  4. [gelöst] update auf 3.2.14 mit Fehlern
4 Beiträge 2 Kommentatoren 444 Aufrufe 3 Beobachtet
  • heinhanH Offline
    heinhanH Offline
    heinhan
    schrieb am zuletzt editiert von heinhan
    Beim Update wurden folgendes angezeigt:
    Update js-controller from @3.2.13 to @3.2.14
    NPM version: 6.14.10
    npm install iobroker.js-controller@3.2.14 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.83-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.83-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.20.1
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    Starting node restart.js
    Aber, alle Instanzen sind auf grün und im LOG werden keine Fehler angezeigt.
    • heinhanH heinhan
      gyp ERR! not ok
      @heinhan
      canvas bzw. pixman-1-dev installieren.
      Möglich, dass das mittlerweile per
      iobroker fix
      funktioniert.
      Und das System per
      sudo apt update
      sudo apt dist-upgrade
      sudo reboot
      auf Stand bringen.
      heinhanH 1 Antwort Letzte Antwort
        @heinhan
        iobroker fix
        funktioniert.
        Und das System per
        sudo apt update
        sudo reboot
        auf Stand bringen.
        heinhanH Offline
        heinhanH Offline
        heinhan
        @thomas-braun Danke für Deine Info. Obige Befehle habe ich durchgeführt, ohne Erfolg. Mit folgendem Befehl wurde das Problem aber beseitigt:
        sudo apt --fix-broken install
        • heinhanH heinhan
          @heinhan
          Dann war deine Paketdatenbank nicht sauber. Das hat aber mit dem ioBroker nix zu tun.
