  2. English
  3. ioBroker general
  4. Zigbee adapter stopped working FIXED
Geplant Angeheftet Gesperrt Verschoben ioBroker general
zigbee
41 Beiträge 4 Kommentatoren 12.0k Aufrufe 4 Beobachtet
  • AsgothianA Asgothian
    @ap2017 I apologise. I should have put quotes around the "npm list", as that was the command i wanted you to check.
    As you can see, there is an extra serialport library installed, but each adapter has (should have) a usable version, so you should be able to remove the extra one.
    npm prune should get rid of it.
    A.
    ap2017
    @Asgothian As previously, keep getting these errors:
    zigbee.0 2020-09-24 10:39:10.082 error (2461) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-he
    zigbee.0 2020-09-24 10:39:10.081 error (2461) Failed to start Zigbee
    zigbee.0 2020-09-24 10:39:09.975 info (2461) Starting Zigbee...
    zigbee.0 2020-09-24 10:39:09.974 info (2461) Try to reconnect. 1 attempts left
    zigbee.0 2020-09-24 10:38:59.972 error (2461) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/z
    zigbee.0 2020-09-24 10:38:59.972 error (2461) Failed to start Zigbee
    • A ap2017
      @Asgothian No problem. I run the following, but still have same extraneous serial library 6..2.2 when run "npm list serialport"
      cd /opt/iobroker
      npm prune --dry-run
      sudo reboot
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @ap2017
      Of course.. the "npm prune --dry-run" only lists what it would do. This is to ensure that it doesn't get rid of something you want to keep
      once you checked the list, you can do "npm prune" (without the dry run)
      a Reboot is not needed..
      A.
      A 1 Antwort Letzte Antwort
        @ap2017
        A.
        ap2017
        @Asgothian The unwanted serial driver 6.2.2 disappeared after pruning, but it did not help to resolve the main issue, see errors below. I rebooted controller after pruning, just in case.
        • A ap2017
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @ap2017
          Unfortunately, that is what i expected. Now you should no longer get any errors on an npm rebuild, but i have the feeling that is not the error. I am starting to think that the firmware on the Zigbee Board / Stick is not responding correctly.
          As long as there is a message that the zigbee library cannot be initialized, the issue is most likely hardware related.
          A.
            @ap2017
            A.
            @ap2017
            Please stop the zwave Adapater and reboot. I may happen that the zwo adapters do block the port.
            And I see a duplicate entry in the zwave entry. I think that only one entry should show there.
              @ap2017
              ap2017
              schrieb am zuletzt editiert von ap2017
              @Thomas-Braun I stopped both zwave and zigbee and rebooted, here is list of serial ports:
              As I mentioned before, when zigbee is off, zwave works fine on both ports ACM0 and ACM1, so it looks like system works properly with ports.
              What would be next step, try to uninstall and reinstall zigbee adapter again? Re-flash CC2531 dongle? Thank you.
              • A ap2017
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @ap2017
                No.
                Please verify if the Zigbee Adapter will start when
                • no zwave sticks are connected to the system
                • no zwave adapter is running.
                A.
                  @ap2017
                  No.
                  A.
                  ap2017
                  @Asgothian Sorry, how do I check if zigbee adapter started?
                  • A ap2017
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @ap2017 Watch the log for an entry that the zigbee adapter started successfully, alternatively, watch the green light in the instance list.
                    A 2 Antworten Letzte Antwort
                      ap2017
                      @Asgothian Of course, I did not pay attention that you asked to disable zwave, not zigbee. Unplugging zwave dongle and disabling zwave adapter did not help. FYI, zigbee behaves same way for ACM0 and ACM1 ports
                        ap2017
                        @Asgothian Here is the latest debug log when trying to restart zigbee adapter. Anything comes to mind? Thank you for your time.
                        zigbee.0 2020-09-27 17:53:02.239 error (4926) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
                        zigbee.0 2020-09-27 17:53:02.239 error (4926) Failed to start Zigbee
                        zigbee.0 2020-09-27 17:53:02.138 debug (4926) Starting zigbee-herdsman...
                        zigbee.0 2020-09-27 17:53:02.137 info (4926) Starting Zigbee...
                        zigbee.0 2020-09-27 17:53:02.137 info (4926) Try to reconnect. 1 attempts left
                        zigbee.0 2020-09-27 17:52:52.136 error (4926) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
                        zigbee.0 2020-09-27 17:52:52.135 error (4926) Failed to start Zigbee
                        zigbee.0 2020-09-27 17:52:52.061 debug (4926) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_09_27-17_52_51.tar.gz success
                        zigbee.0 2020-09-27 17:52:52.004 debug (4926) Starting zigbee-herdsman...
                        zigbee.0 2020-09-27 17:52:52.003 info (4926) Starting Zigbee...
                        zigbee.0 2020-09-27 17:52:51.977 debug (4926) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"database
                        zigbee.0 2020-09-27 17:52:51.960 info (4926) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                        host.AP-Tiny 2020-09-27 17:52:51.188 info instance system.adapter.zigbee.0 started with pid 4926
                        host.AP-Tiny 2020-09-27 17:52:48.684 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        zigbee.0 2020-09-27 17:52:48.172 error at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
                        zigbee.0 2020-09-27 17:52:48.172 error at Zigbee.emit (events.js:315:20)
                        zigbee.0 2020-09-27 17:52:48.172 error at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:442:41)
                        zigbee.0 2020-09-27 17:52:48.172 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:304:20)
                        zigbee.0 2020-09-27 17:52:48.172 error at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:187:42)
                        zigbee.0 2020-09-27 17:52:48.172 error at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:118:43)
                        zigbee.0 2020-09-27 17:52:48.172 error at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:201:49)
                        zigbee.0 2020-09-27 17:52:48.172 error at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
                        zigbee.0 2020-09-27 17:52:48.172 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:234:16)
                        zigbee.0 2020-09-27 17:52:48.172 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:214:55)
                        zigbee.0 2020-09-27 17:52:48.172 error (4705) TypeError: Cannot read property 'getEntries' of null
                        zigbee.0 2020-09-27 17:52:48.171 error (4705) unhandled promise rejection: Cannot read property 'getEntries' of null
                        Unhandled 2020-09-27 17:52:48.170 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        zigbee.0 2020-09-27 17:52:48.170 info (4705) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        zigbee.0 2020-09-27 17:52:48.169 info (4705) terminating
                        zigbee.0 2020-09-27 17:52:48.169 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
                        zigbee.0 2020-09-27 17:52:48.169 error at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
                        zigbee.0 2020-09-27 17:52:48.169 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
                        zigbee.0 2020-09-27 17:52:48.169 error at new Promise (<anonymous>)
                        zigbee.0 2020-09-27 17:52:48.169 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
                        zigbee.0 2020-09-27 17:52:48.169 error at Generator.next (<anonymous>)
                        zigbee.0 2020-09-27 17:52:48.169 error at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
                        zigbee.0 2020-09-27 17:52:48.169 error at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
                        zigbee.0 2020-09-27 17:52:48.169 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
                        zigbee.0 2020-09-27 17:52:48.169 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
                        zigbee.0 2020-09-27 17:52:48.169 error (4705) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                        zigbee.0 2020-09-27 17:52:48.168 info (4705) Zigbee: disabling joining new devices.
                        zigbee.0 2020-09-27 17:52:48.166 info (4705) cleaned everything up...
                        zigbee.0 2020-09-27 17:52:48.165 info (4705) Got terminate signal TERMINATE_YOURSELF
                        host.AP-Tiny 2020-09-27 17:52:48.163 info stopInstance system.adapter.zigbee.0 send kill signal
                        host.AP-Tiny 2020-09-27 17:52:48.159 info stopInstance system.adapter.zigbee.0 (force=false, process=true)
                        • A ap2017
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @ap2017 Things that come to mind:
                          • Put the log in code tags, makes it more readable
                          • The serial port is still locked.
                          • This is not the first entry after trying to start the adapter. It shows a restart attempt.
                          Please follow these steps, and post the resulting log (in code tags)
                          • Disable the zigbee instance
                          • stop the iobroker
                          • verify that no process has the serial device open
                          lsof /def/ttyACM1
                          • If no process has the serial device open, start iobroker
                          • check again if any process has the serial port open
                          • delete the current log (Delete, not clear, in the log view)
                          • attempt to start the zigbee adapter. If it does not start, disable it again, then post the log file.
                          A.
                            • stop the iobroker
                            lsof /def/ttyACM1
                            A.
                            ap2017
                            @Asgothian said in Zigbee adapter stopped working:
                            lsof /def/ttyACM1
                            When iobroker stopped and started same status of serial port is reported (hopefully there is no error in command):
                            Here is log after zigbee adapter started
                            zigbee.0	2020-09-28 23:23:31.400	error	(26678) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/
                            zigbee.0	2020-09-28 23:23:31.399	error	(26678) Failed to start Zigbee
                            zigbee.0	2020-09-28 23:23:23.829	debug	(26678) Starting zigbee-herdsman...
                            zigbee.0	2020-09-28 23:23:23.829	info	(26678) Starting Zigbee...
                            zigbee.0	2020-09-28 23:23:23.828	info	(26678) Try to reconnect. 1 attempts left
                            zigbee.0	2020-09-28 23:23:13.828	error	at /opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:242:12
                            zigbee.0	2020-09-28 23:23:13.828	error	at SerialPort._error (/opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:198:14)
                            zigbee.0	2020-09-28 23:23:13.828	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                            zigbee.0	2020-09-28 23:23:13.828	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                            zigbee.0	2020-09-28 23:23:13.828	error	at new Promise (<anonymous>)
                            zigbee.0	2020-09-28 23:23:13.828	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                            zigbee.0	2020-09-28 23:23:13.828	error	at Generator.next (<anonymous>)
                            zigbee.0	2020-09-28 23:23:13.828	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                            zigbee.0	2020-09-28 23:23:13.828	error	(26678) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1'
                            zigbee.0	2020-09-28 23:23:13.827	error	(26678) Failed to start Zigbee
                            zigbee.0	2020-09-28 23:23:13.744	debug	(26678) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_09_28-23_23_13.tar.gz success
                            zigbee.0	2020-09-28 23:23:13.666	debug	(26678) Starting zigbee-herdsman...
                            zigbee.0	2020-09-28 23:23:13.665	info	(26678) Starting Zigbee...
                            zigbee.0	2020-09-28 23:23:13.628	debug	(26678) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databa
                            zigbee.0	2020-09-28 23:23:13.611	info	(26678) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                            zigbee.0	2020-09-28 23:23:13.150	debug	(26678) statesDB connected
                            zigbee.0	2020-09-28 23:23:13.150	debug	(26678) States connected to redis: 127.0.0.1:9000
                            zigbee.0	2020-09-28 23:23:13.146	debug	(26678) States create System PubSub Client
                            zigbee.0	2020-09-28 23:23:13.145	debug	(26678) States create User PubSub Client
                            zigbee.0	2020-09-28 23:23:13.142	debug	(26678) Redis States: Use Redis connection: 127.0.0.1:9000
                            zigbee.0	2020-09-28 23:23:13.141	debug	(26678) objectDB connected
                            zigbee.0	2020-09-28 23:23:13.138	debug	(26678) Objects connected to redis: 127.0.0.1:9001
                            zigbee.0	2020-09-28 23:23:13.129	debug	(26678) Objects client initialize lua scripts
                            zigbee.0	2020-09-28 23:23:13.128	debug	(26678) Objects create User PubSub Client
                            zigbee.0	2020-09-28 23:23:13.128	debug	(26678) Objects create System PubSub Client
                            zigbee.0	2020-09-28 23:23:13.126	debug	(26678) Objects client ready ... initialize now
                            zigbee.0	2020-09-28 23:23:13.105	debug	(26678) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            host.AP-Tiny	2020-09-28 23:23:12.547	info	instance system.adapter.zigbee.0 started with pid 26678
                            • A ap2017
                              lsof /def/ttyACM1
                              @ap2017
                              lsof /dev/ttyACM1
                              would be correct.
                                @ap2017
                                lsof /dev/ttyACM1
                                would be correct.
                                ap2017
                                @Thomas-Braun Here is response for lsof /dev/ttyACM1 Not sure what it means, is port being used or not? Getting same response with ioBroker on or off
                                ap@AP-Tiny:~$ lsof /dev/ttyACM1
                                ap@AP-Tiny:~$
                                • A ap2017
                                  ap@AP-Tiny:~$
                                  ap2017
                                  @ap2017 Here is response to "npm list serialport"
                                  if it helps
                                  ap@AP-Tiny:/opt/iobroker$ npm list serialport
                                  iobroker.inst@2.0.3 /opt/iobroker
                                  ├─┬ iobroker.discovery@2.3.11
                                  │ └── serialport@8.0.8
                                  ├─┬ iobroker.mysensors@2.0.1
                                  │ └── serialport@7.1.5
                                  ├─┬ iobroker.zigbee@1.2.1
                                  │ └─┬ zigbee-herdsman@0.13.8
                                  │   └── serialport@9.0.1
                                  └─┬ iobroker.zwave2@1.7.0-alpha.2
                                    └─┬ zwave-js@5.0.0-alpha.3
                                      ├─┬ @zwave-js/serial@5.0.0-alpha.0
                                  • A ap2017
                                    After yesterday update of PING, SIMPLE-API and JAVASCRIPT adapters (not sure if failure is related to updates), my Zigbee adapter stopped working. In attempt to configure adapter, message "Error. You need save and run adapter before pairing! appears." Confirming proper communication port /dev/ttyACM1 does not help, same port as I was using for Zigbee for long time. Running
                                    sudo ldconfig
                                    or
                                    sudo ldconfig /usr/local
                                    or
                                    sudo ldconfig /usr/local/lib64
                                    did not help.
                                    See attached log.
                                    9-18-20 Zigbee.txt
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @ap2017 I had problems to understand why this version of the adapter reached the status to be in the default repository. I have now 2 threads open
                                    https://github.com/ioBroker/ioBroker.zigbee/issues/792
                                    https://forum.iobroker.net/topic/37147/zigbee-adapter-1-2-1-nicht-stable
                                    ... and I hope there will be a solution provided by the experts.
                                    meanwhile everything is running in debug mode - and I hope that there will be help by the experts.
                                    I would not complain if this adapter is still only in the latest repository - but I had to learn that you need to be careful expressing your personal opinion if you are not an expert and only a silly end user.
                                    What I can see in your log - that all theses errors are consecutive errors of a previous crash. you should have a look if you have an error like:
                                     Adapter disconnected, stopping
                                    this is the crash of the adapter - all other messages are in my opinion a result of the adapter crash, but not the root cause.
                                    • mickymM mickym
                                      ap2017
                                      @mickym Here is my error log after starting adapter in debug mode. Do not see error that you mentioned. I am not clear what do you mean by "be careful expressing your personal opinion if you are not an expert and only a silly end user"
                                      zigbee.0	2020-09-29 23:37:01.205	error	(22022) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/
                                      zigbee.0	2020-09-29 23:37:01.204	error	(22022) Failed to start Zigbee
                                      zigbee.0	2020-09-29 23:36:53.649	debug	(22022) Starting zigbee-herdsman...
                                      zigbee.0	2020-09-29 23:36:53.648	info	(22022) Starting Zigbee...
                                      zigbee.0	2020-09-29 23:36:53.647	info	(22022) Try to reconnect. 1 attempts left
                                      zigbee.0	2020-09-29 23:36:43.647	error	at /opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:242:12
                                      zigbee.0	2020-09-29 23:36:43.647	error	at SerialPort._error (/opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:198:14)
                                      zigbee.0	2020-09-29 23:36:43.647	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                      zigbee.0	2020-09-29 23:36:43.647	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                      zigbee.0	2020-09-29 23:36:43.647	error	at new Promise (<anonymous>)
                                      zigbee.0	2020-09-29 23:36:43.647	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                      zigbee.0	2020-09-29 23:36:43.647	error	at Generator.next (<anonymous>)
                                      zigbee.0	2020-09-29 23:36:43.647	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                      zigbee.0	2020-09-29 23:36:43.647	error	(22022) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1'
                                      zigbee.0	2020-09-29 23:36:43.646	error	(22022) Failed to start Zigbee
                                      zigbee.0	2020-09-29 23:36:43.500	debug	(22022) Starting zigbee-herdsman...
                                      zigbee.0	2020-09-29 23:36:43.499	info	(22022) Starting Zigbee...
                                      zigbee.0	2020-09-29 23:36:43.498	debug	(22022) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databa
                                      zigbee.0	2020-09-29 23:36:43.483	info	(22022) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                      zigbee.0	2020-09-29 23:36:43.369	debug	(22022) statesDB connected
                                      zigbee.0	2020-09-29 23:36:43.368	debug	(22022) States connected to redis: 127.0.0.1:9000
                                      zigbee.0	2020-09-29 23:36:43.365	debug	(22022) States create System PubSub Client
                                      zigbee.0	2020-09-29 23:36:43.364	debug	(22022) States create User PubSub Client
                                      zigbee.0	2020-09-29 23:36:43.360	debug	(22022) Redis States: Use Redis connection: 127.0.0.1:9000
                                      zigbee.0	2020-09-29 23:36:43.359	debug	(22022) objectDB connected
                                      zigbee.0	2020-09-29 23:36:43.356	debug	(22022) Objects connected to redis: 127.0.0.1:9001
                                      zigbee.0	2020-09-29 23:36:43.347	debug	(22022) Objects client initialize lua scripts
                                      zigbee.0	2020-09-29 23:36:43.347	debug	(22022) Objects create User PubSub Client
                                      zigbee.0	2020-09-29 23:36:43.346	debug	(22022) Objects create System PubSub Client
                                      zigbee.0	2020-09-29 23:36:43.344	debug	(22022) Objects client ready ... initialize now
                                      zigbee.0	2020-09-29 23:36:43.327	debug	(22022) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.AP-Tiny	2020-09-29 23:36:42.857	info	instance system.adapter.zigbee.0 started with pid 22022
                                      • A ap2017
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        @ap2017 the log clearly shows that the Adapter is unable to open the serial port. I have to admit that I am at a loss as to why this is.
                                        Can you try to flash the Firmware in your zigbee device ? It is possible that the Firmware does not work properly and as such does not allow opening the port.
                                        Also - do you have an Alternative System to try and connect to the zigbee device to ensure the serial port works ?
                                        A.
                                          A.
                                          ap2017
                                          @Asgothian I configured zigbee to work with ACM0 (the port normally used by zwave adapter, but for this test zwave adapter is disabled). Just in case, swapped physical ports and connecting cables. Here is log from fresh system start. It seems to me that unable to open com port is secondary error, error log always start with other errors, see below.
                                          I will re-flash the adapter and placed an order for another one.
                                          zigbee.0	2020-09-30 08:42:36.675	debug	(1964) system.adapter.admin.0: logging true
                                          zigbee.0	2020-09-30 08:42:02.506	error	at /opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:242:12
                                          zigbee.0	2020-09-30 08:42:02.506	error	at SerialPort._error (/opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:198:14)
                                          zigbee.0	2020-09-30 08:42:02.506	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                          zigbee.0	2020-09-30 08:42:02.506	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                          zigbee.0	2020-09-30 08:42:02.506	error	at new Promise (<anonymous>)
                                          zigbee.0	2020-09-30 08:42:02.506	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                          zigbee.0	2020-09-30 08:42:02.506	error	at Generator.next (<anonymous>)
                                          zigbee.0	2020-09-30 08:42:02.506	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                          zigbee.0	2020-09-30 08:42:02.506	error	(1964) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                                          zigbee.0	2020-09-30 08:42:02.506	error	(1964) Failed to start Zigbee
                                          zigbee.0	2020-09-30 08:42:02.411	debug	(1964) Starting zigbee-herdsman...
                                          zigbee.0	2020-09-30 08:42:02.411	info	(1964) Starting Zigbee...
                                          zigbee.0	2020-09-30 08:42:02.410	info	(1964) Try to reconnect. 1 attempts left
                                          zigbee.0	2020-09-30 08:41:52.409	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
                                          zigbee.0	2020-09-30 08:41:52.409	error	at Generator.throw (<anonymous>)
                                          zigbee.0	2020-09-30 08:41:52.409	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:89:31)
                                          zigbee.0	2020-09-30 08:41:52.409	error	(1964) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                                          zigbee.0	2020-09-30 08:41:52.408	error	(1964) Failed to start Zigbee
                                          zigbee.0	2020-09-30 08:41:44.793	debug	(1964) Starting zigbee-herdsman...
                                          zigbee.0	2020-09-30 08:41:44.792	info	(1964) Starting Zigbee...
                                          zigbee.0	2020-09-30 08:41:44.791	debug	(1964) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databas
                                          zigbee.0	2020-09-30 08:41:44.776	info	(1964) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                          zigbee.0	2020-09-30 08:41:44.623	debug	(1964) statesDB connected
                                          zigbee.0	2020-09-30 08:41:44.623	debug	(1964) States connected to redis: 127.0.0.1:9000
                                          zigbee.0	2020-09-30 08:41:44.620	debug	(1964) States create System PubSub Client
                                          zigbee.0	2020-09-30 08:41:44.619	debug	(1964) States create User PubSub Client
                                          zigbee.0	2020-09-30 08:41:44.616	debug	(1964) Redis States: Use Redis connection: 127.0.0.1:9000
                                          zigbee.0	2020-09-30 08:41:44.615	debug	(1964) objectDB connected
                                          zigbee.0	2020-09-30 08:41:44.612	debug	(1964) Objects connected to redis: 127.0.0.1:9001
                                          zigbee.0	2020-09-30 08:41:44.601	debug	(1964) Objects client initialize lua scripts
                                          zigbee.0	2020-09-30 08:41:44.600	debug	(1964) Objects create User PubSub Client
                                          zigbee.0	2020-09-30 08:41:44.599	debug	(1964) Objects create System PubSub Client
                                          zigbee.0	2020-09-30 08:41:44.597	debug	(1964) Objects client ready ... initialize now
                                          zigbee.0	2020-09-30 08:41:44.576	debug	(1964) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.AP-Tiny	2020-09-30 08:41:44.042	info	instance system.adapter.zigbee.0 started with pid 1964
