  4. Fehler mit Ring Livestream
ring adapteriobrokeradapterfehlererror
9 Beiträge 3 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • JayRJ Offline
    JayRJ Offline
    JayR
    ich kann im Ring Adapter kein Live Video starten. Bekomme immer diesen Fehler:
    ring.0	2020-12-03 16:48:55.510	info	(8720) Terminated (NO_ERROR): Without reason
    ring.0	2020-12-03 16:48:55.509	info	(8720) terminating
    ring.0	2020-12-03 16:48:55.499	error	(8720) Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed at doWrite (_stream_writable.js:399:19) at writeOrBuffer (_stream_writable.js:387:5) at Socket.Writable.
    ring.0	2020-12-03 16:48:55.499	error	(8720) unhandled promise rejection: Cannot call write after a stream was destroyed
    ring.0	2020-12-03 16:48:55.499	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0	2020-12-03 16:48:55.490	info	(8720) Closing Adapter
    ring.0	2020-12-03 16:48:55.488	error	(8720) Error: spawn ffmpeg ENOENT at Process.ChildProcess._handle.onexit (internal/child_process.js:267:19) at onErrorNT (internal/child_process.js:469:16) at processTicksAndRejections (in
    ring.0	2020-12-03 16:48:55.486	error	(8720) uncaught exception: spawn ffmpeg ENOENT
    ring.0	2020-12-03 16:48:55.250	info	(8720) Starting creating livestream with recording time 10 sec.
    ring.0	2020-12-03 16:48:55.247	info	(8720) Ding Dong for Id 54439917 (on_demand, ringing)
    ring.0	2020-12-03 16:48:55.246	info	(8720) Ding Dong for Id 54439917 (on_demand, ringing)
    Jemand eine Idee?
    • JayRJ JayR
      Jemand eine Idee?
      @JayR
      Falls da Debian oder artverwandtes läuft:
      apt policy ffmpeg
      Wenn das nicht installiert ist:
      sudo apt update
      sudo apt install ffmpeg
      sudo apt dist-upgrade
      sudo reboot
      JayRJ 1 Antwort Letzte Antwort
        @JayR
        apt policy ffmpeg
        sudo apt update
        sudo reboot
        JayRJ Offline
        JayRJ Offline
        JayR
        @Thomas-Braun : Wow, danke für die schnelle Hilfe funktioniert. Andere Frage: wie kann ich das Ganze am besten Visualisieren. Die Datei heißt ja jedes mal anders kann diese ja nicht richtig einbinden. Wie macjt ihr das?
        • JayRJ JayR
          @JayR
          Hab kein vis laufen.
            @JayR
            JayRJ Offline
            JayRJ Offline
            JayR
            @Thomas-Braun :
            Bekomme nun folgenden Fehler. Hast du dazu auch eine Lösung in der Schublade liegen :)
            ring.0	2020-12-06 16:21:26.562	error	(1676) Error: Error setSanpshot()): Error: Could not create Snapshot for 54439917 in getSnapshot(). Error: Snapshot failed to refresh after 40 attempts
            ring.0	2020-12-06 16:21:26.560	info	(1676) Starting creating snapshot
            ring.0	2020-12-06 16:21:20.907	error	(1676) Error: Error setSanpshot()): Error: Could not create Snapshot for 54439917 in getSnapshot(). Error: Snapshot failed to refresh after 40 attempts
            ring.0	2020-12-06 16:21:20.906	info	(1676) Starting creating snapshot
            ring.0	2020-12-06 16:21:20.891	info	(1676) Ding Dong for Id 54439917 (on_demand, ringing)
            ring.0	2020-12-06 16:21:20.879	info	(1676) Ding Dong for Id 54439917 (on_demand, ringing)
            Thomas BraunT W 2 Antworten Letzte Antwort
            • JayRJ JayR
              @Thomas-Braun :
              @JayR
              Tut mir leid, die Schublade ist jetzt leer.
              • JayRJ JayR
                @Thomas-Braun :
                W Offline
                W Offline
                Winnipuuh
                @jayr und @Thomas-Braun
                ich habe leider das selbe Problem gibt es mittlerweile eine Lösung hierzu?
                LG
                Thomas BraunT JayRJ 2 Antworten Letzte Antwort
                • W Winnipuuh
                  LG
                  @winnipuuh
                  Welches?
                  Bitte ein eigenes Thema starten mit den Meldungen aus deinem System.
                  • W Winnipuuh
                    LG
                    JayRJ Offline
                    JayRJ Offline
                    JayR
                    @winnipuuh : Ne leider nicht und der Adapter funktioniert leider auch nicht zuverlässig. Finde die Qualität von manchen Adapter einfach nicht gut. Ich weiß alle Entwickler sind ehrenamtlich und verdienen damit kein Geld. Aber die Adapter sind ein ausschlaggebender Punkt für die Akzeptanz und die Qualität eines solchen Smarthomesystems.
                    Bei Homeassistant ist die Qualität von Integrationen viel viel Besser leider ist das scripting und die individualisierung von visualisierung nicht einfach.
                    Wenn ich mehr Zeit habe werde ich ein neuen Ring Adapter oder den Aktuellen neu entwickeln.
