  4. fb-checkpresence (Feature is deactivated)
fb-checkpresence
6 Beiträge 2 Kommentatoren 633 Aufrufe 2 Beobachtet
    Teller
    ich habe eine Fritzbox 7330 und bekommen im Log diese Meldungen:
    fb-checkpresence.0	2021-02-15 14:38:52.991	warn	(1975413) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2021-02-15 14:38:52.991	warn	(1975413) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2021-02-15 14:38:52.991	info	(1975413) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2021-02-15 14:38:52.952	warn	(1975413) chkService: "service WLANConfiguration3-GetSecurityKeys is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2021-02-15 14:38:52.951	warn	(1975413) chkService: "service WLANConfiguration3-GetInfo is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2021-02-15 14:38:52.951	warn	(1975413) chkService: "service WLANConfiguration3-SetEnable is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2021-02-15 14:38:52.951	info	(1975413) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2021-02-15 14:38:52.841	info	(1975413) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2021-02-15 14:38:52.725	warn	(1975413) chkService: "service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is not supported! Feature is deactivated!"
    fb-checkpresence.0	2021-02-15 14:38:52.664	info	(1975413) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2021-02-15 14:38:52.609	warn	(1975413) chkService: "service Hosts1-X_AVM-DE_GetMeshListPath is not supported! Feature is deactivated!"
    fb-checkpresence.0	2021-02-15 14:38:52.552	warn	(1975413) chkService: "service Hosts1-X_AVM-DE_GetHostListPath is not supported! Feature is deactivated!"
    Muss ich hier noch was aktiveren, die Einträge in den Objects sind leer.
    afuerhoffA 1 Antwort Letzte Antwort
    • T Teller
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      schrieb am zuletzt editiert von afuerhoff
      @Teller
      Welche Firmware hast Du auf der Fritzbox? Die Meldungen sagen, dass die Firmware die Funktionalität nicht unterstützt und deshalb Funktionen deaktiviert werden.
      • afuerhoffA afuerhoff
        @Teller
        Teller
        schrieb am zuletzt editiert von Teller
        @afuerhoff sagte in fb-checkpresence (Feature is deactivated):
        @Teller
        Ich habe laut der FB die neuste Version:
        Ist laut FTP auch die neuste: https://ftp.avm.de/archive/fritz.box/fritzbox.7330/firmware/deutsch/
        Die Zusatzfunktionen werden gar nicht benötig, ich hätte eigentlich nur gerne die Geräteüberwachung (online/offline). Außer die IP-Adresse in bei den Objekten alles leer.
        • T Teller
          @Teller
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          @teller
          Die 6.55 ist schon etwas betagt. Da ist klar warum nicht alles unterstützt wird.
          Du kannst dann nur die Anwesenheit per MAC-Adresse verwenden und alles andere muss deaktiviert werden.
            @teller
            Teller
            @teller
            Ich habe es jetzt nochmal mit der Github-Version probiert, anbei meine Einstellungen für den Test:
            Verbindung steht mit der Fritzbox aber alle Geräte über die MAC auf false. Hast du vielleicht noch eine Idee?
            (mit und ohne SSL getestet)
            • T Teller
              @teller
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              @teller
              Hallo, die Message ist irgendwie an mir vorbeigegangen. Hast du die Probleme noch?
