  5. AirSniffer JavaScript?
    6.3k
javascript
15 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    acidsubway
    schrieb am zuletzt editiert von acidsubway
    ich habe mir einen AirSniffer gekauft, habe aber keine CCU wo ich den Wiffi-WZ adapter benützen kann.
    https://www.stall.biz/project/der-airsniffer-schlechte-luft-kann-man-messen
    Der Sensor haut aber einen json raus:
    // 20210109115441
    // http://192.168.0.37/?json
      "modultyp": "airsniffer",
      "vars": [
          "name": "1",
          "homematic_name": "as_ip",
          "desc": "ip des airsniffer",
          "type": "string",
          "unit": "",
          "value": "192.168.0.37"
          "name": "2",
          "homematic_name": "as_temp",
          "desc": "Temperatur",
          "type": "number",
          "unit": "gradC",
          "value": "21.2"
          "name": "3",
          "homematic_name": "as_feuchte",
          "desc": "Luftfeuchte",
          "type": "number",
          "unit": "%",
          "value": "27.9"
          "name": "19",
          "homematic_name": "as_taupunkt",
          "desc": "Taupunkt",
          "type": "number",
          "unit": "gradC",
          "value": "1.9"
          "name": "18",
          "homematic_name": "as_feuchte_abs",
          "desc": "Absolutfeuchte",
          "type": "number",
          "unit": "g/m3",
          "value": "5.1"
          "name": "9",
          "homematic_name": "as_baro",
          "desc": "Luftdruck",
          "type": "number",
          "unit": "hPa",
          "value": "1020.74"
          "name": "5",
          "homematic_name": "as_luftdrucktrend",
          "desc": "Luftdrucktrend",
          "type": "string",
          "unit": "",
          "value": "stabil"
          "name": "14",
          "homematic_name": "as_pm10",
          "desc": "Partikel 10",
          "type": "number",
          "unit": "ug/m3",
          "value": "18.7"
          "name": "13",
          "homematic_name": "as_pm2_5",
          "desc": "Partikel 2.5",
          "type": "number",
          "unit": "ug/m3",
          "value": "18.6"
          "name": "12",
          "homematic_name": "as_pm1_0",
          "desc": "Partikel 1.0",
          "type": "number",
          "unit": "ug/m3",
          "value": "9.2"
          "name": "17",
          "homematic_name": "as_iaq10",
          "desc": "IAQ Partikel 10",
          "type": "number",
          "unit": "",
          "value": "17"
          "name": "16",
          "homematic_name": "as_iaq1_0",
          "desc": "IAQ Partikel 2.5",
          "type": "number",
          "unit": "",
          "value": "64"
          "name": "15",
          "homematic_name": "as_iaq2_5",
          "desc": "IAQ Partikel 1.0",
          "type": "number",
          "unit": "",
          "value": "38"
          "name": "25",
          "homematic_name": "as_iaq_co2",
          "desc": "Luftqualitaet",
          "type": "number",
          "unit": "",
          "value": "30.00"
          "name": "24",
          "homematic_name": "as_co2_equ",
          "desc": "Luftqualitaetswert",
          "type": "number",
          "unit": "",
          "value": "540.68"
          "name": "23",
          "homematic_name": "as_IAQ_max",
          "desc": "IAQ max",
          "type": "number",
          "unit": "",
          "value": "64"
          "name": "22",
          "homematic_name": "as_IAQ_max_wertung",
          "desc": "IAQ max Wertung",
          "type": "string",
          "unit": "",
          "value": "gut"
          "name": "21",
          "homematic_name": "as_IAQ_max_note",
          "desc": "IAQ max Note",
          "type": "number",
          "unit": "",
          "value": "2"
          "name": "26",
          "homematic_name": "as_r680_value",
          "desc": "Luftqualitaet R",
          "type": "number",
          "unit": "kOhm",
          "value": "296.38"
      "Systeminfo": {
        "MAC-Adresse": "48:3f:da:44:5a:19",
        "Homematic_CCU_ip": "192.168.0.72",
        "WLAN_ssid": "Jebac2",
        "WLAN_Signal_dBm": "-68",
        "sec_seit_reset": "1019577",
        "firmware": "airsniffer_27"
    Kann man das mit einem JavaScript abfragen und als Datenpunke anzeigen?
    Da ich da keine Ahnung davon habe nehme ich gerne jede Hilfe an.
    MfG
    AcidSubway
    paul53P crunchipC 2 Antworten Letzte Antwort
    • A acidsubway
      // 20210109115441
        "vars": [
            "name": "1",
            "type": "string",
            "unit": "",
            "name": "2",
            "type": "number",
            "unit": "gradC",
            "value": "21.2"
            "name": "3",
            "type": "number",
            "unit": "%",
            "value": "27.9"
            "name": "19",
            "desc": "Taupunkt",
            "type": "number",
            "unit": "gradC",
            "value": "1.9"
            "name": "18",
            "type": "number",
            "unit": "g/m3",
            "value": "5.1"
            "name": "9",
            "type": "number",
            "unit": "hPa",
            "value": "1020.74"
            "name": "5",
            "type": "string",
            "unit": "",
            "value": "stabil"
            "name": "14",
            "type": "number",
            "unit": "ug/m3",
            "value": "18.7"
            "name": "13",
            "type": "number",
            "unit": "ug/m3",
            "value": "18.6"
            "name": "12",
            "type": "number",
            "unit": "ug/m3",
            "value": "9.2"
            "name": "17",
            "type": "number",
            "unit": "",
            "value": "17"
            "name": "16",
            "type": "number",
            "unit": "",
            "value": "64"
            "name": "15",
            "type": "number",
            "unit": "",
            "value": "38"
            "name": "25",
            "type": "number",
            "unit": "",
            "value": "30.00"
            "name": "24",
            "type": "number",
            "unit": "",
            "value": "540.68"
            "name": "23",
            "desc": "IAQ max",
            "type": "number",
            "unit": "",
            "value": "64"
            "name": "22",
            "type": "string",
            "unit": "",
            "value": "gut"
            "name": "21",
            "type": "number",
            "unit": "",
            "value": "2"
            "name": "26",
            "type": "number",
            "unit": "kOhm",
            "value": "296.38"
        "Systeminfo": {
      MfG
      AcidSubway
      @acidsubway sagte:
      Wie kommt der JSON in ioBroker an? In einem Datenpunkt?
      A 1 Antwort Letzte Antwort
        @acidsubway sagte:
        acidsubway
        nein, man kann ihn nur Abfragen mit http://192.168.0.37/?json
        MfG
        • A acidsubway
          // 20210109115441
            "vars": [
                "name": "1",
                "type": "string",
                "unit": "",
                "name": "2",
                "type": "number",
                "unit": "gradC",
                "value": "21.2"
                "name": "3",
                "type": "number",
                "unit": "%",
                "value": "27.9"
                "name": "19",
                "desc": "Taupunkt",
                "type": "number",
                "unit": "gradC",
                "value": "1.9"
                "name": "18",
                "type": "number",
                "unit": "g/m3",
                "value": "5.1"
                "name": "9",
                "type": "number",
                "unit": "hPa",
                "value": "1020.74"
                "name": "5",
                "type": "string",
                "unit": "",
                "value": "stabil"
                "name": "14",
                "type": "number",
                "unit": "ug/m3",
                "value": "18.7"
                "name": "13",
                "type": "number",
                "unit": "ug/m3",
                "value": "18.6"
                "name": "12",
                "type": "number",
                "unit": "ug/m3",
                "value": "9.2"
                "name": "17",
                "type": "number",
                "unit": "",
                "value": "17"
                "name": "16",
                "type": "number",
                "unit": "",
                "value": "64"
                "name": "15",
                "type": "number",
                "unit": "",
                "value": "38"
                "name": "25",
                "type": "number",
                "unit": "",
                "value": "30.00"
                "name": "24",
                "type": "number",
                "unit": "",
                "value": "540.68"
                "name": "23",
                "desc": "IAQ max",
                "type": "number",
                "unit": "",
                "value": "64"
                "name": "22",
                "type": "string",
                "unit": "",
                "value": "gut"
                "name": "21",
                "type": "number",
                "unit": "",
                "value": "2"
                "name": "26",
                "type": "number",
                "unit": "kOhm",
                "value": "296.38"
            "Systeminfo": {
          MfG
          AcidSubway
          crunchipC Abwesend
          crunchipC Abwesend
          @acidsubway sagte in AirSniffer JavaScript?:
          deine "ccu" ist doch in dem Fall der IoBroker, zumindest hab ich das so mit meinem Pulscounter und alle Daten werden mit dem Adapter angelegt.
            acidsubway
            @crunchip
            wie hast du das gemacht?
            A crunchipC 2 Antworten Letzte Antwort
            • A acidsubway
              @crunchip
              acidsubway
              ich auch den Adapter wiffi-wz drauf und meinen iobroker als ccu eingestellt, da geht bei mir garnichts, ich habe keine CCU.
              • A acidsubway
                MfG
                @acidsubway sagte:
                Vorschlag (nicht getestet):
                // Airsniffer einlesen und in Datenpunkte schreiben
                const url = 'http://192.168.0.37/?json';
                const path = '0_userdata.0.Luftdaten.';
                schedule('* * * * *', function() { // jede Minute
                    request(url, function(err, response, json) {
                        if(!err && json) {
                            let vars = JSON.parse(json).vars;
                            for(let i = 0; i < vars.length; i++) {
                                let obj = vars[i];
                                let id = path + obj.homematic_name;
                                if(existsState(id)) setState(id, obj.value, true);
                                else {
                                    let role = 'value';
                                    if(obj.type == 'string') role = 'info';
                                    createState(id, obj.value, {type: obj.type, name: obj.desc, unit: obj.unit.replace('gradC', '°C'), role: role});
                • A acidsubway
                  @crunchip
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @acidsubway nach Anleitung eingestellt
                  im Adapter
                  Haupteinstellung
                  • Listen on all Ips
                  Wiffi Geräte
                  Name, Ip deines Gerätes, Zimmer
                  auf deinem Gerät die "CCu" einrichten, mit dem Befehl
                  IpvonGerät/?ccu:myCCU-IP: IPvomIoBroker
                  https://forum.iobroker.net/post/487875
                    im Adapter
                    Haupteinstellung
                    • Listen on all Ips
                    Wiffi Geräte
                    acidsubway
                    @crunchip
                    ich hab ja keine CCU!
                      @acidsubway sagte:
                              if(!err && json) {
                                      let obj = vars[i];
                                      else {
                                          let role = 'value';
                      acidsubway
                      DANKE PAUL!!!!!!!!!!!!!!!!!! es geht!!!!!!!
                      • A acidsubway
                        @acidsubway sagte:
                        es geht!
                        Dann zeige uns mal einen Screenshot der neuen Datenpunkte und markiere das Thema in der Überschrift des ersten Beitrags als [gelöst].
                        • A acidsubway
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @acidsubway oh man ich gebs auf🙄
                          ICH HABE EBENFALLS KEINE CCU
                          du kannst dem Gerät die IP deines IOBROKER geben, was die CCU ersetzt
                            acidsubway
                            @crunchip
                            ich habs nicht hinbekommen, werde deine Posts noch mal durchgehen.
                            hier noch mal ein Fehler der immer wieder aufgetaucht.
                            javascript.0 2021-01-09 14:12:05.537 error (727) Request error: Error: read ECONNRESET
                            • A acidsubway
                              @crunchip
                              @acidsubway sagte:
                              Ist die Abfrage jede Minute vielleicht zu schnell?
                                @acidsubway sagte:
                                acidsubway
                                der sensor ist nicht der schnellst, obwohl es ein esp8266 ist.
