  2. English
  3. ioBroker general
  4. Neato Botvac adapter - further development
Geplant Angeheftet Gesperrt Verschoben ioBroker general
68 Beiträge 12 Kommentatoren 27.1k Aufrufe 10 Beobachtet
  • C csp
    @thomas-braun but maybe how I can check nodejs with iob diag?
    @csp sagte in Neato Botvac adapter - further development:
    iob diag
    Just run it in your terminal and copy the output in the forum.
    iob diag
    C 1 Antwort Letzte Antwort
      iob diag
      iob diag
      csp
      @thomas-braun I think I'm doing something wrong...
      root@iobroker:/opt/iobroker# iob diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      • C csp
        iobroker [command]
        Commands:
        Options:
        @csp
        iob stop
        iob fix
        iob start
        iob diag
        C 2 Antworten Letzte Antwort
          @csp
          iob stop
          iob fix
          iob start
          iob diag
          csp
          v.2023-04-16
          Operatingsystem: Debian GNU/Linux 11 (bullseye)
          Kernel: 4.4.180+
          Installation: Docker
          Timezone: Etc/UTC
          User-ID: 0
          X-Server: false
          Pending OS-Updates: 121
          Pending iob updates: 0
          Nodejs-Installation: /usr/bin/nodejs v12.22.7
          /usr/local/bin/node v18.17.1
          /usr/local/bin/npm 9.6.7
          /usr/local/bin/npx 9.6.7
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          *** nodejs is NOT correctly installed ***
          MEMORY:
          total used free shared buff/cache available
          Mem: 9.8G 3.7G 407M 558M 5.6G 5.2G
          Swap: 7.9G 419M 7.5G
          Total: 17G 4.2G 7.9G
          Active iob-Instances: 34
          Active repo(s): default, beta
          ioBroker Core: js-controller 5.0.12
          admin 6.9.1
          ioBroker Status: iobroker is running on this host.
          Objects type: jsonl
          States type: jsonl
          • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects: 20245
          States: 3
          Size of iob-Database:
          25M /opt/iobroker/iobroker-data/objects.jsonl
          13M /opt/iobroker/iobroker-data/objects.json.migrated
          13M /opt/iobroker/iobroker-data/objects.json.bak.migrated
          61M /opt/iobroker/iobroker-data/states.jsonl
          1.9M /opt/iobroker/iobroker-data/states.json.migrated
          1.9M /opt/iobroker/iobroker-data/states.json.bak.migrated
            @csp
            iob stop
            iob fix
            iob start
            iob diag
            csp
            @thomas-braun here you go:
            v.2023-04-16
            Kernel: 4.4.180+
            Timezone: Etc/UTC
            User-ID: 0
            X-Server: false
            MEMORY:
            admin 6.9.1
            Objects type: jsonl
            States type: jsonl
            Objects: 20245
            States: 3
            • C csp
              v.2023-04-16
              Kernel: 4.4.180+
              Timezone: Etc/UTC
              User-ID: 0
              X-Server: false
              MEMORY:
              admin 6.9.1
              Objects type: jsonl
              States type: jsonl
              Objects: 20245
              States: 3
              No need to read any further...
              The correct installation of nodejs as runtime environment ist crucial.
                csp
                @thomas-braun you are faster than I can correct my double post. :-)
                Yes, saw that as well. Need to see how I fix it.
                • C csp
                  @csp
                  This is a Docker?
                  Use the latest Version of Buanet Docker.
                    @csp
                    This is a Docker?
                    csp
                    @thomas-braun yes, Docker. Will most likely use Portainer to recreate and pull latest image.
                    • C csp
                      csp
                      Did everything and node.js seems fine now. So at least this is fixed.
                      BUT: My original problem with the adapter persists. Deleted and re-installed and same issue...
                      Tried npm install --production in adapter directory. - Also not helping...
                      I'm lost :-/
                      root@iobroker:/opt/iobroker/node_modules/iobroker.botvac# npm install --production
                      npm WARN config production Use `--omit=dev` instead.
                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      added 53 packages in 35s
                      result:
                      host.iobroker
                      2023-09-01 19:33:28.292	info	iobroker npm-rebuild: Rebuilding native modules ...
                      host.iobroker
                      2023-09-01 19:33:26.133	info	iobroker rebuild
                      host.iobroker
                      2023-09-01 19:33:26.133	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                      host.iobroker
                      2023-09-01 19:33:26.132	info	system.adapter.botvac.0 will be rebuilt
                      host.iobroker
                      2023-09-01 19:33:26.131	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
                      host.iobroker
                      2023-09-01 19:33:26.131	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.iobroker
                      2023-09-01 19:33:26.131	error	Caught by controller[0]: Node.js v18.17.1
                      host.iobroker
                      2023-09-01 19:33:26.131	error	Caught by controller[0]: }
                      host.iobroker
                      2023-09-01 19:33:26.131	error	Caught by controller[0]: ]
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: requireStack: [
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                      host.iobroker
                      2023-09-01 19:33:26.130	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: Require stack:
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: ^
                      host.iobroker
                      2023-09-01 19:33:26.129	error	Caught by controller[0]: throw err;
                      host.iobroker
                      2023-09-01 19:33:26.128	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                      host.iobroker
                      2023-09-01 19:33:25.447	info	instance system.adapter.botvac.0 started with pid 816
                      P 1 Antwort Letzte Antwort
                      • C csp
                        I'm lost :-/
                        result:
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        PeterVoronov
                        @csp
                        May be it has sence to downgrade the node version? To v16, i.e. version 7 of docker image ?
                        • P PeterVoronov
                          @csp
                          csp
                          @petervoronov : Just tried that as well. - Same story, same error.
                          Now I try to restore my system. Need to see what backups I have...
                          • C csp
                            csp
                            I'm so glad to have automatic backup enabled on my server... Went back 2 months and it works again. I only moved my most recent objects.jsonl back to the folder. I'm not sure what happened in-between.
                            Just did diag and it looks good. (Will update adapters one by one...)
                                                 v.2023-04-16
                            Kernel:                 4.4.180+
                            Timezone:               Etc/UTC
                            User-ID:                0
                            X-Server:               false
                            Pending OS-Updates:     0
                            Pending iob updates:    13
                            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                    /usr/bin/node           v18.17.1
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                            MEMORY:
                            Mem:            9.8G        3.5G        555M        565M        5.8G        5.5G
                            Swap:           7.9G        434M        7.5G
                            Total:           17G        3.9G        8.1G
                            Active iob-Instances:   35
                            ioBroker Core:          js-controller           4.0.24
                                                    admin                   6.5.9
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                16657
                            States:                 14206
                            26M     /opt/iobroker/iobroker-data/objects.jsonl
                            24M     /opt/iobroker/iobroker-data/states.jsonl
                            • C csp
                                                   v.2023-04-16
                              Kernel:                 4.4.180+
                              Timezone:               Etc/UTC
                              User-ID:                0
                              X-Server:               false
                                                      /usr/bin/npm            9.6.7
                                                      /usr/bin/npx            9.6.7
                              MEMORY:
                                                      admin                   6.5.9
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                16657
                              States:                 14206
                              @csp
                              Please setup the time zone and do not mix the repos:
                                @csp
                                csp
                                schrieb am zuletzt editiert von csp
                                @thomas-braun fixed and thanks for the help.
                                Will now update adapters. I'm curious if js adapter will cause again the issue.
                                Edit: All adapters updated. No problem.
                                Now final step: js controller 4.0.24 -> 5.0.12 - let's see :-)
                                  @csp
                                  csp
                                  @thomas-braun so now I found the issue.
                                  js controller update is causing issue.
                                  Maybe the way I'm doing it is not correct.
                                  Here is what I did:
                                  iobroker console:
                                  pkill -u iobroker
                                  iobroker update
                                  iobroker upgrade self
                                  -> js controller gets upgraded, but now I have the old problem.
                                  What am I'm doing wrong?
                                  • C csp
                                    Here is what I did:
                                    iobroker console:
                                    pkill -u iobroker
                                    iobroker update
                                    Nothing. It seems as if the adapter needs to be adjusted to the current js-controller.
                                      csp
                                      @PeterVoronov -> maybe something you could take a look...
                                      Until then I'll stay on 4.0.24
                                      • C csp
                                        PeterVoronov
                                        @csp
                                        Unfortunatelly I can't do a lot, mostly nothing.
                                        • I'm not an author of the adapter
                                        • Currently I have newsest js-controller installed, but adapter at least started for me. I can't check more, then start of adapter.
                                        • And, unfortunately, I have no any Neato device now(it's died year ago). So, I can't check the further steps ...
                                          ac369a9a-90fe-429b-83c9-6add8fdb2ca0-image.png .
                                        • P PeterVoronov
                                          @csp
                                          csp
                                          @petervoronov : One thing I see is your version number 1.0.4. I'm using 1.0.0 stable.
                                          How to get the 1.0.4? Maybe this already solves the issue.
                                          Thomas
