  4. iobroker sendet 1000.... warnmeldungen...
101 Beiträge 5 Kommentatoren 12.3k Aufrufe 3 Beobachtet
  • E Einstein2002
    @homoran Denke das ist richtig, oder?
    @einstein2002
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
    E 1 Antwort Letzte Antwort
    • E Einstein2002
      @einstein2002 sagte in iobroker sendet 1000.... warnmeldungen...:
      dann mach da mal ein sudo -H -u iobroker npm install iobroker.js-controller@3.2.16 draus
      aber in /opt/iobroker!
        @einstein2002
        cd /opt/iobroker
        Einstein2002
        @thomas-braun sagte in iobroker sendet 1000.... warnmeldungen...:
        Das war es. Sieht doch soweit erstmal gut aus.
        michael@michael-Macmini:/opt/iobroker$ iobroker repo set stable
        Repository "stable" set as active.
        stable      : http://download.iobroker.net/sources-dist.json
        beta        : http://download.iobroker.net/sources-dist-latest.json
        Active repo: stable
        michael@michael-Macmini:/opt/iobroker$ iobroker stop
        michael@michael-Macmini:/opt/iobroker$ iobroker update
        Used repository: stable
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 4.2.1    , installed 5.0.31
        Adapter    "alexa2"        : 3.8.1    , installed 3.9.0
        Adapter    "backitup"      : 2.1.6    , installed 2.1.11
        Adapter    "broadlink2"    : 2.0.3    , installed 2.1.5
        Adapter    "cloud"         : 4.0.10   , installed 4.0.11
        Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
        Adapter    "device-reminder": 1.2.1   , installed 1.2.1
        Adapter    "discovery"     : 2.6.1    , installed 2.6.3
        Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
        Adapter    "dwd"           : 2.7.5    , installed 2.7.5
        Adapter    "fb-checkpresence": 1.1.0   , installed 1.1.4
        Adapter    "feiertage"     : 1.0.17   , installed 1.0.20
        Adapter    "flot"          : 1.10.6   , installed 1.10.6
        Adapter    "history"       : 1.9.12   , installed 1.9.13
        Adapter    "hm-rpc"        : 1.14.37  , installed 1.14.38
        Adapter    "ical"          : 1.7.4    , installed 1.9.3
        Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
        Adapter    "info"          : 1.7.14   , installed 1.7.15
        Adapter    "iot"           : 1.8.16   , installed 1.8.22
        Adapter    "javascript"    : 5.1.3    , installed 5.1.3
        Controller "js-controller" : 3.2.16   , installed 3.3.10
        Adapter    "milight"       : 0.3.6    , installed 0.4.0
        Adapter    "milight-smart-light": 1.2.0   , installed 1.2.1
        Adapter    "mqtt"          : 2.3.5    , installed 2.4.0
        Adapter    "nina"          : 0.0.24   , installed 0.0.24
        Adapter    "openligadb"    : 1.1.0    , installed 1.2.0
        Adapter    "openweathermap": 0.1.0    , installed 0.1.0
        Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
        Adapter    "shelly"        : 4.0.7    , installed 4.0.8
        Adapter    "simple-api"    : 2.5.3    , installed 2.6.1
        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
        Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
        Adapter    "sonos"         : 2.1.1    , installed 2.1.1
        Adapter    "sql"           : 1.15.7   , installed 1.15.7
        Adapter    "tankerkoenig"  : 2.0.5    , installed 2.0.12
        Adapter    "telegram"      : 1.8.1    , installed 1.8.1
        Adapter    "text2command"  : 2.0.7    , installed 2.0.7
        Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
        Adapter    "trashschedule" : 1.1.1    , installed 1.1.3
        Adapter    "unifi"         : 0.5.8    , installed 0.5.9
        Adapter    "vis"           : 1.3.8    , installed 1.3.9
        Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
        Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
        Adapter    "weatherunderground": 3.3.0   , installed 3.3.0
        Adapter    "web"           : 3.4.0    , installed 3.4.1
        Adapter    "yahka"         : 0.12.0   , installed 0.13.1
        michael@michael-Macmini:/opt/iobroker$ cd /opt/iobroker
        michael@michael-Macmini:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
        [sudo] Passwort für michael:
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.12
        > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/system updated
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@3.2.16
        removed 20 packages and updated 6 packages in 43.486s
        74 packages are looking for funding
          run `npm fund` for details
        michael@michael-Macmini:/opt/iobroker$ iobroker start
        michael@michael-Macmini:/opt/iobroker$ iobroker -v
        3.2.16
        Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
        Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
        • E Einstein2002
          Active repo: stable
          update done
          3.2.16
          vor allem soehst du jetzt, wo du überall Betaversionen hast und auf welche version du downgraden solltest
          E 3 Antworten Letzte Antwort
            Einstein2002
            schrieb am zuletzt editiert von Einstein2002
            @homoran Nur wieso komme ich denn auf die Beta?? Ich habe in letzter Zeit nur dann ein Update auf die Adapter gemacht wenn es mir vorgeschlagen worden ist.
            Da stand nix von wegen Beta. Oder irre ich mich?? Ich habe schon länger nix über Github gemacht
              Einstein2002
              @homoran allein beim admin kommt fast täglich ein neues update, dachte immer das sei die freigegebene Version
                Einstein2002
                @homoran die letzte frage für heute: wie kann ich denn downgraden? was muss ich eingeben oder muß ich alle adapter löschen und neu installieren?
                • E Einstein2002
                  @einstein2002
                  Nein, das war die Beta-Quelle.
                  In stable ist es bedeutend ruhiger
                    @einstein2002
                    Einstein2002
                    @thomas-braun okay
                    • E Einstein2002
                      @einstein2002
                      iobroker upgrade adapter@versionsnummer
                        @einstein2002
                        Einstein2002
                        Ihr seid super, vielen Dank und noch einen schönen Abend. Hab ja jetzt ne weile zu tun.
                        Lasst es mich wissen wenn ich euch ne kleinigkeit über paypal zukommen lassen kann.
                        Ist ja doch ne lange Sitzung geworden. Und ich bin noch ganz am Anfang. Ist alles nicht so leicht.....
                        Dankeschön
                        • E Einstein2002
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          Du hast vermutlich hier einmal die Einstellung von stable auf beta geändert und dann bekommst du auch die neuen Beta Versionen der Adapter angeboten. Bleib hier auf "stable" und du bist auf der sicheren Seite :-)
                          • FeuersturmF Feuersturm
                            Einstein2002
                            @feuersturm ist und war eingestellt??? Erschreckend...
                            • E Einstein2002
                              @einstein2002 stable war da nicht die ganze Zeit eingestellt. Sonst hättest du dir nicht die Versionsstände eingehandelt.
                                Einstein2002
                                @thomas-braun ```
                                5725eab4-f9ba-4103-9b81-05174e649efb-grafik.png code_text
                                Ich hab da nichts umgestellt, ehrlich.
                                • E Einstein2002
                                  @thomas-braun ```
                                  @einstein2002 JETZT steht da stable drin. Das ist ja auch eben per Kommandozeile gesetzt worden.
                                  Da muss aber vorher Beta oder Latest drin gestanden haben. Denn sonst hättest du niemals diese Versionsstände in System.
                                    Einstein2002
                                    @thomas-braun Okay,
                                    dann hab ich das aber unbewusst umgestellt. Sorry.
                                    Ich glaub ich habe das nächste problem.....
                                    Oh Man ich könnte Kot...., jetzt sehe ich unter Instanzen nichts mehr, unter Adapter sind Instanzen installiert, werden nur nicht mehr angezeigt.
                                    • FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #66
                                      @einstein2002 Rufst du deinen ioBroker per http oder https auf?
                                      Hast du einmal deinen Browser Cache komplett geleert?
                                      Ist der Bereich unter Skripte auch so grau? Vor kurzem hatte ein anderer User ebenfalls das Verhalten, dass bei "Skripte" alles grau war (https://forum.iobroker.net/topic/45142/alle-skripte-verschwunden)
                                      • E Einstein2002
                                        @thomas-braun Okay,
                                        #67
                                        @einstein2002 Ich glaube da war kürzlich mal was mit 'von Beta zurück und die Instanzen sind nicht sichtbar'.
                                        Musst du mal suchen. Ich glaube im großen 'js-contoller 3.3 im beta'-Thread war es
                                          Einstein2002
                                          #68
                                          @feuersturm per http und ich nehme den Firefox, hab aber auch mal mit Edge versucht, gleiches Ergebnis.
