  4. iobroker sendet 1000.... warnmeldungen...
101 Beiträge 5 Kommentatoren 12.3k Aufrufe 3 Beobachtet
  • E Einstein2002
    @thomas-braun sagte in iobroker sendet 1000.... warnmeldungen...:
    iobroker start
    Läuft wieder, aber wieder mit der 3.3.10
    michael@michael-Macmini:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.js-controller@3.3.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.12
    > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     2298 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      736 |       (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
      770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
    > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
      CXX(target) Release/obj.target/diskusage/src/main.o
    In file included from ../src/main.cpp:3:
    ../src/main.cpp: At global scope:
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
    > iobroker.js-controller@3.3.10 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object _design/system updated
    > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
    > node scripts/postinstall
    > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
    > node install.js
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@3.3.10
    added 188 packages from 155 contributors in 32.179s
    78 packages are looking for funding
      run `npm fund` for details
    michael@michael-Macmini:/opt/iobroker$ iobroker -v
    3.3.10
    michael@michael-Macmini:/opt/iobroker$ iobroker start
    Einstein2002
    @einstein2002 aber es sind schon deutlich weniger Meldungen, jetzt haben die sonoff_pow adapter noch irgendwelche probleme
    Da geh ich morgen früh ran, ist ja schon später... Dir Danke ich für die Mühe und Hilfe. Kann ich Dir was gutes tun??
    Grüße Michael
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
    • E Einstein2002
      @einstein2002 und ein weiterer versuch sieht dann so aus...
      michael@michael-Macmini:~$ iobroker repo set stable
      internal/modules/cjs/loader.js:818
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      michael@michael-Macmini:~$ cd /opt/iobroker
      michael@michael-Macmini:/opt/iobroker$ iobroker repo set stable
        throw err;
        requireStack: []
      @einstein2002 sagte in iobroker sendet 1000.... warnmeldungen...:
      @Thomas-Braun
      kann das sein, dass das repo bei @Einstein2002 anders heisst?
      Thomas BraunT E 2 Antworten Letzte Antwort
        @Thomas-Braun
        Das könnte sein .
        iobroker repo list
        anschauen.
        E 1 Antwort Letzte Antwort
          Das könnte sein .
          iobroker repo list
          anschauen.
          Einstein2002
          iobroker repo list
          michael@michael-Macmini:/opt/iobroker$ iobroker repo list
          stable      : http://download.iobroker.net/sources-dist.json
          beta        : http://download.iobroker.net/sources-dist-latest.json
          Active repo: stable
            @Thomas-Braun
            Einstein2002
            @homoran Denke das ist richtig, oder?
            • E Einstein2002
              @einstein2002
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
              • E Einstein2002
                dann mach da mal ein sudo -H -u iobroker npm install iobroker.js-controller@3.2.16 draus
                aber in /opt/iobroker!
                  @einstein2002
                  cd /opt/iobroker
                  Einstein2002
                  Das war es. Sieht doch soweit erstmal gut aus.
                  Repository "stable" set as active.
                  Active repo: stable
                  michael@michael-Macmini:/opt/iobroker$ iobroker stop
                  michael@michael-Macmini:/opt/iobroker$ iobroker update
                  Used repository: stable
                  hash unchanged, use cached sources
                  update done
                  Adapter    "admin"         : 4.2.1    , installed 5.0.31
                  Adapter    "alexa2"        : 3.8.1    , installed 3.9.0
                  Adapter    "backitup"      : 2.1.6    , installed 2.1.11
                  Adapter    "broadlink2"    : 2.0.3    , installed 2.1.5
                  Adapter    "cloud"         : 4.0.10   , installed 4.0.11
                  Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                  Adapter    "device-reminder": 1.2.1   , installed 1.2.1
                  Adapter    "discovery"     : 2.6.1    , installed 2.6.3
                  Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
                  Adapter    "dwd"           : 2.7.5    , installed 2.7.5
                  Adapter    "fb-checkpresence": 1.1.0   , installed 1.1.4
                  Adapter    "feiertage"     : 1.0.17   , installed 1.0.20
                  Adapter    "flot"          : 1.10.6   , installed 1.10.6
                  Adapter    "history"       : 1.9.12   , installed 1.9.13
                  Adapter    "hm-rpc"        : 1.14.37  , installed 1.14.38
                  Adapter    "ical"          : 1.7.4    , installed 1.9.3
                  Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                  Adapter    "info"          : 1.7.14   , installed 1.7.15
                  Adapter    "iot"           : 1.8.16   , installed 1.8.22
                  Adapter    "javascript"    : 5.1.3    , installed 5.1.3
                  Controller "js-controller" : 3.2.16   , installed 3.3.10
                  Adapter    "milight"       : 0.3.6    , installed 0.4.0
                  Adapter    "milight-smart-light": 1.2.0   , installed 1.2.1
                  Adapter    "mqtt"          : 2.3.5    , installed 2.4.0
                  Adapter    "nina"          : 0.0.24   , installed 0.0.24
                  Adapter    "openligadb"    : 1.1.0    , installed 1.2.0
                  Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                  Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
                  Adapter    "shelly"        : 4.0.7    , installed 4.0.8
                  Adapter    "simple-api"    : 2.5.3    , installed 2.6.1
                  Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                  Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
                  Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                  Adapter    "sql"           : 1.15.7   , installed 1.15.7
                  Adapter    "tankerkoenig"  : 2.0.5    , installed 2.0.12
                  Adapter    "telegram"      : 1.8.1    , installed 1.8.1
                  Adapter    "text2command"  : 2.0.7    , installed 2.0.7
                  Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
                  Adapter    "trashschedule" : 1.1.1    , installed 1.1.3
                  Adapter    "unifi"         : 0.5.8    , installed 0.5.9
                  Adapter    "vis"           : 1.3.8    , installed 1.3.9
                  Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                  Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                  Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                  Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                  Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                  Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                  Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                  Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                  Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                  Adapter    "weatherunderground": 3.3.0   , installed 3.3.0
                  Adapter    "web"           : 3.4.0    , installed 3.4.1
                  Adapter    "yahka"         : 0.12.0   , installed 0.13.1
                  michael@michael-Macmini:/opt/iobroker$ cd /opt/iobroker
                  michael@michael-Macmini:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
                  [sudo] Passwort für michael:
                  > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                  + iobroker.js-controller@3.2.16
                  removed 20 packages and updated 6 packages in 43.486s
                  74 packages are looking for funding
                  3.2.16
                  • E Einstein2002
                    Active repo: stable
                    update done
                    3.2.16
                    vor allem soehst du jetzt, wo du überall Betaversionen hast und auf welche version du downgraden solltest
                    E 3 Antworten Letzte Antwort
                      Einstein2002
                      schrieb am zuletzt editiert von Einstein2002
                      @homoran Nur wieso komme ich denn auf die Beta?? Ich habe in letzter Zeit nur dann ein Update auf die Adapter gemacht wenn es mir vorgeschlagen worden ist.
                      Da stand nix von wegen Beta. Oder irre ich mich?? Ich habe schon länger nix über Github gemacht
                        Einstein2002
                        @homoran allein beim admin kommt fast täglich ein neues update, dachte immer das sei die freigegebene Version
                          Einstein2002
                          @homoran die letzte frage für heute: wie kann ich denn downgraden? was muss ich eingeben oder muß ich alle adapter löschen und neu installieren?
                          • E Einstein2002
                            @einstein2002
                            Nein, das war die Beta-Quelle.
                            In stable ist es bedeutend ruhiger
                              @einstein2002
                              Einstein2002
                              @thomas-braun okay
                              • E Einstein2002
                                @einstein2002
                                iobroker upgrade adapter@versionsnummer
                                  @einstein2002
                                  Einstein2002
                                  Ihr seid super, vielen Dank und noch einen schönen Abend. Hab ja jetzt ne weile zu tun.
                                  Lasst es mich wissen wenn ich euch ne kleinigkeit über paypal zukommen lassen kann.
                                  Ist ja doch ne lange Sitzung geworden. Und ich bin noch ganz am Anfang. Ist alles nicht so leicht.....
                                  Dankeschön
                                  • E Einstein2002
                                    FeuersturmF Offline
                                    FeuersturmF Offline
                                    Feuersturm
                                    Du hast vermutlich hier einmal die Einstellung von stable auf beta geändert und dann bekommst du auch die neuen Beta Versionen der Adapter angeboten. Bleib hier auf "stable" und du bist auf der sicheren Seite :-)
                                    • FeuersturmF Feuersturm
                                      Einstein2002
                                      @feuersturm ist und war eingestellt??? Erschreckend...
                                      • E Einstein2002
                                        @einstein2002 stable war da nicht die ganze Zeit eingestellt. Sonst hättest du dir nicht die Versionsstände eingehandelt.
                                          Einstein2002
                                          @thomas-braun ```
                                          5725eab4-f9ba-4103-9b81-05174e649efb-grafik.png code_text
                                          Ich hab da nichts umgestellt, ehrlich.
