Iobroker startet nicht mehr
Mein iobroker startet nicht mehr und ich bekomme folgende Fehlermeldung bei
iobroker statusBitte um Hilfe für die Behebung
Cannot read system.config: null (OK when migrating or restoring) Cannot find view "system" for search "host" : null iobroker is running on this host. No iobroker host is running. Objects type: file States type: filejs-controller: 3.1.6
admin: 4.1.11
node: v12.20.0
npm: 6.14.8 -
admin: 4.1.11
node: v12.20.0
npm: 6.14.8@JayR
iobroker list instances -
@JayR
iobroker list instances@Thomas-Braun said in Iobroker startet nicht mehr:
pi@Collector:~ $ iobroker list instances Cannot read system.config: null (OK when migrating or restoring) Cannot find view "system" for search "host" : null + instance is alive -
pi@Collector:~ $ iobroker list instances Cannot read system.config: null (OK when migrating or restoring) Cannot find view "system" for search "host" : null + instance is alive@JayR
iobroker stop iobroker fix -
@JayR
iobroker stop iobroker fix@Thomas-Braun said in Iobroker startet nicht mehr:
@JayR
iobroker stop iobroker fixHat nicht geholfen immer noch der gleiche Fehler
@JayR
@JayR
which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs -
@JayR
which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs@Thomas-Braun said in Iobroker startet nicht mehr:
pi@Collector:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs /usr/bin/nodejs v12.20.0 /usr/bin/node v12.20.0 /usr/bin/npm 6.14.8 nodejs: Installiert: 12.20.0-1nodesource1 Installationskandidat: 12.20.0-1nodesource1 Versionstabelle: *** 12.20.0-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.21.0~dfsg-1~deb10u1+rpi1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages -
pi@Collector:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs /usr/bin/nodejs v12.20.0 /usr/bin/node v12.20.0 /usr/bin/npm 6.14.8 nodejs: Installiert: 12.20.0-1nodesource1 Installationskandidat: 12.20.0-1nodesource1 Versionstabelle: *** 12.20.0-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.21.0~dfsg-1~deb10u1+rpi1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages@JayR
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller -
@JayR
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller@Thomas-Braun said in Iobroker startet nicht mehr:
pi@Collector:~ $ iobroker status iobroker is running on this host. At least one iobroker host is running. Objects type: file States type: fileSieht besser aus aber der iobroker startet trotzdem nicht
@JayR
iobroker restart iobroker list instances -
@JayR
iobroker restart iobroker list instances@Thomas-Braun said in Iobroker startet nicht mehr:
pi@Collector:~ $ iobroker restart pi@Collector:~ $ iobroker list instances + instance is alive pi@Collector:~ $ iobroker status iobroker is running on this host. At least one iobroker host is running. Objects type: file States type: file pi@Collector:~ $Komme immer nich nicht auf die Seite
@JayR
iobroker list adapters -
@JayR
iobroker list adapters@Thomas-Braun said in Iobroker startet nicht mehr:
Ich habe den Pi neu aufgesetzt und habe Biobroker neu installiert und ein Backup eingespielt und jetzt bekomme ich folgenden Fehler:
pi@Collector:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs 2021-01-03 10:03:18.852 - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting 2021-01-03 10:03:18.860 - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker 2021-01-03 10:03:18.861 - info: host.Collector hostname: Collector, node: v12.20.0 2021-01-03 10:03:18.863 - info: host.Collector ip addresses: 192.168.20.2 fe80::193:1b45:721e:92d 2021-01-03 10:03:18.987 - info: host.Collector Error inMem-objects listening on port 9001 EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:03:18.992 - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:03:18.994 - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:03:18.996 - info: host.Collector terminated. Could not reset alive status for instances 2021-01-03 10:03:19.001 - info: host.Collector iobroker _restart 2021-01-03 10:03:19.998 - info: host.Collector Error inMem-states listening on port 9000Also I-broker startet immer noch nicht
@JayR
@Homoran said in Iobroker startet nicht mehr:
@JayR sagte in Iobroker startet nicht mehr:
Wie?
Habe den Backup Adapter über die UI installiert und habe das Backup von gestern Abend ausgewählt
@JayR
iobroker fix
pi@Collector:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs 2021-01-03 10:31:38.496 - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting 2021-01-03 10:31:38.503 - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker 2021-01-03 10:31:38.504 - info: host.Collector hostname: Collector, node: v12.20.0 2021-01-03 10:31:38.506 - info: host.Collector ip addresses: 192.168.20.2 fe80::6728:fc45:40bd:6d86 2021-01-03 10:31:40.020 - info: host.Collector Error inMem-objects listening on port 9001 EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:31:40.027 - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:31:40.028 - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:31:40.031 - info: host.Collector terminated. Could not reset alive status for instances 2021-01-03 10:31:40.035 - info: host.Collector iobroker _restart 2021-01-03 10:31:41.296 - info: host.Collector Error inMem-states listening on port 9000 pi@Collector:/opt/iobroker $ iobroker stop pi@Collector:/opt/iobroker $ iobroker fix library: loaded Library version=2020-12-07 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2020-12-07 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_12.x buster InRelease Reading package lists... Done Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@Collector:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs 2021-01-03 10:32:53.481 - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting 2021-01-03 10:32:53.488 - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker 2021-01-03 10:32:53.489 - info: host.Collector hostname: Collector, node: v12.20.0 2021-01-03 10:32:53.491 - info: host.Collector ip addresses: 192.168.20.2 fe80::6728:fc45:40bd:6d86 EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:32:54.959 - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:32:54.960 - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log' 2021-01-03 10:32:54.962 - info: host.Collector terminated. Could not reset alive status for instances 2021-01-03 10:32:54.966 - info: host.Collector iobroker _restartHat auch nichts gebracht. Habe vorher nochmal aufgesetzt und backup von gestern eingespielt.
iobroker fix
@JayR
dmesg -
@JayR
dmesg@Thomas-Braun said in Iobroker startet nicht mehr:
dmesg
pi@Collector:~ $ dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 1012480 [ 0.000000] DMA zone: 2304 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 815872 pages, LIFO batch:63 [ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920 [ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010176 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 smsc95xx.macaddr=DC:A6:32:50:00:01 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=7761be3b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB) [ 0.000000] Memory: 3654596K/4049920K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 133180K reserved, 262144K cma-reserved, 3263488K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 30051 entries in 59 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0 [ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000111] bcm2835: system timer (irq = 17) [ 0.000778] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000798] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000818] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [ 0.000834] Switching to timer-based delay loop, resolution 18ns [ 0.001076] Console: colour dummy device 80x30 [ 0.001568] printk: console [tty1] enabled [ 0.001628] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [ 0.001670] pid_max: default: 32768 minimum: 301 [ 0.001996] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.002037] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.003216] Disabling memory control group subsystem [ 0.003331] CPU: Testing write buffer coherency: ok [ 0.003812] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.004657] Setting up static identity map for 0x200000 - 0x20003c [ 0.004858] rcu: Hierarchical SRCU implementation. [ 0.005491] smp: Bringing up secondary CPUs ... [ 0.006640] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.007904] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.009110] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.009252] smp: Brought up 1 node, 4 CPUs [ 0.009321] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.009346] CPU: All CPU(s) started in HYP mode. [ 0.009369] CPU: Virtualization extensions available. [ 0.010141] devtmpfs: initialized [ 0.023045] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [ 0.023315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.023362] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.031107] pinctrl core: initialized pinctrl subsystem [ 0.032143] NET: Registered protocol family 16 [ 0.035707] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.037342] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.037376] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.037716] Serial: AMBA PL011 UART driver [ 0.041133] bcm2835-mbox fe00b880.mailbox: mailbox enabled [ 0.060888] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start [ 0.070872] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094 [ 0.123663] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1 [ 0.128092] vgaarb: loaded [ 0.128563] SCSI subsystem initialized [ 0.128800] usbcore: registered new interface driver usbfs [ 0.128898] usbcore: registered new interface driver hub [ 0.129029] usbcore: registered new device driver usb [ 0.130521] clocksource: Switched to clocksource arch_sys_counter [ 0.881806] VFS: Disk quotas dquot_6.6.0 [ 0.881936] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.882124] FS-Cache: Loaded [ 0.882306] CacheFiles: Loaded [ 0.883098] simple-framebuffer: probe of 0.framebuffer failed with error -12 [ 0.891135] thermal_sys: Registered thermal governor 'step_wise' [ 0.891493] NET: Registered protocol family 2 [ 0.892281] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 0.892332] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.892426] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.892514] TCP: Hash tables configured (established 8192 bind 8192) [ 0.892668] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.892716] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.892979] NET: Registered protocol family 1 [ 0.893717] RPC: Registered named UNIX socket transport module. [ 0.893746] RPC: Registered udp transport module. [ 0.893770] RPC: Registered tcp transport module. [ 0.893794] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.893828] PCI: CLS 0 bytes, default 64 [ 0.895586] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.897674] Initialise system trusted keyrings [ 0.897918] workingset: timestamp_bits=14 max_order=20 bucket_order=6 [ 0.908543] FS-Cache: Netfs 'nfs' registered for caching [ 0.909285] NFS: Registering the id_resolver key type [ 0.909331] Key type id_resolver registered [ 0.909356] Key type id_legacy registered [ 0.909400] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.910474] Key type asymmetric registered [ 0.910542] Asymmetric key parser 'x509' registered [ 0.910724] bounce: pool size: 64 pages [ 0.910796] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.911027] io scheduler mq-deadline registered [ 0.911055] io scheduler kyber registered [ 0.914781] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [ 0.914822] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff] [ 0.914906] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000 [ 0.914989] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000 [ 0.972633] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC) [ 0.972966] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [ 0.972999] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.973031] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff]) [ 0.973106] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [ 0.973357] pci 0000:00:00.0: PME# supported from D0 D3hot [ 0.976729] PCI: bus0: Fast back to back transfers disabled [ 0.976965] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [ 0.977122] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [ 0.977555] pci 0000:01:00.0: PME# supported from D0 D3cold [ 0.980952] PCI: bus1: Fast back to back transfers disabled [ 0.981023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [ 0.981061] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit] [ 0.981159] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.981195] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [ 0.981507] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [ 0.981749] pcieport 0000:00:00.0: PME: Signaling with IRQ 55 [ 0.982136] pcieport 0000:00:00.0: AER: enabled with IRQ 55 [ 0.982450] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 0.989030] iproc-rng200 fe104000.rng: hwrng registered [ 0.989371] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB) [ 0.989980] vc-sm: Videocore shared memory driver [ 0.990575] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000 [ 1.002086] brd: module loaded [ 1.013778] loop: module loaded [ 1.015072] Loading iSCSI transport class v2.0-870. [ 1.017014] libphy: Fixed MDIO Bus: probed [ 1.017612] bcmgenet fd580000.ethernet: failed to get enet clock [ 1.017645] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [ 1.017680] bcmgenet fd580000.ethernet: failed to get enet-wol clock [ 1.017714] bcmgenet fd580000.ethernet: failed to get enet-eee clock [ 1.017754] bcmgenet: Skipping UMAC reset [ 1.030569] libphy: bcmgenet MII bus: probed [ 1.110631] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [ 1.111635] usbcore: registered new interface driver r8152 [ 1.111715] usbcore: registered new interface driver lan78xx [ 1.111798] usbcore: registered new interface driver smsc95xx [ 1.112211] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 1.112260] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [ 1.114589] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890 [ 1.115860] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 [ 1.115897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.115929] usb usb1: Product: xHCI Host Controller [ 1.115955] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd [ 1.115982] usb usb1: SerialNumber: 0000:01:00.0 [ 1.116565] hub 1-0:1.0: USB hub found [ 1.116670] hub 1-0:1.0: 1 port detected [ 1.117209] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 1.117249] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [ 1.117290] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 1.117742] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04 [ 1.117777] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.117809] usb usb2: Product: xHCI Host Controller [ 1.117835] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd [ 1.117862] usb usb2: SerialNumber: 0000:01:00.0 [ 1.118401] hub 2-0:1.0: USB hub found [ 1.118497] hub 2-0:1.0: 4 ports detected [ 1.119923] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 1.120206] dwc_otg: FIQ enabled [ 1.120217] dwc_otg: NAK holdoff enabled [ 1.120229] dwc_otg: FIQ split-transaction FSM enabled [ 1.120243] Module dwc_common_port init [ 1.120718] usbcore: registered new interface driver uas [ 1.120840] usbcore: registered new interface driver usb-storage [ 1.121043] mousedev: PS/2 mouse device common for all mice [ 1.123034] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 1.125530] sdhci: Secure Digital Host Controller Interface driver [ 1.125560] sdhci: Copyright(c) Pierre Ossman [ 1.126128] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [ 1.126653] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.130354] ledtrig-cpu: registered to indicate activity on CPUs [ 1.130734] hidraw: raw HID events driver (C) Jiri Kosina [ 1.130919] usbcore: registered new interface driver usbhid [ 1.130945] usbhid: USB HID core driver [ 1.131939] vchiq: vchiq_init_state: slot_zero = (ptrval) [ 1.133812] [vc_sm_connected_init]: start [ 1.142681] [vc_sm_connected_init]: end - returning 0 [ 1.144723] Initializing XFRM netlink socket [ 1.144774] NET: Registered protocol family 17 [ 1.144901] Key type dns_resolver registered [ 1.145281] Registering SWP/SWPB emulation handler [ 1.145595] registered taskstats version 1 [ 1.145626] Loading compiled-in X.509 certificates [ 1.146143] Key type ._fscrypt registered [ 1.146170] Key type .fscrypt registered [ 1.156120] uart-pl011 fe201000.serial: cts_event_workaround enabled [ 1.156218] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2 [ 1.162173] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [ 1.163102] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 1.163133] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [ 1.213738] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.215452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.217120] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.220087] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.222385] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.227787] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA [ 1.230566] of_cfs_init [ 1.230687] of_cfs_init: OK [ 1.231741] Waiting for root device PARTUUID=7761be3b-02... [ 1.267632] random: fast init done [ 1.291176] mmc1: new high speed SDIO card at address 0001 [ 1.480554] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 1.663157] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21 [ 1.663195] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.663225] usb 1-1: Product: USB2.0 Hub [ 1.664843] hub 1-1:1.0: USB hub found [ 1.665184] hub 1-1:1.0: 4 ports detected [ 1.811052] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd [ 1.842059] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00 [ 1.842097] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 [ 1.842127] usb 2-1: Product: Best USB Device [ 1.842154] usb 2-1: Manufacturer: ULT-Best [ 1.842179] usb 2-1: SerialNumber: 0420042327B7 [ 1.863132] scsi host0: uas [ 1.864451] scsi 0:0:0:0: Direct-Access SanDisk SSD PLUS 120GB 0 PQ: 0 ANSI: 6 [ 1.866361] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB) [ 1.866555] sd 0:0:0:0: [sda] Write Protect is off [ 1.866588] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 1.866906] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.867593] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes [ 1.870317] sda: sda1 sda2 [ 1.873178] sd 0:0:0:0: [sda] Attached SCSI disk [ 1.902962] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [ 1.903057] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [ 1.905551] devtmpfs: mounted [ 1.913542] Freeing unused kernel memory: 2048K [ 1.940823] Run /sbin/init as init process [ 2.149706] systemd[1]: System time before build time, advancing clock. [ 2.209477] NET: Registered protocol family 10 [ 2.210927] Segment Routing with IPv6 [ 2.237383] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 2.238184] systemd[1]: Detected architecture arm. [ 2.286895] systemd[1]: Set hostname to <Collector>. [ 2.848709] random: systemd: uninitialized urandom read (16 bytes read) [ 2.857687] random: systemd: uninitialized urandom read (16 bytes read) [ 2.858082] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 2.858958] random: systemd: uninitialized urandom read (16 bytes read) [ 2.859443] systemd[1]: Listening on udev Kernel Socket. [ 2.863017] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 2.863869] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 2.882035] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 2.882744] systemd[1]: Listening on fsck to fsckd communication Socket. [ 2.883858] systemd[1]: Listening on udev Control Socket. [ 3.542942] EXT4-fs (sda2): re-mounted. Opts: (null) [ 3.640889] systemd-journald[114]: Received request to flush runtime journal from PID 1 [ 4.125205] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000 [ 4.125700] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [ 4.129607] mc: Linux media interface: v0.10 [ 4.138104] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000 [ 4.143325] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000 [ 4.145577] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [ 4.147648] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 4.147678] [vc_sm_connected_init]: start [ 4.156937] [vc_sm_connected_init]: installed successfully [ 4.164791] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 4.207111] videodev: Linux video capture interface: v2.00 [ 4.239174] bcm2835_audio bcm2835_audio: card created with 8 channels [ 4.247104] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 4.247888] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 4.256671] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [ 4.278056] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 4.306813] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 4.328194] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 4.328259] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 4.328717] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [ 4.329251] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [ 4.329753] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [ 4.330252] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [ 4.330277] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 4.330297] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 4.330316] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 4.330335] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 4.330576] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 4.341423] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 4.341463] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 4.349497] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 4.349539] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 4.421533] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.552795] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.640754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [ 4.646868] [drm] No displays found. Consider forcing hotplug if HDMI is attached [ 4.646991] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4]) [ 4.647014] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 4.647026] [drm] No driver support for vblank timestamp query. [ 4.647037] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL [ 4.648663] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [ 4.673646] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.713394] brcmfmac: F1 signature read @0x18000000=0x15264345 [ 4.731345] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 4.732230] usbcore: registered new interface driver brcmfmac [ 4.739728] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2 [ 4.972427] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 4.986873] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea [ 6.767427] uart-pl011 fe201000.serial: no DMA platform data [ 6.821962] 8021q: 802.1Q VLAN Support v1.8 [ 6.865753] random: crng init done [ 6.865770] random: 7 urandom warning(s) missed due to ratelimiting [ 7.080560] Adding 102396k swap on /var/swap. Priority:-2 extents:2 across:307200k SSFS [ 7.274028] bcmgenet: Skipping UMAC reset [ 7.275478] bcmgenet fd580000.ethernet: configuring instance for external RGMII [ 7.275658] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 7.275841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 13.378458] Bluetooth: Core ver 2.22 [ 13.378515] NET: Registered protocol family 31 [ 13.378523] Bluetooth: HCI device and connection manager initialized [ 13.378540] Bluetooth: HCI socket layer initialized [ 13.378551] Bluetooth: L2CAP socket layer initialized [ 13.378579] Bluetooth: SCO socket layer initialized [ 13.390408] Bluetooth: HCI UART driver ver 2.3 [ 13.390420] Bluetooth: HCI UART protocol H4 registered [ 13.390470] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 13.390699] Bluetooth: HCI UART protocol Broadcom registered [ 13.531883] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 13.531892] Bluetooth: BNEP filters: protocol multicast [ 13.531913] Bluetooth: BNEP socket layer initialized [ 31.124526] FS-Cache: Netfs 'cifs' registered for caching [ 31.138074] Key type cifs.spnego registered [ 31.138090] Key type cifs.idmap registered [ 31.138879] CIFS: Attempting to mount //192.168.1.3/Backup/iobroker -
dmesg
pi@Collector:~ $ dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 1012480 [ 0.000000] DMA zone: 2304 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 815872 pages, LIFO batch:63 [ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920 [ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010176 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 smsc95xx.macaddr=DC:A6:32:50:00:01 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=7761be3b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB) [ 0.000000] Memory: 3654596K/4049920K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 133180K reserved, 262144K cma-reserved, 3263488K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 30051 entries in 59 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0 [ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000111] bcm2835: system timer (irq = 17) [ 0.000778] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000798] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000818] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [ 0.000834] Switching to timer-based delay loop, resolution 18ns [ 0.001076] Console: colour dummy device 80x30 [ 0.001568] printk: console [tty1] enabled [ 0.001628] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [ 0.001670] pid_max: default: 32768 minimum: 301 [ 0.001996] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.002037] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.003216] Disabling memory control group subsystem [ 0.003331] CPU: Testing write buffer coherency: ok [ 0.003812] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.004657] Setting up static identity map for 0x200000 - 0x20003c [ 0.004858] rcu: Hierarchical SRCU implementation. [ 0.005491] smp: Bringing up secondary CPUs ... [ 0.006640] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.007904] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.009110] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.009252] smp: Brought up 1 node, 4 CPUs [ 0.009321] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.009346] CPU: All CPU(s) started in HYP mode. [ 0.009369] CPU: Virtualization extensions available. [ 0.010141] devtmpfs: initialized [ 0.023045] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [ 0.023315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.023362] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.031107] pinctrl core: initialized pinctrl subsystem [ 0.032143] NET: Registered protocol family 16 [ 0.035707] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.037342] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.037376] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.037716] Serial: AMBA PL011 UART driver [ 0.041133] bcm2835-mbox fe00b880.mailbox: mailbox enabled [ 0.060888] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start [ 0.070872] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094 [ 0.123663] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1 [ 0.128092] vgaarb: loaded [ 0.128563] SCSI subsystem initialized [ 0.128800] usbcore: registered new interface driver usbfs [ 0.128898] usbcore: registered new interface driver hub [ 0.129029] usbcore: registered new device driver usb [ 0.130521] clocksource: Switched to clocksource arch_sys_counter [ 0.881806] VFS: Disk quotas dquot_6.6.0 [ 0.881936] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.882124] FS-Cache: Loaded [ 0.882306] CacheFiles: Loaded [ 0.883098] simple-framebuffer: probe of 0.framebuffer failed with error -12 [ 0.891135] thermal_sys: Registered thermal governor 'step_wise' [ 0.891493] NET: Registered protocol family 2 [ 0.892281] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 0.892332] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.892426] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.892514] TCP: Hash tables configured (established 8192 bind 8192) [ 0.892668] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.892716] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.892979] NET: Registered protocol family 1 [ 0.893717] RPC: Registered named UNIX socket transport module. [ 0.893746] RPC: Registered udp transport module. [ 0.893770] RPC: Registered tcp transport module. [ 0.893794] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.893828] PCI: CLS 0 bytes, default 64 [ 0.895586] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.897674] Initialise system trusted keyrings [ 0.897918] workingset: timestamp_bits=14 max_order=20 bucket_order=6 [ 0.908543] FS-Cache: Netfs 'nfs' registered for caching [ 0.909285] NFS: Registering the id_resolver key type [ 0.909331] Key type id_resolver registered [ 0.909356] Key type id_legacy registered [ 0.909400] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.910474] Key type asymmetric registered [ 0.910542] Asymmetric key parser 'x509' registered [ 0.910724] bounce: pool size: 64 pages [ 0.910796] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.911027] io scheduler mq-deadline registered [ 0.911055] io scheduler kyber registered [ 0.914781] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [ 0.914822] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff] [ 0.914906] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000 [ 0.914989] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000 [ 0.972633] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC) [ 0.972966] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [ 0.972999] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.973031] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff]) [ 0.973106] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [ 0.973357] pci 0000:00:00.0: PME# supported from D0 D3hot [ 0.976729] PCI: bus0: Fast back to back transfers disabled [ 0.976965] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [ 0.977122] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [ 0.977555] pci 0000:01:00.0: PME# supported from D0 D3cold [ 0.980952] PCI: bus1: Fast back to back transfers disabled [ 0.981023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [ 0.981061] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit] [ 0.981159] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.981195] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [ 0.981507] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [ 0.981749] pcieport 0000:00:00.0: PME: Signaling with IRQ 55 [ 0.982136] pcieport 0000:00:00.0: AER: enabled with IRQ 55 [ 0.982450] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 0.989030] iproc-rng200 fe104000.rng: hwrng registered [ 0.989371] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB) [ 0.989980] vc-sm: Videocore shared memory driver [ 0.990575] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000 [ 1.002086] brd: module loaded [ 1.013778] loop: module loaded [ 1.015072] Loading iSCSI transport class v2.0-870. [ 1.017014] libphy: Fixed MDIO Bus: probed [ 1.017612] bcmgenet fd580000.ethernet: failed to get enet clock [ 1.017645] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [ 1.017680] bcmgenet fd580000.ethernet: failed to get enet-wol clock [ 1.017714] bcmgenet fd580000.ethernet: failed to get enet-eee clock [ 1.017754] bcmgenet: Skipping UMAC reset [ 1.030569] libphy: bcmgenet MII bus: probed [ 1.110631] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [ 1.111635] usbcore: registered new interface driver r8152 [ 1.111715] usbcore: registered new interface driver lan78xx [ 1.111798] usbcore: registered new interface driver smsc95xx [ 1.112211] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 1.112260] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [ 1.114589] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890 [ 1.115860] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 [ 1.115897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.115929] usb usb1: Product: xHCI Host Controller [ 1.115955] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd [ 1.115982] usb usb1: SerialNumber: 0000:01:00.0 [ 1.116565] hub 1-0:1.0: USB hub found [ 1.116670] hub 1-0:1.0: 1 port detected [ 1.117209] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 1.117249] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [ 1.117290] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 1.117742] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04 [ 1.117777] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.117809] usb usb2: Product: xHCI Host Controller [ 1.117835] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd [ 1.117862] usb usb2: SerialNumber: 0000:01:00.0 [ 1.118401] hub 2-0:1.0: USB hub found [ 1.118497] hub 2-0:1.0: 4 ports detected [ 1.119923] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 1.120206] dwc_otg: FIQ enabled [ 1.120217] dwc_otg: NAK holdoff enabled [ 1.120229] dwc_otg: FIQ split-transaction FSM enabled [ 1.120243] Module dwc_common_port init [ 1.120718] usbcore: registered new interface driver uas [ 1.120840] usbcore: registered new interface driver usb-storage [ 1.121043] mousedev: PS/2 mouse device common for all mice [ 1.123034] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 1.125530] sdhci: Secure Digital Host Controller Interface driver [ 1.125560] sdhci: Copyright(c) Pierre Ossman [ 1.126128] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [ 1.126653] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.130354] ledtrig-cpu: registered to indicate activity on CPUs [ 1.130734] hidraw: raw HID events driver (C) Jiri Kosina [ 1.130919] usbcore: registered new interface driver usbhid [ 1.130945] usbhid: USB HID core driver [ 1.131939] vchiq: vchiq_init_state: slot_zero = (ptrval) [ 1.133812] [vc_sm_connected_init]: start [ 1.142681] [vc_sm_connected_init]: end - returning 0 [ 1.144723] Initializing XFRM netlink socket [ 1.144774] NET: Registered protocol family 17 [ 1.144901] Key type dns_resolver registered [ 1.145281] Registering SWP/SWPB emulation handler [ 1.145595] registered taskstats version 1 [ 1.145626] Loading compiled-in X.509 certificates [ 1.146143] Key type ._fscrypt registered [ 1.146170] Key type .fscrypt registered [ 1.156120] uart-pl011 fe201000.serial: cts_event_workaround enabled [ 1.156218] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2 [ 1.162173] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [ 1.163102] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 1.163133] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [ 1.213738] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.215452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.217120] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.220087] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.222385] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.227787] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA [ 1.230566] of_cfs_init [ 1.230687] of_cfs_init: OK [ 1.231741] Waiting for root device PARTUUID=7761be3b-02... [ 1.267632] random: fast init done [ 1.291176] mmc1: new high speed SDIO card at address 0001 [ 1.480554] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 1.663157] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21 [ 1.663195] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.663225] usb 1-1: Product: USB2.0 Hub [ 1.664843] hub 1-1:1.0: USB hub found [ 1.665184] hub 1-1:1.0: 4 ports detected [ 1.811052] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd [ 1.842059] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00 [ 1.842097] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 [ 1.842127] usb 2-1: Product: Best USB Device [ 1.842154] usb 2-1: Manufacturer: ULT-Best [ 1.842179] usb 2-1: SerialNumber: 0420042327B7 [ 1.863132] scsi host0: uas [ 1.864451] scsi 0:0:0:0: Direct-Access SanDisk SSD PLUS 120GB 0 PQ: 0 ANSI: 6 [ 1.866361] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB) [ 1.866555] sd 0:0:0:0: [sda] Write Protect is off [ 1.866588] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 1.866906] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.867593] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes [ 1.870317] sda: sda1 sda2 [ 1.873178] sd 0:0:0:0: [sda] Attached SCSI disk [ 1.902962] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [ 1.903057] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [ 1.905551] devtmpfs: mounted [ 1.913542] Freeing unused kernel memory: 2048K [ 1.940823] Run /sbin/init as init process [ 2.149706] systemd[1]: System time before build time, advancing clock. [ 2.209477] NET: Registered protocol family 10 [ 2.210927] Segment Routing with IPv6 [ 2.237383] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 2.238184] systemd[1]: Detected architecture arm. [ 2.286895] systemd[1]: Set hostname to <Collector>. [ 2.848709] random: systemd: uninitialized urandom read (16 bytes read) [ 2.857687] random: systemd: uninitialized urandom read (16 bytes read) [ 2.858082] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 2.858958] random: systemd: uninitialized urandom read (16 bytes read) [ 2.859443] systemd[1]: Listening on udev Kernel Socket. [ 2.863017] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 2.863869] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 2.882035] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 2.882744] systemd[1]: Listening on fsck to fsckd communication Socket. [ 2.883858] systemd[1]: Listening on udev Control Socket. [ 3.542942] EXT4-fs (sda2): re-mounted. Opts: (null) [ 3.640889] systemd-journald[114]: Received request to flush runtime journal from PID 1 [ 4.125205] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000 [ 4.125700] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [ 4.129607] mc: Linux media interface: v0.10 [ 4.138104] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000 [ 4.143325] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000 [ 4.145577] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [ 4.147648] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 4.147678] [vc_sm_connected_init]: start [ 4.156937] [vc_sm_connected_init]: installed successfully [ 4.164791] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 4.207111] videodev: Linux video capture interface: v2.00 [ 4.239174] bcm2835_audio bcm2835_audio: card created with 8 channels [ 4.247104] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 4.247888] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 4.256671] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [ 4.278056] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 4.306813] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 4.328194] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 4.328259] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 4.328717] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [ 4.329251] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [ 4.329753] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [ 4.330252] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [ 4.330277] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 4.330297] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 4.330316] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 4.330335] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 4.330576] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 4.341423] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 4.341463] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 4.349497] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 4.349539] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 4.421533] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.552795] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.640754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [ 4.646868] [drm] No displays found. Consider forcing hotplug if HDMI is attached [ 4.646991] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4]) [ 4.647014] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 4.647026] [drm] No driver support for vblank timestamp query. [ 4.647037] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL [ 4.648663] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [ 4.673646] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.713394] brcmfmac: F1 signature read @0x18000000=0x15264345 [ 4.731345] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 4.732230] usbcore: registered new interface driver brcmfmac [ 4.739728] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2 [ 4.972427] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 4.986873] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea [ 6.767427] uart-pl011 fe201000.serial: no DMA platform data [ 6.821962] 8021q: 802.1Q VLAN Support v1.8 [ 6.865753] random: crng init done [ 6.865770] random: 7 urandom warning(s) missed due to ratelimiting [ 7.080560] Adding 102396k swap on /var/swap. Priority:-2 extents:2 across:307200k SSFS [ 7.274028] bcmgenet: Skipping UMAC reset [ 7.275478] bcmgenet fd580000.ethernet: configuring instance for external RGMII [ 7.275658] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 7.275841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 13.378458] Bluetooth: Core ver 2.22 [ 13.378515] NET: Registered protocol family 31 [ 13.378523] Bluetooth: HCI device and connection manager initialized [ 13.378540] Bluetooth: HCI socket layer initialized [ 13.378551] Bluetooth: L2CAP socket layer initialized [ 13.378579] Bluetooth: SCO socket layer initialized [ 13.390408] Bluetooth: HCI UART driver ver 2.3 [ 13.390420] Bluetooth: HCI UART protocol H4 registered [ 13.390470] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 13.390699] Bluetooth: HCI UART protocol Broadcom registered [ 13.531883] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 13.531892] Bluetooth: BNEP filters: protocol multicast [ 13.531913] Bluetooth: BNEP socket layer initialized [ 31.124526] FS-Cache: Netfs 'cifs' registered for caching [ 31.138074] Key type cifs.spnego registered [ 31.138090] Key type cifs.idmap registered [ 31.138879] CIFS: Attempting to mount //192.168.1.3/Backup/iobroker@JayR said in Iobroker startet nicht mehr:
dmesg
pi@Collector:~ $ dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 1012480 [ 0.000000] DMA zone: 2304 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 815872 pages, LIFO batch:63 [ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920 [ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010176 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 smsc95xx.macaddr=DC:A6:32:50:00:01 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=7761be3b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB) [ 0.000000] Memory: 3654596K/4049920K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 133180K reserved, 262144K cma-reserved, 3263488K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 30051 entries in 59 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0 [ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000111] bcm2835: system timer (irq = 17) [ 0.000778] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000798] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000818] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [ 0.000834] Switching to timer-based delay loop, resolution 18ns [ 0.001076] Console: colour dummy device 80x30 [ 0.001568] printk: console [tty1] enabled [ 0.001628] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [ 0.001670] pid_max: default: 32768 minimum: 301 [ 0.001996] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.002037] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.003216] Disabling memory control group subsystem [ 0.003331] CPU: Testing write buffer coherency: ok [ 0.003812] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.004657] Setting up static identity map for 0x200000 - 0x20003c [ 0.004858] rcu: Hierarchical SRCU implementation. [ 0.005491] smp: Bringing up secondary CPUs ... [ 0.006640] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.007904] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.009110] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.009252] smp: Brought up 1 node, 4 CPUs [ 0.009321] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.009346] CPU: All CPU(s) started in HYP mode. [ 0.009369] CPU: Virtualization extensions available. [ 0.010141] devtmpfs: initialized [ 0.023045] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [ 0.023315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.023362] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.031107] pinctrl core: initialized pinctrl subsystem [ 0.032143] NET: Registered protocol family 16 [ 0.035707] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.037342] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.037376] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.037716] Serial: AMBA PL011 UART driver [ 0.041133] bcm2835-mbox fe00b880.mailbox: mailbox enabled [ 0.060888] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start [ 0.070872] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094 [ 0.123663] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1 [ 0.128092] vgaarb: loaded [ 0.128563] SCSI subsystem initialized [ 0.128800] usbcore: registered new interface driver usbfs [ 0.128898] usbcore: registered new interface driver hub [ 0.129029] usbcore: registered new device driver usb [ 0.130521] clocksource: Switched to clocksource arch_sys_counter [ 0.881806] VFS: Disk quotas dquot_6.6.0 [ 0.881936] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.882124] FS-Cache: Loaded [ 0.882306] CacheFiles: Loaded [ 0.883098] simple-framebuffer: probe of 0.framebuffer failed with error -12 [ 0.891135] thermal_sys: Registered thermal governor 'step_wise' [ 0.891493] NET: Registered protocol family 2 [ 0.892281] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 0.892332] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.892426] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.892514] TCP: Hash tables configured (established 8192 bind 8192) [ 0.892668] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.892716] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.892979] NET: Registered protocol family 1 [ 0.893717] RPC: Registered named UNIX socket transport module. [ 0.893746] RPC: Registered udp transport module. [ 0.893770] RPC: Registered tcp transport module. [ 0.893794] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.893828] PCI: CLS 0 bytes, default 64 [ 0.895586] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.897674] Initialise system trusted keyrings [ 0.897918] workingset: timestamp_bits=14 max_order=20 bucket_order=6 [ 0.908543] FS-Cache: Netfs 'nfs' registered for caching [ 0.909285] NFS: Registering the id_resolver key type [ 0.909331] Key type id_resolver registered [ 0.909356] Key type id_legacy registered [ 0.909400] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.910474] Key type asymmetric registered [ 0.910542] Asymmetric key parser 'x509' registered [ 0.910724] bounce: pool size: 64 pages [ 0.910796] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.911027] io scheduler mq-deadline registered [ 0.911055] io scheduler kyber registered [ 0.914781] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [ 0.914822] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff] [ 0.914906] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000 [ 0.914989] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000 [ 0.972633] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC) [ 0.972966] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [ 0.972999] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.973031] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff]) [ 0.973106] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [ 0.973357] pci 0000:00:00.0: PME# supported from D0 D3hot [ 0.976729] PCI: bus0: Fast back to back transfers disabled [ 0.976965] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [ 0.977122] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [ 0.977555] pci 0000:01:00.0: PME# supported from D0 D3cold [ 0.980952] PCI: bus1: Fast back to back transfers disabled [ 0.981023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [ 0.981061] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit] [ 0.981159] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.981195] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [ 0.981507] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [ 0.981749] pcieport 0000:00:00.0: PME: Signaling with IRQ 55 [ 0.982136] pcieport 0000:00:00.0: AER: enabled with IRQ 55 [ 0.982450] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 0.989030] iproc-rng200 fe104000.rng: hwrng registered [ 0.989371] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB) [ 0.989980] vc-sm: Videocore shared memory driver [ 0.990575] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000 [ 1.002086] brd: module loaded [ 1.013778] loop: module loaded [ 1.015072] Loading iSCSI transport class v2.0-870. [ 1.017014] libphy: Fixed MDIO Bus: probed [ 1.017612] bcmgenet fd580000.ethernet: failed to get enet clock [ 1.017645] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [ 1.017680] bcmgenet fd580000.ethernet: failed to get enet-wol clock [ 1.017714] bcmgenet fd580000.ethernet: failed to get enet-eee clock [ 1.017754] bcmgenet: Skipping UMAC reset [ 1.030569] libphy: bcmgenet MII bus: probed [ 1.110631] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [ 1.111635] usbcore: registered new interface driver r8152 [ 1.111715] usbcore: registered new interface driver lan78xx [ 1.111798] usbcore: registered new interface driver smsc95xx [ 1.112211] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 1.112260] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [ 1.114589] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890 [ 1.115860] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 [ 1.115897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.115929] usb usb1: Product: xHCI Host Controller [ 1.115955] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd [ 1.115982] usb usb1: SerialNumber: 0000:01:00.0 [ 1.116565] hub 1-0:1.0: USB hub found [ 1.116670] hub 1-0:1.0: 1 port detected [ 1.117209] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 1.117249] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [ 1.117290] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 1.117742] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04 [ 1.117777] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.117809] usb usb2: Product: xHCI Host Controller [ 1.117835] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd [ 1.117862] usb usb2: SerialNumber: 0000:01:00.0 [ 1.118401] hub 2-0:1.0: USB hub found [ 1.118497] hub 2-0:1.0: 4 ports detected [ 1.119923] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 1.120206] dwc_otg: FIQ enabled [ 1.120217] dwc_otg: NAK holdoff enabled [ 1.120229] dwc_otg: FIQ split-transaction FSM enabled [ 1.120243] Module dwc_common_port init [ 1.120718] usbcore: registered new interface driver uas [ 1.120840] usbcore: registered new interface driver usb-storage [ 1.121043] mousedev: PS/2 mouse device common for all mice [ 1.123034] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 1.125530] sdhci: Secure Digital Host Controller Interface driver [ 1.125560] sdhci: Copyright(c) Pierre Ossman [ 1.126128] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [ 1.126653] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.130354] ledtrig-cpu: registered to indicate activity on CPUs [ 1.130734] hidraw: raw HID events driver (C) Jiri Kosina [ 1.130919] usbcore: registered new interface driver usbhid [ 1.130945] usbhid: USB HID core driver [ 1.131939] vchiq: vchiq_init_state: slot_zero = (ptrval) [ 1.133812] [vc_sm_connected_init]: start [ 1.142681] [vc_sm_connected_init]: end - returning 0 [ 1.144723] Initializing XFRM netlink socket [ 1.144774] NET: Registered protocol family 17 [ 1.144901] Key type dns_resolver registered [ 1.145281] Registering SWP/SWPB emulation handler [ 1.145595] registered taskstats version 1 [ 1.145626] Loading compiled-in X.509 certificates [ 1.146143] Key type ._fscrypt registered [ 1.146170] Key type .fscrypt registered [ 1.156120] uart-pl011 fe201000.serial: cts_event_workaround enabled [ 1.156218] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2 [ 1.162173] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [ 1.163102] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 1.163133] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [ 1.213738] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.215452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.217120] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.220087] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.222385] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.227787] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA [ 1.230566] of_cfs_init [ 1.230687] of_cfs_init: OK [ 1.231741] Waiting for root device PARTUUID=7761be3b-02... [ 1.267632] random: fast init done [ 1.291176] mmc1: new high speed SDIO card at address 0001 [ 1.480554] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 1.663157] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21 [ 1.663195] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.663225] usb 1-1: Product: USB2.0 Hub [ 1.664843] hub 1-1:1.0: USB hub found [ 1.665184] hub 1-1:1.0: 4 ports detected [ 1.811052] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd [ 1.842059] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00 [ 1.842097] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 [ 1.842127] usb 2-1: Product: Best USB Device [ 1.842154] usb 2-1: Manufacturer: ULT-Best [ 1.842179] usb 2-1: SerialNumber: 0420042327B7 [ 1.863132] scsi host0: uas [ 1.864451] scsi 0:0:0:0: Direct-Access SanDisk SSD PLUS 120GB 0 PQ: 0 ANSI: 6 [ 1.866361] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB) [ 1.866555] sd 0:0:0:0: [sda] Write Protect is off [ 1.866588] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 1.866906] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.867593] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes [ 1.870317] sda: sda1 sda2 [ 1.873178] sd 0:0:0:0: [sda] Attached SCSI disk [ 1.902962] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [ 1.903057] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [ 1.905551] devtmpfs: mounted [ 1.913542] Freeing unused kernel memory: 2048K [ 1.940823] Run /sbin/init as init process [ 2.149706] systemd[1]: System time before build time, advancing clock. [ 2.209477] NET: Registered protocol family 10 [ 2.210927] Segment Routing with IPv6 [ 2.237383] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 2.238184] systemd[1]: Detected architecture arm. [ 2.286895] systemd[1]: Set hostname to <Collector>. [ 2.848709] random: systemd: uninitialized urandom read (16 bytes read) [ 2.857687] random: systemd: uninitialized urandom read (16 bytes read) [ 2.858082] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 2.858958] random: systemd: uninitialized urandom read (16 bytes read) [ 2.859443] systemd[1]: Listening on udev Kernel Socket. [ 2.863017] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 2.863869] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 2.882035] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 2.882744] systemd[1]: Listening on fsck to fsckd communication Socket. [ 2.883858] systemd[1]: Listening on udev Control Socket. [ 3.542942] EXT4-fs (sda2): re-mounted. Opts: (null) [ 3.640889] systemd-journald[114]: Received request to flush runtime journal from PID 1 [ 4.125205] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000 [ 4.125700] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [ 4.129607] mc: Linux media interface: v0.10 [ 4.138104] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000 [ 4.143325] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000 [ 4.145577] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [ 4.147648] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 4.147678] [vc_sm_connected_init]: start [ 4.156937] [vc_sm_connected_init]: installed successfully [ 4.164791] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 4.207111] videodev: Linux video capture interface: v2.00 [ 4.239174] bcm2835_audio bcm2835_audio: card created with 8 channels [ 4.247104] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 4.247888] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 4.256671] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [ 4.278056] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 4.306813] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 4.328194] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 4.328259] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 4.328717] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [ 4.329251] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [ 4.329753] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [ 4.330252] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [ 4.330277] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 4.330297] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 4.330316] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 4.330335] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 4.330576] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 4.341423] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 4.341463] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 4.349497] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 4.349539] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 4.421533] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.552795] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.640754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [ 4.646868] [drm] No displays found. Consider forcing hotplug if HDMI is attached [ 4.646991] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4]) [ 4.647014] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 4.647026] [drm] No driver support for vblank timestamp query. [ 4.647037] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL [ 4.648663] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [ 4.673646] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.713394] brcmfmac: F1 signature read @0x18000000=0x15264345 [ 4.731345] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 4.732230] usbcore: registered new interface driver brcmfmac [ 4.739728] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2 [ 4.972427] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 4.986873] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea [ 6.767427] uart-pl011 fe201000.serial: no DMA platform data [ 6.821962] 8021q: 802.1Q VLAN Support v1.8 [ 6.865753] random: crng init done [ 6.865770] random: 7 urandom warning(s) missed due to ratelimiting [ 7.080560] Adding 102396k swap on /var/swap. Priority:-2 extents:2 across:307200k SSFS [ 7.274028] bcmgenet: Skipping UMAC reset [ 7.275478] bcmgenet fd580000.ethernet: configuring instance for external RGMII [ 7.275658] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 7.275841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 13.378458] Bluetooth: Core ver 2.22 [ 13.378515] NET: Registered protocol family 31 [ 13.378523] Bluetooth: HCI device and connection manager initialized [ 13.378540] Bluetooth: HCI socket layer initialized [ 13.378551] Bluetooth: L2CAP socket layer initialized [ 13.378579] Bluetooth: SCO socket layer initialized [ 13.390408] Bluetooth: HCI UART driver ver 2.3 [ 13.390420] Bluetooth: HCI UART protocol H4 registered [ 13.390470] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 13.390699] Bluetooth: HCI UART protocol Broadcom registered [ 13.531883] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 13.531892] Bluetooth: BNEP filters: protocol multicast [ 13.531913] Bluetooth: BNEP socket layer initialized [ 31.124526] FS-Cache: Netfs 'cifs' registered for caching [ 31.138074] Key type cifs.spnego registered [ 31.138090] Key type cifs.idmap registered [ 31.138879] CIFS: Attempting to mount //192.168.1.3/Backup/iobrokerpi@Collector:~ $ node node_modules/iobroker.js-controller/controller.js --logs internal/modules/cjs/loader.js:818 throw err; ^ Error: Cannot find module '/home/pi/node_modules/iobroker.js-controller/controller.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) at internal/main/run_main_module.js:17:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } pi@Collector:~ $
