  2. English
  3. ioBroker general
  4. Neato Botvac adapter - further development
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
68 Beiträge 12 Kommentatoren 28.6k Aufrufe 10 Beobachtet
  • P
    P
    PeterVoronov
    Hi
    Currently I'm trying to make some updates for the adapter.
    First step - it is editable schedule for the robot.
    Currently it available not for all robots, but, if somebody is ready to be a tester - I can continue.
    My D5 has a limited schedule functionality - only to set the time and day.
    For modes and boundaries - it's more or less ready, but I can't test...
    Next steps - it will be a maps and other things ...
    My PR with schedule is accepted by maintainer of the adapter ...
    So - if you have such devices and ready to test - you are welcomed.
    • P PeterVoronov
      Hi
      M
      M
      masgo
      @petervoronov Hi, I have a D7 and would like to help. What should I do?
      P 1 Antwort Letzte Antwort
      • M masgo
        P
        P
        PeterVoronov
        schrieb am zuletzt editiert von PeterVoronov
        @masgo Hi
        Excuse me for long silent.
        You can try to install dev version of adapter
        cd /opt/iobroker/
        iobroker url  https://github.com/PeterVoronov/ioBroker.botvac/tree/dev-1.0.4-1
        And check, what is new object's is created in channel schedule under the your robot device.
        Please share the result.
        Additionally you can try to edit startTime and mode.
        I'm not sure about BoundaryId's now.
        To revert it back:
        cd /opt/iobroker/
        iobroker upgrade iobroker.botvac@1.0.0
        And agree on downgrade.
        • B
          B
          bourton88
          schrieb am zuletzt editiert von bourton88
          Hey Peter,
          i tried to install your developer version of the botvac because in Version 1.0.0. i have the problem
          botvac.0	2021-05-23 06:54:16.262	warn	(7527) could not update robot Nono
          botvac.0	2021-05-23 06:54:15.832	info	(7527) devices found: 1
          Next step i´ve installed the developer version 1.0.4-1 from above and now i have another problem.
          botvac.0	2021-05-23 06:54:54.876	warn	(31575) Device"Nono" with id: Nono is not exists in cloud any more!
          botvac.0	2021-05-23 06:54:54.804	warn	(31575) can not create appropriate objects! Err = "something wrong with devices: {}"
          I tried also to delete the adapter in ioBroker and i reinstall the Botvac D5 conneceted also in the Neato app. Both didn´t help.
          Can you help me how can i fix this problem, at least in one of the versions?
          • B bourton88
            Hey Peter,
            P
            P
            PeterVoronov
            Пользователь @bourton88 написал в Neato Botvac adapter - further development:
            Hey Peter,
            Hi.
            It's strange, but I sometime faced with similar behavior.
            Please try stop the adapter, then do not use mobile app for some period of time, and after that try to start the adapter.
            If it is not help - will add some debugs ... may be it will help
            B 1 Antwort Letzte Antwort
            • P PeterVoronov
              Hey Peter,
              Hi.
              B
              B
              bourton88
              @petervoronov
              Ohh thats cool. Thanks!!
              I stopped the Adapter just for an hour and it works :-)
              I have another assumption because unfortunately i changed two things. I stopped the adapter AND i recognized that the clock-time from the running ioBroker instance was not set to the correct time. So i changed that as well.
              Maybe there is an Sync-Problem with the Neato-Server when the time doesn´t fit?
              • B bourton88
                @petervoronov
                P
                P
                PeterVoronov
                @petervoronov
                It the code for connection I not saw the time-sync recs or functions...
                But by my understanding, it is some limitation on the cloud for the connections in the same time from one account...
                • P PeterVoronov
                  @petervoronov
                  B
                  B
                  bourton88
                  @petervoronov
                  After a long time a had the same issue as before (see post from 23. Mai 2021, 10:11)
                  This time i checked your recommendation first but it doesn´t help. Then i checked the clock-time at my Server again and it doesn´t fit with the current time. So i changed the Server time back to the current time and it works well.
                  There must be a dependency to the time-sync.
                  • B bourton88
                    @petervoronov
                    Thomas BraunT
                    Thomas BraunT
                    Most Active Developer
                    @bourton88
                    Correct timezones in your system?
                    date && date -u
                      @bourton88
                      date && date -u
                      B
                      B
                      bourton88
                      My Server is a QNAP-NAS. So i just correct the time in the settings.
                      • B bourton88
                        D
                        D
                        danielmayer
                        schrieb am zuletzt editiert von danielmayer
                        @PeterVoronov
                        Hey Peter,
                        login is again (?) not working. I found this thread and installed dev-1.0.4-1, but log says "botvac.1 2023-07-15 11:51:19.359 warn login failed"
                        As such, no objects have been discovered/installed.
                        I recognize that there are several neato-plugins for several utilities (Smarthome), which seemed to have the same problem and needed some update work. So I suppose Neato changed their login procedure slightly.
                        Could you provide another update please? I have absolutely no competence in JS or PHP or any programming language...
                        Many thanks,
                        Daniel
                        • D danielmayer
                          @PeterVoronov
                          Hey Peter,
                          Many thanks,
                          Daniel
                          P
                          P
                          PeterVoronov
                          Hi @danielmayer .
                          Unfortunately my botvac broke a few years ago ... Currently I can't check the plugin.
                          At least - it can't find any robots, as it not logged in the Neato system.
                          That's why currently I have no possibility to help ....
                          But I have no any issues with login of plugin...
                          Only "no robots" message ...
                          C 1 Antwort Letzte Antwort
                          • P PeterVoronov
                            Hi @danielmayer .
                            C
                            C
                            csp
                            @petervoronov
                            Hi Peter,
                            the plugin was working fine for quite some time, but after I updated to the latest Node.js 18... it stopped working.
                            Reinstalling doesn't work either, I'm getting following error:
                            Any idea how to get it working again? It seems the adapter is no longer compatible...
                            Thanks,
                            Thomas
                            *host.iobroker
                            2023-08-31 08:54:49.650	info	Rebuild for adapter system.adapter.botvac.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            host.iobroker
                            2023-08-31 08:54:49.650	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.iobroker
                            2023-08-31 08:54:49.650	error	Caught by controller[0]: Node.js v18.17.1
                            host.iobroker
                            2023-08-31 08:54:49.650	error	Caught by controller[0]: }
                            host.iobroker
                            2023-08-31 08:54:49.650	error	Caught by controller[0]: ]
                            host.iobroker
                            2023-08-31 08:54:49.650	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                            host.iobroker
                            2023-08-31 08:54:49.650	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                            host.iobroker
                            2023-08-31 08:54:49.650	error	Caught by controller[0]: requireStack: [
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                            host.iobroker
                            2023-08-31 08:54:49.649	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                            host.iobroker
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: Require stack:
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: ^
                            host.iobroker
                            2023-08-31 08:54:49.648	error	Caught by controller[0]: throw err;
                            host.iobroker
                            2023-08-31 08:54:49.647	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                            host.iobroker
                            2023-08-31 08:54:49.444	info	instance system.adapter.botvac.0 started with pid 22369
                            host.iobroker
                            2023-08-31 08:54:49.370	info	iobroker npm-rebuild: exit 0
                            host.iobroker
                            2023-08-31 08:54:48.355	info	iobroker npm-rebuild: rebuilt dependencies successfullyRebuilding native modules done*
                            • C csp
                              @petervoronov
                              Hi Peter,
                              Thanks,
                              Thomas
                              *host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              host.iobroker
                              P
                              P
                              PeterVoronov
                              @csp
                              I have the same version of node - 18.17.1.
                              As I have no more botvac devices, I can only check the starting adapter and login to the api.
                              For me it's working. But when I made migration to node 18th, I wiped the node_modules directory fully.
                              I will not recommend to follow my way, as it required some additional understanding and manual work.
                              You can try at least to follow the recommendations from error log - execute "npm install --production" in adapter directory manually.
                              • P PeterVoronov
                                @csp
                                C
                                C
                                csp
                                @petervoronov I tried that already. It is a bit difficult, as I'm running it on Synology server in docker.
                                It did run through though, but not worked at the end.
                                Any idea on how to wipe the adapter fully? (Not all of course, just this one)
                                Happy to follow instructions.
                                Thomas
                                • C csp
                                  Thomas
                                  C
                                  C
                                  csp
                                  @csp I just did it again, no success.
                                  So I deinstalled the adapter and manually deleted the module folder.
                                  Reboot ioBroker.
                                  Reinstall bot vac adapter -> OK
                                  Putting credentials in and restart... -> same issue. ioBroker tries 3 times to rebuild and fails...
                                  host.iobroker
                                  2023-09-01 09:37:08.038	info	iobroker npm-rebuild: Rebuilding native modules ...
                                  host.iobroker
                                  2023-09-01 09:37:06.088	info	iobroker rebuild
                                  host.iobroker
                                  2023-09-01 09:37:06.088	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                  host.iobroker
                                  2023-09-01 09:37:06.087	info	system.adapter.botvac.0 will be rebuilt
                                  host.iobroker
                                  2023-09-01 09:37:06.087	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	Caught by controller[0]: Node.js v18.17.1
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	Caught by controller[0]: }
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	Caught by controller[0]: ]
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                                  host.iobroker
                                  2023-09-01 09:37:06.086	error	Caught by controller[0]: requireStack: [
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                  host.iobroker
                                  2023-09-01 09:37:06.085	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: Require stack:
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                                  host.iobroker
                                  2023-09-01 09:37:06.079	error	Caught by controller[0]: ^
                                  host.iobroker
                                  2023-09-01 09:37:06.078	error	Caught by controller[0]: throw err;
                                  host.iobroker
                                  2023-09-01 09:37:06.078	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                                  host.iobroker
                                  2023-09-01 09:37:02.812	info	instance system.adapter.botvac.0 started with pid 912
                                  host.iobroker
                                  2023-09-01 09:36:57.818	info	iobroker exit 0
                                  host.iobroker
                                  2023-09-01 09:36:56.009	info	iobroker host.iobroker object system.adapter.botvac.0 created
                                  host.iobroker
                                  2023-09-01 09:36:54.323	info	iobroker host.iobroker object system.adapter.botvac.0.logLevel created
                                  host.iobroker
                                  2023-09-01 09:36:53.946	info	iobroker host.iobroker object system.adapter.botvac.0.sigKill created
                                  host.iobroker
                                  2023-09-01 09:36:53.779	info	iobroker host.iobroker object system.adapter.botvac.0.eventLoopLag created
                                  host.iobroker
                                  2023-09-01 09:36:53.594	info	iobroker host.iobroker object system.adapter.botvac.0.outputCount created
                                  host.iobroker
                                  2023-09-01 09:36:53.420	info	iobroker host.iobroker object system.adapter.botvac.0.inputCount created
                                  host.iobroker
                                  2023-09-01 09:36:53.287	info	iobroker host.iobroker object system.adapter.botvac.0.uptime created
                                  host.iobroker
                                  2023-09-01 09:36:53.061	info	iobroker host.iobroker object system.adapter.botvac.0.memRss created
                                  host.iobroker
                                  2023-09-01 09:36:52.850	info	iobroker host.iobroker object system.adapter.botvac.0.memHeapTotal created
                                  host.iobroker
                                  2023-09-01 09:36:52.603	info	iobroker host.iobroker object system.adapter.botvac.0.memHeapUsed created
                                  host.iobroker
                                  2023-09-01 09:36:51.671	info	iobroker host.iobroker object system.adapter.botvac.0.cputime created
                                  host.iobroker
                                  2023-09-01 09:36:48.434	info	iobroker host.iobroker object system.adapter.botvac.0.cpu created
                                  host.iobroker
                                  2023-09-01 09:36:48.027	info	iobroker host.iobroker object system.adapter.botvac.0.compactMode created
                                  host.iobroker
                                  2023-09-01 09:36:47.669	info	iobroker host.iobroker object system.adapter.botvac.0.connected created
                                  host.iobroker
                                  2023-09-01 09:36:47.477	info	iobroker host.iobroker object system.adapter.botvac.0.alive created
                                  host.iobroker
                                  2023-09-01 09:36:47.342	info	iobroker host.iobroker create instance botvac
                                  host.iobroker
                                  2023-09-01 09:36:46.191	info	iobroker host.iobroker object system.adapter.botvac created/updated
                                  • C csp
                                    Reboot ioBroker.
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    Thomas BraunT
                                    Thomas BraunT
                                    @csp
                                    I just did a crosscheck on my setup.
                                    The adapter installs without issues here.
                                    Check your setup, especially the nodejs install.
                                    iob diag
                                    may be helpfull.
                                      @csp
                                      iob diag
                                      may be helpfull.
                                      C
                                      C
                                      csp
                                      @thomas-braun Installation works fine on my end as well. But as soon as I want to log in, it doesn't work.
                                      What do I need to do exactly? Can you help?
                                      • C csp
                                        Thomas BraunT
                                        Thomas BraunT
                                        @csp
                                        No, I don't own that device, I just checked the adapter installation.
                                          @csp
                                          C
                                          C
                                          csp
                                          @thomas-braun but maybe how I can check nodejs with iob diag?
                                          84.0k
                                          1.4m
