  4. Zigbee startet nicht mehr
    6.1k
zigbee
30 Beiträge 5 Kommentatoren 2.7k Aufrufe 6 Beobachtet
    @bishop sagte in Zigbee startet nicht mehr:
    [    1.092327] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.099771] mmc0: new high speed SDHC card at address b368
    [    1.103915] mmcblk0: mmc0:b368       7.46 GiB
    [    1.108652] Indeed it is in host mode hprt0 = 00021501
    [    1.171432]  mmcblk0: p1 p2
    [    1.198485] random: fast init done
    [    1.203964] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.209170] VFS: Mounted root (ext4 filesystem) readonly on device 179:2..426793] new mount options do not match the existing superblock, will be ignored
    Sieht ein wenig verdächtig aus, imho.
    Insbesondere, dass / nur ro gemounted wird.
    Schau mal mit
    mount | grep ^/dev
    danach.
    bishop
    @Thomas-Braun
    /dev/mmcblk0p2 on / type ext4 (rw,noatime)
    /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
    • B bishop
      @Thomas-Braun
      @bishop
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      B 1 Antwort Letzte Antwort
        @bishop
        bishop
        schrieb am zuletzt editiert von bishop
        @Thomas-Braun
        pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v10.21.0
        /usr/bin/node
        v10.21.0
        /usr/bin/npm
        6.14.4
        nodejs:
          Installiert:           10.21.0-1nodesource1
          Installationskandidat: 10.21.0-1nodesource1
          Versionstabelle:
         *** 10.21.0-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.21.0~dfsg-1~deb10u1+rpi1 500
        hab mal eine andere Sd Karte benutzt aber leider das gleiche!
        host.raspberrypi	2020-06-28 13:21:51.274	info	"system.adapter.zigbee.0" disabled
        zigbee.0	2020-06-28 13:21:21.452	error	at process._tickCallback (internal/process/next_tick.js:68:7)
        zigbee.0	2020-06-28 13:21:21.452	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:5:58)
        zigbee.0	2020-06-28 13:21:21.452	error	at Generator.next (<anonymous>)
        zigbee.0	2020-06-28 13:21:21.452	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:91:48)
        zigbee.0	2020-06-28 13:21:21.452	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
        zigbee.0	2020-06-28 13:21:21.452	error	at JSON.parse (<anonymous>)
        zigbee.0	2020-06-28 13:21:21.452	error	(1898) SyntaxError: Unexpected token in JSON at position 895
        zigbee.0	2020-06-28 13:21:21.449	error	(1898) Failed to start Zigbee
        zigbee.0	2020-06-28 13:21:21.014	info	(1898) Starting Zigbee...
        zigbee.0	2020-06-28 13:21:21.012	info	(1898) Try to reconnect. 1 attempts left
        zigbee.0	2020-06-28 13:21:11.008	error	at process._tickCallback (internal/process/next_tick.js:68:7)
        zigbee.0	2020-06-28 13:21:11.008	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:5:58)
        zigbee.0	2020-06-28 13:21:11.008	error	at Generator.next (<anonymous>)
        zigbee.0	2020-06-28 13:21:11.008	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:91:48)
        zigbee.0	2020-06-28 13:21:11.008	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
        zigbee.0	2020-06-28 13:21:11.008	error	at JSON.parse (<anonymous>)
        zigbee.0	2020-06-28 13:21:11.008	error	(1898) SyntaxError: Unexpected token in JSON at position 895
        zigbee.0	2020-06-28 13:21:11.005	error	(1898) Failed to start Zigbee
        zigbee.0	2020-06-28 13:21:09.960	info	(1898) Starting Zigbee...
        zigbee.0	2020-06-28 13:21:09.838	info	(1898) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.21.0, js-controller: 3.1.5
        ohne den Stick wird der Adapter auch nicht Grün, also kann es wohl nicht am Stick liegen oder?
        Ein komplettes löschen des ZigbeeAdapters habe ich auch schon versucht.
        • M Malz1902
          Habe bevor ich hier den Thread aufgemacht schon alles gemacht und jetzt auch nochmal.
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.07__Embed_with_CMSIS-DAP_L4300302-if00
          isgt der COM Port
          über USB ist nur der Zigbee Stick dran
          dimaiv
          schrieb am zuletzt editiert von dimaiv
          @Malz1902 sagte in Zigbee startet nicht mehr:
          isgt der COM Port
          Das ist aber kein Stick, oder hast du den umgeflasht?
          ioBroker- NUC8i3 / Proxmox / VM
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          ZigBee Adapter 3.3.1alpha.0
          Zigbee LAN Gateway CC2652P
          Zigbee Firmware 20250321
          • D dimaiv
            isgt der COM Port
            Malz1902
            @dimaiv
            Nutze einen CC1352R1
            Hab die Firmware nochmal neugeflasht, daanch ging wieder alles
              bishop
              hat vielleicht noch jemand ein Tip für mich das ich tun kann?
              • B bishop
                dimaiv
                @bishop
                Hi, hast du das schon mal gemacht:
                ls -la /dev/serial/by-id
                Node.js v22.21.0
                NPM v10.9.4
                JS controller 7.1.0
                Admin 7.7.20
                • D dimaiv
                  @bishop
                  bishop
                  @dimaiv
                  ja
                  pi@raspberrypi:~ $ ls -la /dev/serial/by-id
                  insgesamt 0
                  drwxr-xr-x 2 root root 60 Jun 29 18:21 .
                  drwxr-xr-x 4 root root 80 Jun 29 18:21 ..
                  lrwxrwxrwx 1 root root 13 Jun 29 18:21 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                  ich habe pivccu3 noch auf dem Raspberry laufen mit den dementsprechenden Adapter, kann das ein Problem sein?
                  Lief jetzt alles Monate lang ohne Probleme...
                  • B bishop
                    @dimaiv
                    ja
                    insgesamt 0
                    dimaiv
                    @bishop
                    Also, der Stick funktioniert.
                    Mit pivccu3 kenne mich nicht aus.
                    Node.js v22.21.0
                    NPM v10.9.4
                    JS controller 7.1.0
                    Admin 7.7.20
                    • D dimaiv
                      @bishop
                      bishop
                      @dimaiv
                      mittlerweile kommt:
                      pi@raspberrypi:~ $ ls -la /dev/serial/by-path/
                      insgesamt 0
                      drwxr-xr-x 2 root root 60 Jun 30 16:36 .
                      drwxr-xr-x 4 root root 80 Jun 30 16:36 ..
                      lrwxrwxrwx 1 root root 13 Jun 30 16:36 platform-3f980000.usb-usb-0:1.5:1.0 -> ../../ttyACM0
                      ah falsch von mir
                      insgesamt 0
                      lrwxrwxrwx 1 root root 13 Jun 30 16:36 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
