iobroker update -i
                D 2 Antworten Letzte Antwort
                  Was bringt
                  iobroker update -i
                  derrapf
                  #48
                  OK.
                  Und wie krieg ich die wieder reingefiltert? Ich wüsste nicht, dass ich eine Filterbedingung angegeben hätte. Das Eingabefeld ist ja auch leer. Und auf den Play-Button kann ich drücken wie ich will. Wo gibts denn noch eine Filtermöglichkeit? Ich kenn die neue Oberfläche nicht...
                  Gruss Ralf
                  • D derrapf
                    OK.
                    Gruss Ralf
                    #49
                    auch das war bereits irgendwo schon mal Thema.
                    (ich hab noch was editeiert!
                      Was bringt
                      iobroker update -i
                      derrapf
                      #50
                      @homoran sagte in PINE Rock64 bootet nicht mehr:
                      Was bringt
                      iobroker update -i
                      Da kommt recht viel
                      pi@rock64:/opt/iobroker$ iobroker update -i
                      Used repository: stable
                      hash changed or no sources cached => force download of new sources
                      update done
                      Adapter    "admin"         : 5.1.23   , installed 5.1.23
                      Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
                      Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                      Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                      Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                      Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                      Adapter    "flot"          : 1.10.6   , installed 1.10.6
                      Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                      Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                      Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
                      Adapter    "history"       : 1.9.13   , installed 1.9.13
                      Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                      Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                      Adapter    "ical"          : 1.11.2   , installed 1.11.2
                      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                      Adapter    "icons-material-png": 0.1.0   , installed 0.1.1
                      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.1
                      Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                      Adapter    "info"          : 1.9.8    , installed 1.9.8
                      Adapter    "iot"           : 1.8.22   , installed 1.8.22
                      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                      Controller "js-controller" : 3.3.15   , installed 3.3.15
                      Adapter    "luftdaten"     : 1.0.3    , installed 1.0.3
                      Adapter    "material"      : 1.0.4    , installed 0.13.9 [Updateable]
                      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                      Adapter    "mqtt-client"   : 1.4.0    , installed 1.4.0
                      Adapter    "net-tools"     : 0.1.5    , installed 0.1.5
                      Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
                      Adapter    "owntracks"     : 1.0.0    , installed 1.0.0
                      Adapter    "parser"        : 1.0.7    , installed 1.0.7
                      Adapter    "ping"          : 1.5.0    , installed 1.5.0
                      Adapter    "places"        : 1.0.0    , installed 1.0.0
                      Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                      Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                      Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                      Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                      Adapter    "scenes"        : 2.3.6    , installed 2.3.6
                      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                      Adapter    "synology"      : 1.0.0    , installed 1.0.0
                      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                      Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                      Adapter    "tvspielfilm"   : 1.0.4    , installed 1.0.4
                      Adapter    "vis"           : 1.4.3    , installed 1.4.3
                      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                      Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                      Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
                      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                      Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                      Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.0
                      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                      Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                      Adapter    "vw-connect"    : 0.0.39   , installed 0.0.39
                      Adapter    "web"           : 3.4.7    , installed 3.4.7
                      Gruss Ralf
                      • D derrapf
                        Was bringt
                        iobroker update -i
                        Da kommt recht viel
                        update done
                        Gruss Ralf
                        #51
                        Da kommt recht viel
                        Die hast du alle -installiert?
                        Admin ist ok!
                        und js-controller auch (hatten wir ja schon eben)
                        bis auf material scheint alles drauf und aktuell zu sein
                        Mach mal einen forced refresh des Browsers (STRG-F5)
                        und wenn das nicht hilft bitte ersteinmal
                        iobroker list instances
                          derrapf
                          #52
                          Ja genau. hier. Gab's aber keine Lösung.
                          Gruss Ralf
                          • D derrapf
                            Gruss Ralf
                            #53
                            doch - "richtiges Neuladen", was immer das bedeutet
                              derrapf
                              #54
                              CTRL F5 hab ich mal gemacht. Dann kommt zuerst dass die Seite nicht gefunden wird. Dann das riesige IOBroker Zeichen, dann kommt jetzt so was:
                              Kann es sein dass der IOBroker nur ewig langsam ist?
                              Vorhin, also ich auf die Instanzen Seite zurück bin waren nämlich eine handvoll nicht laufende Instanzen angezeigt, und als ich den Start-Knopf einer Instanz gedrückt hatte war die Seite wieder leer und wurde ewig nicht refreshed.
                              Jetzt sieht sie seit mehreren Minuten aus wie oben.
                              Die Kiste scheint aber auch relativ ausgelastet zu sein
                              Gruss Ralf
                              HomoranH D 2 Antworten Letzte Antwort
                              • D derrapf
                                Gruss Ralf
                                #55
                                bei einer load >4 ist das langsame Verhalten nachvollziehbar
                                sieh mal unter htop nach, da sollte auch der Verursacher benannt werden (nicht nur "node")
                                • D derrapf
                                  Gruss Ralf
                                  derrapf
                                  #56
                                  @derrapf Jetzt!
                                  Nach Minuten!
                                  Sieht es so aus:
                                  Muesste der jscontroller nicht laufen?
                                  Wenn ich auf seinen Werkzeug Button gehe kommt:
                                  Vis geht leider auch nicht; da kommt das die Seite nicht gefunden wird.
                                  Ich glaube fast das Update ist nicht sauber durchgelaufen.
                                  Gruss Ralf
                                    derrapf
                                    #57
                                    Kannst Du damit was anfangen?
                                    • D derrapf
                                      @derrapf Jetzt!
                                      Nach Minuten!
                                      Sieht es so aus:
                                      Gruss Ralf
                                      #58
                                      der gehört da doch gar nicht rein 😕
                                      läuft web?
                                      • D derrapf
                                        #59
                                        nicht wirklich, aber die LOAD ist immer noch >4 und die hm-rpc zieht viel CPU.
                                        Du müsstest mal nach %CPU absteigend sortieren
                                          läuft web?
                                          derrapf
                                          #60
                                          Ja, ich hab ihn da nicht rein. Keine Ahnung wo der her kommt.
                                          Ich hab hier nochmal nach CPU sortiert:
