  5. (Gelöst)Fehlermeldung Update des Javasript Adapters 5.0.12
    6.3k
javascript
10 Beiträge 6 Kommentatoren 662 Aufrufe 5 Beobachtet
  • N Offline
    N Offline
    nichname
    schrieb am zuletzt editiert von nichname
    Nach dem Update des Javascript Adapters bekomme ich Fehlermeldungen im Log.
    host.raspberrypi	2021-03-09 00:01:31.548	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-03-09 00:01:31.547	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi	2021-03-09 00:01:31.547	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi	2021-03-09 00:01:31.546	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-09 00:01:31.546	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-09 00:01:31.546	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-09 00:01:31.545	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-03-09 00:01:31.545	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.raspberrypi	2021-03-09 00:01:31.545	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-03-09 00:01:31.544	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-03-09 00:01:31.544	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-09 00:01:31.543	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-09 00:01:31.542	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-09 00:01:31.542	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-03-09 00:01:31.541	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js:8:16)
    host.raspberrypi	2021-03-09 00:01:31.540	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-03-09 00:01:31.539	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-03-09 00:01:31.539	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-09 00:01:31.538	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-09 00:01:31.537	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-09 00:01:31.537	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-03-09 00:01:31.536	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/server.js:4:10)
    host.raspberrypi	2021-03-09 00:01:31.536	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-03-09 00:01:31.535	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-03-09 00:01:31.535	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-09 00:01:31.534	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-09 00:01:31.534	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-09 00:01:31.533	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
    host.raspberrypi	2021-03-09 00:01:31.533	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
    host.raspberrypi	2021-03-09 00:01:31.532	error	Caught by controller[0]: SyntaxError: Unexpected end of input
    host.raspberrypi	2021-03-09 00:01:31.531	error	Caught by controller[0]:
    host.raspberrypi	2021-03-09 00:01:31.531	error	Caught by controller[0]: getAllCodeActions: function (context) { return codefix.codeFi
    host.raspberrypi	2021-03-09 00:01:31.529	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:140401
    Auch habe ich ständig bei der Bearbeitung von Scripten die Fehlermeldung Instanz ist deaktiviert.
    Ein Backup habe ich schon eingespielt. Keine Änderung.
    Iobroker läuft... aber ständig hängt der Adapter deaktiviert.
    crunchipC UncleSamU 2 Antworten Letzte Antwort
    • N nichname
      crunchipC Abwesend
      crunchipC Abwesend
      @nichname deine JavascriptInstanz.0 funktioniert?
      • N nichname
        UncleSamU Offline
        UncleSamU Offline
        UncleSam
        @nichname Hast du irgendwo in deinen Scripten Code drin, der wie folgt aussieht?
        N 1 Antwort Letzte Antwort
        • N Offline
          N Offline
          nichname
          @crunchip Javascript.0 funktioniert genau so wie Javascript.1. Beide mit den selben Fehlern. Alle Scripte Laufen aber es kommen ständig die Fehler.
          • UncleSamU UncleSam
            N Offline
            N Offline
            nichname
            @unclesam Nein, so einen Code habe ich nicht im Script.
            • N nichname
              UncleSamU Offline
              UncleSamU Offline
              UncleSam
              @nichname Lädst du irgendwelche weiteren Module?
              • AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                schrieb am zuletzt editiert von AlCalzone
                Die betreffende Zeile kommt direkt aus dem typescript-Modul, welches unter der Haube genutzt wird. Für mich sieht das aus, als wären dessen Dateien kaputt.
                SD-Karte am Arsch?
                • GaspodeG Online
                  GaspodeG Online
                  Gaspode
                  @nichname
                  Da du den Titel auf "gelöst" geändert hast:
                  Wie hast du das Problem denn gelöst? War der Grund wirklich eine defekte SD-Karte?
                  wendy2702W N 2 Antworten Letzte Antwort
                  • GaspodeG Gaspode
                    @nichname
                    wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    @alexi sagte in (Gelöst)Fehlermeldung Update des Javasript Adapters 5.0.12:
                    @nichname
                    SEHR GUTE FRAGE!
                    • GaspodeG Gaspode
                      @nichname
                      N Offline
                      N Offline
                      nichname
                      Habe das Probelm jetzt durch eine Neuinstallation gelöst.
                      SD Karte war nicht defekt!
