  2. English
  3. ioBroker general
  4. Neato Botvac adapter - further development
Geplant Angeheftet Gesperrt Verschoben ioBroker general
68 Beiträge 12 Kommentatoren 27.1k Aufrufe 10 Beobachtet
  • C csp
    @petervoronov : One thing I see is your version number 1.0.4. I'm using 1.0.0 stable.
    How to get the 1.0.4? Maybe this already solves the issue.
    Thomas
    csp
    schrieb am zuletzt editiert von csp
    #41
    I was able to pull v1.0.4. But it fails as well. There is a difference though. It gets green and crashes afterwards.
    I'll now stay with my former version of js-controller and hope that the developer can fix it at some point.
    host.iobroker
    2023-09-07 17:33:49.629	error	instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    botvac.0
    2023-09-07 17:33:49.510	info	terminating
    botvac.0
    2023-09-07 17:33:49.074	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
    botvac.0
    2023-09-07 17:33:49.073	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
    botvac.0
    2023-09-07 17:33:49.069	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
    botvac.0
    2023-09-07 17:33:49.068	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
    botvac.0
    2023-09-07 17:33:49.008	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    botvac.0
    2023-09-07 17:33:49.006	info	terminating
    botvac.0
    2023-09-07 17:33:49.003	error	undefined is not a valid state value
    botvac.0
    2023-09-07 17:33:49.003	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17 at Robot.<anonymous> (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17) at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17 at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45 at <anonymous> at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    botvac.0
    2023-09-07 17:33:49.002	error	unhandled promise rejection: undefined is not a valid state value
    botvac.0
    2023-09-07 17:33:49.001	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    botvac.0
    2023-09-07 17:33:48.994	error	undefined is not a valid state value
    botvac.0
    2023-09-07 17:33:48.993	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17 at Robot.<anonymous> (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17) at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17 at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45 at <anonymous> at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    botvac.0
    2023-09-07 17:33:48.991	error	unhandled promise rejection: undefined is not a valid state value
    botvac.0
    2023-09-07 17:33:48.990	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    botvac.0
    2023-09-07 17:33:47.677	warn	Device"unten" with id: unten is not exists in cloud any more!
    botvac.0
    2023-09-07 17:33:46.740	info	devices found: 2
    botvac.0
    2023-09-07 17:33:44.228	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 5.0.12
    P 1 Antwort Letzte Antwort
    • C csp
      host.iobroker
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      botvac.0
      PeterVoronov
      #42
      @csp If you have time for it - please try start 1.0.4 version with debug log.
      Other option - you can share via PM your credentials - and I will try to find a time to look for the solution.
      C 1 Antwort Letzte Antwort
      • P PeterVoronov
        csp
        #43
        @petervoronov
        this is with JS 4.0.24:
        Later I can try to upgrade and check again
        botvac.0
        2023-09-08 08:30:20.179	debug	get schedule {"enabled":false,"events":[]}
        botvac.0
        2023-09-08 08:30:20.174	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:30:20.173	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:30:20.151	info	undefined is not a valid state value for id "botvac.0.unten.status.canPause"
        botvac.0
        2023-09-08 08:30:20.150	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"unten","_serial":"OPS39718-F045DA6FF249","_secret":"D0E3BFDA3824F493627EE28D882CE4963BF6A0A112FEF9CB0EDC7C0E7E273ADA74F0D7DFD29510271AA4E69BB72CBA100410604DAEBF66E611D052A75502373BE1A61A12D177E4FE94F8369B63BCF3DA76E2C481D5AC29EBAEC36BB0C9A080E501F23A01A81485F1F59F526ACBCC376FBDDF97F9E23692CF1D9A35D19117F48B","_token":"Token token=77962ed80b7e7e2c9898ea76ad40d9c3","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"isBinFull":false,"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":null,"state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"meta":{"modelName":"BotVacD5Connected","firmware":"4.5.3-189"}}
        botvac.0
        2023-09-08 08:30:20.093	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:30:20.091	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:30:20.045	info	undefined is not a valid state value for id "botvac.0.obergeschoss.status.canPause"
        botvac.0
        2023-09-08 08:30:20.042	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"obergeschoss","_serial":"OPS36118-F045DA70530D","_secret":"AB23FB0FDE9112F5DA12884631EC2C3A2A89E6F056C9C3E41EF3E616CB0C9747E5DB596626D3BB1581D0F71D6C2058E87D234DACE2485D297F3B8716242BF614D06DB2574BF401C273467B7A45701B91DDE7BEE7444E222AF8337B81214BC0BFF8031D83789CCD1077016184F9EC2D193E9B115D3A89CB0A37AC908498CB0D13","_token":"Token token=77962ed80b7e7e2c9898ea76ad40d9c3","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"isBinFull":true,"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":"dustbin_full","state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"meta":{"modelName":"BotVacD7Connected","firmware":"4.5.3-189"}}
        botvac.0
        2023-09-08 08:30:20.012	debug	get schedule {"type":1,"enabled":false,"events":[]}
        botvac.0
        2023-09-08 08:30:18.831	warn	Device"unten" with id: unten is not exists in cloud any more!
        botvac.0
        2023-09-08 08:30:18.313	info	devices found: 2
        botvac.0
        2023-09-08 08:30:15.559	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 4.0.24
        botvac.0
        2023-09-08 08:30:10.069	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        botvac.0
        2023-09-08 08:30:10.068	info	terminating
        botvac.0
        2023-09-08 08:30:10.067	info	Got terminate signal TERMINATE_YOURSELF
        botvac.0
        2023-09-08 08:29:38.719	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:29:38.718	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:29:38.707	info	undefined is not a valid state value for id "botvac.0.obergeschoss.status.canPause"
        botvac.0
        2023-09-08 08:29:38.706	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"obergeschoss","_serial":"OPS36118-F045DA70530D","_secret":"AB23FB0FDE9112F5DA12884631EC2C3A2A89E6F056C9C3E41EF3E616CB0C9747E5DB596626D3BB1581D0F71D6C2058E87D234DACE2485D297F3B8716242BF614D06DB2574BF401C273467B7A45701B91DDE7BEE7444E222AF8337B81214BC0BFF8031D83789CCD1077016184F9EC2D193E9B115D3A89CB0A37AC908498CB0D13","_token":"Token token=37c8b0e205312639b061254cedc49131","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"isBinFull":true,"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":"dustbin_full","state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"meta":{"modelName":"BotVacD7Connected","firmware":"4.5.3-189"}}
        botvac.0
        2023-09-08 08:29:38.649	debug	get schedule {"type":1,"enabled":false,"events":[]}
        botvac.0
        2023-09-08 08:29:38.588	debug	get schedule {"enabled":false,"events":[]}
        botvac.0
        2023-09-08 08:29:38.570	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:29:38.566	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
        botvac.0
        2023-09-08 08:29:38.541	info	undefined is not a valid state value for id "botvac.0.unten.status.canPause"
        botvac.0
        2023-09-08 08:29:38.538	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"unten","_serial":"OPS39718-F045DA6FF249","_secret":"D0E3BFDA3824F493627EE28D882CE4963BF6A0A112FEF9CB0EDC7C0E7E273ADA74F0D7DFD29510271AA4E69BB72CBA100410604DAEBF66E611D052A75502373BE1A61A12D177E4FE94F8369B63BCF3DA76E2C481D5AC29EBAEC36BB0C9A080E501F23A01A81485F1F59F526ACBCC376FBDDF97F9E23692CF1D9A35D19117F48B","_token":"Token token=37c8b0e205312639b061254cedc49131","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"isBinFull":false,"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":null,"state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"meta":{"modelName":"BotVacD5Connected","firmware":"4.5.3-189"}}
        botvac.0
        2023-09-08 08:29:37.237	warn	Device"unten" with id: unten is not exists in cloud any more!
        botvac.0
        2023-09-08 08:29:36.792	info	devices found: 2
        botvac.0
        2023-09-08 08:29:34.330	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 4.0.24
        • C csp
          @petervoronov
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          botvac.0
          PeterVoronov
          schrieb am zuletzt editiert von PeterVoronov
          #44
          @csp I made a pull request to fix this exact issue.
          I don't know how fast it will be applied ...
          You can try to install it from my fork - https://github.com/PeterVoronov/ioBroker.botvac/tree/patch-1
          In Adapter tab you have to enble expert mode, select custom install and select install from url
          Pedder007P mcm1957M 2 Antworten Letzte Antwort
          • P PeterVoronov
            Pedder007P Online
            Pedder007P Online
            Pedder007
            schrieb am zuletzt editiert von Pedder007
            #45
            @petervoronov Hi and thanks!
            Had the same problem und fixed it with the patch-link 👍
            Edit:
            But recognized that it causes some warnings now, recurring in frequence of 1 minute:
            botvac.0
            2023-09-15 12:46:06.971	warn	State value to set for "botvac.0.Freddi.commands.spotHeight" has value "0" less than min "100"
            botvac.0
            2023-09-15 12:46:06.970	warn	State value to set for "botvac.0.Freddi.commands.spotWidth" has value "0" less than min "100"
            Tried to set the objects manually to '100', but they are overwritten by the machine's data after a minute.
            Okay, the minute was my polling intervall ;-)
            Pedder
            All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
            Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
            Under construction: Smart-WoMo auf Raspi4
            • P PeterVoronov
              mcm1957M Online
              mcm1957M Online
              mcm1957
              #46
              @petervoronov said in Neato Botvac adapter - further development:
              Thanks for the PR
              The adapter has been moved to iobroker-community-adapters recently. I'm currently trying to get it to the ciurrent level of infrastructure (standard github based tests, release and deploy scripts, update dependencies - NO planned code changes).
              I've released a alpha version incorporating most changes (2.0.0-alpha.0) installing via github and as npm - but not yet listes at repositories.
              I would be glad to get some feedback if I did not break things and the code works like the mentioned branch level above.
              mcm1957
              P.S: Feel free to open a issue at botvac rep if I miss any answer here
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              JohGreJ 1 Antwort Letzte Antwort
              • mcm1957M mcm1957
                Thanks for the PR
                mcm1957
                JohGreJ Offline
                JohGreJ Offline
                JohGre
                #47
                @mcm57 hi, have installed the 2.0 alpha today afternoon and no errors. Only some warnings but as i read i can ignore them.
                2023-09-18 18:51:00.735  - warn: botvac.0 (53528) State value to set for "botvac.0.Keller.commands.spotWidth" has value "0" less than min "100"
                2023-09-18 18:51:00.736  - warn: botvac.0 (53528) State value to set for "botvac.0.Keller.commands.spotHeight" has value "0" less than min "100"
                2023-09-18 18:51:00.738  - warn: botvac.0 (53528) State value to set for "botvac.0.Erdgeschoss.commands.spotWidth" has value "0" less than min "100"
                2023-09-18 18:51:00.739  - warn: botvac.0 (53528) State value to set for "botvac.0.Erdgeschoss.commands.spotHeight" has value "0" less than min "100"
                2023-09-18 18:51:00.741  - warn: botvac.0 (53528) State value to set for "botvac.0.Obergeschoss.commands.spotWidth" has value "0" less than min "100"
                2023-09-18 18:51:00.742  - warn: botvac.0 (53528) State value to set for "botvac.0.Obergeschoss.commands.spotHeight" has value "0" less than min "100"
                nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                • JohGreJ JohGre
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #48
                  @johgre said in Neato Botvac adapter - further development:
                  Danke für das Feeback.
                  Ich werde dann mal eine 2.0.0 ins latest schicken.
                  Bezüglich der Warnings erstell bitte ein issue und falls irgendwelche Infos bekannt wann diese Meldungen auftreten, bitte dazu scheiben. Detto bitte die verwendeten Versionen (Dapter, js-controller, ...)
                  Aus Zeitgründen kann ich nicht zusagen ob / wann ich was tun kann. Aber wir sollten die Warnings nicht unter den Teppich kehren.
                  Sorry, I missed that this topic is located at english forum - so english text is delivered lately:
                  I will release a 2.0.0 for latest
                  In regard to warnings please create a issue and add infos if some environment is known which causes these warnings. Please add the related versions too (adapter, js-controller)
                  Du to time limitation I cannot promise any timeframe to check.
                  • mcm1957M mcm1957
                    JohGreJ Offline
                    JohGreJ Offline
                    JohGre
                    #49
                    @mcm57 zu dem Thema gibts schon ein (älteres) Issue
                    js-controller 5.0.12
                    botvac-adapter 2.0 alpha
                    https://github.com/iobroker-community-adapters/ioBroker.botvac/issues/29
                    • JohGreJ JohGre
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #50
                      @johgre
                      Danke.
                      2.0.0 ist auf dem Weg ins stable latest (natürlich). Hab noch diverse Dinge angepasst da der Adapter in den community Bereich übersiedelt ist.
                      2.0.0 sollte ab Morgen im latest sein. Sollten Probleme damit auftreten, bitte mich ev. zusätzlich pingen wenn ich ein post übersehe
                      Sorry missie english root
                      2.0.0 is on the way to latest. I've adjusted several things due to migration of adapter into iobroker-community-adapters.
                      2.0.0 should be available at latest tomorrow. If any problems occure, please ping me if I miss a posting.
                      • mcm1957M mcm1957
                        @johgre
                        Danke.
                        JohGreJ Offline
                        JohGreJ Offline
                        JohGre
                        schrieb am zuletzt editiert von JohGre
                        #51
                        @mcm57 Hallo,
                        plötzlich heute morgen hat der Adapter Fehler geworfen und ist in den Restart loop gekommen und ist dann vom js-controller deaktiviert worden. Anbei die Info-Log aus dieser Zeit.
                        Was möglicherweise der Auslöser sein könnte ist, dass einer der Roboter nicht erreichbar ist. Steht in einem andern Haus und dort dürfte gerade das Internet nicht funktionieren. Aber kann das den Adapter niederreissen?
                        edit: Nachdem der Roboter wieder im Netz war ließ sich der Adapter wieder problemlos starten.
                        https://github.com/iobroker-community-adapters/ioBroker.botvac/issues/46
                        2023-09-19 08:01:00.704 - warn: botvac.0 (57835) could not update robot Turnverein Oben 2023-09-19 08:01:00.705 - warn: botvac.0 (57835) could not update robot Turnverein Oben 2023-09-19 08:01:00.709 - warn: botvac.0 (57835) Read-only state "botvac.0.Turnverein Oben.status.reachable" has been written without ack-flag with value "true" 2023-09-19 08:01:00.755 - warn: botvac.0 (57835) Read-only state "botvac.0.Turnverein Oben.status.reachable" has been written without ack-flag with value "true" 2023-09-19 08:02:14.587 - warn: botvac.0 (57835) could not update robot Turnverein Oben 2023-09-19 08:02:16.367 - info: botvac.0 (57835) devices found: 3 2023-09-19 08:02:16.395 - warn: botvac.0 (57835) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:02:16.635 - warn: botvac.0 (57835) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more! 2023-09-19 08:02:16.636 - warn: botvac.0 (57835) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:02:16.969 - warn: botvac.0 (57835) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more! 2023-09-19 08:02:16.969 - warn: botvac.0 (57835) Device"Keller" with id: Keller is not exists in cloud any more! 2023-09-19 08:02:16.969 - warn: botvac.0 (57835) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:02:17.201 - error: botvac.0 (57835) uncaught exception: Cannot read properties of undefined (reading 'getState') 2023-09-19 08:02:17.202 - error: botvac.0 (57835) TypeError: Cannot read properties of undefined (reading 'getState') at updateRobot (/opt/iobroker/node_modules/iobroker.botvac/main.js:476:11) at update (/opt/iobroker/node_modules/iobroker.botvac/main.js:467:9) at Immediate. (/opt/iobroker/node_modules/iobroker.botvac/main.js:456:25) at process.processImmediate (node:internal/timers:478:21) 2023-09-19 08:02:17.203 - error: botvac.0 (57835) Cannot read properties of undefined (reading 'getState') 2023-09-19 08:02:17.224 - info: botvac.0 (57835) terminating 2023-09-19 08:02:17.225 - warn: botvac.0 (57835) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-09-19 08:02:17.729 - info: botvac.0 (57835) terminating 2023-09-19 08:02:17.844 - error: host.VM-Slave instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-09-19 08:02:49.398 - info: botvac.0 (78675) starting. Version 2.0.0-alpha.1 (non-npm: iobroker-community-adapters/ioBroker.botvac#48bc291c4416ec4a5393cecf340ec39162a7138c) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 5.0.12 2023-09-19 08:02:51.991 - warn: botvac.0 (78675) could not update robot Turnverein Oben 2023-09-19 08:02:54.176 - info: botvac.0 (78675) devices found: 3 2023-09-19 08:02:54.209 - warn: botvac.0 (78675) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:02:54.558 - warn: botvac.0 (78675) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more! 2023-09-19 08:02:54.559 - warn: botvac.0 (78675) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:02:54.826 - warn: botvac.0 (78675) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more! 2023-09-19 08:02:54.826 - warn: botvac.0 (78675) Device"Keller" with id: Keller is not exists in cloud any more! 2023-09-19 08:02:54.827 - warn: botvac.0 (78675) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:02:55.079 - error: botvac.0 (78675) uncaught exception: Cannot read properties of undefined (reading 'getState') 2023-09-19 08:02:55.080 - error: botvac.0 (78675) TypeError: Cannot read properties of undefined (reading 'getState') at updateRobot (/opt/iobroker/node_modules/iobroker.botvac/main.js:476:11) at update (/opt/iobroker/node_modules/iobroker.botvac/main.js:467:9) at Immediate. (/opt/iobroker/node_modules/iobroker.botvac/main.js:456:25) at process.processImmediate (node:internal/timers:478:21) 2023-09-19 08:02:55.081 - error: botvac.0 (78675) Cannot read properties of undefined (reading 'getState') 2023-09-19 08:02:55.109 - info: botvac.0 (78675) terminating 2023-09-19 08:02:55.110 - warn: botvac.0 (78675) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-09-19 08:02:55.611 - info: botvac.0 (78675) terminating 2023-09-19 08:02:55.735 - error: host.VM-Slave instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-09-19 08:03:27.330 - info: botvac.0 (78704) starting. Version 2.0.0-alpha.1 (non-npm: iobroker-community-adapters/ioBroker.botvac#48bc291c4416ec4a5393cecf340ec39162a7138c) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 5.0.12 2023-09-19 08:03:29.998 - warn: botvac.0 (78704) could not update robot Turnverein Oben 2023-09-19 08:03:32.148 - info: botvac.0 (78704) devices found: 3 2023-09-19 08:03:32.179 - warn: botvac.0 (78704) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:03:32.490 - warn: botvac.0 (78704) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more! 2023-09-19 08:03:32.491 - warn: botvac.0 (78704) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:03:32.800 - warn: botvac.0 (78704) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more! 2023-09-19 08:03:32.801 - warn: botvac.0 (78704) Device"Keller" with id: Keller is not exists in cloud any more! 2023-09-19 08:03:32.801 - warn: botvac.0 (78704) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more! 2023-09-19 08:03:33.006 - error: botvac.0 (78704) uncaught exception: Cannot read properties of undefined (reading 'getState') 2023-09-19 08:03:33.007 - error: botvac.0 (78704) TypeError: Cannot read properties of undefined (reading 'getState') at updateRobot (/opt/iobroker/node_modules/iobroker.botvac/main.js:476:11) at update (/opt/iobroker/node_modules/iobroker.botvac/main.js:467:9) at Immediate. (/opt/iobroker/node_modules/iobroker.botvac/main.js:456:25) at process.processImmediate (node:internal/timers:478:21) 2023-09-19 08:03:33.008 - error: botvac.0 (78704) Cannot read properties of undefined (reading 'getState') 2023-09-19 08:03:33.037 - info: botvac.0 (78704) terminating 2023-09-19 08:03:33.039 - warn: botvac.0 (78704) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-09-19 08:03:33.540 - info: botvac.0 (78704) terminating 2023-09-19 08:03:33.677 - error: host.VM-Slave instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-09-19 08:03:33.678 - warn: host.VM-Slave Do not restart adapter system.adapter.botvac.0 because restart loop detected
                        • JohGreJ JohGre
                          @mcm57 Hallo,
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #52
                          @johgre
                          Danke für issue und Info zu Situation bei Fehler.
                          Kenn den Adapter nur minimal und gab nal primär js controller 5 startbar gemacht.
                          Schau mir Problem an sobald ich zeit gabe. Log ist ja dabei.
                          Thanks for issue and information about the environment
                          I know this adapter ruther minimal and have only adjsutes as farr as it is required to start it with js-controller 5.
                          I'll look at the problem as soon as I have time
                          • mcm1957M mcm1957
                            @johgre
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #53
                            @petervoronov
                            Du hast das Problem wenn ichs richtig sehe schon gelöst
                            DANKE
                            Bitte erstell noch einen PR. (Hast zwar geschrieben, dass es den geben sollte aber der dürfte wo anders gelandet sein - ev. in deinem Main; im offiziellen Adapter repo seh ich keinen offenen PR.)
                            You have fixed the problem if I checked correctly.
                            Please add a PR. You have written at issue, that you did it, but it is not visible at the adapter repository .
                            • mcm1957M mcm1957
                              @petervoronov
                              DANKE
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              #54
                              @mcm57 please stay in english.
                              Persönlicher Support
                              Spenden -> paypal.me/J3YC33
                              HomoranH mcm1957M 2 Antworten Letzte Antwort
                              • Jey CeeJ Jey Cee
                                #55
                                @jey-cee wollte ich gerade schreiben!
                                oder darf ich es verschieben/abtrennen?
                                • Jey CeeJ Jey Cee
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #56
                                  @jey-cee said in Neato Botvac adapter - further development:
                                  Sorry,
                                  I missed that this topic is located in english forum. I've added translations
                                  Thanks for reminding me !
                                  @Homoran
                                  I suggest to leave it as it si. If a german discussion is desired by users, they should create a new german topic. I do not knwo that the preferred language for the users posting lately is.
                                  • mcm1957M mcm1957
                                    Sorry,
                                    @Homoran
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #57
                                    @PeterVoronov
                                    @JohGre
                                    @Pedder007
                                    As you posted lately, I would like to leave the decision whether to stay here (in english) or to move to german part to you. I do not know your prefrerred language. I can discuss / help in english and in german in (almost) the same way.
                                    Please feel free to open a german issue if you prefer but link the to topics in this case please.
                                    Pedder007P P 2 Antworten Letzte Antwort
                                    • JohGreJ JohGre
                                      @mcm57 Hallo,
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #58
                                      @johgre
                                      2.0.1 is on the way to latest.
                                      Thanks @PeterVoronov for the fix
                                      • mcm1957M mcm1957
                                        @PeterVoronov
                                        @JohGre
                                        @Pedder007
                                        Pedder007P Online
                                        Pedder007P Online
                                        Pedder007
                                        #59
                                        @mcm57 both languages are fine for me
                                        In my earlier 'Pimatic' times, I had to tackle all these things in English language and job-wise it's also normal for me ;-)
                                        Pedder
                                        • mcm1957M mcm1957
                                          @PeterVoronov
                                          @JohGre
                                          @Pedder007
                                          PeterVoronov
                                          #60
                                          @mcm57
                                          Excuse me, but I'm outside Germany, and can speak only English, except my local languages ...
                                          I will not push on other to speak only English, but, it can influence my understanding of the details ...
