  4. Verbindungsprobleme mit Fritzbox
    6.7k
fritzbox 7590
33 Beiträge 6 Kommentatoren 2.0k Aufrufe 5 Beobachtet
  • ? Offline
    Seit einigen Tagen hakelt es bei Verbindung zur Fritz box.
    Bevor ich morgen ein Backup auf die Fritz box zurück hole und mir damit eventuell neue Problem auflade frage ich lieber bei euch noch mal nach. So sieht das aus:
    tr-064.0	2020-10-31 19:26:19.107	info	(15855) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.19.0, js-controller: 3.1.6
    tr-064.0	2020-10-31 19:26:19.019	info	(15855) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    tr-064.0	2020-10-31 19:25:47.465	warn	(15816) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-10-31 19:25:47.465	error	(15816) ~
    tr-064.0	2020-10-31 19:25:47.465	error	(15816) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
    tr-064.0	2020-10-31 19:25:47.464	error	(15816) ~~ Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-10-31 19:25:47.463	error	(15816) Error: connect ETIMEDOUT 192.168.0.1:49000 - {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.0.1","port":49000}
    tr-064.0	2020-10-31 19:23:40.131	info	(15816) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.19.0, js-controller: 3.1.6
    tr-064.0	2020-10-31 19:23:40.083	info	(15816) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    tr-064.0	2020-10-31 19:23:08.617	warn	(15795) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-10-31 19:23:08.617	error	(15795) ~
    tr-064.0	2020-10-31 19:23:08.617	error	(15795) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
    tr-064.0	2020-10-31 19:23:08.616	error	(15795) ~~ Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-10-31 19:23:08.616	error	(15795) Error: connect ETIMEDOUT 192.168.0.1:49000 - {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.0.1","port":49000}
    tr-064.0	2020-10-31 19:21:01.348	info	(15795) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.19.0, js-controller: 3.1.6
    tr-064.0	2020-10-31 19:21:01.301	info	(15795) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    • IOBroker läuft unter Docker.
    • Fritzbox ist per Ping von der Shell IOBroker aus erreichbar.*
    • Heimnetzfreigabe ist erteilt:
      • Zugriff für Anwendungen zulassen
      • Statusinformationen über UPnP übertragen
    • Anmeldung erfolgt mit FRITZ!Box-Benutzernamen und Kennwort
    • Benutzernamen und Passwort neu vergeben
    • Fritzbox neu gestartet.
    • Adapter und Docker neu gestertet-
    Diese Adapter laufen:
    Fritzbox; Fritzdect.
    diese nicht: ( liefen aber mal !)
    fb-checkpresence, tr-064 V4.1.0
    LGKlaus
    Ralla66R Thomas BraunT crunchipC 3 Antworten Letzte Antwort
      @dslraser sagte in Verbindungsprobleme mit Fritzbox:
      und das hier vielleicht noch
      https://forum.iobroker.net/post/512173
      FB neu gestartet. Sicherheitshalber die beiden Hacken oben weggenommen und danach wieder gesetzt..
      Den TR-64 Adapter habe ich nicht re - installiert. Würde mich wundern wenn es danach ginge
      habe nun gestern Abend ein Restore - nur Heimnetz und Benutzer - gemacht. fb-checkpresence, tr-064 laufen damit wieder. Das blöde ist, dass ich keinen Unterschied bei der FB-Konfiguration vor und nach Restore feststellen kann.
      Vielen Dank für euer Interesse!
        LGKlaus
        Ralla66R Offline
        Ralla66R Offline
        Ralla66
        @biker sagte in Verbindungsprobleme mit Fritzbox:
        Das lass mal sein kommt ja vom tr-064.
        Da hat der Adapter ein Prob aber deine Fritte nicht.
          LGKlaus
          @biker
          192.168.0.1
          Ist die richtige IP?
          Unverändert liegt die Box auf
          192.168.178.1
          ? 1 Antwort Letzte Antwort
            @biker
            192.168.0.1
            192.168.178.1
            @Thomas-Braun sagte in Verbindungsprobleme mit Fritzbox:
            192.168.0.1
            ja immer schon bei mir auf 192.168.0.1 ...
              LGKlaus
              crunchipC Offline
              crunchipC Offline
              @biker hatte ich auch vor kurzem, habe in der Instanz, die IP erneut eingegeben und gespeichert, danach lief es wieder
                @crunchip
                hatte gelesen, das Neueingabe von Passwort erfolgreich war. habe ich gemacht
                Nun auch noch die Adressen neu eingegeben und gespeichert ..
                Leider ohne Erfolg .
                host.iobroker	2020-10-31 20:55:37.296	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                tr-064.0	2020-10-31 20:55:36.778	warn	(17034) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                tr-064.0	2020-10-31 20:55:36.777	error	(17034) ~
                tr-064.0	2020-10-31 20:55:36.777	error	(17034) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                tr-064.0	2020-10-31 20:55:36.776	error	(17034) ~~ Fatal error. Can not connect to your FritzBox.
                tr-064.0	2020-10-31 20:55:36.775	error	(17034) Error: connect ETIMEDOUT 192.168.0.1:49000 - {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.0.1","port":49000}
                  @crunchip
                  Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  @biker
                  Adapter IP auf xxx.xxx.xxx.1 schlimmer geht nicht,
                  Thomas BraunT ? 2 Antworten Letzte Antwort
                  • Ralla66R Ralla66
                    @biker
                    @Ralla66 Warum?
                    • Ralla66R Ralla66
                      @biker
                      @Ralla66 sagte in Verbindungsprobleme mit Fritzbox:
                      @biker
                      Wahrscheinlich geht es besser, bin geeigneteren Adressvergaben gegenüber offen ?
                      Aber ist das denn wirklich so Fatal bzw- Ursache des Problems ?
                      Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                        @biker
                        @biker Welche Firmware läuft auf der Kiste?
                          FRITZ!OS: 07.20 -
                          • dslraserD Offline
                            dslraserD Offline
                            dslraser
                            hier war was ähnliches. Lösung steht auch da.
                            https://forum.iobroker.net/post/512369
                            Lösung war, bei jeder Änderung im Adapter das Kennwort vom User der Fritte neu von Hand in den Adaptereinstellungen eingeben.
                            Edit: vorher vielleicht die Fritte auch neu starten, so wie es in der Fehlermeldung steht.
                            ? Thomas BraunT 2 Antworten Letzte Antwort
                            • dslraserD dslraser
                                @biker
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                Nein, ist es ganz sicher nicht
                                ° Fixer ---> iob fix
                                  @dslraser Witzigerweise war auch dort das Gateway nicht unter 192.168.178.1
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    stimmt, ist es bei mir aber auch nicht und es funktioniert.
                                      @dslraser Muss es ja auch.
                                      Warum .1 jetzt 'schlimm' sein soll muss @Ralla66 aber auch nochmal erläutern.
                                        @Ralla66 Warum?
                                        Ralla66R Offline
                                        Ralla66R Offline
                                        Ralla66
                                        @Thomas-Braun
                                        weil meist auf 1 der Router liegt.
                                        Ich vermeide deswegen 1.
                                        Nicht Tragisch wenn xxx.xxx.anders.1 ist.
                                        • Ralla66R Ralla66
                                          @Thomas-Braun
                                          @Ralla66 Die fragliche FritzBox ist ja auch der Router. Nehme ich jedenfalls stark an.
                                          • NegaleinN Negalein
                                            @Negalein sagte in Verbindungsprobleme mit Fritzbox:
                                            danke !
