  4. Zwave läuft nicht iobroker als Raspberrymatic addon
107 Beiträge 8 Kommentatoren 12.4k Aufrufe 5 Beobachtet
  • apollon77A apollon77
    @rhartmann76 Und in der Admin konfiguration hast Du danach den Port eingetragen und gespeichert?
    rhartmann76
    schrieb am zuletzt editiert von rhartmann76
    #101
    @apollon77 @Thomas-Braun sorry, wo muss man dies einstellen?
    Also in dem Z-wave Adapter habe ich in der Konfiguration /dev/ttyAMA0 eingetragen und einen Code generieren lassen.
    Sonst habe ich nichts geändert.
    2021-03-19 09:57:17.081 - info: host.raspberrypi "system.adapter.zwave2.0" disabled
    2021-03-19 09:57:17.089 - info: host.raspberrypi stopInstance system.adapter.zwave2.0 (force=false, process=true)
    2021-03-19 09:57:17.113 - info: host.raspberrypi stopInstance system.adapter.zwave2.0 send kill signal
    2021-03-19 09:57:17.114 - info: zwave2.0 (1886) Got terminate signal TERMINATE_YOURSELF
    2021-03-19 09:57:17.136 - info: zwave2.0 (1886) Shutting down driver...
    2021-03-19 09:57:17.148 - info: zwave2.0 (1886) terminating
    2021-03-19 09:57:17.154 - info: zwave2.0 (1886) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-19 09:57:17.919 - info: host.raspberrypi instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-19 09:57:20.103 - info: host.raspberrypi "system.adapter.zwave2.0" enabled
    2021-03-19 09:57:20.250 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 1916
    2021-03-19 09:57:27.107 - info: zwave2.0 (1916) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.21.0, js-controller: 3.2.16
    • R rhartmann76
      #102
      @rhartmann76
      sudo timedatectl set-timezone Europe/Berlin
      R 1 Antwort Letzte Antwort
        @rhartmann76
        rhartmann76
        #103
        2021-03-19 10:06:24.385 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
        2021-03-19 10:06:24.388 - warn: host.raspberrypi instance system.adapter.zwave2.0 terminated due to SIGABRT
        2021-03-19 10:06:24.390 - info: host.raspberrypi instance system.adapter.zwave2.0 terminated with code NaN ()
        2021-03-19 10:06:24.391 - info: host.raspberrypi Restart adapter system.adapter.zwave2.0 because enabled
        2021-03-19 10:06:54.436 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 1949
        2021-03-19 10:07:01.114 - info: zwave2.0 (1949) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.21.0, js-controller: 3.2.16
        2021-03-19 10:09:45.749 - info: host.raspberrypi "system.adapter.zwave2.0" disabled
        2021-03-19 10:09:45.758 - info: host.raspberrypi stopInstance system.adapter.zwave2.0 (force=false, process=true)
        2021-03-19 10:09:45.791 - info: host.raspberrypi stopInstance system.adapter.zwave2.0 send kill signal
        2021-03-19 10:09:45.796 - info: zwave2.0 (1949) Got terminate signal TERMINATE_YOURSELF
        2021-03-19 10:09:45.818 - info: zwave2.0 (1949) Shutting down driver...
        2021-03-19 10:09:45.823 - info: zwave2.0 (1949) terminating
        2021-03-19 10:09:45.827 - info: zwave2.0 (1949) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-03-19 10:09:46.556 - info: host.raspberrypi instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-03-19 10:09:47.825 - info: host.raspberrypi "system.adapter.zwave2.0" enabled
        2021-03-19 10:09:47.963 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 2012
        2021-03-19 11:09:54.749 - info: zwave2.0 (2012) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.21.0, js-controller: 3.2.16
        • R rhartmann76
          #104
          @rhartmann76 sagte in Zwave läuft nicht iobroker als Raspberrymatic addon:
          free -h
          sagt?
            free -h
            sagt?
            rhartmann76
            #105
            @thomas-braun said in Zwave läuft nicht iobroker als Raspberrymatic addon:
            free -h
            pi@raspberrypi:~ $ free -h
            Mem:          924Mi       330Mi       445Mi       6.0Mi       148Mi       562Mi
            Swap:          99Mi          0B        99Mi
            • R rhartmann76
              free -h
              Swap:          99Mi          0B        99Mi
              #106
              @rhartmann76
              Gut, da ist eigentlich nicht viel los.
              Keine Ahnung warum da auf dem Heap der Speicher ausgeht.
              Und auf dem Master schaut das wie aus?
                @rhartmann76
                rhartmann76
                #107
                @thomas-braun das ist der Master - ich habe auf dem Pi3, wo das zwave Modul steckt, nun den Master eingerichtet.
