  5. trying to get value of updated object id sent to telegram
10 Beiträge 2 Kommentatoren 1.2k Aufrufe 1 Beobachtet
  • dony71D Offline
    dony71D Offline
    dony71
    Hi expert scripter
    I have problem in my blocky script
    I'm trying to get value of updated object id sent to telegram
    Blocky looks like below
    I have several mqtt.1 object, for ex. mqtt.1.bedroom, mqtt.1.classroom, etvc
    If there is update in value of one mqtt.1 object, for ex. mqtt.1.bedroom.MSG, I want telegram to send value of mqtt.1.bedroom.MSG
    However with this blocky, telegram only send word "Server" without value
    How to do this?
    dony71D paul53P 2 Antworten Letzte Antwort
    • dony71D dony71
      Hi expert scripter
      How to do this?
      dony71D Offline
      dony71D Offline
      dony71
      @dony71 btw, i can understand german, so anybody can reply in german language
      • dony71D dony71
        Hi expert scripter
        How to do this?
        @dony71 sagte: I want telegram to send value of mqtt.1.bedroom.MSG
        dony71D 1 Antwort Letzte Antwort
          dony71D Offline
          dony71D Offline
          dony71
          @paul53 by inserting value "server", it will show all mqtt.1.* object, not only updated object
          so for ex. I have mqtt.1.bedroom.MSG and mqtt.1.classroom.MSG, then
          server = mqtt.1.bedroom.MSG,mqtt.1.classroom.MSG
          • dony71D dony71
            @dony71
            Wert (object value) shows the value of the just updated datapoint. You will find it under "Trigger".
            If you want to send the ID (for ex. "mqtt.1.bedroom.MSG") of the updated datapoint:
            If you want to send both (id and value):
              @dony71
              dony71D Offline
              dony71D Offline
              dony71
              @paul53 yeap, it works, thank you
              Now I have another problem
              I notice script will not trigger if object id not exist before
              for ex. let says object "mqtt.1.diningroom.MSG" not exist yet
              Then I publish "mosquitto_pub -t /mqtt/1/diningroom/MSG -m hallo",
              script won't trigger anything (no telegram msg being sent)
              After that even if I redo publish "mosquitto_pub -t /mqtt/1/diningroom/MSG -m world",
              script still won't trigger anything.
              Is there anything I should do to fix this?
              • dony71D dony71
                @dony71 sagte: After that even if I redo publish "mosquitto_pub -t /mqtt/1/diningroom/MSG -m world", script still won't trigger anything.
                It's a problem of the buffer inside the javascript instance: Restart the javascript instance.
                  dony71D Offline
                  dony71D Offline
                  dony71
                  schrieb am zuletzt editiert von dony71
                  @paul53 Restart java script won't help. I have to restart blocky script. This means each time mosquitto_pub publish new object instance, I have to restart the script then re-publish this new object then trigger works.
                  How could it be? Maybe I'm missing some setting?
                  FYI below my updated blocky script
                  • dony71D dony71
                    @dony71
                    Try replacing $Selector with RegExp.
                    The $Selector does not recognise new data points because it uses the buffer of the Javascript instance. A subscription with RegExp captures new data points.
                      @dony71
                      dony71D Offline
                      dony71D Offline
                      dony71
                      @paul53 thanks .... it's working well
                      you're really the expert
