  4. iobroker sendet 1000.... warnmeldungen...
101 Beiträge 5 Kommentatoren 12.3k Aufrufe 3 Beobachtet
    @einstein2002
    Rückmeldung in der Konsole sah wie aus?
    Gerne wieder komplett, dann sehe ich besser wo du da gerade herumhüpfst.
    Einstein2002
    #41
    @thomas-braun jetzt ist kein js mehr drauf
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
    • E Einstein2002
      #42
      @einstein2002
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker start
      E 1 Antwort Letzte Antwort
        @einstein2002
        cd /opt/iobroker
        iobroker start
        Einstein2002
        #43
        @thomas-braun sagte in iobroker sendet 1000.... warnmeldungen...:
        iobroker start
        Läuft wieder, aber wieder mit der 3.3.10
        michael@michael-Macmini:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        > iobroker.js-controller@3.3.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.12
        > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../src/unix_dgram.cc:5:
        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         2298 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        In file included from ../../nan/nan.h:54,
        ../src/unix_dgram.cc: At global scope:
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
          736 |       (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
          770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
          404 | NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
          CXX(target) Release/obj.target/diskusage/src/main.o
        In file included from ../src/main.cpp:3:
        ../src/main.cpp: At global scope:
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
           42 | NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
        > iobroker.js-controller@3.3.10 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/system updated
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
        > node install.js
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@3.3.10
        added 188 packages from 155 contributors in 32.179s
        78 packages are looking for funding
          run `npm fund` for details
        michael@michael-Macmini:/opt/iobroker$ iobroker -v
        3.3.10
        michael@michael-Macmini:/opt/iobroker$ iobroker start
        • E Einstein2002
          iobroker start
          > node-gyp rebuild
          > node rebuild.js
          > node-gyp rebuild
          > node install.js
          3.3.10
          Einstein2002
          #44
          @einstein2002 aber es sind schon deutlich weniger Meldungen, jetzt haben die sonoff_pow adapter noch irgendwelche probleme
          Da geh ich morgen früh ran, ist ja schon später... Dir Danke ich für die Mühe und Hilfe. Kann ich Dir was gutes tun??
          Grüße Michael
          • E Einstein2002
            @einstein2002 und ein weiterer versuch sieht dann so aus...
            michael@michael-Macmini:~$ iobroker repo set stable
            internal/modules/cjs/loader.js:818
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                at internal/main/run_main_module.js:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            michael@michael-Macmini:~$ cd /opt/iobroker
            michael@michael-Macmini:/opt/iobroker$ iobroker repo set stable
              throw err;
              requireStack: []
            HomoranH Offline
            HomoranH Offline
            #45
            @einstein2002 sagte in iobroker sendet 1000.... warnmeldungen...:
            @Thomas-Braun
            kann das sein, dass das repo bei @Einstein2002 anders heisst?
            Thomas BraunT E 2 Antworten Letzte Antwort
              @Thomas-Braun
              #46
              Das könnte sein .
              iobroker repo list
              anschauen.
                Das könnte sein .
                iobroker repo list
                anschauen.
                Einstein2002
                #47
                iobroker repo list
                michael@michael-Macmini:/opt/iobroker$ iobroker repo list
                stable      : http://download.iobroker.net/sources-dist.json
                beta        : http://download.iobroker.net/sources-dist-latest.json
                Active repo: stable
                  @Thomas-Braun
                  Einstein2002
                  #48
                  @homoran Denke das ist richtig, oder?
                  • E Einstein2002
                    #49
                    @einstein2002
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
                    • E Einstein2002
                      HomoranH Offline
                      HomoranH Offline
                      #50
                      dann mach da mal ein sudo -H -u iobroker npm install iobroker.js-controller@3.2.16 draus
                      aber in /opt/iobroker!
                        @einstein2002
                        cd /opt/iobroker
                        Einstein2002
                        #51
                        Das war es. Sieht doch soweit erstmal gut aus.
                        Repository "stable" set as active.
                        Active repo: stable
                        michael@michael-Macmini:/opt/iobroker$ iobroker stop
                        michael@michael-Macmini:/opt/iobroker$ iobroker update
                        Used repository: stable
                        hash unchanged, use cached sources
                        update done
                        Adapter    "admin"         : 4.2.1    , installed 5.0.31
                        Adapter    "alexa2"        : 3.8.1    , installed 3.9.0
                        Adapter    "backitup"      : 2.1.6    , installed 2.1.11
                        Adapter    "broadlink2"    : 2.0.3    , installed 2.1.5
                        Adapter    "cloud"         : 4.0.10   , installed 4.0.11
                        Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                        Adapter    "device-reminder": 1.2.1   , installed 1.2.1
                        Adapter    "discovery"     : 2.6.1    , installed 2.6.3
                        Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
                        Adapter    "dwd"           : 2.7.5    , installed 2.7.5
                        Adapter    "fb-checkpresence": 1.1.0   , installed 1.1.4
                        Adapter    "feiertage"     : 1.0.17   , installed 1.0.20
                        Adapter    "flot"          : 1.10.6   , installed 1.10.6
                        Adapter    "history"       : 1.9.12   , installed 1.9.13
                        Adapter    "hm-rpc"        : 1.14.37  , installed 1.14.38
                        Adapter    "ical"          : 1.7.4    , installed 1.9.3
                        Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                        Adapter    "info"          : 1.7.14   , installed 1.7.15
                        Adapter    "iot"           : 1.8.16   , installed 1.8.22
                        Adapter    "javascript"    : 5.1.3    , installed 5.1.3
                        Controller "js-controller" : 3.2.16   , installed 3.3.10
                        Adapter    "milight"       : 0.3.6    , installed 0.4.0
                        Adapter    "milight-smart-light": 1.2.0   , installed 1.2.1
                        Adapter    "mqtt"          : 2.3.5    , installed 2.4.0
                        Adapter    "nina"          : 0.0.24   , installed 0.0.24
                        Adapter    "openligadb"    : 1.1.0    , installed 1.2.0
                        Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                        Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
                        Adapter    "shelly"        : 4.0.7    , installed 4.0.8
                        Adapter    "simple-api"    : 2.5.3    , installed 2.6.1
                        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                        Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
                        Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                        Adapter    "sql"           : 1.15.7   , installed 1.15.7
                        Adapter    "tankerkoenig"  : 2.0.5    , installed 2.0.12
                        Adapter    "telegram"      : 1.8.1    , installed 1.8.1
                        Adapter    "text2command"  : 2.0.7    , installed 2.0.7
                        Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
                        Adapter    "trashschedule" : 1.1.1    , installed 1.1.3
                        Adapter    "unifi"         : 0.5.8    , installed 0.5.9
                        Adapter    "vis"           : 1.3.8    , installed 1.3.9
                        Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                        Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                        Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                        Adapter    "weatherunderground": 3.3.0   , installed 3.3.0
                        Adapter    "web"           : 3.4.0    , installed 3.4.1
                        Adapter    "yahka"         : 0.12.0   , installed 0.13.1
                        michael@michael-Macmini:/opt/iobroker$ cd /opt/iobroker
                        michael@michael-Macmini:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
                        [sudo] Passwort für michael:
                        > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                        > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                        + iobroker.js-controller@3.2.16
                        removed 20 packages and updated 6 packages in 43.486s
                        74 packages are looking for funding
                        3.2.16
                        • E Einstein2002
                          Active repo: stable
                          update done
                          3.2.16
                          HomoranH Offline
                          HomoranH Offline
                          #52
                          vor allem soehst du jetzt, wo du überall Betaversionen hast und auf welche version du downgraden solltest
                          E 3 Antworten Letzte Antwort
                            Einstein2002
                            schrieb am zuletzt editiert von Einstein2002
                            #53
                            @homoran Nur wieso komme ich denn auf die Beta?? Ich habe in letzter Zeit nur dann ein Update auf die Adapter gemacht wenn es mir vorgeschlagen worden ist.
                            Da stand nix von wegen Beta. Oder irre ich mich?? Ich habe schon länger nix über Github gemacht
                              Einstein2002
                              #54
                              @homoran allein beim admin kommt fast täglich ein neues update, dachte immer das sei die freigegebene Version
                                Einstein2002
                                #55
                                @homoran die letzte frage für heute: wie kann ich denn downgraden? was muss ich eingeben oder muß ich alle adapter löschen und neu installieren?
                                • E Einstein2002
                                  #56
                                  @einstein2002
                                  Nein, das war die Beta-Quelle.
                                  In stable ist es bedeutend ruhiger
                                    @einstein2002
                                    Einstein2002
                                    #57
                                    @thomas-braun okay
                                    • E Einstein2002
                                      #58
                                      @einstein2002
                                      iobroker upgrade adapter@versionsnummer
                                        @einstein2002
                                        Einstein2002
                                        #59
                                        Ihr seid super, vielen Dank und noch einen schönen Abend. Hab ja jetzt ne weile zu tun.
                                        Lasst es mich wissen wenn ich euch ne kleinigkeit über paypal zukommen lassen kann.
                                        Ist ja doch ne lange Sitzung geworden. Und ich bin noch ganz am Anfang. Ist alles nicht so leicht.....
                                        Dankeschön
                                        • E Einstein2002
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #60
                                          Du hast vermutlich hier einmal die Einstellung von stable auf beta geändert und dann bekommst du auch die neuen Beta Versionen der Adapter angeboten. Bleib hier auf "stable" und du bist auf der sicheren Seite :-)
