  4. Node-Red
  5. Alexa ein befehl true oder false
    1.0k
    3.2k
74 Beiträge 4 Kommentatoren 8.6k Aufrufe 5 Beobachtet
  • AphofisA Aphofis
    @mickym
    Da kam ein Debug raus nur halt jetzt nicht mehr!
            "id": "6dac84f0.fc2eec",
            "type": "tab",
            "label": "Aquarium Info",
            "disabled": false,
            "info": ""
            "id": "a79b37b1.ab50d8",
            "type": "switch",
            "z": "6dac84f0.fc2eec",
            "name": "",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "eq",
                    "v": "false",
                    "vt": "str"
                    "t": "eq",
                    "v": "true",
                    "vt": "str"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 530,
            "y": 300,
            "wires": [
                    "c3b65007.dd9628"
                    "7d3d0e47.b569"
            "id": "be3e85ef.aeb568",
            "type": "ioBroker get",
            "name": "Aquarium_Info",
            "topic": "Aqua_Control.0.System.Aquarium_Info",
            "attrname": "payload",
            "payloadType": "value",
            "x": 380,
            "y": 300,
            "wires": [
                    "a79b37b1.ab50d8"
            "id": "c3b65007.dd9628",
            "type": "change",
            "name": "false",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "false",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 670,
            "y": 260,
            "wires": [
                    "b56db490.8a04e"
            "id": "7d3d0e47.b569",
            "type": "change",
            "name": "true",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "true",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 670,
            "y": 340,
            "wires": [
                    "b56db490.8a04e"
            "id": "b56db490.8a04e",
            "type": "ioBroker out",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 840,
            "y": 300,
            "wires": []
            "id": "ccc7fafa.991e28",
            "type": "alexa-local",
            "devicename": "aquarium-info",
            "inputtrigger": false,
            "x": 140,
            "y": 300,
            "wires": [
                    "be3e85ef.aeb568"
    OK verstanden mache ich ! ich wusste es einfach nihct besser und hatte rum probiert bis irgendwas funktionierte
    mickymM Offline
    mickymM Offline
    mickym
    @Aphofis So sieht das doch nicht schlecht aus. Du musst nur die beiden Change Nodes umgekehrt an den Switch Node anschliessen. ;) - Du willst ja das es umschaltet. So setzt Du false wenn false und true wenn true. ;)
    AphofisA 2 Antworten Letzte Antwort
    • mickymM mickym
      AphofisA Offline
      AphofisA Offline
      Aphofis
      @mickym
      i will try
      • mickymM mickym
        AphofisA Offline
        AphofisA Offline
        Aphofis
        schrieb am zuletzt editiert von Aphofis
        @mickym
        Alexa will einfach kein neues Gerät finden!
                "id": "8c9f0f34.ebd0a",
                "type": "tab",
                "label": "Badezimmer",
                "disabled": false,
                "info": ""
                "id": "a2e50519.903df8",
                "z": "8c9f0f34.ebd0a",
                "name": "badezimmer",
                "topic": "sonoff.0.bad_decke.POWER1",
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 870,
                "y": 400,
                "wires": []
                "id": "a14b9dd2.72fbe",
                "type": "switch",
                "name": "",
                "rules": [
                        "t": "eq",
                        "v": "false",
                        "vt": "str"
                        "t": "eq",
                        "v": "true",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 550,
                "y": 400,
                "wires": [
                        "a548aea7.e190d8"
                        "869f8b34.fe117"
                "id": "1ef29d63.705e2b",
                "x": 370,
                "y": 400,
                "wires": [
                        "a14b9dd2.72fbe"
                "id": "869f8b34.fe117",
                "type": "change",
                "name": "false",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "false",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 710,
                "y": 440,
                "wires": [
                        "a2e50519.903df8",
                        "e5404bcb.f01f08"
                "id": "a548aea7.e190d8",
                "type": "change",
                "name": "true",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "true",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 710,
                "y": 380,
                "wires": [
                        "a2e50519.903df8",
                        "dfb36ffa.d5fa1"
                "id": "c2f76a62.3e73f8",
                "devicename": "badezimmer",
                "x": 190,
                "y": 400,
                "wires": [
                        "1ef29d63.705e2b",
                        "87e0941e.5f0e6"
                "id": "dfb36ffa.d5fa1",
                "type": "debug",
                "name": "",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "complete": "false",
                "statusVal": "",
                "statusType": "auto",
                "x": 880,
                "y": 340,
                "wires": []
                "id": "e5404bcb.f01f08",
                "type": "debug",
                "name": "",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 870,
                "y": 480,
                "wires": []
                "id": "87e0941e.5f0e6",
                "type": "debug",
                "name": "",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 370,
                "y": 340,
                "wires": []
        Sei mir jetzt nihct böse das ich es mit badezimmer Decke mache! da bei dem switch nicht so viel text geredet wird von Alexa also insofern sie das gerät mal finden würde.
        nach dem Switch habe ich jetzt einfavh am switch true dann false angeschlossen und bei false umgekehrt.
        AphofisA mickymM 2 Antworten Letzte Antwort
        • AphofisA Aphofis
          @mickym
                  "type": "tab",
                  "disabled": false,
                  "info": ""
                  "ack": "false",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 870,
                  "y": 400,
                  "wires": []
                  "type": "switch",
                  "name": "",
                  "rules": [
                          "t": "eq",
                          "v": "false",
                          "vt": "str"
                          "t": "eq",
                          "v": "true",
                          "vt": "str"
                  "checkall": "true",
                  "repair": false,
                  "outputs": 2,
                  "x": 550,
                  "y": 400,
                  "wires": [
                          "a548aea7.e190d8"
                          "869f8b34.fe117"
                  "x": 370,
                  "y": 400,
                  "wires": [
                          "a14b9dd2.72fbe"
                  "type": "change",
                  "name": "false",
                  "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "false",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 710,
                  "y": 440,
                  "wires": [
                          "a2e50519.903df8",
                          "e5404bcb.f01f08"
                  "type": "change",
                  "name": "true",
                  "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "true",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 710,
                  "y": 380,
                  "wires": [
                          "a2e50519.903df8",
                          "dfb36ffa.d5fa1"
                  "x": 190,
                  "y": 400,
                  "wires": [
                          "1ef29d63.705e2b",
                          "87e0941e.5f0e6"
                  "type": "debug",
                  "name": "",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 880,
                  "y": 340,
                  "wires": []
                  "type": "debug",
                  "name": "",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 870,
                  "y": 480,
                  "wires": []
                  "type": "debug",
                  "name": "",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 370,
                  "y": 340,
                  "wires": []
          AphofisA Offline
          AphofisA Offline
          Aphofis
          komisch ist das ich über 20 flows habe, die Alexa alle einwandfrei erkannt hat und auch geschaltet werden können.
          nur seid einer woche wills nicht mehr so richtig
          • AphofisA Aphofis
            @mickym
                    "type": "tab",
                    "disabled": false,
                    "info": ""
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 870,
                    "y": 400,
                    "wires": []
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "eq",
                            "v": "false",
                            "vt": "str"
                            "t": "eq",
                            "v": "true",
                            "vt": "str"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 550,
                    "y": 400,
                    "wires": [
                            "a548aea7.e190d8"
                            "869f8b34.fe117"
                    "x": 370,
                    "y": 400,
                    "wires": [
                            "a14b9dd2.72fbe"
                    "type": "change",
                    "name": "false",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "false",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 710,
                    "y": 440,
                    "wires": [
                            "a2e50519.903df8",
                            "e5404bcb.f01f08"
                    "type": "change",
                    "name": "true",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "true",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 710,
                    "y": 380,
                    "wires": [
                            "a2e50519.903df8",
                            "dfb36ffa.d5fa1"
                    "x": 190,
                    "y": 400,
                    "wires": [
                            "1ef29d63.705e2b",
                            "87e0941e.5f0e6"
                    "type": "debug",
                    "name": "",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 880,
                    "y": 340,
                    "wires": []
                    "type": "debug",
                    "name": "",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 870,
                    "y": 480,
                    "wires": []
                    "type": "debug",
                    "name": "",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 370,
                    "y": 340,
                    "wires": []
            mickymM Offline
            mickymM Offline
            mickym
            @Aphofis said in Alexa ein befehl true oder false:
            Nun bei der Kommunikation mit Alexa kann ich Dir nicht helfen. Das hat aber mit dem Flow nichts zu tun. Im Prinzip dienen die Alexa Nodes ja nur als Trigger. Die Flows an sich kannst Du ja mit einem Inject Node testen.
            Bei Deinem Badezimmer Flow schaut das prinzipiell gut aus. Nur musst Du halt wissen ob Du die Datenpunkte mit true/false oder on/off schalten musst. Bei dem Sonoff Adapter kenn ich mich auch nicht aus. Wenn Du Tasmota über mqtt steuerst, dann ist der Datenpunkt um den Status auszulesen ein anderer, als der mit dem Du schaltest.
            Aber im Prinzip müssten die Flows nun funktionieren. Wie gesagt teste es einfach in dem Du Inject-Nodes verwendest. Alexa ist wie gesagt eine andere Baustelle - da ich Siri nutze. ;)
            AphofisA 1 Antwort Letzte Antwort
            • mickymM mickym
              AphofisA Offline
              AphofisA Offline
              Aphofis
              @mickym
              Das macht ja der Flow. Ich schalte true oder false und die steuerung macht daraus on oder off da Alexa mit true oder false nix anfangen kann. ich meine ich brauche doch nur eine wechsel schaltung.
              Also zB. wenn ich sage Bad und der Datenpunkt ist false wird er geändert auf true sage ich noch mal Alexa: bad wird der datenpunkt auf false gestellt.
              • AphofisA Aphofis
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @aphofis In dem Du einfach den Status am Besten true/false status ausliest (mit einer get-Node) und dann das Gegenteil setzt.
                        "id": "9295c9be.627c88",
                        "type": "change",
                        "z": "6e170384.60c96c",
                        "name": "Negation",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "$not(payload)\t",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 2040,
                        "y": 4460,
                        "wires": [
                        "id": "658584c8.db959c",
                        "name": "Example state",
                        "topic": "0_userdata.0.example_state",
                        "x": 1840,
                        "y": 4460,
                        "wires": [
                                "9295c9be.627c88"
                Die Change Node mit der Negation sieht wie folgt aus - als Input darf natürlich nur eine Boolean Variable geholt werden:
                Falls Du halt die unselige Option in dem Adapter angehakt hast, dass alles in Strings umgewandelt wird - dann musst halt den Umweg über eine neue Typvariable in der Change Node gehen.
                • mickymM mickym
                          "type": "change",
                          "name": "Negation",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 2040,
                          "y": 4460,
                          "wires": [
                          "x": 1840,
                          "y": 4460,
                          "wires": [
                                  "9295c9be.627c88"
                  AphofisA Offline
                  AphofisA Offline
                  Aphofis
                  @mickym
                  Serh Cool Vielen dank ich teste das mal !
                  • mickymM mickym
                            "type": "change",
                            "name": "Negation",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 2040,
                            "y": 4460,
                            "wires": [
                            "x": 1840,
                            "y": 4460,
                            "wires": [
                                    "9295c9be.627c88"
                    AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    @mickym
                    Ist nur die Frage, wo binde ich das ein !?
                            "id": "9210c811.e5cf7",
                            "type": "tab",
                            "label": "bad_decke",
                            "disabled": false,
                            "info": ""
                            "id": "f2936f54.4900d",
                            "type": "function",
                            "z": "9210c811.e5cf7",
                            "name": "true",
                            "func": "msg.payload = true;\nreturn msg;",
                            "outputs": 1,
                            "noerr": 0,
                            "initialize": "",
                            "finalize": "",
                            "x": 950,
                            "y": 220,
                            "wires": [
                                    "de05e9b9.b4cd5"
                            "id": "de05e9b9.b4cd5",
                            "name": "bad_decke POWER",
                            "topic": "sonoff.0.bad_decke.POWER",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1220,
                            "y": 240,
                            "wires": []
                            "id": "44863659.638d7",
                            "type": "function",
                            "name": "false",
                            "func": "msg.payload = false;\nreturn msg;",
                            "outputs": 1,
                            "noerr": 0,
                            "initialize": "",
                            "finalize": "",
                            "x": 950,
                            "y": 260,
                            "wires": [
                                    "de05e9b9.b4cd5"
                            "id": "9b08d19a.45c8a",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "eq",
                                    "v": "on",
                                    "vt": "str"
                                    "t": "eq",
                                    "v": "off",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 710,
                            "y": 240,
                            "wires": [
                                    "f2936f54.4900d"
                                    "44863659.638d7"
                            "id": "f71963ce.72d2",
                            "devicename": "bad",
                            "x": 490,
                            "y": 240,
                            "wires": [
                                    "9b08d19a.45c8a"
                            "type": "change",
                            "name": "Negation",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "true",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "false",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "str"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "true",
                                    "fromt": "bool",
                                    "to": "false",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 320,
                            "y": 240,
                            "wires": [
                                    "f71963ce.72d2"
                            "name": "bad_decke  POWER1",
                            "x": 140,
                            "y": 240,
                            "wires": [
                                    "9295c9be.627c88"
                    • AphofisA Aphofis
                      @mickym
                              "type": "tab",
                              "disabled": false,
                              "info": ""
                              "type": "function",
                              "name": "true",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "x": 950,
                              "y": 220,
                              "wires": [
                                      "de05e9b9.b4cd5"
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 1220,
                              "y": 240,
                              "wires": []
                              "type": "function",
                              "name": "false",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "x": 950,
                              "y": 260,
                              "wires": [
                                      "de05e9b9.b4cd5"
                              "type": "switch",
                              "name": "",
                              "rules": [
                                      "t": "eq",
                                      "v": "on",
                                      "vt": "str"
                                      "t": "eq",
                                      "v": "off",
                                      "vt": "str"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 710,
                              "y": 240,
                              "wires": [
                                      "f2936f54.4900d"
                                      "44863659.638d7"
                              "x": 490,
                              "y": 240,
                              "wires": [
                                      "9b08d19a.45c8a"
                              "type": "change",
                              "name": "Negation",
                              "rules": [
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "true",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "false",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "str"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "true",
                                      "fromt": "bool",
                                      "to": "false",
                                      "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 320,
                              "y": 240,
                              "wires": [
                                      "f71963ce.72d2"
                              "x": 140,
                              "y": 240,
                              "wires": [
                                      "9295c9be.627c88"
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @aphofis sagte in Alexa ein befehl true oder false:
                      Anstelle Deinens Switches und den beiden function Nodes true und falls - also nur
                      aquarium-info die türkise Alexa Node - dann die beiden Nodes, die ich Dir geschickt habe und die iobroker-out Node.
                      In die get-Node musst Du im Topic natürlich noch den Pfad zu dem Aquarium_Info Node eingeben, um den aktuellen Zustand zu ermitteln.
                      Im Prinzip interessiert Dich nicht WAS Alexa sagt, sondern nur DASS sie was sagt. Dann holst Du Dir die jetzige Einstellung und schaltest das Gegenteil.
                      • mickymM mickym
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        @mickym
                        OK also praktisch so !?
                                "type": "tab",
                                "disabled": false,
                                "info": ""
                                "x": 510,
                                "y": 240,
                                "wires": [
                                        "658584c8.db959c"
                                "type": "change",
                                "name": "Negation",
                                "rules": [
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "true",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "false",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "str"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "true",
                                        "fromt": "bool",
                                        "to": "false",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 880,
                                "y": 240,
                                "wires": [
                                "name": "bad  POWER1",
                                "x": 700,
                                "y": 240,
                                "wires": [
                                        "9295c9be.627c88"
                        • AphofisA Aphofis
                          @mickym
                                  "type": "tab",
                                  "disabled": false,
                                  "info": ""
                                  "x": 510,
                                  "y": 240,
                                  "wires": [
                                          "658584c8.db959c"
                                  "type": "change",
                                  "name": "Negation",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "true",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "false",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "str"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "true",
                                          "fromt": "bool",
                                          "to": "false",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 880,
                                  "y": 240,
                                  "wires": [
                                  "x": 700,
                                  "y": 240,
                                  "wires": [
                                          "9295c9be.627c88"
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @aphofis Ja und Nein.
                          Du hast jetzt den Change Node genommen, der in Deinem Datenpunkt Text erwartet und nicht die Negation.
                          Grundsätzlich musst Du halt noch den iobroker-out Node dahinter hängen. Dann schau halt noch mal ob Dein Datenpunkt sonoff.0.bad_decke.POWER überhaupt true oder falls enthält wenn der ON oder OFF enthält dann musst Du die Change Node natürlich umschreiben.
                          Hast Du in Deiner Adapterkonfiguration alles in strings umzuwandeln angekreuzt?
                          • mickymM mickym
                            AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            @mickym
                            Ne der Datenpunkt enthält true oder false
                            • AphofisA Aphofis
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @aphofis OK - und ist diese dumme Option in Deiner Adapterkonfig nun angekreuzt oder nicht?
                              • mickymM mickym
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                @mickym
                                Ja ist aktiviert
                                nur ich blicke nicht mehr durch in welcher reihenfolge die elemente sein müssen
                                • AphofisA Aphofis
                                  @mickym
                                  Ja ist aktiviert
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @aphofis Na ich weiß nicht wieiviel Flows Du schon hast - sonst würde ich das Ding in jedem Fall ausmachen. Aber so wie es jetzt ist, kannst Du den Flow nehmen, sowie von Dir gepostet -aber Du musst halt das Ergebnis über eine iobroker-out Node noch in den Datenpunkt schicken, der das Ding dann ein oder ausschaltet.
                                  Wenn Du den Haken jetzt raus machst, dann kann es sein, dass Deine bisherigen Flows nicht mehr funktionieren. Es ist eine Schande, dass man den Haken standardmäßig einschaltet.
                                  In dem Flow wie oben dargestellt ist das ja Aquarium_Info.
                                  • mickymM mickym
                                    AphofisA Offline
                                    AphofisA Offline
                                    Aphofis
                                    @mickym
                                    ist es so korrekt ?
                                            "type": "tab",
                                            "disabled": false,
                                            "info": ""
                                            "x": 530,
                                            "y": 240,
                                            "wires": [
                                                    "658584c8.db959c"
                                            "type": "change",
                                            "name": "Negation",
                                            "rules": [
                                                    "t": "change",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "from": "true",
                                                    "fromt": "str",
                                                    "to": "true",
                                                    "tot": "bool"
                                                    "t": "change",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "from": "false",
                                                    "fromt": "str",
                                                    "to": "true",
                                                    "tot": "str"
                                                    "t": "change",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "from": "true",
                                                    "fromt": "bool",
                                                    "to": "false",
                                                    "tot": "str"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 940,
                                            "y": 240,
                                            "wires": [
                                                    "ed7d17b7.c4d448"
                                            "x": 740,
                                            "y": 240,
                                            "wires": [
                                                    "9295c9be.627c88"
                                            "id": "ed7d17b7.c4d448",
                                            "topic": "Aqua_Control.0.System.badezimmer",
                                            "ack": "false",
                                            "stateName": "",
                                            "role": "",
                                            "payloadType": "",
                                            "readonly": "",
                                            "stateUnit": "",
                                            "stateMin": "",
                                            "stateMax": "",
                                            "x": 1140,
                                            "y": 240,
                                            "wires": []
                                    mickymM AphofisA 2 Antworten Letzte Antwort
                                    • AphofisA Aphofis
                                      @mickym
                                      ist es so korrekt ?
                                              "type": "tab",
                                              "disabled": false,
                                              "info": ""
                                              "x": 530,
                                              "y": 240,
                                              "wires": [
                                                      "658584c8.db959c"
                                              "type": "change",
                                              "name": "Negation",
                                              "rules": [
                                                      "t": "change",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "from": "true",
                                                      "fromt": "str",
                                                      "to": "true",
                                                      "tot": "bool"
                                                      "t": "change",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "from": "false",
                                                      "fromt": "str",
                                                      "to": "true",
                                                      "tot": "str"
                                                      "t": "change",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "from": "true",
                                                      "fromt": "bool",
                                                      "to": "false",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 940,
                                              "y": 240,
                                              "wires": [
                                                      "ed7d17b7.c4d448"
                                              "x": 740,
                                              "y": 240,
                                              "wires": [
                                                      "9295c9be.627c88"
                                              "ack": "false",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "readonly": "",
                                              "stateUnit": "",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 1140,
                                              "y": 240,
                                              "wires": []
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @aphofis
                                      @mickym
                                      Ja ist aktiviert
                                      Warum - dann scheinst Du den Flow nicht zu verstehen!!!
                                      1. Die Alexa Node - schickt eine Nachricht, wenn Du was sagst
                                      2. Im Prinzip interessiert Dich nicht, was Alexa sagt - nur dass sie was sagt - also Deinen Flow triggert.
                                      3. Du schaust in bad POWER1 für ein Status geschaltet ist (true oder false)
                                      4. Du schickst das Gegenteil an die badezimmer node.
                                      Ja - der Flow sollte funktionieren.
                                      • AphofisA Aphofis
                                        @mickym
                                        ist es so korrekt ?
                                                "type": "tab",
                                                "disabled": false,
                                                "info": ""
                                                "x": 530,
                                                "y": 240,
                                                "wires": [
                                                        "658584c8.db959c"
                                                "type": "change",
                                                "name": "Negation",
                                                "rules": [
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "true",
                                                        "fromt": "str",
                                                        "to": "true",
                                                        "tot": "bool"
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "false",
                                                        "fromt": "str",
                                                        "to": "true",
                                                        "tot": "str"
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "true",
                                                        "fromt": "bool",
                                                        "to": "false",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 940,
                                                "y": 240,
                                                "wires": [
                                                        "ed7d17b7.c4d448"
                                                "x": 740,
                                                "y": 240,
                                                "wires": [
                                                        "9295c9be.627c88"
                                                "ack": "false",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "readonly": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1140,
                                                "y": 240,
                                                "wires": []
                                        AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        bad POWER1 ist der Datenpunkt vom sonoff (Tasmota) gerät was die Deckenlampe schaltet und badezimmer ist ein true false datenpunkt der mit einem blockly dann die tatsächliche deckenlampe schaltet! da ich absolut nicht weiss wie man das nur in node red realisiert das direkt die deckenlampe mit node red geschaltet wird wenn man alexa sagt zb badezimmer dann wird halt die deckenlampe ein oder ausgeschaltet
                                        • AphofisA Aphofis
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @aphofis Wie gesagt es sollte funktionieren. Warum weißt Du nicht, wie man das in node Red realisiert? Du brauchst doch nur schauen, welchen Datenpunkt Dein blockly schaltet und gibst diesen in Deiner iobroker out Node an.
