  4. Backitup für einen auf dem Synology laufenden IO-Broker
nas backitup docker
46 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • M Mueller1842
    Debug-Liste
    tarted...
    [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":""},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":""},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":""},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":""},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":""},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.DS-Iobroker-Master 407 states saved
    [DEBUG] [iobroker] - host.DS-Iobroker-Master 513 objects saved
    [ERROR] [iobroker] - host.DS-Iobroker-Master Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2020_11_01-22_32_28_backupiobroker.tar.gz'
    [ERROR] [iobroker] - host.DS-Iobroker-Master Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
    [DEBUG] [iobroker] - done
    [ERROR] [historyDB] - [IGNORED] No source for compress!
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [history] - backitup.0.history.html
    [EXIT] 9
    [DEBUG] [history] - backitup.0.history.json
    [EXIT] 9
    [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":""},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"","time":"01. November 2020 at 22:32 Hours"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":""},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":""},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":""},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"","time":"01. November 2020 at 22:32 Hours"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":""},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":""},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":""},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":""},"backupDir":"/opt/iobroker/backups"}
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @Mueller1842
    Editiere dein Beitrag !!!!
    zu CodeTags ...
    • GlasfaserG Glasfaser
      @Mueller1842 sagte in Backitup für einen auf dem Synology laufenden IO-Broker:
      @Glasfaser
      hast du auch nicht iobroker selber gemountet !?
      sehe nur ein Eintrag .
      Mueller1842
      @Glasfaser
      Dann wahrscheinlich eher nicht.
      Wo und wie macht man das?
      • M Mueller1842
        Debug-Liste
        tarted...
        [EXIT] 9
        [EXIT] 9
        AggroRalf
        Hi @Mueller1842,
        mal eine andere Frage: Bei Docker hast Du ja den Mount aufs File-System für das Verzeichnis "iobroker-data".
        Warum sicherst Du nicht einfach das mit den Bordmitteln von Synology ?
        Damit und mit einem neuen Docker-Image sollte der Restore ja kein Problem sein.
        • M Mueller1842
          @Glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Du meinst jetzt iobroker Mount .... siehe ganz oben mein Screenshot
          • A AggroRalf
            Hi @Mueller1842,
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @AggroRalf sagte in Backitup für einen auf dem Synology laufenden IO-Broker:
            Das kann er später mal machen ... bring Ihn nicht durcheinander .
            Er hat ja noch kein Mount dazu !!!
              Mueller1842
              @Glasfaser
              Sorry, leider finde ich für den 2. Eintrag keinen passenden Ordner. Wenn ich das richtig verstehe, erstellt der Adapter erst mal einen Backup in der Dockerumgebung und dann wird der rüberkopiert auf die eigentliche Sicherungsstelle.
              Aber so was für den 2. Eintrag finde ich im Menü leider nicht:
              GlasfaserG 2 Antworten Letzte Antwort
              • M Mueller1842
                @Glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @Mueller1842
                Du must schon den Ordner selber dazu erstellen.
                da wird nichts kopiert .... der Ordner wird ist/nur gemountet .
                • M Mueller1842
                  @Glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  @Mueller1842
                  Da stimmt etwas mit den Rechten vom Ordner nicht .
                  und editiere den Log in Code-Tags !!!!!!!!!!!!!!!!!!!!!!
                    @Mueller1842
                    Mueller1842
                    @Glasfaser
                    So, jetzt habe ich diese Einstellung
                    "Editiere den Log in Code-Tags"??? Sorry, für mich nur Bahnhof.
                    • M Mueller1842
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      Habe oben ein kleines Video dazu dir eingefügt , wie es geht
                      Hast du den Ordner über das Dockerfenster angelegt ( Ordner hinzufügen )!??? :
                        Mueller1842
                        @Glasfaser
                        Ich habe den Ordner erst in der Filestation erstellt und dann über das Fenster zugefügt.
                        • M Mueller1842
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          @Mueller1842
                          Beide Ordner oder nur den für den Backups !?
                            @Mueller1842
                            Mueller1842
                            @Glasfaser
                            Im Prinzip beide. Die Backupverzeichnisse waren schon früher eingerichtet und über das Fenster hinzugefügt.
                            Das Fehlende habe ich gerade eben erstellt und dann mit dem Fenster eingerichtet.
                            Das mit dem Edit-Log... War das so gemeint?
                            • M Mueller1842
                              @Glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              fast ...
                              schau dir das Video an :
                              Klicke auf das Symbol </> und dann wo code_text steht , ersetzt du es mit deinem Logtext
                              code_text
                                fast ...
                                code_text
                                Mueller1842
                                @Glasfaser
                                Habe es hoffe ich jetzt hingekriegt.
                                • M Mueller1842
                                  @Glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  @Mueller1842
                                  .... gehen wir mal vom Log weg ..
                                  ..... dazu habe ich dir ja schon geantwortet was für eine Fehlermeldung ausschlaggebend war.
                                  Wie weit bist du jetzt ... hast du alle zwei Ordner gemountet und iobroker gestartet.
                                  Wird der Mountorder ( opt/iobroker ) jetzt befüllt
                                    @Mueller1842
                                    Mueller1842
                                    @Glasfaser
                                    Der neue Ordner wird befüllt.
                                    In dem anderen Ordner steht noch nichts drin.
                                    • M Mueller1842
                                      @Glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      sehr gut ...
                                      lösche den anderen Ordner (für Backups) ...... und lege ihn so an wie du Ihn jetzt für ioBroker angelegt hast .
                                        sehr gut ...
                                        Mueller1842
                                        @Glasfaser
                                        Ist passiert. Muss ich den jetzt gerade erstellten Ordner auch wieder neu mounten?
                                        • M Mueller1842
                                          @Glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          @Mueller1842
                                          ich denke mal schon ... du hast ihm doch einen anderen Namen gegeben !?
                                          Später must du darauf achten , wer den Ordner benutzen darf .
                                          Siehe hier bei mir :
                                          Also nicht root sondern der User 1000 ( ist dann Docker ioBroker )
