  4. Yet another HomeKit adapter
    6.4k
1.8k Beiträge 206 Kommentatoren 1.1m Aufrufe 68 Beobachtet
  • J Offline
    JW86
    #521
    @eumats:
    Eine ähnliche Idee hatte ich auch schon und fummele da schon ein paar Nächte dran rum, aber es hapert bei mir an der Umsetzung. Daher wäre ich Dir sehr dankbar, wenn Du mir das Skript erstellen könntest!! `
    Probier mal das hier:
    const FallbackTimerInMilliseconds = 10000;
    ! function FibaroWindowCoverStateEmulator(levelId, powerId, fakeCurrentStateId, fakeTargetStateId) {
    this.levelId = levelId;
    this.powerId = powerId;
    this.fakeCurrentStateId = fakeCurrentStateId;
    this.fakeTargetStateId = fakeTargetStateId;
    this.fallbackTimerId = undefined;
    on({id: levelId}, () => this.refreshFakeStates());
    on({id: powerId}, () => this.refreshFakeStates());
    on({id: fakeTargetStateId}, this.fakeTargetChanged.bind(this))
    ! FibaroWindowCoverStateEmulator.prototype = {
    refreshFakeStates: function() {
    var level = getState(this.levelId).val;
    var levelAck = getState(this.levelId).ack;
    var power = getState(this.powerId).val;
    var powerAck = getState(this.powerId).ack;
        console.log('refreshing fake states, level: ' + level + '(' + levelAck + ') | power: ' + power + '(' + powerAck + ')');
        if (levelAck) {
            this.setCurrentState(level, 'level ack is true');
        } else {
            this.setTargetState(level, 'level ack is false');
        this.clearFallbackTimer();
        if (power < 1) {
            this.setupFallbackTimer();
    clearFallbackTimer: function() {
        if(this.fallbackTimerId === undefined)
            return;
        clearTimeout(this.fallbackTimerId);
    setupFallbackTimer: function() {
        if(this.fallbackTimerId !== undefined)
        setTimeout(this.fallbackTimerRaised.bind(this), FallbackTimerInMilliseconds);
    fallbackTimerRaised: function() {
        this.setCurrentState(level, 'fallback timer');
        this.setTargetState(level, 'fallback timer');
    setCurrentState: function(value, reason) {
        setState(this.fakeCurrentStateId, value, true);
        console.log('setted ' + this.fakeCurrentStateId + ' to ' + value + ' | reason: ' + reason);
    setTargetState: function(value, reason) {
        setState(this.fakeTargetStateId, value, true);
        console.log('setted ' + this.fakeTargetStateId + ' to ' + value + ' | reason: ' + reason);
    setLevel: function(value, reason) {
        setState(this.levelId, value, true);
        console.log('setted ' + this.levelId + ' to ' + value + ' | reason: ' + reason);
    fakeTargetChanged: function(stateObject) {
        if (stateObject.newState.ack) {
            console.log('cancel fake target change handler - ack is true');
            return
        this.setLevel(stateObject.newState.val, 'fake target changed');
    ! var test1 = new FibaroWindowCoverStateEmulator("Test1.Level", "Test1.Power2", "Test1.fakeCurrent", "Test1.fakeTarget")
    FallbackTimerInMilliseconds kannst du wahrscheinlich kleiner machen - musst du testen.
    In Homekit CurrentState und TargetState auf die Fake Werte schauen lassen. Conversion kann jetzt "passthrough" sein.
    Wie zuvor auch, musst du die beiden States selbst anlegen.
    Falls was nicht geht, log posten ;-)
    • eumatsE Offline
      eumatsE Offline
      eumats
      #522
      @JW86:
      Falls was nicht geht, log posten ;-) `
      Wow. Das ging schnell. Besten Dank.
      Ein erster kurzer Test hat leider nicht funktioniert. Ich wollte den Rollladen von 33% auf 22% fahren lassen. Der Slide ist dann wieder auf 31% zurückgefallen.
      De Anzeige in HomeKit (wird geöffnet, …) war leider auch nicht korrekt... Meine yahka Konfiguration siehe Screenshot...
      Log-Ausgabe:
      javascript.0 2018-01-16 22:52:06.504 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:06.504 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:06.503 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:06.485 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:06.484 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:06.483 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:05.083 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:05.079 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:05.078 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:05.018 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:05.014 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:05.013 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:04.994 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:04.994 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:04.993 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:04.947 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:04.943 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:04.942 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: fallback timer
      javascript.0 2018-01-16 22:52:04.496 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: level ack is true
      javascript.0 2018-01-16 22:52:04.495 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: refreshing fake states, level: 31(true) | power: 0.7(true)
      javascript.0 2018-01-16 22:52:04.474 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 31 | reason: level ack is true
      javascript.0 2018-01-16 22:52:04.473 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: refreshing fake states, level: 31(true) | power: 0.7(true)
      javascript.0 2018-01-16 22:52:03.072 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 33 | reason: level ack is true
      javascript.0 2018-01-16 22:52:03.071 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: refreshing fake states, level: 33(true) | power: 0.7(true)
      javascript.0 2018-01-16 22:52:03.008 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.CurrentLevel to 33 | reason: level ack is true
      javascript.0 2018-01-16 22:52:03.007 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: refreshing fake states, level: 33(true) | power: 0.7(true)
      javascript.0 2018-01-16 22:52:02.988 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:02.985 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 31 | reason: level ack is false
      javascript.0 2018-01-16 22:52:02.985 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: refreshing fake states, level: 31(false) | power: 0.7(true)
      javascript.0 2018-01-16 22:52:02.978 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.LevelRollo to 31 | reason: fake target changed
      javascript.0 2018-01-16 22:52:02.944 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: cancel fake target change handler - ack is true
      javascript.0 2018-01-16 22:52:02.940 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.TargetLevel to 22 | reason: level ack is false
      javascript.0 2018-01-16 22:52:02.939 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: refreshing fake states, level: 22(false) | power: 0.7(true)
      javascript.0 2018-01-16 22:52:02.927 info script.js.common.Devices.Rolladen.FibaroWindowCoverStateEmulator: setted javascript.0.virtualDevice.Rolllaeden.EsszimmerOsten.LevelRollo to 22 | reason: fake target changed
      die Funktion setLevel musste ich wie folgt anpassen, da sonst der Fibaro Autor nicht getriggert wird.
          //setState(this.levelId, value, true);
          setState(this.levelId, value);
      [3610_untitled.jpg](/assets/uploads/files/3610_untitled.jpg)
      • eumatsE Offline
        eumatsE Offline
        eumats
        #523
        @eumats:
        De Anzeige in HomeKit (wird geöffnet, …) war leider auch nicht korrekt... `
        @ JW86:
        In Anlehnung an den Skript habe ich nun eine Lösung gefunden. Ich werde sie bei Gelegenheit hier im Forum posten…
        Nach mal Danke für Deine Hilfe!
          danny030
          #524
          vermutlich seid ihr die Frage schon leid, aber ich habe nun auch dieses ominöse Cannot start file.
          Bei mir lief der Adapter unter 0.5.5 reibungslos - alles in Ordnung. Ich habe mir dann, scheinbar dummerweise, zugetraut das Update auf 0.6.1 durchzuführen über "Installieren aus eigenem URL".
          Anschließend kommt im Log:
          startInstance yahka.0: cannot find start file!
          Alles, was ich bisher dazu als mögliche Lösungen gelesen habe, funktioniert nicht. Den Adapter kann ich als Instanz hinzufügen. Wenn ich das Konfigurationsmenü öffne, sind alle Buttons aber wirkungslos. Es passiert nichts, wenn man drauf klickt.
          ! sudo apt-get install avahi-daemon libnss-mdns avahi-discover avahi-utils sudo nano /etc/avahi/avahi-daemon.conf ! host-name=sd-pi domain-name=local enable-dbus=yes disable-publishing=no disable-user-service-publishing=no ! sudo /etc/init.d/avahi-daemon restart !
          ! Und schließlich sogar Neustart von ioBroker (über Admin)
          Während ich schreibe, ein Downgrade auf 0.6.0 sah erst etwas besser aus. Konfiguration ist nun möglich. Der Adapter läuft aber nicht, bleibt rot. Fehlermeldung im Log:
          ! Restart adapter system.adapter.yahka.0 because enabled host.sd-pi 2018-01-27 23:17:45.311 error instance system.adapter.yahka.0 terminated with code 1 () host.sd-pi 2018-01-27 23:17:45.311 error Caught by controller[2]: at bootstrap_node.js:608:3 host.sd-pi 2018-01-27 23:17:45.311 error Caught by controller[2]: at startup (bootstrap_node.js:187:16) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at Function.Module.runMain (module.js:684:10) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at Function.Module._load (module.js:491:3) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at tryModuleLoad (module.js:499:12) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at Module.load (module.js:556:32) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at Object.Module._extensions..js (module.js:654:10) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at Module._compile (module.js:643:30) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/main.js:5:57) host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: TypeError: utils.adapter is not a function host.sd-pi 2018-01-27 23:17:45.310 error Caught by controller[2]: ^ host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[2]: var yahkaAdapter = new hkAdapter.TIOBrokerAdapter(utils.adapter({ name: 'yahka', systemConfig: true }), utils.controllerDir); host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[2]: /opt/iobroker/node_modules/iobroker.yahka/main.js:5 host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[1]: *** WARNING *** For more information see host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi! host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[1]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[1]: *** WARNING *** For more information see host.sd-pi 2018-01-27 23:17:45.309 error Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi! host.sd-pi 2018-01-27 23:17:45.306 error Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. host.sd-pi 2018-01-27 23:17:44.449 info instance system.adapter.yahka.0 started with pid 30758 !
          Jetzt bin ich wieder zurück auf 0.5.5. Alle Einstellungen trotzdem leider weg. Ich habe vorher mit ioBroker backup ein Backup erstellt und konnte daher mit ioBroker restore 0 die Daten wiederherstellen. ABER:
          Jetzt ist der yahka-Adapter trotzdem kaputt. Alles andere funktioniert wieder/weiterhin, nur yahka nicht. Fehlermeldung sieht übel aus:
          ! ` > host.sd-pi 2018-01-27 23:32:44.415 error instance system.adapter.yahka.0 terminated with code 0 (OK)
          Caught 2018-01-27 23:32:44.415 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 4
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
          Caught 2018-01-27 23:32:44.414 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["getSt
          Caught 2018-01-27 23:32:44.413 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
          Caught 2018-01-27 23:32:44.413 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/
          Caught 2018-01-27 23:32:44.413 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 3
          Caught 2018-01-27 23:32:44.413 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
          Caught 2018-01-27 23:32:44.413 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging"]]}
          Caught 2018-01-27 23:32:44.413 error by controller[173]: Sat, 27 Jan 2018 22:32:44 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
          Caught 2018-01-27 23:32:44.412 error by controller[172]: Sat, 27 Jan 2018 22:32:44 GMT engine.io-client:socket flushing 35 packets in socket
          Caught 2018-01-27 23:32:44.412 error by controller[171]: Sat, 27 Jan 2018 22:32:44 GMT engine.io-client:socket flushing 11 packets in socket
          Caught 2018-01-27 23:32:44.412 error by controller[170]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
          Caught 2018-01-27 23:32:44.412 error by controller[170]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
          Caught 2018-01-27 23:32:44.412 error by controller[170]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
          Caught 2018-01-27 23:32:44.411 error by controller[169]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 2
          Caught 2018-01-27 23:32:44.411 error by controller[168]: at EventedHTTPServer. (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10) errorCode: -65537 }
          Caught 2018-01-27 23:32:44.411 error by controller[168]: at EventedHTTPServer.emit (events.js:211:7)
          Caught 2018-01-27 23:32:44.411 error by controller[168]: at emitOne (events.js:116:13)
          Caught 2018-01-27 23:32:44.411 error by controller[168]: at HAPServer._onListening (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
          Caught 2018-01-27 23:32:44.411 error by controller[168]: at HAPServer.emit (events.js:211:7)
          Caught 2018-01-27 23:32:44.410 error by controller[168]: at emitOne (events.js:116:13)
          Caught 2018-01-27 23:32:44.410 error by controller[168]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/lib/Accessory.js:661:20)
          Caught 2018-01-27 23:32:44.410 error by controller[168]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
          Caught 2018-01-27 23:32:44.410 error by controller[168]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/iobroker.yahka/node_modules/mdns/lib/advertisement.js:64:10)
          Caught 2018-01-27 23:32:44.410 error by controller[168]: at new Advertisement (/opt/iobroker/node_modules/iobroker.yahka/node_modules/mdns/lib/advertisement.js:56:10)
          Caught 2018-01-27 23:32:44.410 error by controller[168]: { Error: dns service error: unknown
          Caught 2018-01-27 23:32:44.410 error by controller[167]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yahka.0.
          Caught 2018-01-27 23:32:44.409 error by controller[167]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.409 error by controller[166]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.409 error by controller[165]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.409 error by controller[165]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.409 error by controller[165]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.408 error by controller[164]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.408 error by controller[164]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.407 error by controller[164]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.407 error by controller[163]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 18
          Caught 2018-01-27 23:32:44.407 error by controller[162]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.407 error by controller[162]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.407 error by controller[162]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.406 error by controller[161]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.406 error by controller[161]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.406 error by controller[161]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.406 error by controller[160]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 17
          Caught 2018-01-27 23:32:44.406 error by controller[159]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.405 error by controller[159]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.405 error by controller[159]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.405 error by controller[158]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.405 error by controller[158]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.405 error by controller[158]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.404 error by controller[157]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 16
          Caught 2018-01-27 23:32:44.404 error by controller[156]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.404 error by controller[155]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.404 error by controller[155]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.404 error by controller[155]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.403 error by controller[154]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.403 error by controller[154]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.403 error by controller[154]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 15
          Caught 2018-01-27 23:32:44.403 error by controller[153]: HAP Warning: Characteristic 0000006D-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291. Adding anyway.
          Caught 2018-01-27 23:32:44.402 error by controller[152]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.402 error by controller[152]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.402 error by controller[152]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.402 error by controller[151]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.402 error by controller[151]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.401 error by controller[151]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.401 error by controller[150]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 14
          Caught 2018-01-27 23:32:44.401 error by controller[149]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.401 error by controller[149]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.401 error by controller[149]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.401 error by controller[148]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.400 error by controller[148]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.400 error by controller[148]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.400 error by controller[147]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 13
          Caught 2018-01-27 23:32:44.400 error by controller[146]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.400 error by controller[146]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.399 error by controller[145]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.399 error by controller[145]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.399 error by controller[145]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.399 error by controller[144]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.399 error by controller[144]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 12
          Caught 2018-01-27 23:32:44.398 error by controller[143]: HAP Warning: Characteristic 0000006D-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291. Adding anyway.
          Caught 2018-01-27 23:32:44.398 error by controller[142]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.398 error by controller[142]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.398 error by controller[142]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.398 error by controller[141]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.397 error by controller[141]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.397 error by controller[141]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.397 error by controller[140]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 11
          Caught 2018-01-27 23:32:44.397 error by controller[139]: HAP Warning: Characteristic 0000006D-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291. Adding anyway.
          Caught 2018-01-27 23:32:44.397 error by controller[138]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.396 error by controller[138]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.396 error by controller[138]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.396 error by controller[137]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.396 error by controller[137]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.396 error by controller[137]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.395 error by controller[136]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 10
          Caught 2018-01-27 23:32:44.395 error by controller[135]: HAP Warning: Characteristic 0000006D-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291. Adding anyway.
          Caught 2018-01-27 23:32:44.395 error by controller[134]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.395 error by controller[134]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.394 error by controller[134]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.394 error by controller[133]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
          Caught 2018-01-27 23:32:44.394 error by controller[133]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
          Caught 2018-01-27 23:32:44.394 error by controller[133]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
          Caught 2018-01-27 23:32:44.394 error by controller[132]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:socket emitting packet with ack id 9
          Caught 2018-01-27 23:32:44.393 error by controller[131]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.adapt
          Caught 2018-01-27 23:32:44.393 error by controller[131]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.393 error by controller[131]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"}
          Caught 2018-01-27 23:32:44.393 error by controller[131]: Sat, 27 Jan 2018 22:32:44 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya `
          Jemand noch einen Vorschlag? Auch Reboot des Raspberry hat nichts geändert.
          Viele Grüße
          Daniel
          PS. einmal mehr, never change a running system :roll:
            Monox
            #525
            bei mir funktioniert die 0.60.0 und 0.60.1 auch nicht, allerdings kann ich ohne Problem zurück zur 0.5.5..
            direkt beim update findet sich folgendes bei mir im log..
            ! 2018-01-28 12:59:12.463 - info: iobroker upgrade yahka
            ! 2018-01-28 12:59:15.106 - info: iobroker Update yahka from @0.5.5 to @0.6.1
            ! 2018-01-28 12:59:15.111 - info: iobroker npm install iobroker.yahka@0.6.1 –production --prefix "/opt/iobroker" (System call)
            ! 2018-01-28 12:59:24.474 - error: yahka.0 uncaught exception: dns service error: unknown
            ! 2018-01-28 12:59:24.489 - error: yahka.0 Error: dns service error: unknown
            ! at Advertisement.on_service_registered (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/lib/advertisement.js:42:24)
            ! at SocketWatcher.MDNSService.self.watcher.callback (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/lib/mdns_service.js:18:40)
            ! 2018-01-28 12:59:24.493 - info: yahka.0 cleaned everything up...
            ! 2018-01-28 12:59:24.529 - info: yahka.0 terminating
            ! 2018-01-28 12:59:24.601 - error: host.iobroker instance system.adapter.yahka.0 terminated with code 0 (OK)
            ! 2018-01-28 12:59:24.602 - info: host.iobroker Restart adapter system.adapter.yahka.0 because enabled
            ! 2018-01-28 12:59:54.633 - info: host.iobroker instance system.adapter.yahka.0 started with pid 25147
            ! 2018-01-28 12:59:55.501 - error: host.iobroker instance system.adapter.yahka.0 terminated with code 1 ()
            ! 2018-01-28 12:59:55.502 - info: host.iobroker Restart adapter system.adapter.yahka.0 because enabled
            nach dem Update von avahi-daemon avahi-discover libnss-mdns sieht es so aus…..
            ! 2018-01-28 13:33:07.069 - info: iobroker upgrade yahka
            ! 2018-01-28 13:33:09.882 - info: iobroker Update yahka from @0.5.5 to @0.6.1
            ! 2018-01-28 13:33:09.889 - info: iobroker npm install iobroker.yahka@0.6.1 –production --prefix "/opt/iobroker" (System call)
            ! 2018-01-28 13:35:19.025 - info: iobroker npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.yahka"
            ! 2018-01-28 13:35:22.142 - info: iobroker got /opt/iobroker/node_modules/iobroker.yahka/admin
            ! 2018-01-28 13:35:22.168 - info: iobroker upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
            ! 2018-01-28 13:35:22.193 - info: yahka.0 objectChange system.adapter.yahka {"_id":"system.adapter.yahka","type":"adapter","common":{"name":"yahka","version":"0.6.1","news":{"0.6.1":{"en":"Fixed a bug which prevent Yahka from Start","de":"Fixed a bug which prevent Yahka from Start","ru":"Fixed a bug which prevent Yahka from Start"},"0.6.0":{"en":"Support for IP-Cameras","de":"Support für IP-Kameras","ru":"Поддержка IP-Камер"},"0.5.5":{"en":"Make a config dialog bigger","de":"Config-Dialog ist vergrößert","ru":"Увеличен размер окна настроек"}},"title":"Homekit yahka adapter","desc":{"en":"ioBroker yet another homekit adapter","de":"ioBroker yet another homekit adapter","ru":"ioBroker Homekit адаптер"},"platform":"Javascript/Node.js","mode":"daemon","icon":"yahka.png","enabled":true,"extIcon":"<url url="https://raw.githubusercontent.com/jensweigele/ioBroker.yahka/master/admin/yahka.png","keywords"}],"installedVersion":"0.6.1"},"native":{"firstTimeInitialized":false,"bridge":{"devices":[]}},"from":"system.host.iobroker.cli","ts":1517142922121}
            ! 2018-01-28 13:35:22.299 - info: iobroker Update "system.adapter.yahka.0"upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
            ! 2018-01-28 13:35:22.331 - info: host.iobroker object change system.adapter.yahka.0
            ! 2018-01-28 13:35:22.339 - info: yahka.0 cleaned everything up…
            ! 2018-01-28 13:35:22.335 - info: host.iobroker stopInstance system.adapter.yahka.0
            ! 2018-01-28 13:35:22.335 - info: host.iobroker stopInstance system.adapter.yahka.0 killing pid 2758
            ! 2018-01-28 13:35:22.360 - info: yahka.0 terminating
            ! 2018-01-28 13:35:22.420 - info: host.iobroker instance system.adapter.yahka.0 terminated with code 0 (OK)
            ! 2018-01-28 13:35:22.428 - info: iobroker upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
            ! 2018-01-28 13:35:22.528 - info: iobroker upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
            ! 2018-01-28 13:35:22.595 - info: iobroker upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
            ! 2018-01-28 13:35:22.666 - info: iobroker upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
            ! 2018-01-28 13:35:22.730 - info: iobroker upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
            ! 2018-01-28 13:35:22.839 - info: iobroker upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
            ! 2018-01-28 13:35:23.177 - info: iobroker upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
            ! 2018-01-28 13:35:23.313 - info: iobroker upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
            ! 2018-01-28 13:35:23.463 - info: iobroker upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
            ! 2018-01-28 13:35:23.777 - info: iobroker upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
            ! 2018-01-28 13:35:23.879 - info: iobroker upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
            ! 2018-01-28 13:35:23.986 - info: iobroker upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
            ! 2018-01-28 13:35:24.054 - info: iobroker upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
            ! 2018-01-28 13:35:24.116 - info: iobroker upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
            ! 2018-01-28 13:35:24.178 - info: iobroker upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
            ! 2018-01-28 13:35:24.246 - info: iobroker upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
            ! 2018-01-28 13:35:24.314 - info: iobroker upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
            ! 2018-01-28 13:35:24.388 - info: iobroker Adapter "yahka" updated
            ! 2018-01-28 13:35:24.433 - info: iobroker exit 0
            ! 2018-01-28 13:35:24.894 - info: host.iobroker instance system.adapter.yahka.0 started with pid 7125
            ! 2018-01-28 13:35:26.080 - error: host.iobroker instance system.adapter.yahka.0 terminated with code 1 ()
            ! 2018-01-28 13:35:26.081 - info: host.iobroker Restart adapter system.adapter.yahka.0 because enabled
            Grüße Monox
              danny030
              #526
              Ich hab immerhin die 0.5.5 auch wieder zum Laufen gebracht. Musste alles, was ich in der /etc/avahi/avahi-daemon.conf geändert habe (also entfernen der Kommentare) wieder auskommentieren und den Ursprungszustand herstellen. Dann ging auch die 0.5.5 wieder.
              Würde natürlich trotzdem gerne die aktuelle Version verwenden, wenn also jemand noch einen Tipp dazu hat, wäre ich dankbar.
              Viele Grüße
              Danny
                Palood
                #527
                ich habe in den letzten Tagen mit dem Adapter ein wenig rumgespielt und soweit klappt es auch (bis auf sehr viele Fehler beim Speichern der Instanz). Aber anschließend funktioniert trotz der Fehler soweit alles.
                Allerdings habe ich es noch nicht hinbekommen, den State CurrentSecuritySystemState zu verwenden. Ich habe einen State angelegt, um die 5 States zu speichern (0-4). Also ein State als Integer/Number.
                Das Problem ist, dass das Lesen des States problemlos klappt und eine Änderung im ioBroker sofort in Homekit übernommen wird.
                Wenn ich jedoch in Homekit versuche den Status zu ändern, sagt Homekit dauerhaft nur "Aktualisieren" und im ioBroker ändert sich leider nichts.
                Fehlt hier vielleicht noch eine Implementierung?
                Grüße,
                Jan
                • eumatsE Offline
                  eumatsE Offline
                  eumats
                  #528
                  Was sind denn die Ausgaben wenn du auf Debug stellst?
                    Palood
                    #529
                    das Problem hat sich gerade erledigt.
                    Über den Homekit Developer Simulator konnte ich gerade erkennen, dass folgendes passiert:
                    SecuritySystemCurrentState: Wenn sich dieser Status ändert, wird der Status an Homekit übermittelt.
                    SecuritySystemTargetState: Dieser Status wird von Homekit versendet und erwartet entsprechend die Bestätigung durch den CurrentState.
                    Daher: Ich habe nun den State im ioBroker als Current und Target gesetzt und schon funktioniert es prima.
                    Gruß Jan
                    • C Offline
                      captaindork
                      #530
                      Hi zusammen,
                      Ich wollte grade mal versuchen meine Bewässerung von Switch auf die neuen Valves/Faucets von 0.7.0 umzustellen (Danke @JW).
                      Leider tauchen diese bei den Servicetypen im Dropdown aber garnicht auf. Muss ich da unter der Haube noch was tun? Ein Update von hap-nodejs oder sowas? Sorry, bin lost…
                      Thx
                      • eumatsE Offline
                        eumatsE Offline
                        eumats
                        #531
                        Versuch mal ein „iobroker yahka upload“ und dann den Adapter neu starten.
                        • C Offline
                          captaindork
                          #532
                          …danke!!! der wars!
                          • I Offline
                            I Offline
                            izi
                            #533
                            @Paulchen67:
                            @JW86:
                            @Paulchen67:
                            Danke, aber leider funktioniert das bei Homematic Dimmern auch nicht. `
                            Kannst du mal Screenshots deiner Konfig schicken? `
                            So hab ich sie momentan eingestellt.
                            Funktioniert so halbwegs. Licht flackert beim regeln, geht nicht immer aus beim Aus drücken.
                            Merkt nicht das das Licht an ist wenn es von anderer Stelle eingeschaltet wird.
                            Homematic Dimmer HM-LC-Dim1TPBU-FM
                            Das sind die Objekteigenschaften dazu.
                            Das ist die andere Variante an Dimmer die ich im Einsatz habe.
                            Da ist das verhalten noch schlechter.
                            Homematic iP Dimmer HmIP-FDT
                            Die Objekteigenschaften dazu:
                            Astrein funktionieren die Dimmer wenn ich sie in Yahka als Door definiere.
                            Was halt daran unschön ist, ist die Darstellung in der Home App als Tür und
                            an Stelle von Ein/Aus steht halt Geöffnet/Geschlossen dran.
                            Hatte dir schon mal ne PN geschrieben wegen dem Einfügen des Dimmer in die Yahka Dropdown Liste.
                            Gruss Paulchen `
                            Hallo Paulchen,
                            hast Du mittlerweile eine bessere Lösung zur Einstellung der Homematic Dimmer in YAHKA gefunden?
                            Ich bin nämlich letzte Woche auf das gleiche Problem gestoßen als ich recht selbstsicher als letztes die Dimmeraktoren in YAHKA einrichten wollte :?
                            izi
                            • Paulchen67P Offline
                              Paulchen67P Offline
                              Paulchen67
                              #534
                              @izi:
                              Hallo Paulchen,
                              izi `
                              @JW86:
                              Ok. Ich habe nun auch mal einen Dimmer Testweise eingerichtet um zu schauen was Homekit so sendet wenn man an/aus schaltet etc.
                              Aus meiner Sicht bekommst du deine Dimmer aktuell nicht in Yahka zum laufen (als Lightbulb). Du könntest es mit Javascript vllt irgendwie hinbekommen.
                              Ich mach mir mal dazu Gedanken und schreibe erstelle einen GitHub-Issue `
                              So hat JW86 der den YAhka Adapter gemacht hat geantwortet, und auf dem Stand stehe ich momentan.
                              Hab an den Dimmer seither nichts gemacht.
                              ioBroker mit Ubuntu auf Intel NUC
                              piVCCU auf Raspberry Pi 3
                              • W Offline
                                W Offline
                                worfinator
                                #535
                                Hallo zusammen!
                                Ich habe hier HmIP-BROLL statt der normalen HomeMatic Rolladenaktoren. Steuern kann ich sie. Allerdings fehlt mir "DIRECTION" das gibt es so in der Form dort nicht.
                                Entsprechend falsch ist auch die Anzeige in HomeKit. Hat jemand schon eine Lösung dafür?
                                Grüße,
                                Marc.
                                • W Offline
                                  W Offline
                                  worfinator
                                  #536
                                  Hey Leute!
                                  Für die HmIP BROLL dürfte es ansich einfach möglich sein, den Status zu konvertieren.
                                  Ich wollte gerne eine Funktion erstellten, die ich direkt bei "PositionState" eintragen kann, die also den richtigen Wert zurückliefert.
                                  Leider weiss ich nicht, wie ich an den Quell-Wert komme. Der steht bei dem HmIP BROLL in Kanal 4 unter SECTION.
                                  parameter=this.4.SECTION; war so ein versucht. Funktioniert aber nicht. Direkt die Geräte ID will ich da nicht hinpacken, die Funktion soll für mehrere BROLL
                                  funktionieren.
                                  Naja. Wie ich konvertieren muss ist mir klar, siehe der Code unten. Aber wie ich zurück liefern müsste ist mir auch nicht klar.
                                  setState(this.PositionState, rollade_direction, true);
                                  War auch so ein Versuch.
                                  Ich hoffe, jemand Kundiges hier kann mir die entscheidendes Tipps geben. Dann sollte die HmIP BROLL mit diesem Adapter eigentlich laufen.
                                  (So ich denn dann nicht auf neue Probleme stosse…)
                                  var parameter;
                                  var rollade_direction;
                                  rollade_direction = 0;
                                  if (parameter==3)
                                      rollade_direction = 1;
                                  if (parameter==7)
                                      rollade_direction = 2;
                                  console.log(rollade_direction);
                                    Applefrank
                                    #537
                                    Hat jemand eine Idee wie ich einen CO2 Sensor im yahka Homekit Adapter einbinden kann, damit er mir die ppm Werte anzeigt.
                                    Lieben Gruß aus den Berliner Umland
                                      m.bumann
                                      #538
                                      hat es schon jemand geschafft eine HUE-RGB mit dem Homekit-Adapter zum Laufen zu bekommen? Normale White-LED funktionieren tadellos. Selbst die Ikea Tradfri LED mit unterschiedlicher Farbtemperatur funktioniert problemlos. Aber bei einer RGB bekomme ich einfach keinen Farbwechsel hin. Hat vielleicht jemand ein Beispiel?
                                      • W Offline
                                        W Offline
                                        worfinator
                                        #539
                                        @Applefrank:
                                        Lieben Gruß aus den Berliner Umland `
                                        Das ist ganz einfach! Einfach den Service "CarbonDioxideService" auswählen und dann "CarbonDioxideLevel" mit dem ppm-Wert füllen!
                                        Für den Alarm "CarbonDioxideDetected" auf 1 oder 0. Läuft ohne jedes Problem…
                                          Basti1234
                                          #540
                                          @worfinator:
                                          @Applefrank:
                                          Für den Alarm "CarbonDioxideDetected" auf 1 oder 0. Läuft ohne jedes Problem… `
                                          Du meinst also den Detected auf Constant = 1 setzen, sodass er immer Co2 detected hat? Oder läuft ein Skript, was den Wert auf 1 setzt ab einem von dir definierten Wert?
