  2. English
  3. Scripting / Logic
  5. Pause script for x time
    6.0k
3 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    Tomiol80
    Hi
    Any advice how I can pause script for 720 minutes? Now if I press light button my lights turn on again immediately.
    BR,
    -Tomi-
    • T Tomiol80
      Hi
      BR,
      -Tomi-
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @tomiol80
      you want to:
      • define a variable "block_script"
      • set the variable to "false" before the trigger
      • your "if actual time is between" you want to extend with a logic block so that the condition reads "if actual time is between 15:00 and 23:00 and block_script = false
      • inside the trigger where you have the pause, you want to set it the variable to true
      • then start a timeout for 720 minutes. Inside the timeout, set the variable to false.
      A.
      • AsgothianA Asgothian
        @tomiol80
        you want to:
        A.
        Tomiol80
        @asgothian
        Ok. Thank you very much.
        I think I got it right now.
