  2. English
  3. ioBroker general
  4. How to replace null with 0 using alias-manager
Geplant Angeheftet Gesperrt Verschoben ioBroker general
25 Beiträge 9 Kommentatoren 4.7k Aufrufe 7 Beobachtet
  • Tomasz NowakT Tomasz Nowak
    @apollon77
    This is JSON for an alias object:
      "user": "system.user.admin",
      "ts": 1619609676629,
      "common": {
        "name": "Scene ID",
        "role": "level",
        "type": "number",
        "read": true,
        "write": true,
        "alias": {
          "id": "zwave2.0.Node_014.Scene_Activation.sceneId",
          "read": "val == null?0:val"
      "native": {},
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "alias.0.Fibaro_Dimmer_1_SceneID.sceneId",
      "type": "state"
    and this is for the source object:
      "type": "state",
      "common": {
        "role": "level",
        "read": true,
        "write": true,
        "name": "Scene ID",
        "type": "number",
        "min": 1,
        "max": 255
      "native": {
        "nodeId": 14,
        "valueId": {
          "commandClass": 43,
          "endpoint": 0,
          "property": "sceneId"
      "from": "system.adapter.zwave2.0",
      "ts": 1619558168447,
      "_id": "zwave2.0.Node_014.Scene_Activation.sceneId",
      "acl": {
        "object": 1636,
        "state": 1636,
    Thanks
    Tomasz NowakT Offline
    Tomasz Nowak
    Mqtt-client crash log is here (I've created an issue out of this):
    https://github.com/Pmant/ioBroker.mqtt-client/issues/45
      @tomasz-nowak js-controller Version??
      Tomasz NowakT 1 Antwort Letzte Antwort
      • apollon77A apollon77
        Tomasz Nowak
        @apollon77
        • JS-Controller version: 3.2.16
        • Node version: v12.22.1
        • Operating system: docker image @ Raspberry OS
        • all adapters in current released versions
        • apollon77A Offline
          Ok, jetuzt mal ganz genau: was ist der exakte wert?
          • In allen screenshots ist gar kein Wert zu sehen - auch nicht "null"
          • Der mqtt-client Adapter crasht weil der state an sich "null" ist - also NICHT "state wert ist null" sondern es gibt gar keinen state!! Nix
          • Aliasse greifen dann nicht weil Sie nur Werte mappen - bedeutet also das der resulting Alias auch "keinen Wert hat"
          Am besten dazu jetzt mal
          iobroker state get zwave2.0.Node_014.Scene_Activation.sceneId
          machen und Ausgabe posten.
            Tomasz Nowak
            @apollon77 said in How to replace null with 0 using alias-manager:
            Yes, no value is seen on the screenshots because there no value at all for most of the time. It gets "26" or "24" depending on number of clicks, but only for a second. Then it returns to empty / null.
            Now, because mqtt-client can't handle this correctly, I've been trying to alias this object somehow to push it to MQTT anyway. So, I can not rewrite empty object with any custom value (such as "0" for instance)?
              Tomasz Nowak
              schrieb am zuletzt editiert von Tomasz Nowak
              Thats strange:
              And I still see this object in ioBroker admin panel
                Ok nicht englishc.
                Nicht Dinge vermischen!!
                Es gibt Objekte - das siehst Du im Admin. Und Objekte haben (vielleicht) einen Wert. Ein Wert kann da sein und einen value haben und der Wert kann auch NICHT da sein (weil nie gesetzt wurde, weil expired oder weil gelöscht.
                Also: Jetzt wieder zwave2 Frage ... warum existiert der state nicht?
                  Ok nicht englishc.
                  Tomasz Nowak
                  @apollon77
                  That issue I've also reported here :)
                  https://github.com/AlCalzone/ioBroker.zwave2/issues/597
                    @apollon77
                    @tomasz-nowak ;üsste man umformulieren!
                    Wie gesagt der crash ist ein Fehler in mqtt-client! Die Frage an zwave2 ist warum der state gelöscht wird
                      Thats strange:
                      @tomasz-nowak
                      If the state expires after a second, use a script:
                      on({id: 'zwave2.0.Node_014.Scene_Activation.sceneId'}, function(dp) {
                          setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', dp.state.val, true);
                          setTimeout(function() {
                              setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', 0, true);
                          }, 1000);
                        @tomasz-nowak
                            }, 1000);
                        Tomasz Nowak
                        I've never used Javascript in ioBroker, but I have installed Javascript adapter now, created that channel and object under 0_userdata.0 and......
                        WOW, it works as it should !!!!!!!!!!!!
                        I get 26 and 24 values on 1- and 2-click and then the objects turns to 0. And it works with mqtt-client putting it to the broker just fine:
                        Thank you @paul53 for this quick solution! 🙌
                        I hope mqtt-client (and probably zwave2) adapters will be address with this issue in the future, but for now I may switch my lights again!
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @tomasz-nowak sagte in How to replace null with 0 using alias-manager:
                          and probably zwave2
                          I can only repeat myself: This is not a problem in zwave2. It just uses the expire feature for states which mqtt-client doesn't handle correctly.
                          Tomasz NowakT paul53P 2 Antworten Letzte Antwort
                          • AlCalzoneA AlCalzone
                            and probably zwave2
                            Tomasz Nowak
                            Yes, that's true.
                            And for the record, this issue (with Fibaro sceneId) is totally solved with two PR's to mqtt-client adapter proposed by @AlCalzone (#46 & #47) and merged by @apollon77
                            You guys are amazing!
                              and probably zwave2
                              @alcalzone sagte: It just uses the expire feature for states
                              Wozu ist ein Datenpunkt ohne Zustand gut? Bringt es irgend einen Vorteil, state.expire zu nutzen?
                              AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @paul53 Im vorliegenden Fall handelt es sich um Events, die eigentlich nur exakt in dem Moment, in dem sie empfangen werden, eine Bedeutung haben (z.B. kurzer Knopfdruck). Damit man trotzdem sowohl darauf reagieren kann, als auch im Admin etwas sieht, habe ich mich entschieden, diese für jeweils 1 Sekunde im State zu speichern.
                                Expire macht diese Funktion recht praktisch, weil sich ioBroker bzw. die Datenbank dann ums Timeout kümmert und man nicht selbst jeden State tracken muss.
                                Das Zurücksetzen funktioniert so auch dann noch, wenn innerhalb der Sekunde der Adapter beendet wird.
                                  @paul53 Naja Formal ist es ein Unterschied (auf einer reinen Datenebene) ob ein State einen Wert hat - und ja formal ist auch "null" ein Wert der eine spezifische Bedeutung haben kann. Damit braucht es eine Abgrenzung zu "es ist kein Wert da" und das ist genau der Fall hier.
                                  Auch das zurücksetzen von Werten (einige Adapter machen bei "Button" States die an sich immer nur auf true getriggert werden extra timeouts damit der Button wieder auf false zurückgesetzt wird (weil User das gern in Visus so haben wollen ... no offense ;-) ) Wenn aber jetzt der Adapter beendet wird oder das Skript nicht mehr läuft bleibt das halt auf true stehen.
                                  Mit expires kann du den Wert automatisiert "clearen" weil das in der Verantwortung der Datenbank liegt (File-DB bzw Redis sorgt dafür)
                                  Mit expires kann man auch durchaus Überwachungen bauen. Zum Beispiel funktionieren die wie system.adapter.alive so, dass diese alle 15s neu gesetzt werden mit einem expire von 30s oder so. So lange also der prozess läuft expired das nie weil es immer neu gesetzt wird.
                                  Wenn jetzt der Adater komisch hängenbleibt, sodass er nicht crasht aber auch nicht regelmässig alive setzen kann wird der state expiren ... das registriert der Controller und reragiert durch kill des prozesses und neustart ...
                                  Also es gibt durchaus sinnvolle Anwendungsformen.
                                  Die die @AlCalzone beschrieben hat könnte man für alle buttons nutzen (wenn es mit alles visus und der User erwartung kompatibel wäre ;-) )
