  2. English
  3. ioBroker general
  4. Neato Botvac adapter - further development
Geplant Angeheftet Gesperrt Verschoben ioBroker general
68 Beiträge 12 Kommentatoren 27.1k Aufrufe 10 Beobachtet
  • C csp
    v.2023-04-16
    Operatingsystem: Debian GNU/Linux 11 (bullseye)
    Kernel: 4.4.180+
    Installation: Docker
    Timezone: Etc/UTC
    User-ID: 0
    X-Server: false
    Pending OS-Updates: 121
    Pending iob updates: 0
    Nodejs-Installation: /usr/bin/nodejs v12.22.7
    /usr/local/bin/node v18.17.1
    /usr/local/bin/npm 9.6.7
    /usr/local/bin/npx 9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    *** nodejs is NOT correctly installed ***
    MEMORY:
    total used free shared buff/cache available
    Mem: 9.8G 3.7G 407M 558M 5.6G 5.2G
    Swap: 7.9G 419M 7.5G
    Total: 17G 4.2G 7.9G
    Active iob-Instances: 34
    Active repo(s): default, beta
    ioBroker Core: js-controller 5.0.12
    admin 6.9.1
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: jsonl
    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 20245
    States: 3
    Size of iob-Database:
    25M /opt/iobroker/iobroker-data/objects.jsonl
    13M /opt/iobroker/iobroker-data/objects.json.migrated
    13M /opt/iobroker/iobroker-data/objects.json.bak.migrated
    61M /opt/iobroker/iobroker-data/states.jsonl
    1.9M /opt/iobroker/iobroker-data/states.json.migrated
    1.9M /opt/iobroker/iobroker-data/states.json.bak.migrated
    @csp sagte in Neato Botvac adapter - further development:
    No need to read any further...
    The correct installation of nodejs as runtime environment ist crucial.
    C 1 Antwort Letzte Antwort
      csp
      @thomas-braun you are faster than I can correct my double post. :-)
      Yes, saw that as well. Need to see how I fix it.
      • C csp
        @csp
        This is a Docker?
        Use the latest Version of Buanet Docker.
          @csp
          This is a Docker?
          csp
          @thomas-braun yes, Docker. Will most likely use Portainer to recreate and pull latest image.
          • C csp
            csp
            Did everything and node.js seems fine now. So at least this is fixed.
            BUT: My original problem with the adapter persists. Deleted and re-installed and same issue...
            Tried npm install --production in adapter directory. - Also not helping...
            I'm lost :-/
            root@iobroker:/opt/iobroker/node_modules/iobroker.botvac# npm install --production
            npm WARN config production Use `--omit=dev` instead.
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            added 53 packages in 35s
            result:
            host.iobroker
            2023-09-01 19:33:28.292	info	iobroker npm-rebuild: Rebuilding native modules ...
            host.iobroker
            2023-09-01 19:33:26.133	info	iobroker rebuild
            host.iobroker
            2023-09-01 19:33:26.133	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
            host.iobroker
            2023-09-01 19:33:26.132	info	system.adapter.botvac.0 will be rebuilt
            host.iobroker
            2023-09-01 19:33:26.131	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
            host.iobroker
            2023-09-01 19:33:26.131	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.iobroker
            2023-09-01 19:33:26.131	error	Caught by controller[0]: Node.js v18.17.1
            host.iobroker
            2023-09-01 19:33:26.131	error	Caught by controller[0]: }
            host.iobroker
            2023-09-01 19:33:26.131	error	Caught by controller[0]: ]
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: requireStack: [
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
            host.iobroker
            2023-09-01 19:33:26.130	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: Require stack:
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: ^
            host.iobroker
            2023-09-01 19:33:26.129	error	Caught by controller[0]: throw err;
            host.iobroker
            2023-09-01 19:33:26.128	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
            host.iobroker
            2023-09-01 19:33:25.447	info	instance system.adapter.botvac.0 started with pid 816
            P 1 Antwort Letzte Antwort
            • C csp
              I'm lost :-/
              result:
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              PeterVoronov
              @csp
              May be it has sence to downgrade the node version? To v16, i.e. version 7 of docker image ?
              • P PeterVoronov
                @csp
                csp
                @petervoronov : Just tried that as well. - Same story, same error.
                Now I try to restore my system. Need to see what backups I have...
                • C csp
                  csp
                  I'm so glad to have automatic backup enabled on my server... Went back 2 months and it works again. I only moved my most recent objects.jsonl back to the folder. I'm not sure what happened in-between.
                  Just did diag and it looks good. (Will update adapters one by one...)
                                       v.2023-04-16
                  Kernel:                 4.4.180+
                  Timezone:               Etc/UTC
                  User-ID:                0
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    13
                  Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                          /usr/bin/node           v18.17.1
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                  MEMORY:
                  Mem:            9.8G        3.5G        555M        565M        5.8G        5.5G
                  Swap:           7.9G        434M        7.5G
                  Total:           17G        3.9G        8.1G
                  Active iob-Instances:   35
                  ioBroker Core:          js-controller           4.0.24
                                          admin                   6.5.9
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                16657
                  States:                 14206
                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                  24M     /opt/iobroker/iobroker-data/states.jsonl
                  • C csp
                                         v.2023-04-16
                    Kernel:                 4.4.180+
                    Timezone:               Etc/UTC
                    User-ID:                0
                    X-Server:               false
                                            /usr/bin/npm            9.6.7
                                            /usr/bin/npx            9.6.7
                    MEMORY:
                                            admin                   6.5.9
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                16657
                    States:                 14206
                    @csp
                    Please setup the time zone and do not mix the repos:
                    C 2 Antworten Letzte Antwort
                      @csp
                      csp
                      schrieb am zuletzt editiert von csp
                      @thomas-braun fixed and thanks for the help.
                      Will now update adapters. I'm curious if js adapter will cause again the issue.
                      Edit: All adapters updated. No problem.
                      Now final step: js controller 4.0.24 -> 5.0.12 - let's see :-)
                        @csp
                        csp
                        @thomas-braun so now I found the issue.
                        js controller update is causing issue.
                        Maybe the way I'm doing it is not correct.
                        Here is what I did:
                        iobroker console:
                        pkill -u iobroker
                        iobroker update
                        iobroker upgrade self
                        -> js controller gets upgraded, but now I have the old problem.
                        What am I'm doing wrong?
                        • C csp
                          Here is what I did:
                          iobroker console:
                          pkill -u iobroker
                          iobroker update
                          Nothing. It seems as if the adapter needs to be adjusted to the current js-controller.
                            csp
                            @PeterVoronov -> maybe something you could take a look...
                            Until then I'll stay on 4.0.24
                            • C csp
                              PeterVoronov
                              @csp
                              Unfortunatelly I can't do a lot, mostly nothing.
                              • I'm not an author of the adapter
                              • Currently I have newsest js-controller installed, but adapter at least started for me. I can't check more, then start of adapter.
                              • And, unfortunately, I have no any Neato device now(it's died year ago). So, I can't check the further steps ...
                                ac369a9a-90fe-429b-83c9-6add8fdb2ca0-image.png .
                              • P PeterVoronov
                                @csp
                                csp
                                @petervoronov : One thing I see is your version number 1.0.4. I'm using 1.0.0 stable.
                                How to get the 1.0.4? Maybe this already solves the issue.
                                Thomas
                                • C csp
                                  Thomas
                                  csp
                                  I was able to pull v1.0.4. But it fails as well. There is a difference though. It gets green and crashes afterwards.
                                  I'll now stay with my former version of js-controller and hope that the developer can fix it at some point.
                                  host.iobroker
                                  2023-09-07 17:33:49.629	error	instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  botvac.0
                                  2023-09-07 17:33:49.510	info	terminating
                                  botvac.0
                                  2023-09-07 17:33:49.074	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
                                  botvac.0
                                  2023-09-07 17:33:49.073	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
                                  botvac.0
                                  2023-09-07 17:33:49.069	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
                                  botvac.0
                                  2023-09-07 17:33:49.068	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
                                  botvac.0
                                  2023-09-07 17:33:49.008	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  botvac.0
                                  2023-09-07 17:33:49.006	info	terminating
                                  botvac.0
                                  2023-09-07 17:33:49.003	error	undefined is not a valid state value
                                  botvac.0
                                  2023-09-07 17:33:49.003	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17 at Robot.<anonymous> (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17) at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17 at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45 at <anonymous> at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  botvac.0
                                  2023-09-07 17:33:49.002	error	unhandled promise rejection: undefined is not a valid state value
                                  botvac.0
                                  2023-09-07 17:33:49.001	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  botvac.0
                                  2023-09-07 17:33:48.994	error	undefined is not a valid state value
                                  botvac.0
                                  2023-09-07 17:33:48.993	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17 at Robot.<anonymous> (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17) at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17 at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45 at <anonymous> at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  botvac.0
                                  2023-09-07 17:33:48.991	error	unhandled promise rejection: undefined is not a valid state value
                                  botvac.0
                                  2023-09-07 17:33:48.990	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  botvac.0
                                  2023-09-07 17:33:47.677	warn	Device"unten" with id: unten is not exists in cloud any more!
                                  botvac.0
                                  2023-09-07 17:33:46.740	info	devices found: 2
                                  botvac.0
                                  2023-09-07 17:33:44.228	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 5.0.12
                                  • C csp
                                    host.iobroker
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    botvac.0
                                    PeterVoronov
                                    @csp If you have time for it - please try start 1.0.4 version with debug log.
                                    Other option - you can share via PM your credentials - and I will try to find a time to look for the solution.
                                    • P PeterVoronov
                                      csp
                                      @petervoronov
                                      this is with JS 4.0.24:
                                      Later I can try to upgrade and check again
                                      botvac.0
                                      2023-09-08 08:30:20.179	debug	get schedule {"enabled":false,"events":[]}
                                      botvac.0
                                      2023-09-08 08:30:20.174	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:30:20.173	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:30:20.151	info	undefined is not a valid state value for id "botvac.0.unten.status.canPause"
                                      botvac.0
                                      2023-09-08 08:30:20.150	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"unten","_serial":"OPS39718-F045DA6FF249","_secret":"D0E3BFDA3824F493627EE28D882CE4963BF6A0A112FEF9CB0EDC7C0E7E273ADA74F0D7DFD29510271AA4E69BB72CBA100410604DAEBF66E611D052A75502373BE1A61A12D177E4FE94F8369B63BCF3DA76E2C481D5AC29EBAEC36BB0C9A080E501F23A01A81485F1F59F526ACBCC376FBDDF97F9E23692CF1D9A35D19117F48B","_token":"Token token=77962ed80b7e7e2c9898ea76ad40d9c3","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"isBinFull":false,"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":null,"state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"meta":{"modelName":"BotVacD5Connected","firmware":"4.5.3-189"}}
                                      botvac.0
                                      2023-09-08 08:30:20.093	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:30:20.091	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:30:20.045	info	undefined is not a valid state value for id "botvac.0.obergeschoss.status.canPause"
                                      botvac.0
                                      2023-09-08 08:30:20.042	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"obergeschoss","_serial":"OPS36118-F045DA70530D","_secret":"AB23FB0FDE9112F5DA12884631EC2C3A2A89E6F056C9C3E41EF3E616CB0C9747E5DB596626D3BB1581D0F71D6C2058E87D234DACE2485D297F3B8716242BF614D06DB2574BF401C273467B7A45701B91DDE7BEE7444E222AF8337B81214BC0BFF8031D83789CCD1077016184F9EC2D193E9B115D3A89CB0A37AC908498CB0D13","_token":"Token token=77962ed80b7e7e2c9898ea76ad40d9c3","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"isBinFull":true,"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":"dustbin_full","state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"meta":{"modelName":"BotVacD7Connected","firmware":"4.5.3-189"}}
                                      botvac.0
                                      2023-09-08 08:30:20.012	debug	get schedule {"type":1,"enabled":false,"events":[]}
                                      botvac.0
                                      2023-09-08 08:30:18.831	warn	Device"unten" with id: unten is not exists in cloud any more!
                                      botvac.0
                                      2023-09-08 08:30:18.313	info	devices found: 2
                                      botvac.0
                                      2023-09-08 08:30:15.559	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 4.0.24
                                      botvac.0
                                      2023-09-08 08:30:10.069	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      botvac.0
                                      2023-09-08 08:30:10.068	info	terminating
                                      botvac.0
                                      2023-09-08 08:30:10.067	info	Got terminate signal TERMINATE_YOURSELF
                                      botvac.0
                                      2023-09-08 08:29:38.719	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:29:38.718	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:29:38.707	info	undefined is not a valid state value for id "botvac.0.obergeschoss.status.canPause"
                                      botvac.0
                                      2023-09-08 08:29:38.706	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"obergeschoss","_serial":"OPS36118-F045DA70530D","_secret":"AB23FB0FDE9112F5DA12884631EC2C3A2A89E6F056C9C3E41EF3E616CB0C9747E5DB596626D3BB1581D0F71D6C2058E87D234DACE2485D297F3B8716242BF614D06DB2574BF401C273467B7A45701B91DDE7BEE7444E222AF8337B81214BC0BFF8031D83789CCD1077016184F9EC2D193E9B115D3A89CB0A37AC908498CB0D13","_token":"Token token=37c8b0e205312639b061254cedc49131","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"isBinFull":true,"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":"dustbin_full","state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"meta":{"modelName":"BotVacD7Connected","firmware":"4.5.3-189"}}
                                      botvac.0
                                      2023-09-08 08:29:38.649	debug	get schedule {"type":1,"enabled":false,"events":[]}
                                      botvac.0
                                      2023-09-08 08:29:38.588	debug	get schedule {"enabled":false,"events":[]}
                                      botvac.0
                                      2023-09-08 08:29:38.570	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:29:38.566	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
                                      botvac.0
                                      2023-09-08 08:29:38.541	info	undefined is not a valid state value for id "botvac.0.unten.status.canPause"
                                      botvac.0
                                      2023-09-08 08:29:38.538	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"unten","_serial":"OPS39718-F045DA6FF249","_secret":"D0E3BFDA3824F493627EE28D882CE4963BF6A0A112FEF9CB0EDC7C0E7E273ADA74F0D7DFD29510271AA4E69BB72CBA100410604DAEBF66E611D052A75502373BE1A61A12D177E4FE94F8369B63BCF3DA76E2C481D5AC29EBAEC36BB0C9A080E501F23A01A81485F1F59F526ACBCC376FBDDF97F9E23692CF1D9A35D19117F48B","_token":"Token token=37c8b0e205312639b061254cedc49131","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"isBinFull":false,"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":null,"state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"meta":{"modelName":"BotVacD5Connected","firmware":"4.5.3-189"}}
                                      botvac.0
                                      2023-09-08 08:29:37.237	warn	Device"unten" with id: unten is not exists in cloud any more!
                                      botvac.0
                                      2023-09-08 08:29:36.792	info	devices found: 2
                                      botvac.0
                                      2023-09-08 08:29:34.330	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 4.0.24
                                      • C csp
                                        @petervoronov
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        botvac.0
                                        PeterVoronov
                                        schrieb am zuletzt editiert von PeterVoronov
                                        @csp I made a pull request to fix this exact issue.
                                        I don't know how fast it will be applied ...
                                        You can try to install it from my fork - https://github.com/PeterVoronov/ioBroker.botvac/tree/patch-1
                                        In Adapter tab you have to enble expert mode, select custom install and select install from url
                                        Pedder007P mcm1957M 2 Antworten Letzte Antwort
                                        • P PeterVoronov
                                          Pedder007P Online
                                          Pedder007P Online
                                          Pedder007
                                          schrieb am zuletzt editiert von Pedder007
                                          @petervoronov Hi and thanks!
                                          Had the same problem und fixed it with the patch-link 👍
                                          Edit:
                                          But recognized that it causes some warnings now, recurring in frequence of 1 minute:
                                          botvac.0
                                          2023-09-15 12:46:06.971	warn	State value to set for "botvac.0.Freddi.commands.spotHeight" has value "0" less than min "100"
                                          botvac.0
                                          2023-09-15 12:46:06.970	warn	State value to set for "botvac.0.Freddi.commands.spotWidth" has value "0" less than min "100"
                                          Tried to set the objects manually to '100', but they are overwritten by the machine's data after a minute.
                                          Okay, the minute was my polling intervall ;-)
                                          Pedder
                                          All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                                          Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                                          Under construction: Smart-WoMo auf Raspi4
