  4. [gelöst] Update mihome-vaccum Adapter auf 2.0.7 schlägt fehl
mi vacuumupdate adapter
3 Beiträge 2 Kommentatoren 424 Aufrufe 2 Beobachtet
  • F Offline
    FabianFranz
    schrieb am zuletzt editiert von FabianFranz
    ich bin auf der Fehlersuche. Das Update des mihome-vacuum Adapter von @1.1.5 to @2.0.7 schlägt mit folgendem Log fehl. Für Tips wäre ich dankbar :-)
    Mein System:
    Multihost. Master
    Admin: 4.1.1
    JS controller: 3.1.4
    Node.js: v12.18.0
    NPM: 6.14.4
    2020-06-28 19:32:49.206 - info: host.ioBrokerMaster iobroker upgrade mihome-vacuum
    2020-06-28 19:32:51.329 - info: host.ioBrokerMaster iobroker Update mihome-vacuum from @1.1.5 to @2.0.7
    2020-06-28 19:32:51.947 - info: host.ioBrokerMaster iobroker NPM version: 6.14.4
    2020-06-28 19:32:51.949 - info: host.ioBrokerMaster iobroker npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
    2020-06-28 19:33:15.000 - info: host.ioBrokerMaster iobroker Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    2020-06-28 19:33:15.003 - info: host.ioBrokerMaster iobroker gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    2020-06-28 19:33:15.021 - info: host.ioBrokerMaster iobroker gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    2020-06-28 19:33:15.031 - info: host.ioBrokerMaster iobroker node-pre-gyp ERR! build error
    2020-06-28 19:33:15.032 - info: host.ioBrokerMaster iobroker node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    2020-06-28 19:33:15.033 - info: host.ioBrokerMaster iobroker node-pre-gyp ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
    2020-06-28 19:33:15.035 - info: host.ioBrokerMaster iobroker ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.18.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    2020-06-28 19:33:16.789 - info: host.ioBrokerMaster iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    2020-06-28 19:33:16.805 - info: host.ioBrokerMaster iobroker
    2020-06-28 19:33:16.806 - info: host.ioBrokerMaster iobroker npm ERR!
    2020-06-28 19:33:16.807 - info: host.ioBrokerMaster iobroker A complete log of this run can be found in:npm
    2020-06-28 19:33:16.810 - info: host.ioBrokerMaster iobroker ERR! /home/iobroker/.npm/_logs/2020-06-28T17_33_16_783Z-debug.log
    2020-06-28 19:33:16.831 - error: host.ioBrokerMaster iobroker host.ioBrokerMaster Cannot install iobroker.mihome-vacuum@2.0.7: 1
    mrbungle64M 1 Antwort Letzte Antwort
    • F FabianFranz
      Mein System:
      Multihost. Master
      Admin: 4.1.1
      Node.js: v12.18.0
      NPM: 6.14.4
      mrbungle64M Offline
      mrbungle64M Offline
      mrbungle64
      @FabianFranz
      https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
      Das sollte nach Installation der genannten Packages behoben sein
      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
      • F Offline
        FabianFranz
        @mrbungle64 Perfekt, danke für den Hinweis ✌
