  2. English
  3. ioBroker general
  4. How to replace null with 0 using alias-manager
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
25 Beiträge 9 Kommentatoren 5.1k Aufrufe 7 Beobachtet
  • Tomasz NowakT
    Tomasz NowakT
    Tomasz Nowak
    I have an object that returns a value (number) on button press but then it shows null.
    I need to convert that null tu value 0.
    I've tried the alias-manager adapter, but I don't know how to write a proper rule for that.
    This below doesn't seem to work:
    Any help appreciated!
    HomoranH AlCalzoneA 2 Antworten Letzte Antwort
    • Tomasz NowakT Tomasz Nowak
      @tomasz-nowak sagte in How to replace null with 0 using alias-manager:
      I really don't know, but please try val === null?0:val
      Tomasz NowakT 1 Antwort Letzte Antwort
        Tomasz NowakT
        Tomasz NowakT
        Tomasz Nowak
        @homoran said in How to replace null with 0 using alias-manager:
        Thanks, but it doesn't seem to work :(
          can you please try val == null?0:val
          • apollon77A
            apollon77A
            Zeig doch bitte mal dwie das Alias objekt aussieht was da rausfällt.
              AlCalzoneA
              AlCalzoneA
              AlCalzone
              @tomasz-nowak The common.type seems wrong - the original state is numeric. Maybe that confuses the alias function.
              Warum sudo böse ist: https://forum.iobroker.net/post/17109
              • AlCalzoneA AlCalzone
                Tomasz NowakT
                Tomasz NowakT
                Tomasz Nowak
                @alcalzone I've changed common.type to number - no change.
                @Homoran Tried also == and no change.
                So I have this object: SceneId:
                When I press a mono-switch connected that dimmer I see value "26" for a blink of an eye, than there's noting in that field (I believe its "null"). This null somehow crashes mqtt-broker, so I wanted to change "null" to "0".
                But in an alias object:
                Its exactly the same - 26 shows for a blink of the eye and then nothing. Both with val === null?0:val and val == null?0:val.
                This alias object also crashes mqtt-client adapter with uncaught null exception.
                This is full config of my alias. I'm not sure if I understand all correctly.
                  apollon77A
                  apollon77A
                  @tomasz-nowak Crashes? Logs please :-)
                  Also I would like to see the Core JSON of the created alias object because that matters (not a UI) ;-)
                  Go into Admin please, Objects Tab, go to that state and enable expert mode, klick on pencil on right side, in dialog "raw" and copy the json please here
                  • apollon77A apollon77
                    Tomasz NowakT
                    Tomasz NowakT
                    Tomasz Nowak
                    @apollon77
                    This is JSON for an alias object:
                      "user": "system.user.admin",
                      "ts": 1619609676629,
                      "common": {
                        "name": "Scene ID",
                        "role": "level",
                        "type": "number",
                        "read": true,
                        "write": true,
                        "alias": {
                          "id": "zwave2.0.Node_014.Scene_Activation.sceneId",
                          "read": "val == null?0:val"
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "owner": "system.user.admin",
                        "state": 1636
                      "_id": "alias.0.Fibaro_Dimmer_1_SceneID.sceneId",
                      "type": "state"
                    and this is for the source object:
                      "type": "state",
                      "common": {
                        "role": "level",
                        "read": true,
                        "write": true,
                        "name": "Scene ID",
                        "type": "number",
                        "min": 1,
                        "max": 255
                      "native": {
                        "nodeId": 14,
                        "valueId": {
                          "commandClass": 43,
                          "endpoint": 0,
                          "property": "sceneId"
                      "from": "system.adapter.zwave2.0",
                      "ts": 1619558168447,
                      "_id": "zwave2.0.Node_014.Scene_Activation.sceneId",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    Thanks
                      @apollon77
                        "common": {
                          "name": "Scene ID",
                          "role": "level",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "alias": {
                        "native": {},
                        "acl": {
                          "object": 1636,
                          "state": 1636
                        "type": "state"
                        "type": "state",
                        "common": {
                          "role": "level",
                          "read": true,
                          "write": true,
                          "name": "Scene ID",
                          "type": "number",
                          "min": 1,
                          "max": 255
                        "native": {
                          "nodeId": 14,
                          "valueId": {
                            "commandClass": 43,
                            "endpoint": 0,
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                      Thanks
                      Tomasz NowakT
                      Tomasz NowakT
                      Tomasz Nowak
                      Mqtt-client crash log is here (I've created an issue out of this):
                      https://github.com/Pmant/ioBroker.mqtt-client/issues/45
                        apollon77A
                        apollon77A
                        @tomasz-nowak js-controller Version??
                          Tomasz NowakT
                          Tomasz NowakT
                          Tomasz Nowak
                          @apollon77
                          • JS-Controller version: 3.2.16
                          • Node version: v12.22.1
                          • Operating system: docker image @ Raspberry OS
                          • all adapters in current released versions
                          • apollon77A
                            apollon77A
                            Ok, jetuzt mal ganz genau: was ist der exakte wert?
                            • In allen screenshots ist gar kein Wert zu sehen - auch nicht "null"
                            • Der mqtt-client Adapter crasht weil der state an sich "null" ist - also NICHT "state wert ist null" sondern es gibt gar keinen state!! Nix
                            • Aliasse greifen dann nicht weil Sie nur Werte mappen - bedeutet also das der resulting Alias auch "keinen Wert hat"
                            Am besten dazu jetzt mal
                            iobroker state get zwave2.0.Node_014.Scene_Activation.sceneId
                            machen und Ausgabe posten.
                              Tomasz NowakT
                              Tomasz NowakT
                              Tomasz Nowak
                              @apollon77 said in How to replace null with 0 using alias-manager:
                              Yes, no value is seen on the screenshots because there no value at all for most of the time. It gets "26" or "24" depending on number of clicks, but only for a second. Then it returns to empty / null.
                              Now, because mqtt-client can't handle this correctly, I've been trying to alias this object somehow to push it to MQTT anyway. So, I can not rewrite empty object with any custom value (such as "0" for instance)?
                                Tomasz NowakT
                                Tomasz NowakT
                                Tomasz Nowak
                                schrieb am zuletzt editiert von Tomasz Nowak
                                Thats strange:
                                And I still see this object in ioBroker admin panel
                                • apollon77A
                                  apollon77A
                                  Ok nicht englishc.
                                  Nicht Dinge vermischen!!
                                  Es gibt Objekte - das siehst Du im Admin. Und Objekte haben (vielleicht) einen Wert. Ein Wert kann da sein und einen value haben und der Wert kann auch NICHT da sein (weil nie gesetzt wurde, weil expired oder weil gelöscht.
                                  Also: Jetzt wieder zwave2 Frage ... warum existiert der state nicht?
                                    Ok nicht englishc.
                                    Tomasz NowakT
                                    Tomasz NowakT
                                    Tomasz Nowak
                                    @apollon77
                                    That issue I've also reported here :)
                                    https://github.com/AlCalzone/ioBroker.zwave2/issues/597
                                      @apollon77
                                      apollon77A
                                      apollon77A
                                      @tomasz-nowak ;üsste man umformulieren!
                                      Wie gesagt der crash ist ein Fehler in mqtt-client! Die Frage an zwave2 ist warum der state gelöscht wird
                                        Thats strange:
                                        paul53P
                                        paul53P
                                        @tomasz-nowak
                                        If the state expires after a second, use a script:
                                        on({id: 'zwave2.0.Node_014.Scene_Activation.sceneId'}, function(dp) {
                                            setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', dp.state.val, true);
                                            setTimeout(function() {
                                                setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', 0, true);
                                            }, 1000);
                                        Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                                          @tomasz-nowak
                                              }, 1000);
                                          Tomasz NowakT
                                          Tomasz NowakT
                                          Tomasz Nowak
                                          I've never used Javascript in ioBroker, but I have installed Javascript adapter now, created that channel and object under 0_userdata.0 and......
                                          WOW, it works as it should !!!!!!!!!!!!
                                          I get 26 and 24 values on 1- and 2-click and then the objects turns to 0. And it works with mqtt-client putting it to the broker just fine:
                                          Thank you @paul53 for this quick solution! 🙌
                                          I hope mqtt-client (and probably zwave2) adapters will be address with this issue in the future, but for now I may switch my lights again!
                                          84.0k
                                          1.4m
