  4. NPM Problem
    1.6k
    1.5k
NPM Problem
28 Beiträge 5 Kommentatoren 5.2k Aufrufe 5 Beobachtet
    Hallo Zusammen,
    hm. auch ich habe das o.g. Problem neuerdings. Ich habe auch lediglich iobroker über die Konsole bisher geupgraded. Seit einigen Tagen kann ich keine Adapter mehr updaten.
    Meine Fehlermeldung beim Versuch irgendein Adapter zu updaten oder eben den veralteten tr-=64 Adapter übder die Konsle zu deaktivieren:
    npm uninstall tr-O64
    npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm ERR! code EINVALIDTAGNAME
    npm ERR! Invalid tag name "node_modules\tr-O64": Tags may not have any characters that encodeURIComponent encodes.
    Would you like to upgrade vw-connect from @0.0.39 to @0.0.40 now? [(y)es, (n)o]: y
    Update vw-connect from @0.0.39 to @0.0.40
    NPM version: 6.14.14
    npm install iobroker.vw-connect@0.0.40 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR!     /home/iobroker/.npm/_logs/2021-08-31T16_46_07_551Z-debug.log
    upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
    upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/pngupload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
    upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
    upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
    Adapter "vw-connect" updated
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v14.17.5
    /usr/local/bin/node
    v14.17.5
    /usr/local/bin/npm
    6.14.14
    nodejs:
      Installiert:           14.17.5-1nodesource1
      Installationskandidat: 14.17.6-deb-1nodesource1
      Versionstabelle:
         14.17.6-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
     *** 14.17.5-1nodesource1 100
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u1 500
    iobroker update -i
    pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ iobroker update -i
    Used repository: latest
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
    Adapter    "history"       : 1.9.13   , installed 1.9.13
    Adapter    "hue"           : 3.5.23   , installed 3.5.22 [Updateable]
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "influxdb"      : 2.2.0    , installed 2.1.1 [Updateable]
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "innogy-smarthome": 0.3.7   , installed 0.3.7
    Adapter    "jarvis"        : 2.2.3    , installed 2.2.3
    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
    Controller "js-controller" : 3.3.15   , installed 3.3.15
    Adapter    "meross"        : 1.6.3    , installed 1.6.3
    Adapter    "netatmo"       : 1.4.4    , installed 1.4.4
    Adapter    "pi-hole"       : 1.3.2    , installed 1.3.2
    Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "terminal"      : 0.1.2    , installed 0.1.2
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "vis"           : 1.4.3    , installed 1.4.3
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "vw-connect"    : 0.0.40   , installed 0.0.39 [Updateable]
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.9    , installed 3.4.9
    Adapter    "yahka"         : 0.13.1   , installed 0.13.1
    Adapter    "yeelight-2"    : 1.1.2    , installed 1.1.2
    iobroker list instances
    pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi4                          -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker-RasPi4                          -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBroker-RasPi4                          -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker-RasPi4                          -  enabled, port: 443
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-RasPi4                          -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-RasPi4                          -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker-RasPi4                          -  enabled, port: 8086
    + system.adapter.innogy-smarthome.0       : innogy-smarthome      : ioBroker-RasPi4                          -  enabled
    + system.adapter.jarvis.0                 : jarvis                : ioBroker-RasPi4                          -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          -  enabled
    + system.adapter.netatmo.0                : netatmo               : ioBroker-RasPi4                          -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : ioBroker-RasPi4                          -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-RasPi4                          -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-RasPi4                          -  enabled
    + system.adapter.web.0                    : web                   : ioBroker-RasPi4                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.1                  : yahka                 : ioBroker-RasPi4                          -  enabled
    + instance is alive
    iobroker list adapters
    pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.1.25
    system.adapter.backitup                : backitup       - v1.5.6
    system.adapter.daswetter               : daswetter      - v3.0.7
    system.adapter.discovery               : discovery      - v2.7.0
    system.adapter.fritzdect               : fritzdect      - v2.1.15
    system.adapter.hue                     : hue            - v3.5.22
    system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
    system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
    system.adapter.influxdb                : influxdb       - v2.1.1
    system.adapter.info                    : info           - v1.9.8
    system.adapter.innogy-smarthome        : innogy-smarthome - v0.3.7
    system.adapter.jarvis                  : jarvis         - v2.2.3
    system.adapter.javascript              : javascript     - v5.2.8
    system.adapter.netatmo                 : netatmo        - v1.4.4
    system.adapter.pi-hole                 : pi-hole        - v1.3.2
    system.adapter.pollenflug              : pollenflug     - v1.0.6
    system.adapter.simple-api              : simple-api     - v2.6.1
    system.adapter.socketio                : socketio       - v3.1.4
    system.adapter.terminal                : terminal       - v0.1.2
    system.adapter.vis                     : vis            - v1.4.3
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
    system.adapter.vis-google-fonts        : vis-google-fonts - v0.1.0
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
    system.adapter.vis-metro               : vis-metro      - v1.1.2
    system.adapter.vis-plumb               : vis-plumb      - v1.0.2
    system.adapter.vw-connect              : vw-connect     - v0.0.39
    system.adapter.weatherunderground      : weatherunderground - v3.3.1
    system.adapter.web                     : web            - v3.4.9
    system.adapter.yahka                   : yahka          - v0.13.1
    iobroker version
    pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ iobroker version
    3.3.15
    Ich schneine einen sehr ähnliches Problem zu haben wie Rich90. Wie könnte ich den meine iobroker-Installation noch retten?
    VG vsa
    Thomas BraunT
    Thomas BraunT
    @vsa
    nodeJS ist schon mal falsch installiert. Schau in meiner Signatur, da wirds erklärt.
    Und der Adapter heißt tr-064, nicht tr-O64
    ? 1 Antwort Letzte Antwort
      @vsa
      Dank schonmal.
      Ja, das hatte ich gelesen,
      trotz Deiner Anleitung wird in
      /usr/bin/nodejs
      v14.17.5
      /usr/local/bin/node
      v14.17.5
      /usr/local/bin/npm
      6.14.14
      installiert. Und nicht in /usr/bin
      Wie kann ich das forcieren?
      VG vsa
        Dank schonmal.
        /usr/bin/nodejs
        v14.17.5
        /usr/local/bin/node
        v14.17.5
        /usr/local/bin/npm
        6.14.14
        VG vsa
        Thomas BraunT
        Thomas BraunT
        @vsa sagte in NPM Problem:
        trotz Deiner Anleitung wird in /usr/local/bin/ installiert
        Das kann nicht sein.
          Hallo nochmals.
          Gerne hier mein Mitschnitt:
          pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ iobroker stop
          pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ sudo nano /etc/apt/sources.list.d/nodesource.list
          pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ sudo apt upgrade
          Paketaktualisierung (Upgrade) wird berechnet... Fertig
          Die folgenden Pakete werden aktualisiert (Upgrade):
            bluez nodejs
          2 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 23,6 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 135 kB Plattenplatz zusätzlich benutzt.
          Möchten Sie fortfahren? [J/n]
          Holen:1 http://archive.raspberrypi.org/debian buster/main armhf bluez armhf 5.50-1.2~deb10u2+rpt1 [770 kB]
          Holen:2 https://deb.nodesource.com/node_14.x buster/main armhf nodejs armhf 14.17.6-deb-1nodesource1 [22,8 MB]
          Es wurden 23,6 MB in 2 s geholt (10,1 MB/s).
          Changelogs werden gelesen... Fertig
          (Lese Datenbank ... 61329 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../bluez_5.50-1.2~deb10u2+rpt1_armhf.deb ...
          Entpacken von bluez (5.50-1.2~deb10u2+rpt1) über (5.50-1.2~deb10u2) ...
          Vorbereitung zum Entpacken von .../nodejs_14.17.6-deb-1nodesource1_armhf.deb ...
          Entpacken von nodejs (14.17.6-deb-1nodesource1) über (14.17.5-1nodesource1) ...
          nodejs (14.17.6-deb-1nodesource1) wird eingerichtet ...
          bluez (5.50-1.2~deb10u2+rpt1) wird eingerichtet ...
          Trigger für systemd (241-7~deb10u8+rpi1) werden verarbeitet ...
          Trigger für man-db (2.8.5-2) werden verarbeitet ...
          Trigger für dbus (1.12.20-0+deb10u1) werden verarbeitet ...
          soweit so gut...
          nun weiter.
          pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ apt policy nodejs
          nodejs:
            Installiert:           14.17.6-deb-1nodesource1
            Versionstabelle:
           *** 14.17.6-deb-1nodesource1 500
          und jetzt die 14er Version installieren: (mit der 12er passiert das gleiche)
          pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ sudo apt reinstall nodejs=14.17.6-deb-1nodesource1
          0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 22,8 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
          Holen:1 https://deb.nodesource.com/node_14.x buster/main armhf nodejs armhf 14.17.6-deb-1nodesource1 [22,8 MB]
          Es wurden 22,8 MB in 2 s geholt (10.000 kB/s).
          (Lese Datenbank ... 61339 Dateien und Verzeichnisse sind derzeit installiert.)
          Entpacken von nodejs (14.17.6-deb-1nodesource1) über (14.17.6-deb-1nodesource1) ...
          Ergebnis ansehen:
          pi@ioBroker-RasPi4:/opt/iobroker/node_modules $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          /usr/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v14.17.6
          v14.17.5
          6.14.14
          Holen:1 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
          OK:2 https://deb.nodesource.com/node_14.x buster InRelease
          Holen:3 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
          OK:4 https://packages.grafana.com/enterprise/deb stable InRelease
          OK:5 http://raspbian.raspberrypi.org/raspbian buster InRelease
          OK:6 https://repos.influxdata.com/debian buster InRelease
          Holen:7 https://deb.nodesource.com/node_12.x buster/main armhf Packages [780 B]
          Holen:8 http://archive.raspberrypi.org/debian buster/main armhf Packages [378 kB]
          Es wurden 416 kB in 2 s geholt (185 kB/s).
          Alle Pakete sind aktuell.
          OK:3 https://packages.grafana.com/enterprise/deb stable InRelease
          OK:4 https://deb.nodesource.com/node_12.x buster InRelease
          OK:5 https://repos.influxdata.com/debian buster InRelease
          OK:6 https://deb.nodesource.com/node_14.x buster InRelease
          nodejs:
            Versionstabelle:
               12.22.6-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
          Gibt es etwas das ich übersehen haben könnte?
          VG vsa
            Hallo nochmals.
              bluez nodejs
            soweit so gut...
            nun weiter.
            nodejs:
              Versionstabelle:
            Ergebnis ansehen:
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v14.17.6
            v14.17.5
            6.14.14
            nodejs:
              Versionstabelle:
            VG vsa
            Thomas BraunT
            Thomas BraunT
            @vsa
            Ja, du löschst den Kram nicht aus dem falschen Verzeichnis raus.
            /usr/local/bin liegt früher im $PATH, deswegen wird eine dort liegende Version immer zuerst gefunden.
            Muss also weg von dort.
            Die v14.17.5 hast du mal irgendwie selber ins System geprügelt, die Version über apt wird schon richtig installiert. War sie schon immer. Hättest du gar nicht reinstallieren brauchen.
              @vsa
              Danke für die Aufklärung. Das hat geholfen. Ich habe nodejs deinstalliert und die Verzeichnisse aus /usr/local/bin herausgelöscht.
              Danach bin ich frisch mit Deiner Anleitung rangegangen. Jetzt liegt alles in /usr/bin/.
              Dennoch, beim versuch iobroker zu updaten:
              pi@ioBroker-RasPi4:/opt/iobroker $ iobroker upgrade
              This upgrade of "vw-connect" will introduce the following changes:
              -> 0.0.40:
              add climate v3 for newer cars. Add Powerpass and Seat Elli
              NPM version: 6.14.15
              npm ERR!     /home/iobroker/.npm/_logs/2021-08-31T21_18_53_993Z-debug.log
              Den Adapter tr-064 hatte ich ja schon rausgeschmissen.... :-/
              VG vsa
                -> 0.0.40:
                VG vsa
                Thomas BraunT
                Thomas BraunT
                @vsa Schau in der package.json nach dem Eintrag. Vorher Kopie anfertigen und ioBroker stoppen.
                Ich vermute, man kann den Eintrag dann löschen.
                Kannst aber auch mal nach der Meldung suchen, die hatten wir schonmal hier im Forum.
                  Vielen herzlichen Dank! Wieder einiges dazugelernt.
                  Ich habe den entsprechenden Eintrag entfernt, danach kamen noch gyp ERR! Auch einen Tipp von Dir folgend habe ich den Terminal Adapter deinstalliert. Jetzt kann ich wieder updaten!
                  Jetzt kann ich wieder ruhig schlafen ;-)
                  VG vsa
                  1.4m
