  4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    6.7k
zigbee
95 Beiträge 5 Kommentatoren 10.9k Aufrufe 3 Beobachtet
  • birdyB birdy
    @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
    @birdy
    Du stehst im falschen Verzeichnis. Du hast das jetzt in /home/pi installiert.
    cd /opt/iobroker
    npm i iobroker.zigbee@1.2.1 --force
    Alternativ probier mal
    iobroker install zigbee
    iobroker upload zigbee
    So, jetzt im richtigen Pfad...
    pi@raspberrypi:/opt/iobroker $ npm i iobroker.zigbee@1.2.1 --force
    npm WARN using --force I sure hope you know what you are doing.
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
      COPY Release/canvas-postbuild.node
      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
    In file included from ../src/backend/PdfBackend.h:4:0,
                     from ../src/backend/PdfBackend.cc:1:
    ../src/backend/../closure.h:6:21: fatal error: jpeglib.h: Datei oder Verzeichnis nicht gefunden
     #include <jpeglib.h>
    compilation terminated.
    canvas.target.mk:142: die Regel für Ziel „Release/obj.target/canvas/src/backend/PdfBackend.o“ scheiterte
    make: *** [Release/obj.target/canvas/src/backend/PdfBackend.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.66-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.18.4
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    node-pre-gyp ERR! System Linux 4.19.66-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.18.4
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    > osx-temperature-sensor@1.0.7 install /opt/iobroker/node_modules/osx-temperature-sensor
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird betreten
      SOLINK_MODULE(target) Release/obj.target/none.node
      COPY Release/none.node
    make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird verlassen
    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
     #include <vips/vips8>
    sharp.target.mk:138: die Regel für Ziel „Release/obj.target/sharp/src/common.o“ scheiterte
    make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! not ok
    > @serialport/bindings@9.0.1 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=12.18.4 runtime=node arch=arm libc= platform=linux)
    make: Verzeichnis „/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build“ wird betreten
      CXX(target) Release/obj.target/bindings/src/serialport.o
      CXX(target) Release/obj.target/bindings/src/serialport_unix.o
      CXX(target) Release/obj.target/bindings/src/poller.o
      CXX(target) Release/obj.target/bindings/src/serialport_linux.o
      SOLINK_MODULE(target) Release/obj.target/bindings.node
      COPY Release/bindings.node
    make: Verzeichnis „/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build“ wird verlassen
    > serialport@9.0.1 postinstall /opt/iobroker/node_modules/zigbee-herdsman/node_modules/serialport
    > node thank-you.js
    Thank you for using serialport!
    If you rely on this package, please consider supporting our open collective:
    > https://opencollective.com/serialport/donate
    + iobroker.zigbee@1.2.1
    added 68 packages from 112 contributors, removed 244 packages, updated 3 packages and moved 3 packages in 128.73s
    20 packages are looking for funding
      run `npm fund` for details
    birdyB Offline
    birdyB Offline
    birdy
    #61
    @birdy
    WOW!!!
    Der Adapter ist auf 1.2.1!!!
    • birdyB birdy
      @birdy
      WOW!!!
      #62
      @birdy
      Fein. Willst du jetzt den canvas-Kram auch noch versuchen gerade zu ziehen?
      sudo apt install libgdcm2-dev
      birdyB 1 Antwort Letzte Antwort
        @birdy
        birdyB Offline
        birdyB Offline
        birdy
        #63
        @birdy
        Gerne, wenn du noch die Nerven hast... :)
        pi@raspberrypi:/opt/iobroker $ sudo apt install libgdcm2-dev
        Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
          realpath
        Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
        The following additional packages will be installed:
          libcharls1 libgdcm2.6 libjson-c3 libsocket++1
        Die folgenden NEUEN Pakete werden installiert:
          libcharls1 libgdcm2-dev libgdcm2.6 libjson-c3 libsocket++1
        0 aktualisiert, 5 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
        Es müssen 1.977 kB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 12,5 MB Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n] J
        Holen:1 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libsocket++1 armhf 1.12.13-8 [35,9 kB]
        Holen:2 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libcharls1 armhf 1.1.0+dfsg-2 [45,1 kB]
        Holen:3 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libjson-c3 armhf 0.12.1-1.1+deb9u1 [24,3 kB]
        Holen:4 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libgdcm2.6 armhf 2.6.6-3 [1.613 kB]
        Holen:5 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libgdcm2-dev armhf 2.6.6-3 [259 kB]
        Es wurden 1.977 kB in 1 s geholt (1.586 kB/s).
        Vormals nicht ausgewähltes Paket libsocket++1:armhf wird gewählt.
        (Lese Datenbank ... 126983 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../libsocket++1_1.12.13-8_armhf.deb ...
        Entpacken von libsocket++1:armhf (1.12.13-8) ...
        Vormals nicht ausgewähltes Paket libcharls1:armhf wird gewählt.
        Vorbereitung zum Entpacken von .../libcharls1_1.1.0+dfsg-2_armhf.deb ...
        Entpacken von libcharls1:armhf (1.1.0+dfsg-2) ...
        Vormals nicht ausgewähltes Paket libjson-c3:armhf wird gewählt.
        Vorbereitung zum Entpacken von .../libjson-c3_0.12.1-1.1+deb9u1_armhf.deb ...
        Entpacken von libjson-c3:armhf (0.12.1-1.1+deb9u1) ...
        Vormals nicht ausgewähltes Paket libgdcm2.6:armhf wird gewählt.
        Vorbereitung zum Entpacken von .../libgdcm2.6_2.6.6-3_armhf.deb ...
        Entpacken von libgdcm2.6:armhf (2.6.6-3) ...
        Vormals nicht ausgewähltes Paket libgdcm2-dev wird gewählt.
        Vorbereitung zum Entpacken von .../libgdcm2-dev_2.6.6-3_armhf.deb ...
        Entpacken von libgdcm2-dev (2.6.6-3) ...
        libjson-c3:armhf (0.12.1-1.1+deb9u1) wird eingerichtet ...
        libcharls1:armhf (1.1.0+dfsg-2) wird eingerichtet ...
        libsocket++1:armhf (1.12.13-8) wird eingerichtet ...
        Trigger für libc-bin (2.24-11+deb9u4) werden verarbeitet ...
        libgdcm2.6:armhf (2.6.6-3) wird eingerichtet ...
        libgdcm2-dev (2.6.6-3) wird eingerichtet ...
        • birdyB birdy
          @birdy
            realpath
          #64
          @birdy
          Da hängt aber noch mehr in der Pipeline.
          sudo apt update
          sudo apt dist-upgrade
            @birdy
            sudo apt update
            birdyB Offline
            birdyB Offline
            birdy
            #65
            @Thomas-Braun
            Aktuelisiert gerade...
            Zu Zigbee noch eine Frage... Muss ich da nicht eine USB-Nummer eingeben? Ich erinnere mich da dunkel...
            • birdyB birdy
              @Thomas-Braun
              #66
              @birdy
              Die Gerätedatei für den com-Port muss man angeben.
              Ist meist irgendwas um /dev/ttyS0 oder /dev/ttyAMA0
              Hängt vom Zigbee-Stick ab.
              Nach dem apt dist-upgrade am besten mal
              sudo reboot
                @birdy
                sudo reboot
                birdyB Offline
                birdyB Offline
                birdy
                #67
                @Thomas-Braun
                So, reboot durchgeführt... Gibt es noch etwas, das ich tun kann?
                • birdyB birdy
                  @Thomas-Braun
                  #68
                  @birdy
                  sudo apt update
                  sagt jetzt, dass alle Pakete aktuell seien? Oder wird da noch was zurückgehalten?
                    @birdy
                    sudo apt update
                    birdyB Offline
                    birdyB Offline
                    birdy
                    #69
                    @birdy
                    sudo apt update
                    pi@raspberrypi:~ $ sudo apt update
                    OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                    OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                    OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
                    Alle Pakete sind aktuell.
                    • birdyB birdy
                      @birdy
                      sudo apt update
                      #70
                      @birdy
                      Gut, passt.
                      Jetzt müssen wir nochmal nach 'canvas' schauen.
                      cd /opt/iobroker
                      npm i canvas
                        @birdy
                        Gut, passt.
                        cd /opt/iobroker
                        npm i canvas
                        birdyB Offline
                        birdyB Offline
                        birdy
                        #71
                        @birdy
                        Gut, passt.
                        cd /opt/iobroker
                        npm i canvas
                        Da scheint noch was im Argen zu sein...
                        pi@raspberrypi:~ $ cd /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ npm i canvas
                        gyp ERR! not ok
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the canvas@2.6.1 install script.
                        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T19_00_07_883Z-debug.log
                        • birdyB birdy
                          @birdy
                          Gut, passt.
                          cd /opt/iobroker
                          npm i canvas
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          #72
                          @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
                          jpeglib.h
                          apt policy libgdcm2-dev
                            jpeglib.h
                            birdyB Offline
                            birdyB Offline
                            birdy
                            #73
                            jpeglib.h
                            pi@raspberrypi:/opt/iobroker $ apt policy libgdcm2-dev
                            libgdcm2-dev:
                              Installiert:           2.6.6-3
                              Installationskandidat: 2.6.6-3
                              Versionstabelle:
                             *** 2.6.6-3 500
                                    500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                                    100 /var/lib/dpkg/status
                            • birdyB birdy
                              jpeglib.h
                              libgdcm2-dev:
                                Versionstabelle:
                               *** 2.6.6-3 500
                              #74
                              @birdy
                              sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                @birdy
                                birdyB Offline
                                birdyB Offline
                                birdy
                                #75
                                @birdy
                                pi@raspberrypi:/opt/iobroker $ sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                build-essential ist schon die neueste Version (12.3).
                                libpango1.0-dev ist schon die neueste Version (1.40.5-1).
                                libcairo2-dev ist schon die neueste Version (1.14.8-1+rpi1).
                                Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                  coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15 realpath
                                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                Vorgeschlagene Pakete:
                                  librsvg2-doc
                                  gir1.2-rsvg-2.0 libgdk-pixbuf2.0-dev libgif-dev libjpeg-dev
                                  libjpeg62-turbo-dev librsvg2-dev
                                0 aktualisiert, 6 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                Es müssen 447 kB an Archiven heruntergeladen werden.
                                Nach dieser Operation werden 1.409 kB Plattenplatz zusätzlich benutzt.
                                Holen:1 http://mirror.inode.at/raspbian/raspbian stretch/main armhf gir1.2-rsvg-2.0 armhf 2.40.21-0+deb9u1 [15,3 kB]
                                Holen:2 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libgdk-pixbuf2.0-dev armhf 2.36.5-2+deb9u2 [53,8 kB]
                                Holen:3 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libgif-dev armhf 5.1.4-0.4 [43,0 kB]
                                Holen:4 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libjpeg62-turbo-dev armhf 1:1.5.1-2+deb9u1 [179 kB]
                                Holen:5 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libjpeg-dev all 1:1.5.1-2+deb9u1 [56,5 kB]
                                Holen:6 http://mirror.inode.at/raspbian/raspbian stretch/main armhf librsvg2-dev armhf 2.40.21-0+deb9u1 [99,4 kB]
                                Es wurden 447 kB in 1 s geholt (338 kB/s).
                                Vormals nicht ausgewähltes Paket gir1.2-rsvg-2.0:armhf wird gewählt.
                                (Lese Datenbank ... 133212 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../0-gir1.2-rsvg-2.0_2.40.21-0+deb9u1_armhf.deb ...
                                Entpacken von gir1.2-rsvg-2.0:armhf (2.40.21-0+deb9u1) ...
                                Vormals nicht ausgewähltes Paket libgdk-pixbuf2.0-dev wird gewählt.
                                Vorbereitung zum Entpacken von .../1-libgdk-pixbuf2.0-dev_2.36.5-2+deb9u2_armhf.deb ...
                                Entpacken von libgdk-pixbuf2.0-dev (2.36.5-2+deb9u2) ...
                                Vormals nicht ausgewähltes Paket libgif-dev wird gewählt.
                                Vorbereitung zum Entpacken von .../2-libgif-dev_5.1.4-0.4_armhf.deb ...
                                Entpacken von libgif-dev (5.1.4-0.4) ...
                                Vormals nicht ausgewähltes Paket libjpeg62-turbo-dev:armhf wird gewählt.
                                Vorbereitung zum Entpacken von .../3-libjpeg62-turbo-dev_1%3a1.5.1-2+deb9u1_armhf.deb ...
                                Entpacken von libjpeg62-turbo-dev:armhf (1:1.5.1-2+deb9u1) ...
                                Vormals nicht ausgewähltes Paket libjpeg-dev wird gewählt.
                                Vorbereitung zum Entpacken von .../4-libjpeg-dev_1%3a1.5.1-2+deb9u1_all.deb ...
                                Entpacken von libjpeg-dev (1:1.5.1-2+deb9u1) ...
                                Vormals nicht ausgewähltes Paket librsvg2-dev:armhf wird gewählt.
                                Vorbereitung zum Entpacken von .../5-librsvg2-dev_2.40.21-0+deb9u1_armhf.deb ...
                                Entpacken von librsvg2-dev:armhf (2.40.21-0+deb9u1) ...
                                libgif-dev (5.1.4-0.4) wird eingerichtet ...
                                libgdk-pixbuf2.0-dev (2.36.5-2+deb9u2) wird eingerichtet ...
                                gir1.2-rsvg-2.0:armhf (2.40.21-0+deb9u1) wird eingerichtet ...
                                Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                                libjpeg62-turbo-dev:armhf (1:1.5.1-2+deb9u1) wird eingerichtet ...
                                librsvg2-dev:armhf (2.40.21-0+deb9u1) wird eingerichtet ...
                                libjpeg-dev (1:1.5.1-2+deb9u1) wird eingerichtet ...
                                • birdyB birdy
                                  @birdy
                                    librsvg2-doc
                                  #76
                                  @birdy
                                  Dann schau nochmal, ob canvas nun baut:
                                  cd /opt/iobroker
                                  npm i canvas
                                  • birdyB birdy
                                    @birdy
                                      librsvg2-doc
                                    #77
                                    @birdy
                                    sudo apt autoremove
                                    haut die Meldungen über die nicht mehr benötigten Pakete weg.
                                    birdyB 2 Antworten Letzte Antwort
                                      @birdy
                                      sudo apt autoremove
                                      birdyB Offline
                                      birdyB Offline
                                      birdy
                                      #78
                                      @birdy
                                      sudo apt autoremove
                                      Schaut gut aus...
                                        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                                        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                                      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                                      ../src/bmp/BMPParser.cc:189:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                         E(ptr - data > imgdOffset, "image data overlaps with another structure");
                                      ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                                       #define E(cond, msg) if(cond) return setErr(msg)
                                      ../src/bmp/BMPParser.cc:204:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                         E(ptr - data + imgdSize > len, "not enough image data");
                                        CXX(target) Release/obj.target/canvas/src/Backends.o
                                        CXX(target) Release/obj.target/canvas/src/Canvas.o
                                      ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/Canvas.cc:415:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                           if (canvas->nBytes() > node::Buffer::kMaxLength) {
                                        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                                        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                                        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                                        CXX(target) Release/obj.target/canvas/src/closure.o
                                        CXX(target) Release/obj.target/canvas/src/color.o
                                        CXX(target) Release/obj.target/canvas/src/Image.o
                                        CXX(target) Release/obj.target/canvas/src/ImageData.o
                                        CXX(target) Release/obj.target/canvas/src/init.o
                                        CXX(target) Release/obj.target/canvas/src/register_font.o
                                        SOLINK_MODULE(target) Release/obj.target/canvas.node
                                        COPY Release/canvas.node
                                      + canvas@2.6.1
                                      added 6 packages from 15 contributors in 176.083s
                                        @birdy
                                        sudo apt autoremove
                                        birdyB Offline
                                        birdyB Offline
                                        birdy
                                        #79
                                        @birdy
                                        sudo apt autoremove
                                        pi@raspberrypi:/opt/iobroker $ sudo apt autoremove
                                        Die folgenden Pakete werden ENTFERNT:
                                        0 aktualisiert, 0 neu installiert, 4 zu entfernen und 0 nicht aktualisiert.
                                        Nach dieser Operation werden 9.219 kB Plattenplatz freigegeben.
                                        (Lese Datenbank ... 133294 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Entfernen von coinor-libipopt1v5 (3.11.9-2.1) ...
                                        Entfernen von libmumps-seq-4.10.0 (4.10.0.dfsg-4+b1) ...
                                        Entfernen von libraw15:armhf (0.17.2-6+deb9u1) ...
                                        Entfernen von realpath (8.26-3) ...
                                        • birdyB birdy
                                          @birdy
                                          sudo apt autoremove
                                          #80
                                          @birdy
                                          Dann müsste dein System jetzt sauber sein.
                                          iobroker update
                                          iobroker upgrade
                                          meckert jetzt nix mehr an?
